January 09, 2026, 12:42:40 pm
Hoffman Amps Forum image Author Topic: PRR Third watt amp  (Read 30744 times)
PRR Third watt amp
« on: November 02, 2008, 08:26:50 pm »
I think Blind Lemon built a version of this and likes it. Don't know whether this is the schematic he ultimately used or not.  I wanted to try to get it saved for the forum members.
Here is a layout that I found that is "supposed" to match this. Check for errors and comparison.
The original thread was maybe 10/07 and is gone.  I found another thread that talked about using:
120:120 Isolation transformer for the PT
Hammond  262E6
P-T442  (from Antique Electronics Supply)
Fender replace reverb trannie used for the OT
« Last Edit: February 01, 2009, 06:12:55 am by tubenit »
Offline rumble
Re: PRR Third watt amp
« Reply #1 on: May 06, 2009, 12:25:19 pm »
hello
i found this site searching for a diy guitar tube amp with a small output in watt 's
i hope this is the correct topic to interact about this amp
it would be my first build, and would need some extra info about the isolation transformer because our power supply is 240 AC.
do i understand i correct i need a 240:120 isolation transformer?
and the other device is the p-t442
are there alternatives for this device?
watt kind of speaker would be needed in Ohms?
Offline blackcorvo
    • Blackcorvo.com
« Reply #2 on: November 30, 2009, 05:07:18 pm »
yes, you got it right.
it will depend on the output transformer you will use, if you don't use the model pointed in the schem. but i think it's a 8ohms load for that model.
i also have some question about this schem:
- i'd like a lil more of power... as close to 1w as possible. what if i increase the voltage to 230v? should i do mods in the output section?
- also, i only have one 6 au6, but i have a 12AX7 and wanted to use it in the pre-amp instead of the 6au6... any sugestions of pre-amp circuits? (fender, marshall, anything?)
thanks for any informations!!!
- http://blackcorvo.com
She/Her since August 2021
Offline CraigB
« Reply #3 on: January 21, 2010, 05:08:37 pm »
Here is a layout that I plan to use to build PRR's cool little 3rd watter.
Any comments or suggestions welcome!
Regards,
Craig
« Last Edit: January 21, 2010, 05:11:48 pm by CraigB »
« Reply #4 on: January 22, 2010, 06:04:29 pm »
very nice layout!   :smiley:
when are you going to build it?
Offline CraigB
« Reply #5 on: January 24, 2010, 10:06:57 am »
Today  :grin:
Regards,
Craig
Offline 2twang2
  • I came, I saw, I soldered
« Reply #6 on: January 24, 2010, 01:51:23 pm »
Excellent! Hope you'll post pics. I built a 12AU6 version a while back and have had a lot of fun with. It drives a 12" speaker in an open back cab.
Offline CraigB
« Reply #7 on: January 26, 2010, 04:08:45 pm »
Got sidetracked on another project on Sun., but...almost done.
Regards,
Craig
Offline CraigB
« Reply #8 on: January 31, 2010, 01:41:56 pm »
Layout works good, fired it up this morning.  I chose to make the chassis grounding point on the input jack side of the chassis - one wire from the board buss, a wire to ground the 1M pot, and a third wire to ground the 100K pot.  The input jack and 1M resistor are not wired to the ground terminal.  It's nice and quiet, even through a big speaker.  It is really fun to play. Thanks PRR!
Regards,
Craig
Offline 2twang2
« Reply #9 on: February 01, 2010, 12:14:53 am »
Excellent!
« Reply #10 on: September 29, 2015, 08:29:51 pm »
Images lost over time.
Offline isaac_teller
« Reply #11 on: May 07, 2023, 10:09:40 am »
Hello. What would I have to change in order to make this a headphone amp(mono of course for monitoring purposes. Thank you
