Jacks-Plugs-Connectors Tubes-Valves Tube Sockets Fuse Holders-Cords-AC Items
Switches Tube Sockets Jacks-Plugs-Connectors Transformers
Transformers Pots-Knobs Jacks-Plugs-Connectors Bike Light Parts
Resistors Switches Chassis-Boxes Capacitors
Handles-Amp Trim Parts Capacitors Pots-Knobs Screws-Nuts-Washers
Tubes-Valves Transformers Wire-Cable-Heat shrink Tubes-Valves
Pots-Knobs Circuit Board Building parts Switches Handles-Amp Trim Parts
Bike Light Parts Circuit Board Building parts Pots-Knobs Hoffman Turret Boards
Pots-Knobs Tube Sockets Tubes-Valves Lamps-Diodes-Channel Switching
Lamps-Diodes-Channel Switching Tube Sockets Tube Sockets Lamps-Diodes-Channel Switching
Pots-Knobs Tools and Batteries Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Capacitors Eyelet Boards
Hoffman Turret Boards Transformers Capacitors Tube Sockets
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Jacks-Plugs-Connectors Capacitors
Screws-Nuts-Washers Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching
Pots-Knobs Handles-Amp Trim Parts Capacitors Jacks-Plugs-Connectors
Lamps-Diodes-Channel Switching Hoffman Turret Boards Circuit Board Building parts Resistors
Handles-Amp Trim Parts Fuse Holders-Cords-AC Items Eyelet Boards Resistors
Chassis-Boxes Foot Pedals Capacitors Fuse Holders-Cords-AC Items
Guitar Strings Jacks-Plugs-Connectors Hoffman Turret Boards Pots-Knobs
Wire-Cable-Heat shrink Capacitors Switches Fuse Holders-Cords-AC Items
Switches Resistors Pots-Knobs Hoffman Turret Boards
Lamps-Diodes-Channel Switching Foot Pedals Tube Sockets Fuse Holders-Cords-AC Items
Handles-Amp Trim Parts Tube Sockets Misc Hardware-Grommets-Feet-Ring terminals Tubes-Valves
Tools and Batteries Tools and Batteries Capacitors Lamps-Diodes-Channel Switching
Lamps-Diodes-Channel Switching Tube Sockets Misc Hardware-Grommets-Feet-Ring terminals Pots-Knobs
Pots-Knobs Capacitors Wire-Cable-Heat shrink Pots-Knobs
Transformers Pots-Knobs Jacks-Plugs-Connectors Wire-Cable-Heat shrink
Books Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Jacks-Plugs-Connectors
Transformers Tubes-Valves Circuit Board Building parts Eyelet Boards
Reverb tanks and Bags Foot Pedals Lamps-Diodes-Channel Switching Tube Sockets
Jacks-Plugs-Connectors Tools and Batteries Tools and Batteries Switches
Handles-Amp Trim Parts Screws-Nuts-Washers Jacks-Plugs-Connectors
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello guest
April 21, 2015, 07:07:07 am
Login with username, password and session length
Author Topic: 2 X 10'' speaker cab ideal dimensions  (Read 4831 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: September 19, 2011, 05:49:20 am »
Hi,
I plan to build a small 2 X 10 speaker cab and I'd like to know the optimum dimensions that it should have.
I am a rock/blues player ( not the Fender tone but more the Gibson style bluesy tone ). I would go with 25w speakers ( weber ? ) open back , closed back ? Any suggestions ?
Regards
Colas
P.S.: call me Alvin.
Offline FYL
Re: 2 X 10'' speaker cab ideal dimensions
« Reply #1 on: September 19, 2011, 09:57:19 am »
I've got a tweed cab with a pair of Weber 10A125s (20-watt version) in 560 x 450 x 240 mm open back, 18 mm pine plus a 12 mm Baltic birch plywood baffle. Works very nicely for blues/rock with a late-50s style amp and P90s or humbuckers but YMMV.
Offline Boots Deville
« Reply #2 on: September 19, 2011, 10:47:42 am »
Here are some plans that are pretty close to FYL's dimensions, about 1.5" wider.
http://www.award-session.com/pdfs/AS210A_Plans.pdf
I've built a cab from their 1x12" plans, but never this particular 2x10".
  • MAKE LOVE NOT WAR
« Reply #3 on: September 19, 2011, 02:05:20 pm »
FYL,
I'm not sure if I get you right, you'd sell your cab or you only wanted to give me the dimensions ?
Colas
Offline Frankenamp
  • What does this button do?
This problem calls for a bigger hammer!
Offline FYL
« Reply #5 on: September 20, 2011, 02:15:13 am »
Dimensions.
  • MAKE LOVE NOT WAR
« Reply #6 on: September 21, 2011, 06:44:23 am »
Thank you sir
Regards
Colas
« Reply #7 on: September 21, 2011, 05:05:24 pm »
For amps, Fender generally used combos with open backs.  Marshall used closed back speaker cabs.  Fender/Gibson guitars guitars sound great through either set-up.
Open back cabs are not design critical.  You can make the cab any size & shape -- as to height, width and depth -- that fits your convenience (and is stable and won't fall over!).  Closed back cabs are sensitive to size and shape, including internal volume.  This called Thiele parameters.  Ideally this should be matched to the published specs of the speakers to be used.  Info is available online; Eminence speakers I think has info on its web site.  Or plagiarize from an enclosed 2 x 10 design that you like.
Offline Frankenamp
« Reply #8 on: September 22, 2011, 12:46:55 am »
Agreed. Most vintage utility tens and twelves were designed (mostly trial and error) to work more or less in a two cubic foot box. They didn't have T/S parameters. Speaker design and measurement were in their infancy. Nowadays, If I was to look for a speaker to work well in an open back box, I would look for a speaker with a Qts of .7 to 1.0 give or take. This will allow the response to roll off smoothly around the resonant frequency (Fo). A lower Qts will sound thin and anemic as the bass rolls off quicker. A Qts above 1 will start to sound boomy and unnatural. These are some rules of thumb that work most of the time. YMMV. A woofer tester and some box modeling software are necesesary for accurate results. Golden triangle dimensions are also usually ignored by guitar box designers. Have Fun!
Mobile Device Catalog Link Choose a link from the Hoffman Amplifiers parts catalog
Resistors Board Building Parts Amp trim/Handles Misc. Hardware
Capacitors Hoffman Turret Boards Foot Pedals Screws/Nuts/Washers
Pots/Knobs Hoffman Eyelet Boards Reverb Items Tools/Batteries
Switches Jacks/Plugs/Connectors Guitar Strings/Books Bike Lighting Parts
Tube Sockets Fuses/Cords/AC Chassis/Boxes Lamps/Diodes/Channel Switching
Tubes/Valves Transformers Wire/Cable What's New
Tube Amp Library of information
Tube Amp Schematics library
Design your own custom Turret Board
Custom Turret Board Price calculator
Design your own custom Eyelet Board
Custom Eyelet Board Price calculator
Transformer Wiring Diagrams
