September 17, 2026, 12:03:00 am
Hoffman Amps Forum image Author Topic: Mosfet FX loop  (Read 17761 times)
Mosfet FX loop
« on: May 28, 2012, 06:58:28 pm »
Guys,
Do you think this would work to use mosfets instead of a tube for a D-latorish style active FX loop?
Revised the schematic and reposted it.
« Last Edit: May 29, 2012, 08:23:55 pm by tubenit »
Re: Mosfet FX loop
« Reply #1 on: May 28, 2012, 10:19:13 pm »
What does the original circuit look like?
Offline Geezer
Re: Mosfet FX loop
« Reply #2 on: May 28, 2012, 11:21:59 pm »
Steve,
Sorta like this....
G
LND150 Datasheet>  http://www.datasheetarchive.com/LND150-datasheet.html#
« Last Edit: May 28, 2012, 11:30:43 pm by Geezer »
Re: Mosfet FX loop
« Reply #3 on: May 29, 2012, 06:23:27 am »
I think it's doable. May not even need tweaking.
Re: Mosfet FX loop
« Reply #4 on: May 29, 2012, 02:34:29 pm »
Looks good T, I assume this circuit won't draw much current?? As i am already close to max with the transformers i have on the little wing
Re: Mosfet FX loop
« Reply #5 on: May 29, 2012, 08:25:04 pm »
I am thinking this might be better.
with respect, Tubenit
Re: Mosfet FX loop
« Reply #6 on: July 14, 2012, 01:12:46 pm »
Hi tubenit,
Have you tried this on your amp yet? JFETs appear to be "plug and play" but they aren't that easy as they need to be biased properly same as using tubes. I just discovered this LND150 on own about a month ago. (wish I'd been looking at these threads in SS before now as you guys are as usual ahead of the curve - "my curve" anyway)
Re: Mosfet FX loop
« Reply #7 on: July 15, 2012, 05:58:16 pm »
Haven't tried it and decided to not build it.  Sorry.
