Jacks-Plugs-Connectors Tubes-Valves Tube Sockets Fuse Holders-Cords-AC Items
Switches Tube Sockets Jacks-Plugs-Connectors Transformers
Transformers Pots-Knobs Jacks-Plugs-Connectors Bike Light Parts
Resistors Switches Chassis-Boxes Capacitors
Handles-Amp Trim Parts Capacitors Pots-Knobs Screws-Nuts-Washers
Tubes-Valves Transformers Wire-Cable-Heat shrink Tubes-Valves
Pots-Knobs Circuit Board Building parts Switches Handles-Amp Trim Parts
Bike Light Parts Circuit Board Building parts Pots-Knobs Hoffman Turret Boards
Pots-Knobs Tube Sockets Tubes-Valves Lamps-Diodes-Channel Switching
Lamps-Diodes-Channel Switching Tube Sockets Tube Sockets Lamps-Diodes-Channel Switching
Pots-Knobs Tools and Batteries Jacks-Plugs-Connectors Jacks-Plugs-Connectors
Wire-Cable-Heat shrink Lamps-Diodes-Channel Switching Capacitors Eyelet Boards
Hoffman Turret Boards Transformers Capacitors Tube Sockets
Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Jacks-Plugs-Connectors Capacitors
Screws-Nuts-Washers Screws-Nuts-Washers Misc Hardware-Grommets-Feet-Ring terminals Lamps-Diodes-Channel Switching
Pots-Knobs Handles-Amp Trim Parts Capacitors Jacks-Plugs-Connectors
Lamps-Diodes-Channel Switching Hoffman Turret Boards Circuit Board Building parts Resistors
Handles-Amp Trim Parts Fuse Holders-Cords-AC Items Eyelet Boards Resistors
Chassis-Boxes Foot Pedals Capacitors Fuse Holders-Cords-AC Items
Guitar Strings Jacks-Plugs-Connectors Hoffman Turret Boards Pots-Knobs
Wire-Cable-Heat shrink Capacitors Switches Fuse Holders-Cords-AC Items
Switches Resistors Pots-Knobs Hoffman Turret Boards
Lamps-Diodes-Channel Switching Foot Pedals Tube Sockets Fuse Holders-Cords-AC Items
Handles-Amp Trim Parts Tube Sockets Misc Hardware-Grommets-Feet-Ring terminals Tubes-Valves
Tools and Batteries Tools and Batteries Capacitors Lamps-Diodes-Channel Switching
Lamps-Diodes-Channel Switching Tube Sockets Misc Hardware-Grommets-Feet-Ring terminals Pots-Knobs
Pots-Knobs Capacitors Wire-Cable-Heat shrink Pots-Knobs
Transformers Pots-Knobs Jacks-Plugs-Connectors Wire-Cable-Heat shrink
Books Jacks-Plugs-Connectors Fuse Holders-Cords-AC Items Jacks-Plugs-Connectors
Transformers Tubes-Valves Circuit Board Building parts Eyelet Boards
Reverb tanks and Bags Foot Pedals Lamps-Diodes-Channel Switching Tube Sockets
Jacks-Plugs-Connectors Tools and Batteries Tools and Batteries Switches
Handles-Amp Trim Parts Screws-Nuts-Washers Jacks-Plugs-Connectors
You can scroll through the images above using the Image scroll controls or you can use the Left and Right arrow keys on your keyboard.
Hello guest
April 25, 2015, 05:17:08 pm
Login with username, password and session length
Author Topic: Express SCH info - Download links - Custom components file - Sch File Index  (Read 14183 times)
Here's the link to the sch file library index
http://el34world.com/charts/SchFiles.php
I see this asked all the time and so I set up this sticky post.
If you want to open the .sch files here on the forum, you have to Download one of the programs below
Download link for ExpressPCB/ExpressSch
http://www.expresspcb.com/expresspcbhtm/Download.htm
or
Jschem is a java based program that works on any platform
It can import .sch files
Jschem creates .jsch files
Download link for Jschem
http://dhost.info/jschem/
Custom tube amp components for Express SCH
Here's is a zip file with all my .sch tube amp symbols
My sch components collection
And another component file
http://el34world.com/charts/SchFiles/complib.zip
More info further down the page about adding custom components
My first tip is that Jschem can import .sch files and export them in several formats like (PDF, JPG, GIF, PNG)
There's no need to do this in ExpressSch.
Use the pull down menu to expose all the different file types that Jschem can save your .sch file as.
.jpg is for photo images, the quality is not very good for line drawing type images. jpg leaves lots of little artifacts around the lines.
Here's two ways I do it in ExpressSch
ExpressSch can only export as Bitmap .bmp files
.bmp are drawing files, but they are way larger than .gif files
But you can open a .bmp file in your favorite drawing program and then save it as a .gif file
I use paint shop pro to do this
Method #1
Open the .sch file in ExpressSch
Go to the File menu and pick Export Schematic image
Export the sch drawing as a Bitmap file
Open the .bmp file in your drawing program ( I use Paint shop pro)
Edit the file, crop it down, etc
Save the file as a .gif file in your drawing program.
Method #2
You can capture screen shots on PC's
This is handy if you just want to grab a quick shot of anything displayed on your screen.
You can grab just a small section of a drawing, like just one tube, zoom in very close on something, etc
Whatever you capture gets put onto the Windows clipboard as temp storage.
Then your drawing program can access the windows clipboard to get that data.
The images in this post are all screen shots.
Position the drawing or whatever you want to copy on your screen so you can see it.
Hit the PrtSc or Print Screen button on your keyboard (upper right on most windows keyboards)
You may have to hit shift or function to get the Print Screen button to capture.
Open your favorite drawing program
Find the Paste as new Image function, (most likely in the edit menu.)
I use Paint shop pro, but I am sure most drawing programs are able to do this.
« Last Edit: August 09, 2014, 11:53:07 am by EL34 »
Adding Custom Components
« Reply #1 on: November 15, 2006, 10:03:04 pm »
Here's my component file.
Custom sch components
Download this zip file.
Unzip it into your ExpressPCB folder.
The next time you open Express Sch, click on the components manager button and then tick the custom components box to see all the new symbols.
If the SchComponents_Custom folder does not exist, it will be created when you unzip it.
If you already have a SchComponents_Custom folder, just add the files into your folder
Put all the component files in this folder.
Click on the picture of the desktop or navigate to your desktop with the up arrow at the top of the box.
Click Save after you have chosen your desktop as the save location.
« Last Edit: August 09, 2014, 11:17:53 am by EL34 »
The file will download to your desktop.
Click Close after it is done downloading.
« Last Edit: August 09, 2014, 10:52:15 am by EL34 »
Go to your desktop and then right click your mouse on the SchComponents_Custom.zip file icon.
A dialog box will open.
Choose Extract all
« Last Edit: August 09, 2014, 10:52:28 am by EL34 »
Click Next
« Last Edit: August 09, 2014, 10:52:41 am by EL34 »
The dialog box on the left opens first.
Hit the Browse button.
Browse down to the ExpressPCB folder using the image on the right as your guide.
The ExpressPCB folder should be highlighted just like in the picture.
Press the Next button.
« Last Edit: August 09, 2014, 10:52:58 am by EL34 »
The SchComponents_Custom folder is now extracted under the ExpressPCB folder.
If you did not have the folder, it is created there.
Uncheck the Show extracted files box
Click Finish.
If you already had the SchComponents_Custom folder, you will want to extract the zip folder and then move all the files inside into your SchComponents_Custom folder.
The next time you start the Express SCh program, there will be a bunch of new custom components.
« Last Edit: August 09, 2014, 10:53:15 am by EL34 »
or
My .sch components collection
See this post about adding custom components
http://el34world.com/Forum/index.php?topic=590.0
Unzip the file and copy all the files inside to the SchComponents_Custom folder after you have installed Express PCB/SCH
Method #1
Method #2
« Last Edit: August 09, 2014, 11:00:53 am by EL34 »
Mobile Device Catalog Link Choose a link from the Hoffman Amplifiers parts catalog
Resistors Board Building Parts Amp trim/Handles Misc. Hardware
Capacitors Hoffman Turret Boards Foot Pedals Screws/Nuts/Washers
Pots/Knobs Hoffman Eyelet Boards Reverb Items Tools/Batteries
Switches Jacks/Plugs/Connectors Guitar Strings/Books Bike Lighting Parts
Tube Sockets Fuses/Cords/AC Chassis/Boxes Lamps/Diodes/Channel Switching
Tubes/Valves Transformers Wire/Cable What's New
Tube Amp Library of information
Tube Amp Schematics library
Design your own custom Turret Board
Custom Turret Board Price calculator
Design your own custom Eyelet Board
Custom Eyelet Board Price calculator
Transformer Wiring Diagrams
