April 29, 2026, 02:59:33 am
Hoffman Amps Forum image Author Topic: sawing Hoffman turret board material  (Read 6182 times)
« on: July 04, 2013, 01:50:32 pm »
I've mentioned it before ......................
I use an ordinary hacksaw to cut Hoffman's board material. VERY quick and very little dust to contend with.
Cutting a 12 " line with a hacksaw took me maybe 20 - 30 seconds.  I just clamped the board down. I then hit the edge of the cut board with an orbital sander using 80 grit for just a couple of seconds and done.
with respect, Tubenit
Re: sawing Hoffman turret board material
« Reply #1 on: July 05, 2013, 12:21:33 am »
Me too.
« Reply #2 on: July 05, 2013, 04:47:09 pm »
I took this to restore my apartment
so now I use it also for other things
before I used a cutter to engrave the board and then a pair of pliers to remove the excess
Offline drew
« Reply #3 on: July 05, 2013, 08:22:57 pm »
That's interesting - a miter saw that doubles as a table saw?  I don't think I've ever seen one like that here in the US.
« Reply #4 on: July 05, 2013, 11:37:18 pm »
Hoffman's board material is fiber-glass reinforced.
It will dull a saw.
Hand hack-saw blades are less than $1.
Circular saw blades are $5 to $15.
Yes, if you do VERY little work with a carbide-tooth circular saw, it stays sharp.
With house and garage and loft and now the tractor-shed, I use my table saw a LOT, and replace the blade a few times a year.
Better to dull a $1 hacksaw than a $15 table-saw blade.
Also the glass dust is bad for your lungs. The circular saw throws fine dust in your face, the hack-saw dribbles crumbs on the floor.
A trick most of you do not need. You can make a large hole in Hoffman's board material with a metal-cutting hole-saw. This is tricky and maybe dangerous. I securely clamped dense Oak front and back, then clamped the whole thing on a work-bench. I should have used a heavy drill-press. With hand drill it does want to "grab" and break your wrist. (This gives me one 2" hole where there were several 1" holes in an electrical box; and very arc/flame resistant.)
« Reply #5 on: July 06, 2013, 06:45:16 pm »
Miter saw that doubles in table saw is very common here
however you must consider that the table saw is very small
The circular blades I use are much more expensive than $15
they have widia teeth and has a good durability
I must say that for my boards I principally use bakelite and only sometime fiberglass
