<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>4</major>
    <minor>37</minor>
    <build>0</build>
  </fileVersion>
  <title>AB763 Reverb Section</title>
  <author>TDVT</author>
  <description>6/2/2024</description>
  <width value="29.0" unit="cm"/>
  <height value="21.0" unit="cm"/>
  <gridSpacing value="0.025" unit="in"/>
  <dotSpacing>1</dotSpacing>
  <components>
    <diylc.tube.TriodeSymbol>
      <name>V1</name>
      <value></value>
      <color hex="000000"/>
      <display>NONE</display>
      <showHeaters>true</showHeaters>
      <orientation>DEFAULT</orientation>
      <flip>X</flip>
      <controlPoints>
        <point x="4.25" y="5.675"/>
        <point x="3.95" y="5.375"/>
        <point x="4.05" y="5.975"/>
        <point x="3.95" y="5.975"/>
        <point x="3.85" y="5.975"/>
      </controlPoints>
      <directlyHeated>false</directlyHeated>
    </diylc.tube.TriodeSymbol>
      <name>V2</name>
      <value></value>
      <display>NAME</display>
      <flip>NONE</flip>
      <controlPoints>
        <point x="4.55" y="5.375"/>
        <point x="4.45" y="5.975"/>
        <point x="4.55" y="5.975"/>
        <point x="4.65" y="5.975"/>
      </controlPoints>
    <diylc.passive.ResistorSymbol>
      <name>2.2K</name>
      <alpha>127</alpha>
      <length value="0.2" unit="in"/>
      <width value="0.08" unit="in"/>
      <points>
        <point x="4.25" y="6.175"/>
        <point x="4.25" y="6.575"/>
        <point x="4.15" y="6.375"/>
      </points>
      <borderColor hex="0000ff"/>
      <labelColor hex="000000"/>
      <leadColor hex="000000"/>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>true</moveLabel>
      <hideShortLeads>false</hideShortLeads>
      <labelPosition>ABOVE</labelPosition>
      <power>HALF</power>
      <powerNew value="0.5" unit="W"/>
    </diylc.passive.ResistorSymbol>
    <diylc.connectivity.Line>
      <name>LN7</name>
      <alpha>127</alpha>
      <points>
        <point x="4.45" y="6.175"/>
        <point x="0.0" y="0.0"/>
      </points>
      <bodyColor hex="ffffff"/>
      <borderColor hex="000000"/>
      <leadColor hex="cccccc"/>
      <moveLabel>false</moveLabel>
      <style>SOLID</style>
      <thickness value="1.0" unit="px"/>
      <arrowSize value="5.0" unit="px"/>
      <arrowTx serialization="custom">
        <java.awt.geom.AffineTransform>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
        </java.awt.geom.AffineTransform>
      </arrowTx>
      <arrowStart>false</arrowStart>
      <arrowEnd>false</arrowEnd>
    </diylc.connectivity.Line>
      <name>LN14</name>
      <alpha>127</alpha>
      <points>
        <point x="4.45" y="6.575"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN15</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN16</name>
      <alpha>127</alpha>
      <points>
        <point x="4.25" y="5.975"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.misc.GroundSymbol>
      <name>GND2</name>
      <point x="4.25" y="6.65"/>
      <size value="0.15" unit="in"/>
      <type>DEFAULT</type>
      <stroke>2</stroke>
    </diylc.misc.GroundSymbol>
      <name>LN18</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.connectivity.Dot>
      <name>Dot8</name>
      <size value="1.0" unit="mm"/>
    </diylc.connectivity.Dot>
      <name>Dot12</name>
      <name>Dot13</name>
      <name>LN27</name>
      <alpha>127</alpha>
      <points>
        <point x="3.725" y="5.675"/>
        <point x="3.525" y="5.675"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN28</name>
      <alpha>127</alpha>
      <points>
        <point x="3.525" y="4.625"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN29</name>
      <alpha>127</alpha>
      <points>
        <point x="4.9" y="5.375"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Dot14</name>
      <name>Dot16</name>
    <diylc.passive.TransformerCoil>
      <name>L48</name>
      <controlPoints>
        <point x="4.9" y="5.775"/>
      </controlPoints>
      <color hex="0000ff"/>
      <tapSpacing value="0.4" unit="in"/>
      <body>
        <java.awt.geom.GeneralPath serialization="custom">
          <unserializable-parents/>
          <java.awt.geom.Path2D_-Float>
            <default/>
            <byte>48</byte>
            <int>4</int>
            <int>8</int>
            <byte>1</byte>
            <byte>64</byte>
            <float>980.0</float>
            <float>1075.0</float>
            <byte>65</byte>
            <float>1005.0</float>
            <byte>64</byte>
            <float>1155.0</float>
            <byte>65</byte>
            <byte>97</byte>
          </java.awt.geom.Path2D_-Float>
        </java.awt.geom.GeneralPath>
            <default/>
            <byte>48</byte>
            <int>9</int>
            <int>50</int>
            <byte>1</byte>
            <byte>64</byte>
            <byte>67</byte>
            <float>1015.0</float>
            <float>1085.0</float>
            <byte>67</byte>
            <float>1095.0</float>
            <byte>67</byte>
            <float>1105.0</float>
            <byte>67</byte>
            <float>1115.0</float>
            <byte>67</byte>
            <float>1125.0</float>
            <byte>67</byte>
            <float>1135.0</float>
            <byte>67</byte>
            <float>1145.0</float>
            <byte>67</byte>
            <byte>97</byte>
      </body>
    </diylc.passive.TransformerCoil>
      <name>LN33</name>
      <alpha>127</alpha>
      <points>
        <point x="4.9" y="6.475"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>GND4</name>
      <point x="3.525" y="6.3"/>
      <stroke>2</stroke>
    <diylc.passive.TransformerCore>
      <name>T4</name>
      <controlPoints>
        <point x="5.1" y="5.425"/>
        <point x="5.1" y="5.725"/>
      </controlPoints>
    </diylc.passive.TransformerCore>
      <name>L49</name>
      <controlPoints>
        <point x="5.3" y="5.775"/>
        <point x="5.3" y="5.375"/>
      </controlPoints>
      <orientation>_180</orientation>
      <body>
            <default/>
            <byte>48</byte>
            <int>4</int>
            <int>8</int>
            <byte>1</byte>
            <byte>64</byte>
            <float>1060.0</float>
            <byte>65</byte>
            <float>1035.0</float>
            <byte>64</byte>
            <byte>65</byte>
            <byte>97</byte>
            <default/>
            <byte>48</byte>
            <int>9</int>
            <int>50</int>
            <byte>1</byte>
            <byte>64</byte>
            <byte>67</byte>
            <float>1025.0</float>
            <byte>67</byte>
            <byte>67</byte>
            <byte>67</byte>
            <byte>67</byte>
            <byte>67</byte>
            <byte>67</byte>
            <byte>67</byte>
            <byte>97</byte>
      </body>
      <name>GND7</name>
      <point x="5.3" y="6.475"/>
      <stroke>2</stroke>
      <name>LN34</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN37</name>
      <alpha>127</alpha>
      <points>
        <point x="5.6" y="5.525"/>
        <point x="5.4" y="5.525"/>
        <point x="9.25" y="0.65"/>
      </points>
    <diylc.shapes.Rectangle>
      <name>RECT3</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="5.6" y="5.375"/>
        <point x="5.65" y="5.525"/>
      </controlPoints>
      <firstPoint x="5.6" y="5.375"/>
      <secondPoint x="5.65" y="5.525"/>
      <color hex="ffffff"/>
      <borderThickness value="0.25" unit="mm"/>
      <edgeRadius value="0.0" unit="mm"/>
    </diylc.shapes.Rectangle>
      <name>LN52</name>
      <alpha>127</alpha>
      <points>
        <point x="5.475" y="5.375"/>
        <point x="9.1" y="0.5"/>
      </points>
      <arrowSize value="1.0" unit="px"/>
      <name>LN54</name>
      <alpha>127</alpha>
      <points>
        <point x="5.525" y="5.425"/>
        <point x="9.3" y="0.525"/>
      </points>
      <name>LN74</name>
      <alpha>127</alpha>
      <points>
        <point x="5.575" y="5.375"/>
        <point x="9.35" y="0.525"/>
      </points>
      <name>GND9</name>
      <stroke>2</stroke>
      <name>Dot17</name>
      <name>LN51</name>
      <alpha>127</alpha>
      <points>
        <point x="4.3" y="4.625"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.passive.CapacitorSymbol>
      <name>500P</name>
      <alpha>127</alpha>
      <length value="0.05" unit="in"/>
      <width value="0.15" unit="in"/>
      <points>
        <point x="4.5" y="4.625"/>
        <point x="4.4" y="4.515"/>
      </points>
      <voltage>_63V</voltage>
      <polarized>false</polarized>
    </diylc.passive.CapacitorSymbol>
      <name>LN79</name>
      <alpha>127</alpha>
      <points>
        <point x="7.125" y="4.625"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>1M</name>
      <alpha>127</alpha>
      <points>
        <point x="3.525" y="5.875"/>
        <point x="3.525" y="6.225"/>
        <point x="3.6" y="6.05"/>
      </points>
      <power>HALF</power>
      <name>LN80</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Dot18</name>
      <name>Dot19</name>
      <name>LN81</name>
      <alpha>127</alpha>
      <points>
      </points>
      <arrowTx reference="../../diylc.connectivity.Line[5]/arrowTx"/>
      <name>LN83</name>
      <alpha>127</alpha>
      <points>
        <point x="6.1" y="5.525"/>
        <point x="6.275" y="5.525"/>
      </points>
      <name>RECT4</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="6.1" y="5.375"/>
        <point x="6.05" y="5.525"/>
      </controlPoints>
      <firstPoint x="6.05" y="5.375"/>
      <secondPoint x="6.1" y="5.525"/>
      <borderThickness value="0.22" unit="mm"/>
      <name>LN84</name>
      <alpha>127</alpha>
      <points>
        <point x="6.225" y="5.375"/>
        <point x="6.4" y="5.375"/>
      </points>
      <name>LN86</name>
      <alpha>127</alpha>
      <points>
        <point x="6.175" y="5.425"/>
      </points>
      <name>LN87</name>
      <alpha>127</alpha>
      <points>
        <point x="6.125" y="5.375"/>
      </points>
      <name>GND12</name>
      <stroke>2</stroke>
      <name>RECT6</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="5.675" y="5.35"/>
        <point x="6.025" y="5.575"/>
      </controlPoints>
      <firstPoint x="5.675" y="5.35"/>
      <secondPoint x="6.025" y="5.575"/>
      <borderThickness value="0.2" unit="mm"/>
      <name>V3</name>
      <value></value>
      <flip>NONE</flip>
      <controlPoints>
        <point x="6.675" y="5.375"/>
        <point x="6.975" y="5.075"/>
        <point x="6.875" y="5.675"/>
        <point x="6.975" y="5.675"/>
        <point x="7.075" y="5.675"/>
      </controlPoints>
      <name>LN92</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>1.5K</name>
      <alpha>127</alpha>
      <points>
        <point x="6.875" y="5.775"/>
        <point x="6.875" y="6.175"/>
        <point x="6.775" y="5.975"/>
      </points>
      <power>HALF</power>
      <name>25uF</name>
      <alpha>127</alpha>
      <points>
        <point x="7.05" y="5.775"/>
        <point x="7.05" y="6.175"/>
        <point x="7.175" y="5.975"/>
      </points>
      <value value="25.0"/>
      <name>LN93</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN96</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN97</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>GND14</name>
      <point x="6.875" y="6.25"/>
      <stroke>2</stroke>
      <name>LN114</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Dot20</name>
      <name>Dot21</name>
      <name>GND15</name>
      <point x="6.45" y="6.25"/>
      <stroke>2</stroke>
      <name>220K</name>
      <alpha>127</alpha>
      <points>
        <point x="6.45" y="5.775"/>
        <point x="6.45" y="6.175"/>
        <point x="6.525" y="5.975"/>
      </points>
      <power>HALF</power>
      <name>LN116</name>
      <alpha>127</alpha>
      <points>
        <point x="6.45" y="5.325"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Dot24</name>
      <name>Dot25</name>
      <name>LN117</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN130</name>
      <alpha>127</alpha>
      <points>
        <point x="6.25" y="4.95"/>
        <point x="6.45" y="4.95"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN115</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>GND16</name>
      <point x="6.25" y="5.175"/>
      <stroke>2</stroke>
      <name>LN128</name>
      <alpha>127</alpha>
      <points>
        <point x="6.25" y="5.075"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Dot27</name>
      <name>Dot28</name>
      <name>LN132</name>
      <alpha>127</alpha>
      <points>
        <point x="6.325" y="5.075"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Dot32</name>
      <point x="6.45" y="5.375"/>
      <name>LN134</name>
      <alpha>127</alpha>
      <points>
        <point x="7.375" y="5.075"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>100K</name>
      <alpha>127</alpha>
      <points>
        <point x="7.375" y="5.475"/>
        <point x="7.45" y="5.275"/>
      </points>
      <value value="100.0"/>
      <power>HALF</power>
      <name>LN135</name>
      <alpha>127</alpha>
      <points>
        <point x="7.375" y="6.0"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>.003uF</name>
      <alpha>127</alpha>
      <points>
        <point x="7.625" y="5.075"/>
        <point x="7.5" y="4.965"/>
      </points>
      <value value="0.003"/>
    <diylc.passive.PotentiometerSymbol>
      <name></name>
      <value></value>
      <controlPoints>
        <point x="7.825" y="5.275"/>
        <point x="7.625" y="5.475"/>
        <point x="7.625" y="5.275"/>
      </controlPoints>
      <flip>X</flip>
    </diylc.passive.PotentiometerSymbol>
      <name>GND17</name>
      <stroke>2</stroke>
      <name>LN138</name>
      <alpha>127</alpha>
      <points>
        <point x="7.825" y="4.8"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN151</name>
      <alpha>127</alpha>
      <points>
        <point x="7.475" y="4.8"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>3.3M</name>
      <alpha>127</alpha>
      <width value="0.05" unit="in"/>
      <points>
        <point x="7.125" y="1.9"/>
        <point x="7.475" y="1.9"/>
        <point x="7.3125" y="1.975"/>
      </points>
      <value value="3.3" unit="K"/>
      <power>HALF</power>
      <name>10P</name>
      <alpha>127</alpha>
      <points>
        <point x="7.125" y="1.725"/>
        <point x="7.475" y="1.725"/>
        <point x="7.3" y="1.615"/>
      </points>
      <name>LN153</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN154</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>25uF</name>
      <alpha>127</alpha>
      <points>
        <point x="4.56" y="6.375"/>
      </points>
      <name>LN159</name>
      <alpha>127</alpha>
      <points>
        <point x="7.525" y="1.9"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>V5</name>
      <value></value>
      <flip>NONE</flip>
      <controlPoints>
        <point x="7.5" y="1.9"/>
        <point x="7.8" y="1.6"/>
        <point x="7.7" y="2.2"/>
        <point x="7.8" y="2.2"/>
        <point x="7.9" y="2.2"/>
      </controlPoints>
      <name>1.5K</name>
      <alpha>127</alpha>
      <points>
        <point x="7.7" y="2.325"/>
        <point x="7.7" y="2.725"/>
        <point x="7.76" y="2.525"/>
      </points>
      <value value="1.5" unit="K"/>
      <power>HALF</power>
      <name>GND18</name>
      <point x="7.7" y="2.875"/>
      <size value="0.1" unit="in"/>
      <stroke>1</stroke>
      <name>LN174</name>
      <alpha>127</alpha>
      <points>
        <point x="3.625" y="2.325"/>
      </points>
      <name>25uF</name>
      <alpha>127</alpha>
      <width value="0.1" unit="in"/>
      <points>
        <point x="7.875" y="2.725"/>
        <point x="7.875" y="2.325"/>
        <point x="7.79" y="2.525"/>
      </points>
      <voltageNew value="25.0" unit="V"/>
      <name>Dot34</name>
      <name>LN181</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN183</name>
      <alpha>127</alpha>
      <points>
        <point x="7.475" y="4.4"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>470K</name>
      <alpha>127</alpha>
      <points>
        <point x="7.400000000000002" y="4.6"/>
      </points>
      <power>HALF</power>
      <name>LN184</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Dot40</name>
      <name>Dot41</name>
      <name>LN186</name>
      <alpha>127</alpha>
      <points>
        <point x="8.15" y="1.6"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>100K</name>
      <alpha>127</alpha>
      <points>
        <point x="8.15" y="1.9"/>
        <point x="8.225" y="1.75"/>
      </points>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="1.0" unit="W"/>
      <name>LN187</name>
      <alpha>127</alpha>
      <points>
        <point x="8.15" y="3.6"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>220K</name>
      <alpha>127</alpha>
      <points>
        <point x="8.075" y="5.075"/>
        <point x="8.075" y="5.475"/>
        <point x="8.15" y="5.275"/>
      </points>
      <power>HALF</power>
      <name>220K</name>
      <stroke>2</stroke>
      <name>LN189</name>
      <alpha>127</alpha>
      <points>
        <point x="7.475" y="4.35"/>
        <point x="8.075" y="4.35"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN197</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN198</name>
      <alpha>127</alpha>
      <points>
        <point x="8.15" y="3.675"/>
        <point x="7.925" y="2.66"/>
      </points>
      <name>LN200</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN201</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Dot4</name>
    <diylc.misc.CommonNode>
      <name>CN1</name>
      <point x="4.9" y="6.525"/>
      <text>B+2</text>
      <font name="Dialog.plain" size="14" style="0"/>
      <bgColor hex="eeeeee"/>
      <shape>RECTANGLE</shape>
    </diylc.misc.CommonNode>
    <diylc.misc.Label>
      <name>LAB1</name>
      <point x="5.85" y="5.475"/>
      <text>Reverb&lt;br&gt;Tank</text>
      <font name="Dialog.bold" size="14" style="1"/>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
    </diylc.misc.Label>
      <name>CN2</name>
      <point x="7.375" y="6.05"/>
      <text>B+4</text>
    <diylc.misc.Label>
      <name>LAB4</name>
      <point x="7.925" y="2.35"/>
      <text>+</text>
      <font name="Tahoma" size="14" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB5</name>
      <point x="7.55" y="5.3"/>
      <text>100K-L</text>
      <orientation>_270</orientation>
    </diylc.misc.Label>
      <name>Dot1</name>
      <name>Dot2</name>
      <name>Dot3</name>
      <name>Dot5</name>
      <name>LN1</name>
      <alpha>127</alpha>
      <points>
        <point x="6.85" y="1.9"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN2</name>
      <alpha>127</alpha>
      <points>
        <point x="8.35" y="1.6"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.misc.Label>
      <name>LAB2</name>
      <point x="6.325" y="4.85"/>
      <text>Foot Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB3</name>
      <point x="3.925" y="5.475"/>
      <text>1</text>
      <font name="Dialog.plain" size="12" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB6</name>
      <point x="6.95" y="5.15"/>
      <text>1</text>
      <font reference="../../diylc.misc.Label[5]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB7</name>
      <point x="3.75" y="5.625"/>
      <text>2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB8</name>
      <point x="6.775" y="5.325"/>
      <text>2</text>
      <font reference="../../diylc.misc.Label[7]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB9</name>
      <point x="7.1" y="5.55"/>
      <text>3</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB10</name>
      <point x="4.1" y="5.825"/>
      <text>3</text>
      <font reference="../../diylc.misc.Label[9]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB11</name>
      <point x="7.775" y="1.7"/>
      <text>6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB12</name>
      <point x="4.525" y="5.475"/>
      <text>6</text>
      <font reference="../../diylc.misc.Label[11]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB13</name>
      <point x="4.35" y="5.625"/>
      <text>7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB14</name>
      <point x="7.6" y="1.85"/>
      <text>7</text>
      <font reference="../../diylc.misc.Label[13]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB15</name>
      <point x="7.65" y="2.05"/>
      <text>8</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB16</name>
      <point x="4.425" y="5.825"/>
      <text>8</text>
      <font reference="../../diylc.misc.Label[15]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB17</name>
      <point x="5.55" y="4.175"/>
      <text>AB763 Reverb Section</text>
      <font name="Dialog.bold" size="20" style="1"/>
    </diylc.misc.Label>
  </components>
  <groups>
    <set>
      <diylc.passive.ResistorSymbol reference="../../../components/diylc.passive.ResistorSymbol[10]"/>
      <diylc.misc.GroundSymbol reference="../../../components/diylc.misc.GroundSymbol[11]"/>
    </set>
  </groups>
  <lockedLayers/>
  <lockedComponents/>
  <hiddenLayers/>
</project>
