September 08, 2026, 03:33:14 pm
Hoffman Amps Forum image Author Topic: GA-90 fuse size  (Read 4395 times)
Offline malti
GA-90 fuse size
« on: March 30, 2018, 01:00:27 pm »
I would like to know how to calculate the correct fuse value for a 1953 Gibson GA 90 amp. The schematic that I found does not depict the fuse.
« Last Edit: March 30, 2018, 01:28:09 pm by sluckey »
Online sluckey
Re: GA-90 fuse size
« Reply #1 on: March 30, 2018, 01:27:39 pm »
Set your meter to measure several amps of AC current. Connect the leads across the fuse holder. Remove any fuse. Turn the amp on and let it warm up a few minutes. Note the meter reading. Now double that reading and use the closest available slo-blo fuse.
Or...
This is a quote from the Gibson Amplifier Master Service Book, page 273...
"The fuse in the GA-90 Amplifier is a type AG of three ampere rating. DO NOT USE FUSES OF HIGHER RATING."
« Last Edit: March 30, 2018, 01:42:27 pm by sluckey »
