Transformers Tubes-Valves Tube Sockets Fuse Holders-Cords-AC Items
Pots-Knobs Wire-Cable-Heat shrink Foot Pedals Tubes-Valves
Circuit Board Building parts Jacks-Plugs-Connectors Pots-Knobs Misc Hardware-Grommets-Feet-Ring terminals
Chassis-Boxes Chassis-Boxes Tube Sockets Pots-Knobs
Capacitors Reverb tanks and Bags Handles-Amp Trim Parts Misc Hardware-Grommets-Feet-Ring terminals
Pots-Knobs Wire-Cable-Heat shrink Tools and Batteries Fuse Holders-Cords-AC Items
Handles-Amp Trim Parts Capacitors Circuit Board Building parts Guitar Strings
Handles-Amp Trim Parts Books Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Transformers Fuse Holders-Cords-AC Items Jacks-Plugs-Connectors Pots-Knobs
Wire-Cable-Heat shrink Wire-Cable-Heat shrink Jacks-Plugs-Connectors Circuit Board Building parts
Lamps-Diodes-Channel Switching Capacitors Pots-Knobs Jacks-Plugs-Connectors
Pots-Knobs Resistors Tools and Batteries Capacitors
Resistors Tube Sockets Switches Tube Sockets
Tubes-Valves Tube Sockets Handles-Amp Trim Parts Fuse Holders-Cords-AC Items
Pots-Knobs Jacks-Plugs-Connectors Pots-Knobs Lamps-Diodes-Channel Switching
Switches Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Tubes-Valves
Tube Sockets Tools and Batteries Lamps-Diodes-Channel Switching Bike Light Parts
Tube Sockets Circuit Board Building parts Jacks-Plugs-Connectors Tools and Batteries
Circuit Board Building parts Transformers Resistors Lamps-Diodes-Channel Switching
Capacitors Transformers Switches Screws-Nuts-Washers
Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching Handles-Amp Trim Parts Switches
Foot Pedals Misc Hardware-Grommets-Feet-Ring terminals Jacks-Plugs-Connectors Resistors
Switches Pots-Knobs Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching
Lamps-Diodes-Channel Switching Tools and Batteries Tube Sockets Screws-Nuts-Washers
Jacks-Plugs-Connectors Transformers Lamps-Diodes-Channel Switching Tube Sockets
Pots-Knobs Bike Light Parts Screws-Nuts-Washers Transformers
Tubes-Valves Screws-Nuts-Washers Pots-Knobs Wire-Cable-Heat shrink
Tubes-Valves Screws-Nuts-Washers Fuse Holders-Cords-AC Items Switches
Foot Pedals
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello guest
August 22, 2014, 06:44:54 am
Login with username, password and session length
Author Topic: Roland Spirit  (Read 2533 times)
Offline Throstur
Roland Spirit
« on: December 17, 2010, 01:41:59 am »
Hoho
I have a very nice solid state amp made in 1981. It is a Roland Spirit and although I am am dedicated tube man I must say that this is one fine amp. Im having hard time finding diagram/schematic for it. Can anyone help me there.
Merry Christmas to you all
Throstur
Cheers
T
Re: Roland Spirit
« Reply #1 on: December 18, 2010, 02:40:27 pm »
What isn't working? If a Roland is working well, you probably don't want to go inside.
There were at least three models.... the model number may be helpful?
Owner manual for the 10 25 40 series:
  http://media.rolandus.com/manuals/SPIRIT-10A_25A_40A_OM.pdf
A shop which sells repro manuals for $5-up and seems to have much Roland:
  http://www.stereomanuals.com/man/rep/roland/index.htm
Roland SPIRIT-10 Guitar Amp Service Manual (1982) 1st Edition G2 ROLSPIRIT10-SM 4 total pages (2 intentionally blank) consisting of (1) single-side printed 11in x 17in sheet with no additional covers or binding. Overall quality is Very Good to Excellent. Normally folded and mailed in ordinary business envelope.
Roland SPIRIT-30 Guitar Amp Service Manual (1981) Also SPIRIT-50. 1st Edition G2 ROLSPIRIT30-SM 4 total pages consisting of (1) double-side printed 11in x 17in sheet with no additional covers or binding. Models covered: SPIRIT-30, SPIRIT-50. Overall quality is Very Good to Excellent. Normally folded and mailed in ordinary business envelope.
Roland SPIRIT-50 Guitar Amp Service See SPIRIT-30
Roland SPIRIT BASS-15 Bass Amp Service Manual (1982) 1st Edition G2 ROLSPBASS15-SM 4 total pages consisting of (1) double-side printed 11in x 17in sheet with no additional covers or binding. Overall quality is Very Good to Excellent. Normally folded and mailed in ordinary business envelope.
Roland SPIRIT BASS-30 Bass Amp Service Manual (1982) Also SPIRIT BASS-50. 1st Edition G2 ROLSPBASS30-SM 4 total pages consisting of (1) double-side printed 11in x 17in sheet with no additional covers or binding. Models covered: SPIRIT BASS-30, SPIRIT BASS-50. Overall quality is Very Good to Excellent. Normally folded and mailed in ordinary business envelope.
Roland SPIRIT BASS-50 Bass Amp Service See SPIRIT BASS-30
Offline Throstur
Re: Roland Spirit
« Reply #2 on: December 18, 2010, 04:43:33 pm »
Hi PRR. Its a Spirit 30 and its working fine. I am just interested to find out why this one sounds so fine, even breaks up like a tube amp at higher volumes!
Cheers
T
Re: Roland Spirit
« Reply #3 on: December 23, 2010, 09:48:32 pm »
Nothing exotic or erotic. Good 1980s Japanese design. A lot like an oversize effects pedal.
DO NOT SHORT THE OUTPUT!! There is NO protection for the power transistors.
Input amp is NFET-PNP working from quite high voltages. Volume pot, and clipping diodes with high part-numbers suggesting a late revision. NFET buffer. Fender-like tonestack. Tone recovery with another NFET-PNP pair. More clipper diodes. Reverb feed, NPN buffer, reverb mix, power amp.
Spirit 30 and Spirit 50 differ in supply voltages, appropriate gain change, and frills. The 50 has overdrive knob and Pre-Out Main-In jacks. The connections are on the PCB, just not used on the 30.
I got the manual from the link above:
The site has instructions for PayPal-ing an order. Get his pay-to email address. Be sure your PayPal account has your proper mailing address. Send 5 bucks with this info in the "Additional Notes":
Item #101219090038  $4.00  Shipping $1.00  TOTAL $5.00
This is the Hoffman amplifiers tube amp parts catalog, please choose a link below.
Amp trim/Handles Bike Lighting parts Board Building Parts Guitar Strings/Books
Capacitors Chassis/Boxes Foot Pedals Fuses/Cords/AC
Jacks/Plugs/connectors Pots/Knobs Lamps/Diodes/Channel Switching Misc. Hardware
Resistors Reverb Items Screws/Nuts/Washers Switches
Tools-Batteries Transformers Tubes/Valves Tube Sockets
Wire/Cable Public Parts list Page Search the Hoffman Amps parts catalog Non Stocked Parts
Click the link above for Tube amp info, Schematics, Board building information, Projects, Mods, Transformer diagrams, Photos, Sound clips.
Check out our huge library of schematics here
Create your own custom Turret lug board
Click here to search EL34 World
