September 14, 2026, 07:11:05 am
Hoffman Amps Forum image Author Topic: 5F2A build  (Read 6641 times)
Offline Lindsay
5F2A build
« on: December 12, 2017, 06:43:06 pm »
I've posted this on a few other forums so apologies if you've seen it already. Given the build is based on the Hoffman layout I though a few may be interested. I built three amps at once, one as a birthday gift for a mate and the other two for Sydney muso's.
I folded and TIG welded my own aluminium chassis',  and wound my own transformers and choke (15H). The cathode has a switchable bypass cap on the preamp, the NFB can be switched on/off at 6 db (22K as per Dougs schematic)
Using the 5Y3 rectifier I have 315V on the plate. Substituting a 5AR4 gives 340V but I prefer the lower voltage sound. Technically the 5Y3 puts out 2 W's at 10% distortion and the 5AR4 3 W's. I can't really tell the difference in output volume.
The OT is a bit larger than a typical original, and is wound on  grain orientated core so has a wider range.
The attached video was just a bit of fun and not meant to be a full amp test. Played by a friend using a loop pedal and a dose of Tennessee Whiskey.
Lindsay
Re: 5F2A build
« Reply #1 on: December 12, 2017, 07:10:31 pm »
VERY IMPRESSIVE!
Offline Joel
Re: 5F2A build
« Reply #2 on: December 13, 2017, 12:05:20 am »
Hi Lindsay,
Those are some nice looking amps!  Beautiful work.
Would you mind telling me where you got your transformer parts?  When I made my own transformers I recycled some older ones.  Couldn't find any suppliers in Adelaide.
And I'd love to know how you did your faceplates or where you got them from.
The mouth of a happy man is filled with beer  - Egyptian Proverb
Re: 5F2A build
« Reply #3 on: December 13, 2017, 12:17:20 am »
 :thumbsup:
Offline Lindsay
Re: 5F2A build
« Reply #4 on: December 13, 2017, 03:44:11 am »
Hi Lindsay,
G'day Joel,
Core purchased from : http://www.brightsteel.com.au/
You have to purchase 30kg at a time  :BangHead: .
Bobbins and sleeves from : Engineering Enterprises
                                            376 Bayswater Rd, Bayswater VIC 3153
                                            Phone: (03) 9729 3333
This business is run old style so no internet, phone call or fax only. I don't know how much longer they will remain in business but have great product with no minimum order quantity.
I have a large stock of wire/insulation/tapes on hand, but if I need any it's from: http://www.bew.com.au/  in Sydney
The face plates I created in Corel Draw. Two were laser cut/engraved on plastic material and the 3rd was done on laser engraved aluminium but I had to drill the holes myself (very thin 0.5mm material) Both products look okay and were $30 each from a Canberra based trophy shop.
I hope this helps,
Regards
Lindsay
Goulburn NSW
Offline Joel
Re: 5F2A build
« Reply #5 on: December 14, 2017, 03:19:38 am »
Thank you!  Info duly saved.
Offline MFowler
Re: 5F2A build
« Reply #6 on: December 15, 2017, 01:53:08 pm »
The chassis, transformers and boards all look professional and it sounded great.
A real Renaissance Man.
Mark
