Capacitors Transformers Tubes-Valves Tube Sockets
Tubes-Valves Jacks-Plugs-Connectors Pots-Knobs Capacitors
Pots-Knobs Misc Hardware-Grommets-Feet-Ring terminals Jacks-Plugs-Connectors Pots-Knobs
Chassis-Boxes Tubes-Valves Fuse Holders-Cords-AC Items Switches
Pots-Knobs Transformers Transformers Handles-Amp Trim Parts
Tube Sockets Tubes-Valves Circuit Board Building parts Lamps-Diodes-Channel Switching
Pots-Knobs Lamps-Diodes-Channel Switching Circuit Board Building parts Capacitors
Pots-Knobs Bike Light Parts Capacitors Jacks-Plugs-Connectors
Wire-Cable-Heat shrink Tube Sockets Misc Hardware-Grommets-Feet-Ring terminals Pots-Knobs
Switches Capacitors Pots-Knobs Foot Pedals
Hoffman Turret Boards Tube Sockets Handles-Amp Trim Parts Hoffman Turret Boards
Pots-Knobs Jacks-Plugs-Connectors Tools and Batteries Wire-Cable-Heat shrink
Jacks-Plugs-Connectors Tools and Batteries Transformers Tube Sockets
Eyelet Boards Capacitors Screws-Nuts-Washers Handles-Amp Trim Parts
Switches Switches Fuse Holders-Cords-AC Items Foot Pedals
Foot Pedals Capacitors Wire-Cable-Heat shrink Resistors
Capacitors Wire-Cable-Heat shrink Tube Sockets Tools and Batteries
Resistors Eyelet Boards Tubes-Valves Screws-Nuts-Washers
Fuse Holders-Cords-AC Items Pots-Knobs Tools and Batteries Switches
Tools and Batteries Tube Sockets Lamps-Diodes-Channel Switching Lamps-Diodes-Channel Switching
Lamps-Diodes-Channel Switching Tubes-Valves Fuse Holders-Cords-AC Items Wire-Cable-Heat shrink
Handles-Amp Trim Parts Eyelet Boards Misc Hardware-Grommets-Feet-Ring terminals Tube Sockets
Fuse Holders-Cords-AC Items Tube Sockets Resistors Books
Handles-Amp Trim Parts Screws-Nuts-Washers Pots-Knobs Capacitors
Jacks-Plugs-Connectors Screws-Nuts-Washers Handles-Amp Trim Parts Hoffman Turret Boards
Resistors Jacks-Plugs-Connectors Jacks-Plugs-Connectors Guitar Strings
Lamps-Diodes-Channel Switching Hoffman Turret Boards Fuse Holders-Cords-AC Items Tube Sockets
Switches Jacks-Plugs-Connectors Transformers Misc Hardware-Grommets-Feet-Ring terminals
Circuit Board Building parts Hoffman Turret Boards Jacks-Plugs-Connectors Lamps-Diodes-Channel Switching
Chassis-Boxes Pots-Knobs Lamps-Diodes-Channel Switching Bike Light Parts
Circuit Board Building parts Jacks-Plugs-Connectors Screws-Nuts-Washers Jacks-Plugs-Connectors
Pots-Knobs Capacitors Lamps-Diodes-Channel Switching Lamps-Diodes-Channel Switching
Jacks-Plugs-Connectors Reverb tanks and Bags Transformers
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello guest
May 26, 2015, 03:23:03 am
Login with username, password and session length
Author Topic: THd Yellow Jackets schematic  (Read 1813 times)
Offline jgriff123
« on: February 10, 2011, 06:38:05 am »
Hey guys, its been awhile since I've been on here.  Does anyone have a schematic laying around for the thd yellow jackets?  Thanks ahead of time. JG
Offline jgriff123
Re: THd Yellow Jackets schematic
« Reply #1 on: February 10, 2011, 08:41:42 am »
basically what im trying to do is run el84s in a dlitethat I built.  I would like to be able to run either 6l6's or 84's.  I was thinking about putting in a couple 9 pins sockets so I can run eithewr tubes.(not at the same time)  Any suggestions would be great.  JG
Offline FYL
« Reply #2 on: February 10, 2011, 10:06:11 am »
The schemo below was posted here a while ago...
« Reply #3 on: February 10, 2011, 05:13:57 pm »
Give a look here
Kagliostro
Offline jgriff123
« Reply #4 on: February 10, 2011, 06:11:14 pm »
thanks guys, that is exactly what I needed!  JG
Offline jgriff123
« Reply #5 on: February 12, 2011, 05:08:34 pm »
one more question.  Why do they use zenor diodes and could you use regular diodes instead?  JG
Offline FYL
« Reply #6 on: February 12, 2011, 07:20:32 pm »
The Zener string drops B+ to levels compatible with EL84s.
Mobile Device Catalog Link Choose a link from the Hoffman Amplifiers parts catalog
Resistors Board Building Parts Amp trim/Handles Misc. Hardware
Capacitors Hoffman Turret Boards Foot Pedals Screws/Nuts/Washers
Pots/Knobs Hoffman Eyelet Boards Reverb Items Tools/Batteries
Switches Jacks/Plugs/Connectors Guitar Strings/Books Bike Lighting Parts
Tube Sockets Fuses/Cords/AC Chassis/Boxes Lamps/Diodes/Channel Switching
Tubes/Valves Transformers Wire/Cable What's New
Tube Amp Library of information
Tube Amp Schematics library
Design your own custom Turret Board
Custom Turret Board Price calculator
Design your own custom Eyelet Board
Custom Eyelet Board Price calculator
Transformer Wiring Diagrams
