June 15, 2026, 05:37:32 am
Hoffman Amps Forum image Author Topic: DoubleCavers5.3  (Read 11056 times)
DoubleCavers5.3
« on: March 30, 2019, 10:28:06 am »
started spring clean and found pieces parts  :icon_biggrin:
since the 2 tubes are 6SN7, went looking and found Blue Velvet's pre.  Gonna splice into the RCA stereo SS 10W PA.
gonna try something different, I'm gonna drill out the turret board for the octal, put turrets on top with tube.  Put standoffs in the 4 corners and have a piece of colored plexi or, (if it don't break the bank), glass to "cover" the parts, with hole for tubes to stick through.
layout is for 1 channel only, but they look the same  :laugh:
EDIT
update layout
link to original build
http://enjoythemusic.com/magazine/equipment/1103/midmonth
« Last Edit: April 02, 2019, 02:38:36 pm by shooter »
Re: DoubleCavers5.3
« Reply #1 on: March 30, 2019, 11:07:52 am »
That's a lot of NFB on the second triode. What's on the input? Where does the output go?
Re: DoubleCavers5.3
« Reply #2 on: March 30, 2019, 12:03:11 pm »
the input, I believe, set up for "phono" in level signal, gotta do sum webin there to be sure, the "out" will get hacked into the SS PA amp
I've driven the SS amp with both line level and phono level
The "frontend" on the schematic were added for another build.
Re: DoubleCavers5.3
« Reply #3 on: April 01, 2019, 07:04:47 pm »
trying to do the PS on paper, it's not as fun as gatorclipin  :icon_biggrin:
The design folk say I need 204vdc @ 40mA for feeding of the 6SN7s   :w2:
Calc my PS test Dummyload = 5.1k @ 8w
My donor tranny is XPWR050-120
Sec 250 – 0vac at 200mA
Cheatsheet shows FWB into Cap = .9 X 250 = 225v avg
Idc = Iac * .65 =  130mA dc avg
I’m trying to guess at R1 & R2
Since RL needs 204v drop, R1 + R2 drop 21v. @40mA = 525ohms
So… guessing each 330ohms with fudge factor?
Am I askin for problems with a low R big C filter stages?
Re: DoubleCavers5.3
« Reply #4 on: April 02, 2019, 01:16:16 pm »
Why have you figured current demand from this stray-find transformer??
The current to run the 6SN7 preamp can be figured from the notated plan for the preamp. I get 57mA.
I can't believe "204V" is critical, but a little more figuring shows it runs the poor 6SN7s HOT, so we don't want more.
250VAC makes 350VDC. You want 200V or 150V drop. 150V/0.057A is 2,600 Ohms. You want two maybe three R-C stages. Total heat in droppers is a whopping 8.55 Watts! I would start with three 1K 10W resistors. That may come a little low of 204V, but best to start low and trim up.
Re: DoubleCavers5.3
« Reply #5 on: April 02, 2019, 02:52:37 pm »
I can't get the link to work, their PS is insane  :think1:
part of the 57mA you got goes to feeding a pair of 0A2's.
the notation says 40mA for 6SN7 the rest for the voltage regulators
Ya, their sonic testing showed the best results with the N7's at 70% or better.  They compromised at around 50% idle
250VAC makes 350VDC
That's where I get hung up on paper, the Hammond design sheet for rectifiers says .9X for avg, 1.4X for pk which trips me up since I'm guessing idle current near 20mA, (avg??) with peak at 40mA
The cathode R is 326  :laugh:
I cheated and found 2 carbon comp 330ohmers that measure 327  :icon_biggrin:
Re: DoubleCavers5.3
« Reply #6 on: April 02, 2019, 05:53:53 pm »
Maybe I had a break-through, or break-down  :think1:
250 X1.4 = 350
250 X .9 = 225
Tranny rated @ 200mA I need 20mA to idle, 40mA max
So;
20mA = 10% of 200mA, 90% of 350v = 315vdc
Does the logic track??
Re: DoubleCavers5.3
« Reply #7 on: April 03, 2019, 02:14:08 am »
dude! XPWR050? you're trying to wedge a cat 399 into a fiat 500.  :laugh:
suggestion: use a pair of 120V:6V 2A radio shack PT back2back - the 120VAC sec. will produce around 180VDC with that load.
Re: DoubleCavers5.3
« Reply #8 on: April 03, 2019, 08:48:12 am »
dude!
:laugh:
I DO, have future dreams for an upgrade, but future $'s......  :icon_biggrin:
Ideally I replace the 10wSS stereo with 2PSE /ch EL84's.
besides it's running 12deg below normal here so a little handwarmer is nice  :laugh:
Re: DoubleCavers5.3
« Reply #9 on: April 03, 2019, 12:49:50 pm »
I have not seen any 0A2s posted here.
I get 57mA *simply* by Ohm's Law on the plate resistors and their voltage drop.
Well, they could just pick plate resistors which did not strain the poor little 6SN7s. Given the heavy load, hotter is better, but this is a crude approach.
Which has errors. And can easily mislead.
Cap-input rectifier filter, you only want the 1.414 *Voltage* factor.
Choke-input uses the 0.9 *voltage* factor.
I don't know why you apply these numbers to *currents*. Or why you seem to think the power supply DC current will have a "peak". The DC current in this affair is dead constant. (V1 goes up, V2 goes down, sum stays the same; also any preamp's signal current should be totally absorbed in the filter caps.)
Re: DoubleCavers5.3
« Reply #10 on: April 03, 2019, 02:17:59 pm »
here's where I stole the idea, sans PS
http://enjoythemusic.com/magazine/equipment/1103/midmonth/bluevelvet.htm
thanks
scribblin notes to self  :laugh:
1st pass, I never paid attention to Iac vs Idc in the tranny specs before. was surprised to "see??" a scale factor like .65 which I'm thinking on paper makes most of my "designs" iffy, ie, need a 100mA, got a 120mA tranny, good, next step....
2nd pass, my quirky understanding;
I've always "seen" I, R, E as equal partners in the same equation, change 1 the other two gotta compensate, so I sorta "talk" in terms of I since the other 2 are just potential energy until they can agree and get I moving,
Ya I know, "glad I didn't have that nut case in my class "   :icon_biggrin:
I do appreciate the effort though  :laugh:
Re: DoubleCavers5.3
« Reply #11 on: April 04, 2019, 07:45:12 pm »
got the iron hot for 5minutes  :icon_biggrin:
I screwed up my order to Doug enough I thought he'd ban me from shopping  :laugh:
He still managed to re-package and have it here on the 2nd work day!!.  Been 5 work days and my PE order made it to "shipped"  :think1:
Re: DoubleCavers5.3
« Reply #12 on: April 05, 2019, 07:09:23 pm »
no parts! BUT the air had almost imagined heat, so went barn scrounging, found a nice piece of redwood.
Re: DoubleCavers5.3
« Reply #13 on: April 07, 2019, 07:58:12 pm »
sadly the Bose funded the winter avoidance acct, so I pulled the trigger for a poor mans replacement, weeded through 10 speakers <300
https://www.stereophile.com/standloudspeakers/204klipsch/index.html
Re: DoubleCavers5.3
« Reply #14 on: April 09, 2019, 08:15:51 pm »
drew the layout like I was doing a chassis build  :think1:
so cris-cross wires under.  this build already has more self induced bugs than all my others combined  :cussing:, ah well, I kinda miss troubleshooting  :icon_biggrin:
Re: DoubleCavers5.3
« Reply #15 on: April 13, 2019, 07:14:21 pm »
on hold for a weekish, possible snow tomorrow, and the speakers haven't been broke in  :think1:
already stole the 10W stereo, so runnin through a mono-block, close 'yer eyes and ya see separation!!  :m15
and they ARE sweet soundin  :icon_biggrin:
Re: DoubleCavers5.3
« Reply #16 on: April 14, 2019, 05:25:58 pm »
stuck all the schematic pieces together  :icon_biggrin:
still breakin in the speakers, but I get dirty looks when I go downstairs  :icon_biggrin:
Re: DoubleCavers5.3
« Reply #17 on: April 16, 2019, 08:44:16 pm »
took the filter stage and sent off for a Doug turret, had 2 made.
bought new cutoff wheels for the dremel, IIRC 1.5" X 3"
Re: DoubleCavers5.3
« Reply #18 on: April 22, 2019, 08:28:12 pm »
there was enough time in the day to get the board cut and jumpers in
it's 9:20  :icon_biggrin:
Re: DoubleCavers5.3
« Reply #19 on: April 25, 2019, 07:30:34 pm »
It's only 8:20, but spent the day OUTSIDE :happy1:
managed to get the parts ready for solder rainday
Re: DoubleCavers5.3
« Reply #20 on: April 26, 2019, 06:54:39 pm »
got tired of hauling ballast around outside so a little work indoors
Re: DoubleCavers5.3
« Reply #21 on: April 27, 2019, 03:06:50 pm »
waiting for whatever crap Willabe is gonna send across the big pond  :cussing:
re-thinking the redwood, not ruled out yet, speakers got 100hrs sooooo....
4:20 soon, power tools down for the day  :icon_biggrin:
Re: DoubleCavers5.3
« Reply #22 on: April 29, 2019, 03:08:11 pm »
on hold while the speaker out jacks show up  :think1:
That's ok, building a kayak arc so we can escape in a day or two  :icon_biggrin:
Heath kit 2.0
Re: DoubleCavers5.3
« Reply #23 on: May 04, 2019, 08:36:56 pm »
Great day! Got Mama to the salt free ocean, picked up 3 new old vinyl for test driving.  Had to force the paint in the wife's oven, so far so good  :icon_biggrin:
AND I started!!
Re: DoubleCavers5.3
« Reply #24 on: May 05, 2019, 09:17:12 pm »
TOOO Sunny for solder!
1 wire n a gatorclip and PS is ready for test
It musta been good   :icon_biggrin: when I laid out the lines for the CRC rail  :think1:
Re: DoubleCavers5.3
« Reply #25 on: May 08, 2019, 07:02:07 pm »
repair bench waiting on parts, weather got the M month wrong!
hot iron tomorrow, maybe
Re: DoubleCavers5.3
« Reply #26 on: May 11, 2019, 07:08:50 pm »
EPIC FAIL  :cussing:
the DC side was good, but the AC side, NOT.  Hummm, odd phase-shifting, but that was inside the FBloop along with some 52khz positive lobe thing  :dontknow:
ALL is not lost though, the sand side works just fine, the "foot_print" for the tube board is close enough for the mono brick from here;
http://el34world.com/Forum/index.php?topic=23598.0
That will drive the Altec 15" (center channel)
and in the mean time, I gotta go flip the vinyl  :icon_biggrin:
