July 29, 2026, 02:37:57 am
Hoffman Amps Forum image Author Topic: Impossible output transformer  (Read 7715 times)
Offline gja
« on: March 17, 2020, 09:41:14 am »
Hi guys,
I know there’s a zillion posts about unknown transformers, and how to work out the turns ratio etc...but just cant get my head around this one.
It came with a 2x6sk7 2x6v6 amp I got on the bay umpteen years ago.
I had marked out the secondary side but assuming it’s a pp transformer I cant figure out which one is the b+.
I get all sorts of readings which don’t make sense ( ex 1,5k if using pin 3 as b+ and pins 1 and 7 for anodes).
Maybe I am assuming wrong and this was a parralleled se amp.
Anyway, the combinations between pins is just too vast for me to understand.
Pin 4 is the only one that goes nowhere (no resistance reading between any of the pins and nr4).
Any help would be really appreciated and sorry if this is just another guy trying to figure out an unknown output trafo...
Re: Impossible output transformer
« Reply #1 on: March 17, 2020, 10:23:03 am »
Maybe pin 4 is the connection to an internal shield that is to be connected to ground
About other pin
use your ohmmeter and draw on paper the numbers of pin that are connected each other, it will be nice also if you can write the resistence between pins that are connected to the same winding (but to measure such a low resistence you require a special tool)
if you can do this, indicate which pins have the thinnest wires connected and which the biggest wires
Post here the paper with your notes
« Last Edit: March 17, 2020, 10:26:13 am by kagliostro »
Offline gja
« Reply #2 on: March 17, 2020, 11:48:39 am »
Hi Franco,
Can’t see the thickness of wires unfortunately ...
Attached my readings, again number 4 is isolated from all the rest.
Thanks in advance for your help!
« Reply #3 on: March 17, 2020, 12:08:10 pm »
Assuming you know the secondary side, put a low voltage into that: say, 1 - 6.3VAC.  Then use a DMM on the primary side to find the HT wires.
« Reply #4 on: March 17, 2020, 12:40:24 pm »
here's a schematic image for crayoning  :icon_biggrin:
« Reply #5 on: March 17, 2020, 07:14:24 pm »
The numbers of interest are
1-2 = 107
1-3 = 107 (??)
1-4 = --- (looking the photo seems that pin 4 is connected to nothing - no internal shield to be clare)
1-5 = 121
1-6 = 156
1-7 = 180
So all the pin are connected, in different point to the same winding (except pin #4)
You wrote 1-3 = 107, (the first number looks like 1 -- 107) that seems odd, please can you verify
Other question for you, do you see a pin where there is soldered more than one wire ?
To establish if is an SE or PP transformer look to the laminations, if E & I are mixed the transformer is a PP if E & I are all on the same side, all the E together and all the I together, it is an SE transformer
« Last Edit: March 17, 2020, 07:30:59 pm by kagliostro »
Offline gja
« Reply #6 on: March 19, 2020, 03:01:16 am »
Yes. pin 4 is connected to nothing...
Kagliostro, I forgot to check that 1-3 this morning...
Attached are my readings with 5v applied to secondary and bottom frame removed to show the core stack.
Difficult to see if more than one wire is soldered to a single pin.
« Reply #7 on: March 19, 2020, 08:15:03 am »
Laminations are interleaved, so PP transformer
Waiting for the resistance measure pin 1 - 3
Offline gja
« Reply #8 on: March 19, 2020, 10:40:24 am »
Hi Franco,
1-2 = 39 ohms
Hope this helps
« Reply #9 on: March 19, 2020, 10:42:17 am »
IF you can open a word doc., here's fun with transformers ;
« Reply #10 on: March 19, 2020, 01:05:40 pm »
1-2 = 39 ohms
Hope this helps
I was asking for 1 - 3 .....
Before 1 - 2 was 107
now you say 39
which one is correct ?
Offline Williamblake
« Reply #11 on: March 19, 2020, 01:53:01 pm »
Why don`t you have 5V in the drawing then? It is easier to tell what`s going on if you had a drawing where one could _see_ the connections between pins (like lines) an the resistances between pins.
« Reply #12 on: March 19, 2020, 02:02:10 pm »
what tabs did you apply 5vac to??
Offline gja
« Reply #13 on: March 19, 2020, 02:52:41 pm »
Confirm mistake was between 1 & 2 and it is 39.
1-3 is 107
I applied 5v to A & F because I could see they had some soldering on...just guesswork.
Attached drawing...
« Reply #14 on: March 19, 2020, 03:12:22 pm »
Don't see how it fits 2*6V6, but here's numbers:
« Reply #15 on: March 19, 2020, 03:18:40 pm »
against what?  A speaker soldered to it?, a 1/4 jack labeled speaker?
where on the chassis was it mounted, if you recall?
« Reply #16 on: March 19, 2020, 03:32:25 pm »
What is this ?
Seems that an additional wire is connected to pin #3
So an UL OT with 35% intakes
Impedance seems more fine for 6L6 tubes
« Last Edit: March 19, 2020, 03:41:10 pm by kagliostro »
Offline gja
« Reply #17 on: March 20, 2020, 03:31:06 am »
Franco many thanks 3 as CT is what i suspected...
Cant see any additional wire soldered.
Shooter it was mounted on little chassis and the guy who sold it to me had marked "to speaker " on the secondary side.
How is the secondary configured? There´s a jumper between B and H and between C and G.
If anyone can draw out how this works between different windings i ´d really appreciate learning a little more.
I suppose you can change the impedance used...
« Reply #18 on: March 20, 2020, 05:20:28 am »
Ciao gia
Not me, PRR did the job before I was able to arrive to a definitive clue, you have to thank him
Offline gja
« Reply #19 on: March 20, 2020, 07:22:11 am »
Thanks PRR and everyone !!
« Reply #20 on: March 20, 2020, 10:41:22 am »
