September 13, 2026, 10:37:25 pm
Hoffman Amps Forum image Author Topic: Carolina Overdrive Special 5879 plus  (Read 7755 times)
« on: April 09, 2017, 03:57:16 pm »
I am continuing to experiment with different Dumblish inspired designs where you have a clean and an overdrive channel.  The PT on this one is 300-0-300 150ma.   A tweed bassman OT would work well with it, I think.
My goal on this one was to use 3 gain stages in the clean channel to try and keep the tone reasonably clean up to 12 noon on the volume dial.  I feel like I succeeded reasonably well with this.  It has  nice full tone to it, IMO and has some musical sweetness in the tone.  It is reasonably Fenderish but slightly less mid-scooped.
One of the things that really surprised me was how quite the thing is at idle.  Even at volumes beyond what I will normally play at, the idle noise is very very quiet.  The original Princeton Reveb I owned once was more noisy at idle then this is.  I think it could be easy to walk out of the room and forget to turn the amp off?  However, when you hit a chord, it is surprisingly loud.
The overdrive is also to my liking and is very touch responsive with the 5879 tube. I may try tweaking this some more, but if it never got any smoother, I'd still be very happy with it. The 5879 tube does have a little chime inherent in it's tone.
This has more contrast between the clean truly being clean and the overdrive being more boosted & slightly richer tone compared to the clean tone.
Just thought I'd share in case someone is looking for a new idea.  Look into the SCH library for editable files.
« Last Edit: May 23, 2017, 08:22:24 pm by tubenit »
Offline MakerDP
Re: Carolina Overdrive Special 5879 plus
« Reply #1 on: April 09, 2017, 07:26:16 pm »
Looks good! Would love to hear some samples.
As always, thanks for sharing.
« Reply #2 on: May 23, 2017, 08:20:47 pm »
Guys, I'm loving this amp!  Amazingly quiet at idle.  Very musical tone and touch sensitive.  Maybe the best clean tone I've gotten out of an amp.  The amp is getting a very full tone and good bass with very low volume.
You can get some pretty overdriven tones out of the OD channel, but I am liking it best more like a boosted clean that has richer harmonics and longer sustain.  Depending on how you set the 3 OD volume pots you can get some fairly wide range of OD tones.
Editable SCH schematic and layout here:  http://el34world.com/Forum/index.php?topic=21804.0
with respect, Tubenit
« Last Edit: May 24, 2017, 06:39:48 am by tubenit »
« Reply #3 on: May 25, 2017, 03:28:03 pm »
Looks nice, do you have 225 OD throughout?  Have you tried a 12AX7 in V1?  Still clean?
« Reply #4 on: May 26, 2017, 04:22:44 am »
I am using Orange Drop PS everywhere except Musicaps in V1-6, V2-6, V4-2 & V4-6.
I haven't tried a 12AX7 in V1 but have tried a 5751 and it still gives a great clean tone.
I'm using an Emminence Delta-Pro 12A speaker.
