<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>4</major>
    <minor>37</minor>
    <build>0</build>
  </fileVersion>
  <title>AB763 6V6 Single Channel No Tremolo</title>
  <author>Modified from RobRobinette.com</author>
  <description>1963 blackfacw Amp Vibrato Channel only with tremolo deleted&lt;br&gt;6V6</description>
  <width value="18.9" unit="in"/>
  <height value="11.4" unit="in"/>
  <gridSpacing value="0.05" unit="in"/>
  <dotSpacing>1</dotSpacing>
  <components>
    <diylc.electromechanical.IECSocket>
      <name defined-in="diylc.AbstractComponent"></name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="1.0" y="10.5"/>
        <point x="0.7" y="10.7"/>
        <point x="1.3" y="10.7"/>
      </controlPoints>
      <name>IEC1</name>
      <orientation>DEFAULT</orientation>
      <bodyColor hex="555555"/>
      <borderColor hex="3b3b3b"/>
    </diylc.electromechanical.IECSocket>
    <diylc.passive.MultiSectionCapacitor>
      <name>C1</name>
      <alpha>127</alpha>
      <value>
        <org.diylc.core.measures.Capacitance value="40.0" unit="uF"/>
        <org.diylc.core.measures.Capacitance value="20.0" unit="uF"/>
      </value>
      <voltage value="500.0" unit="V"/>
      <orientation>_270</orientation>
      <controlPoints>
        <point x="5.35" y="5.4"/>
        <point x="5.5572949016875155" y="5.1146830451114536"/>
        <point x="5.892705098312485" y="5.223664424312258"/>
        <point x="5.892705098312485" y="5.576335575687742"/>
        <point x="5.5572949016875155" y="5.685316954888546"/>
      </controlPoints>
      <bodyColor hex="6b6dce"/>
      <baseColor hex="333333"/>
      <borderColor hex="4a4c90"/>
      <labelColor hex="ffffff"/>
      <pinColor hex="759daf"/>
      <display>NAME</display>
      <diameter value="1.0" unit="in"/>
    </diylc.passive.MultiSectionCapacitor>
    <diylc.boards.BlankBoard>
      <name>Main</name>
      <alpha>127</alpha>
      <value>Main</value>
      <controlPoints>
        <point x="7.5" y="4.25"/>
        <point x="18.0" y="7.375"/>
      </controlPoints>
      <firstPoint x="7.5" y="4.25"/>
      <secondPoint x="18.0" y="7.375"/>
      <boardColor hex="999999"/>
      <borderColor hex="ada47d"/>
      <coordinateColor hex="b6b6b6"/>
      <drawCoordinates>true</drawCoordinates>
      <coordinateOrigin>Top_Left</coordinateOrigin>
      <length value="10.5" unit="in"/>
      <width value="3.125" unit="in"/>
      <mode>Explicit</mode>
      <type>SQUARE</type>
    </diylc.boards.BlankBoard>
    <diylc.connectivity.Eyelet>
      <name>Eyelet63</name>
      <size value="0.2" unit="in"/>
      <holeSize value="0.1" unit="in"/>
      <color hex="ffcc00"/>
      <point x="11.0" y="5.3"/>
      <value>Hoffman Eyelet</value>
    </diylc.connectivity.Eyelet>
      <name>Eyelet54</name>
      <point x="12.85" y="5.75"/>
    <diylc.connectivity.HookupWire>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.7" y="4.15"/>
        <point x="0.6" y="4.05"/>
        <point x="0.55" y="4.0"/>
      </controlPoints2>
      <color hex="339900"/>
      <pointCount>THREE</pointCount>
      <style>SOLID</style>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_18</gauge>
      <striped>false</striped>
      <stripeColor hex="ffff00"/>
    </diylc.connectivity.HookupWire>
    <diylc.electromechanical.MiniToggleSwitch>
      <name defined-in="diylc.AbstractComponent">Power</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="0.45" y="2.1"/>
        <point x="0.45" y="2.3"/>
      </controlPoints>
      <switchType>SPST</switchType>
      <orientation>VERTICAL</orientation>
      <spacing value="0.2" unit="in"/>
      <bodyColor hex="3299cc"/>
      <borderColor hex="236b8e"/>
    </diylc.electromechanical.MiniToggleSwitch>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.25" y="2.7"/>
        <point x="20.55" y="2.7"/>
      </controlPoints2>
      <color hex="000000"/>
      <pointCount>TWO</pointCount>
      <style>DOTTED</style>
      <gauge>_30</gauge>
      <name>Eyelet50</name>
      <size value="0.5" unit="in"/>
      <holeSize value="0.25" unit="in"/>
      <color hex="cccccc"/>
      <point x="13.25" y="10.65"/>
      <value>Jack</value>
    <diylc.connectivity.SolderPad>
      <name>Pad1</name>
      <size value="0.09" unit="in"/>
      <type>ROUND</type>
      <holeSize value="0.8" unit="mm"/>
      <layer>_1</layer>
    </diylc.connectivity.SolderPad>
      <point x="14.35" y="10.65"/>
      <value>Jack</value>
      <name>Pad1</name>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="15.35" y="10.65"/>
      <value>Jack</value>
      <name>Pad1</name>
      <type>ROUND</type>
      <layer>_1</layer>
    <diylc.shapes.Ellipse>
      <name>ELL2</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="3.1" y="10.4"/>
        <point x="3.7" y="11.0"/>
      </controlPoints>
      <firstPoint x="3.1" y="10.4"/>
      <secondPoint x="3.7" y="11.0"/>
      <color hex="ffffff"/>
      <borderColor hex="000000"/>
      <borderThickness value="0.2" unit="mm"/>
    </diylc.shapes.Ellipse>
    <diylc.passive.PotentiometerPanel>
      <name>Bias</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="7.35" y="3.95"/>
        <point x="7.65" y="3.95"/>
        <point x="7.95" y="3.95"/>
      </controlPoints>
      <resistance value="10.0" unit="K"/>
      <taper>LIN</taper>
      <bodyDiameter value="1.0" unit="in"/>
      <spacing value="0.3" unit="in"/>
      <lugDiameter value="0.15" unit="in"/>
      <bodyColor hex="c0c0c0"/>
      <borderColor hex="808080"/>
      <nutColor hex="cbd5db"/>
      <waferColor hex="cd8500"/>
      <type>ThroughHole</type>
      <showShaft>true</showShaft>
      <view>ShaftUp</view>
    </diylc.passive.PotentiometerPanel>
    <diylc.shapes.Rectangle>
      <name>Power Transformer</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="1.75" y="4.4"/>
        <point x="4.55" y="7.15"/>
      </controlPoints>
      <firstPoint x="1.75" y="4.4"/>
      <secondPoint x="4.55" y="7.15"/>
      <color hex="333333"/>
      <edgeRadius value="20.0" unit="mm"/>
    </diylc.shapes.Rectangle>
    <diylc.tube.TubeSocket>
      <name>V7</name>
      <alpha>127</alpha>
      <angle>50</angle>
      <base>OCTAL</base>
      <type>GZ34</type>
      <color hex="f7f7ef"/>
      <electrodeLabels>1,2,3,4,5,6,7,8,9,10,11,12</electrodeLabels>
      <mount>PCB</mount>
      <labelColor hex="acaca7"/>
      <controlPoints>
        <point x="2.8" y="8.78"/>
        <point x="2.9" y="9.105"/>
        <point x="2.64" y="9.08"/>
        <point x="2.47" y="8.88"/>
        <point x="2.495" y="8.62"/>
        <point x="2.695" y="8.45"/>
        <point x="2.955" y="8.475"/>
        <point x="3.125" y="8.675"/>
        <point x="3.1" y="8.935"/>
      </controlPoints>
    </diylc.tube.TubeSocket>
      <name>W2</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="13.8" y="5.25"/>
        <point x="14.0" y="5.3"/>
        <point x="14.35" y="5.45"/>
        <point x="15.05" y="6.1"/>
      </controlPoints2>
      <color hex="ffff00"/>
      <pointCount>FOUR</pointCount>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="11.35" y="5.5"/>
        <point x="12.55" y="5.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="13.3" y="6.1"/>
        <point x="13.45" y="6.3"/>
        <point x="14.2" y="6.8"/>
        <point x="15.4" y="6.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Bias Board</name>
      <alpha>127</alpha>
      <value>Bias</value>
      <controlPoints>
        <point x="3.7" y="2.8"/>
        <point x="6.7" y="3.95"/>
      </controlPoints>
      <firstPoint x="3.7" y="2.8"/>
      <secondPoint x="6.7" y="3.95"/>
      <length value="76.2" unit="mm"/>
      <width value="29.21" unit="mm"/>
      <mode>TwoPoints</mode>
      <type>SQUARE</type>
      <name>Eyelet3</name>
      <point x="8.969999999999999" y="7.075"/>
      <name>Eyelet4</name>
      <point x="9.35" y="6.19"/>
      <name>Eyelet5</name>
      <point x="10.139999999999999" y="6.055"/>
      <name>Eyelet6</name>
      <point x="9.819999999999999" y="7.075"/>
      <name>Eyelet7</name>
      <point x="10.45" y="7.075"/>
      <name>Eyelet8</name>
      <point x="10.95" y="7.025"/>
      <name>Eyelet9</name>
      <point x="10.95" y="5.95"/>
      <name>Eyelet10</name>
      <point x="11.455" y="6.145"/>
      <name>Eyelet11</name>
      <point x="11.47" y="7.075"/>
      <name>Eyelet20</name>
      <point x="12.39" y="6.975"/>
      <name>Eyelet22</name>
      <point x="12.84" y="7.075"/>
      <name>Eyelet23</name>
      <point x="13.67" y="7.025"/>
      <name>Eyelet24</name>
      <point x="14.12" y="6.975"/>
      <name>Eyelet25</name>
      <point x="14.62" y="6.975"/>
      <name>Eyelet26</name>
      <point x="15.07" y="7.125"/>
      <name>Eyelet27</name>
      <point x="15.75" y="7.125"/>
      <name>Eyelet28</name>
      <point x="16.62" y="7.125"/>
      <name>Eyelet29</name>
      <point x="17.01" y="6.975"/>
      <name>Eyelet40</name>
      <point x="16.999999999999996" y="5.075"/>
      <name>Eyelet41</name>
      <point x="16.589999999999996" y="5.175"/>
      <name>Eyelet42</name>
      <point x="16.255" y="5.2"/>
      <name>Eyelet43</name>
      <point x="15.755" y="5.62"/>
      <name>Eyelet45</name>
      <point x="15.41" y="6.105"/>
      <name>Eyelet46</name>
      <point x="15.05" y="6.115"/>
      <name>Eyelet47</name>
      <point x="15.3" y="5.065"/>
      <name>Eyelet49</name>
      <point x="14.37" y="5.125"/>
      <point x="13.78" y="5.275"/>
      <name>Eyelet51</name>
      <point x="13.4" y="5.0249999999999995"/>
      <name>Eyelet52</name>
      <point x="13.685" y="5.75"/>
      <name>Eyelet53</name>
      <name>Eyelet55</name>
      <point x="12.61" y="5.44"/>
      <name>Eyelet56</name>
      <point x="11.99" y="5.0249999999999995"/>
      <name>Eyelet65</name>
      <point x="10.45" y="4.874999999999999"/>
      <name>Eyelet66</name>
      <point x="9.819999999999999" y="4.874999999999999"/>
      <name>Eyelet67</name>
      <point x="9.344999999999999" y="5.71"/>
      <name>Eyelet68</name>
      <point x="8.95" y="4.85"/>
      <name>Eyelet71</name>
      <point x="7.67" y="6.975"/>
      <size value="0.3" unit="in"/>
      <point x="6.02" y="7.8"/>
      <value>Grommet</value>
      <holeSize value="0.05" unit="in"/>
      <point x="4.87" y="4.45"/>
      <point x="14.02" y="8.9"/>
      <point x="13.29" y="7.0"/>
      <name>Eyelet39</name>
      <color hex="c3e4ed"/>
      <point x="3.1" y="5.75"/>
      <value></value>
      <name>Eyelet32</name>
      <point x="0.65" y="8.65"/>
      <value>Bolt</value>
      <size value="0.7" unit="in"/>
      <point x="15.9" y="2.2"/>
      <value>Jack</value>
      <point x="16.83" y="2.2"/>
      <value>Jack</value>
      <name>Pad1</name>
      <point x="16.25" y="2.2"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="16.45" y="2.2"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="16.05" y="1.85"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="17.1" y="2.5"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="16.05" y="2.55"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="16.7" y="2.55"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="5.27" y="3.05"/>
      <point x="4.17" y="3.05"/>
      <point x="4.32" y="3.5"/>
      <point x="6.22" y="3.5"/>
      <point x="6.22" y="3.05"/>
      <name>Pad2</name>
      <point x="1.0" y="2.4000000000000004"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad2</name>
      <point x="1.25" y="2.45"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="10.1" y="10.7"/>
      <value>Jack</value>
      <point x="11.18" y="10.7"/>
      <value>Jack</value>
      <name>Pad1</name>
      <point x="10.45" y="10.7"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="11.4" y="11.0"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="10.25" y="10.35"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="11.4" y="10.4"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="10.25" y="11.05"/>
      <type>ROUND</type>
      <layer>_1</layer>
    <diylc.passive.AxialFilmCapacitor>
      <name>.1uF  630v Bass</name>
      <alpha>127</alpha>
      <length value="1.02" unit="in"/>
      <width value="0.29" unit="in"/>
      <points>
        <point x="16.6" y="5.2"/>
        <point x="16.6" y="7.15"/>
        <point x="16.6" y="6.175"/>
      </points>
      <bodyColor hex="ffff00"/>
      <borderColor hex="b29e02"/>
      <labelColor hex="000000"/>
      <leadColor hex="cccccc"/>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>false</moveLabel>
      <value value="0.1" unit="uF"/>
      <voltage>_63V</voltage>
      <voltageNew value="630.0" unit="V"/>
      <showOuterFoil>false</showOuterFoil>
      <outerFoilColor hex="ffffff"/>
    </diylc.passive.AxialFilmCapacitor>
    <diylc.passive.RadialCeramicDiskCapacitor>
      <name>Treble</name>
      <alpha>127</alpha>
      <length value="0.3" unit="in"/>
      <width value="0.125" unit="in"/>
      <points>
        <point x="15.75" y="5.65"/>
        <point x="15.75" y="7.1"/>
        <point x="15.75" y="6.375"/>
      </points>
      <bodyColor hex="f0e68c"/>
      <borderColor hex="a8a162"/>
      <display>VALUE</display>
      <pinSpacing value="0.1" unit="in"/>
      <value value="250.0" unit="pF"/>
      <voltageNew value="500.0" unit="V"/>
    </diylc.passive.RadialCeramicDiskCapacitor>
    <diylc.passive.Resistor>
      <name>Plate Load</name>
      <alpha>127</alpha>
      <length value="0.4" unit="in"/>
      <width value="0.14" unit="in"/>
      <points>
        <point x="15.575" y="6.6"/>
      </points>
      <bodyColor hex="996600"/>
      <borderColor hex="cc6600"/>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="1.0" unit="W"/>
      <colorCode>_4_BAND</colorCode>
      <shape>Tubular</shape>
    </diylc.passive.Resistor>
      <alpha>127</alpha>
      <points>
        <point x="15.05" y="7.1"/>
        <point x="15.225" y="6.6"/>
      </points>
      <power>HALF</power>
      <name>Cathode</name>
      <alpha>127</alpha>
      <points>
        <point x="17.0" y="5.1"/>
        <point x="16.999999999999996" y="6.95"/>
        <point x="16.999999999999996" y="6.025"/>
      </points>
      <value value="1.5" unit="K"/>
      <power>HALF</power>
      <powerNew value="0.5" unit="W"/>
      <name>.047uF  630v Mid</name>
      <alpha>127</alpha>
      <length value="0.73" unit="in"/>
      <width value="0.28" unit="in"/>
      <points>
        <point x="16.25" y="5.2"/>
        <point x="16.25" y="6.65"/>
        <point x="16.25" y="5.925"/>
      </points>
      <value value="0.047" unit="uF"/>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.6" y="7.1"/>
        <point x="16.55" y="6.95"/>
        <point x="16.25" y="6.9"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.passive.AxialElectrolyticCapacitor>
      <name>25uF  50v</name>
      <alpha>127</alpha>
      <length value="0.53" unit="in"/>
      <width value="0.26" unit="in"/>
      <points>
        <point x="17.299999999999997" y="6.5"/>
        <point x="17.3" y="5.55"/>
        <point x="17.299999999999997" y="6.025"/>
      </points>
      <bodyColor hex="6666ff"/>
      <labelColor hex="ffff00"/>
      <value value="25.0" unit="uF"/>
      <voltageNew value="50.0" unit="V"/>
      <markerColor hex="333333"/>
      <tickColor hex="ffffff"/>
      <polarized>true</polarized>
    </diylc.passive.AxialElectrolyticCapacitor>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.000000000000004" y="6.95"/>
        <point x="17.15" y="6.85"/>
        <point x="17.25" y="6.85"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.3" y="5.25"/>
        <point x="17.2" y="5.15"/>
        <point x="17.0" y="5.05"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>.022uF  630v</name>
      <alpha>127</alpha>
      <length value="0.63" unit="in"/>
      <width value="0.23" unit="in"/>
      <points>
        <point x="15.05" y="6.15"/>
        <point x="15.05" y="6.625"/>
      </points>
      <bodyColor hex="ff6600"/>
      <value value="0.022" unit="uF"/>
      <name>Reverb Filter</name>
      <alpha>127</alpha>
      <points>
        <point x="15.3" y="5.05"/>
        <point x="15.175" y="5.575"/>
      </points>
      <value value="500.0" unit="pF"/>
      <alpha>127</alpha>
      <points>
        <point x="14.35" y="5.15"/>
        <point x="14.6" y="6.95"/>
        <point x="14.475" y="6.05"/>
      </points>
      <power>HALF</power>
      <name>2.2k 3W</name>
      <alpha>127</alpha>
      <points>
        <point x="14.1" y="6.95"/>
        <point x="14.225" y="6.05"/>
      </points>
      <value value="2.2" unit="K"/>
      <power>HALF</power>
      <powerNew value="3.0" unit="W"/>
      <alpha>127</alpha>
      <points>
        <point x="14.8" y="6.4"/>
        <point x="14.7" y="5.45"/>
        <point x="14.75" y="5.925"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.65" y="5.2"/>
        <point x="14.6" y="5.15"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <alpha>127</alpha>
      <points>
        <point x="13.95" y="6.4"/>
        <point x="14.05" y="5.45"/>
        <point x="14.0" y="5.925"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.95" y="6.85"/>
        <point x="13.95" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.1" y="5.2"/>
        <point x="14.15" y="5.2"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.75" y="6.75"/>
        <point x="14.8" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>Grid Leak</name>
      <alpha>127</alpha>
      <points>
        <point x="14.38" y="5.15"/>
        <point x="14.84" y="5.1"/>
      </points>
      <value value="1.0" unit="M"/>
      <power>HALF</power>
      <name>Reverb Mix</name>
      <alpha>127</alpha>
      <points>
        <point x="13.8" y="5.3"/>
        <point x="12.6" y="5.45"/>
        <point x="13.2" y="5.375"/>
      </points>
      <value value="3.3" unit="M"/>
      <power>HALF</power>
      <name>Reverb Attn</name>
      <alpha>127</alpha>
      <points>
        <point x="13.4" y="5.05"/>
        <point x="13.0" y="5.25"/>
      </points>
      <value value="470.0" unit="K"/>
      <power>HALF</power>
      <name>Reverb Bright</name>
      <alpha>127</alpha>
      <points>
        <point x="13.55" y="5.4"/>
        <point x="13.0" y="5.6"/>
        <point x="13.275" y="5.5"/>
      </points>
      <value value="10.0" unit="pF"/>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.7" y="5.35"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.8" y="5.55"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>.003uF  630v</name>
      <alpha>127</alpha>
      <length value="0.51" unit="in"/>
      <width value="0.16" unit="in"/>
      <points>
        <point x="13.65" y="5.75"/>
        <point x="13.65" y="7.0"/>
        <point x="13.65" y="6.375"/>
      </points>
      <value value="0.003" unit="uF"/>
      <alpha>127</alpha>
      <points>
        <point x="13.475" y="6.55"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="12.85" y="7.05"/>
        <point x="13.075" y="6.575"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="12.0" y="5.05"/>
        <point x="12.4" y="6.95"/>
        <point x="12.2" y="6.0"/>
      </points>
      <value value="820.0" unit="R"/>
      <power>HALF</power>
      <name>25 uF 50V</name>
      <alpha>127</alpha>
      <length value="0.52" unit="in"/>
      <points>
        <point x="12.0" y="6.55"/>
        <point x="11.9" y="5.6"/>
        <point x="11.95" y="6.075"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.8" y="5.3"/>
        <point x="11.9" y="5.15"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.1" y="6.85"/>
        <point x="12.1" y="6.75"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>.1uF  630v Coupling</name>
      <alpha>127</alpha>
      <length value="0.8" unit="in"/>
      <points>
        <point x="12.85" y="6.4"/>
      </points>
      <alpha>127</alpha>
      <points>
        <point x="12.3" y="5.25"/>
      </points>
      <value value="220.0" unit="K"/>
      <power>HALF</power>
      <name>.001uF  630v</name>
      <alpha>127</alpha>
      <width value="0.18" unit="in"/>
      <points>
        <point x="11.45" y="6.15"/>
        <point x="11.45" y="7.05"/>
        <point x="11.45" y="6.6"/>
      </points>
      <value value="0.001" unit="uF"/>
      <name>Channel Mix</name>
      <alpha>127</alpha>
      <points>
        <point x="11.225" y="5.725"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="10.45" y="7.05"/>
        <point x="10.7" y="6.5"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="11.45" y="7.1"/>
        <point x="11.2" y="6.525"/>
      </points>
      <power>HALF</power>
      <name>PI Tail</name>
      <alpha>127</alpha>
      <points>
        <point x="10.45" y="4.85"/>
        <point x="10.7" y="5.4"/>
      </points>
      <value value="22.0" unit="K"/>
      <power>HALF</power>
      <name>PI Cathode</name>
      <alpha>127</alpha>
      <points>
        <point x="10.95" y="7.0"/>
        <point x="10.95" y="6.475"/>
      </points>
      <value value="470.0" unit="R"/>
      <power>HALF</power>
      <name>.1uF  200v AC Shunt</name>
      <alpha>127</alpha>
      <points>
        <point x="10.45" y="5.95"/>
      </points>
      <voltageNew value="200.0" unit="V"/>
      <name>NFB</name>
      <alpha>127</alpha>
      <points>
        <point x="10.149999999999999" y="6.05"/>
        <point x="10.15" y="5.25"/>
        <point x="10.15" y="5.65"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="9.799999999999999" y="4.9"/>
        <point x="9.799999999999999" y="7.05"/>
        <point x="9.799999999999999" y="5.975"/>
      </points>
      <alpha>127</alpha>
      <points>
        <point x="8.95" y="7.05"/>
        <point x="8.95" y="5.95"/>
      </points>
      <name>PI Plate Load</name>
      <alpha>127</alpha>
      <points>
        <point x="9.35" y="6.2"/>
        <point x="9.8" y="7.05"/>
        <point x="9.575" y="6.625"/>
      </points>
      <value value="82.0" unit="K"/>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="8.95" y="7.1"/>
        <point x="9.149999999999999" y="6.65"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="9.35" y="5.7"/>
        <point x="9.149999999999999" y="5.275"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="9.575" y="5.3"/>
      </points>
      <power>HALF</power>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.05" y="7.8"/>
        <point x="6.25" y="7.3"/>
        <point x="6.95" y="7.15"/>
        <point x="7.65" y="7.0"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.15" y="7.15"/>
        <point x="7.05" y="6.45"/>
        <point x="7.7" y="6.55"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.0" y="7.2"/>
        <point x="5.9" y="7.05"/>
      </controlPoints2>
      <color hex="ff0000"/>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.45" y="5.45"/>
        <point x="6.05" y="6.25"/>
        <point x="5.55" y="5.7"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.2" y="3.95"/>
        <point x="7.35" y="3.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.25" y="6.7"/>
      <text>PI Plate Load</text>
      <font name="Tahoma" size="14" style="0"/>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.25" y="5.15"/>
      <text>Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.65" y="6.1"/>
      <text>LTP PI</text>
      <font name="Tahoma" size="20" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.4" y="5.75"/>
      <text>Channel Mix</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.7" y="5.1"/>
      <text>PI Tail</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.7" y="6.6"/>
      <text>Coupling</text>
      <verticalAlignment>TOP</verticalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.8" y="6.05"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.95" y="5.1"/>
      <text>Attenuation</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.45" y="5.55"/>
      <text>Bright</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.8" y="6.35"/>
      <text>V3A Coupling</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.2" y="6.6"/>
      <text>V3 Plate Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.4" y="6.75"/>
      <text>V1 Plate Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.4" y="7.1"/>
      <text>Slope</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.2" y="5.9"/>
      <text>Reverb</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.3" y="5.9"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.9" y="6.55"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.85" y="5.95"/>
      <text>Treble</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.95" y="5.9"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.85" y="5.9"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.15" y="5.75"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.75" y="4.9"/>
      <text>V2 Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.65" y="4.9"/>
      <text>Reverb Mix</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.7" y="7.0"/>
      <text>V4A Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.7" y="6.9"/>
      <text>V4B Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.25" y="5.05"/>
      <text>Power Tube</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.95" y="5.3"/>
      <text>NFB</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.95" y="4.85"/>
      <text>NFB Tail</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.95" y="5.05"/>
      <text>Reverb</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.4" y="7.2"/>
      <text>A (B+1)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.35" y="6.45"/>
      <text>B (B+2)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.5" y="0.5"/>
      <text>RR763R BLACKVIBE REVERB</text>
      <font name="Tahoma" size="140" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.1" y="6.2"/>
      <text>V1A Cathode</text>
      <horizontalAlignment>RIGHT</horizontalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.45" y="6.25"/>
      <text>V1B Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.25" y="6.25"/>
      <text>V2 Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.1" y="6.2"/>
      <text>V3 Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.15" y="6.75"/>
      <text>PI Cathode</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.1" y="8.95"/>
        <point x="3.95" y="8.9"/>
        <point x="6.05" y="6.05"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V1</name>
      <alpha>127</alpha>
      <angle>320</angle>
      <base>B9A</base>
      <type>12AX7</type>
      <electrodeLabels>1,2,3,4,5,6,7,8,9</electrodeLabels>
      <mount>PCB</mount>
      <controlPoints>
        <point x="17.2" y="9.0"/>
        <point x="17.61" y="8.97"/>
        <point x="17.545" y="9.215"/>
        <point x="17.35" y="9.38"/>
        <point x="17.1" y="9.4"/>
        <point x="16.88" y="9.265"/>
        <point x="16.785" y="9.025"/>
        <point x="16.85" y="8.78"/>
        <point x="17.045" y="8.615"/>
        <point x="17.295" y="8.595"/>
      </controlPoints>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.45" y="7.6"/>
        <point x="16.6" y="7.7"/>
        <point x="18.35" y="8.65"/>
        <point x="17.55" y="9.2"/>
      </controlPoints2>
      <color hex="ff3333"/>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.0" y="7.6"/>
        <point x="16.0" y="7.8"/>
        <point x="16.8" y="8.4"/>
        <point x="16.85" y="8.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.75" y="7.15"/>
        <point x="16.65" y="8.15"/>
        <point x="17.95" y="8.55"/>
        <point x="17.6" y="8.95"/>
      </controlPoints2>
      <color hex="ffcc33"/>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.85" y="7.5"/>
        <point x="16.35" y="8.95"/>
        <point x="16.8" y="9.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.75" y="8.3"/>
        <point x="16.9" y="7.8"/>
        <point x="17.05" y="8.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.9" y="9.25"/>
        <point x="16.85" y="9.4"/>
        <point x="17.0" y="9.45"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.999999999999996" y="7.0"/>
        <point x="18.0" y="8.65"/>
        <point x="18.2" y="9.45"/>
        <point x="17.35" y="9.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V2</name>
      <alpha>127</alpha>
      <angle>320</angle>
      <base>B9A</base>
      <type>12AT7</type>
      <mount>PCB</mount>
      <controlPoints>
        <point x="15.6" y="9.0"/>
        <point x="16.01" y="8.97"/>
        <point x="15.945" y="9.215"/>
        <point x="15.75" y="9.38"/>
        <point x="15.5" y="9.4"/>
        <point x="15.28" y="9.265"/>
        <point x="15.185" y="9.025"/>
        <point x="15.25" y="8.78"/>
        <point x="15.445" y="8.615"/>
        <point x="15.695" y="8.595"/>
      </controlPoints>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.4" y="7.0"/>
        <point x="15.05" y="8.55"/>
        <point x="15.25" y="8.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.15" y="7.0"/>
        <point x="14.75" y="8.6"/>
        <point x="15.2" y="8.2"/>
        <point x="15.45" y="8.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.3" y="9.25"/>
        <point x="15.25" y="9.4"/>
        <point x="15.4" y="9.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V3</name>
      <alpha>127</alpha>
      <angle>320</angle>
      <base>B9A</base>
      <type>12AX7</type>
      <mount>PCB</mount>
      <controlPoints>
        <point x="12.4" y="8.95"/>
        <point x="12.81" y="8.92"/>
        <point x="12.745" y="9.165"/>
        <point x="12.55" y="9.33"/>
        <point x="12.3" y="9.35"/>
        <point x="12.08" y="9.215"/>
        <point x="11.985" y="8.975"/>
        <point x="12.05" y="8.73"/>
        <point x="12.245" y="8.565"/>
        <point x="12.495" y="8.545"/>
      </controlPoints>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.1" y="9.6"/>
        <point x="12.95" y="9.2"/>
        <point x="12.75" y="9.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.65" y="7.8"/>
        <point x="12.1" y="8.3"/>
        <point x="12.05" y="8.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.65" y="7.05"/>
        <point x="13.6" y="8.1"/>
        <point x="13.2" y="8.5"/>
        <point x="12.8" y="8.9"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.85" y="7.1"/>
        <point x="11.6" y="8.05"/>
        <point x="11.75" y="9.0"/>
        <point x="12.0" y="8.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.4" y="7.0"/>
        <point x="12.1" y="7.65"/>
        <point x="12.45" y="8.05"/>
        <point x="12.25" y="8.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.1" y="9.2"/>
        <point x="12.1" y="9.35"/>
        <point x="12.25" y="9.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V4</name>
      <alpha>127</alpha>
      <angle>320</angle>
      <base>B9A</base>
      <type>12AT7</type>
      <mount>PCB</mount>
      <controlPoints>
        <point x="10.55" y="8.95"/>
        <point x="10.96" y="8.92"/>
        <point x="10.895" y="9.165"/>
        <point x="10.7" y="9.33"/>
        <point x="10.45" y="9.35"/>
        <point x="10.23" y="9.215"/>
        <point x="10.135" y="8.975"/>
        <point x="10.2" y="8.73"/>
        <point x="10.395" y="8.565"/>
        <point x="10.645" y="8.545"/>
      </controlPoints>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.85" y="7.95"/>
        <point x="11.55" y="8.95"/>
        <point x="10.9" y="9.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.45" y="7.1"/>
        <point x="10.45" y="7.75"/>
        <point x="9.75" y="8.3"/>
        <point x="10.2" y="8.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.15" y="8.2"/>
        <point x="11.35" y="8.5"/>
        <point x="10.95" y="8.9"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.149999999999999" y="8.25"/>
        <point x="9.85" y="9.0"/>
        <point x="10.15" y="8.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.95" y="7.05"/>
        <point x="10.7" y="7.8"/>
        <point x="10.35" y="8.25"/>
        <point x="10.4" y="8.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.25" y="9.2"/>
        <point x="10.25" y="9.35"/>
        <point x="10.4" y="9.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V6</name>
      <alpha>127</alpha>
      <angle>50</angle>
      <base>OCTAL</base>
      <type>6V6GT</type>
      <mount>PCB</mount>
      <controlPoints>
        <point x="5.4" y="8.8"/>
        <point x="5.5" y="9.125"/>
        <point x="5.24" y="9.1"/>
        <point x="5.07" y="8.9"/>
        <point x="5.095" y="8.64"/>
        <point x="5.295" y="8.47"/>
        <point x="5.555" y="8.495"/>
        <point x="5.725" y="8.695"/>
        <point x="5.7" y="8.955"/>
      </controlPoints>
      <name>V5</name>
      <alpha>127</alpha>
      <angle>50</angle>
      <base>OCTAL</base>
      <type>6V6GT</type>
      <mount>PCB</mount>
      <controlPoints>
        <point x="7.3" y="8.8"/>
        <point x="7.4" y="9.125"/>
        <point x="7.14" y="9.1"/>
        <point x="6.97" y="8.9"/>
        <point x="6.995" y="8.64"/>
        <point x="7.195" y="8.47"/>
        <point x="7.455" y="8.495"/>
        <point x="7.625" y="8.695"/>
        <point x="7.6" y="8.955"/>
      </controlPoints>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.7" y="8.95"/>
        <point x="6.45" y="9.25"/>
        <point x="7.7" y="9.65"/>
        <point x="7.6" y="8.95"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W14</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.45" y="8.5"/>
        <point x="7.3" y="8.05"/>
        <point x="6.0" y="8.2"/>
        <point x="5.55" y="8.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W34</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.05" y="8.9"/>
        <point x="4.25" y="8.9"/>
        <point x="5.7" y="7.5"/>
        <point x="6.0" y="7.8"/>
      </controlPoints2>
      <color hex="663300"/>
      <gauge>_20</gauge>
      <name>W35</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.0" y="7.5"/>
        <point x="6.35" y="7.8"/>
        <point x="6.95" y="8.9"/>
      </controlPoints2>
      <color hex="0000cc"/>
      <gauge>_20</gauge>
      <name>Grid Stopper</name>
      <alpha>127</alpha>
      <width value="0.13" unit="in"/>
      <points>
        <point x="5.3" y="8.5"/>
        <point x="5.5" y="9.15"/>
        <point x="5.4" y="8.825"/>
      </points>
      <borderColor hex="5b90b1"/>
      <power>HALF</power>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.5" y="8.6"/>
        <point x="4.85" y="6.45"/>
        <point x="4.85" y="4.45"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <alpha>127</alpha>
      <points>
        <point x="7.2" y="8.5"/>
        <point x="7.4" y="9.15"/>
        <point x="7.3" y="8.825"/>
      </points>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="17.55" y="8.95"/>
      <text>1</text>
      <font name="Tahoma" size="24" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="17.2" y="9.65"/>
      <text>V1  12AX7</text>
      <font name="Tahoma" size="34" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="17.35" y="8.55"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="17.05" y="9.3"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="17.25" y="8.65"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="15.6" y="9.65"/>
      <text>V2  12AT7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="15.6" y="9.85"/>
      <text>Reverb Driver</text>
      <font name="Tahoma" size="22" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="15.7" y="8.5"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="15.45" y="9.3"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="15.65" y="8.65"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="12.5" y="9.55"/>
      <text>V3  12AX7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.5" y="9.9"/>
      <text>B Vibrato Preamp 3</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="12.55" y="8.45"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="12.25" y="9.25"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="12.5" y="8.6"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="10.6" y="9.55"/>
      <text>V4  12AT7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="10.6" y="9.75"/>
      <text>LTP Phase Inverter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="10.7" y="8.45"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="10.45" y="9.25"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="10.65" y="8.6"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.35" y="9.15"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.5" y="9.2"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="7.3" y="9.5"/>
      <text>V5 6V6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="5.3" y="9.5"/>
      <text>V6  6V6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.15" y="9.2"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.8" y="8.6"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.1" y="9.2"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.65" y="8.7"/>
      <text>Fil 1</text>
      <horizontalAlignment>LEFT</horizontalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="6.3" y="9.7"/>
      <text>Push-Pull Power Tubes</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.35" y="9.0"/>
      <text>Grid Stopper</text>
      <font name="Tahoma" size="15" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.15" y="8.9"/>
      <text>3</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="6.9" y="8.9"/>
      <text>3</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="6.95" y="8.65"/>
      <text>4</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.05" y="8.65"/>
      <text>4</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.25" y="8.4"/>
      <text>5</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.35" y="8.4"/>
      <text>5</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.65" y="8.5"/>
      <text>6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.55" y="8.5"/>
      <text>6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.25" y="9.0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.65" y="8.95"/>
      <text>8</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.7" y="8.95"/>
      <text>8</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.7" y="9.4"/>
        <point x="8.8" y="5.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.45" y="9.7"/>
        <point x="8.6" y="5.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Screen</name>
      <alpha>127</alpha>
      <length value="0.35" unit="in"/>
      <points>
        <point x="5.1" y="8.65"/>
        <point x="5.325" y="8.575"/>
      </points>
      <bodyColor hex="cccccc"/>
      <power>HALF</power>
      <shape>Standard</shape>
    <diylc.connectivity.Jumper>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="10.7" y="9.3"/>
        <point x="10.45" y="8.6"/>
        <point x="10.575" y="8.95"/>
      </points>
      <bodyColor hex="ffffff"/>
    </diylc.connectivity.Jumper>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="12.55" y="9.3"/>
        <point x="12.25" y="8.6"/>
      </points>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="15.75" y="9.35"/>
        <point x="15.45" y="8.65"/>
      </points>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.2" y="9.0"/>
        <point x="15.45" y="9.1"/>
        <point x="15.7" y="9.15"/>
        <point x="16.0" y="8.95"/>
      </controlPoints2>
      <color hex="0000ff"/>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.55" y="9.05"/>
        <point x="15.6" y="9.25"/>
        <point x="15.95" y="9.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.05" y="8.9"/>
        <point x="14.6" y="8.8"/>
        <point x="14.65" y="8.65"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.3" y="7.0"/>
        <point x="13.9" y="7.6"/>
        <point x="14.25" y="8.2"/>
        <point x="14.0" y="8.9"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.75" y="9.35"/>
        <point x="14.95" y="9.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W52</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.95" y="2.85"/>
        <point x="0.95" y="2.6"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.65" y="2.6"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W46</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.65" y="8.25"/>
        <point x="2.85" y="8.25"/>
        <point x="2.7" y="8.45"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W47</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.35" y="8.5"/>
        <point x="3.0" y="8.85"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W48</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.75" y="8.9"/>
        <point x="2.65" y="9.1"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W45</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.4" y="8.3"/>
        <point x="2.45" y="8.85"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W59</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.9" y="8.25"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>Vibrato Volume</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="14.75" y="1.55"/>
        <point x="14.45" y="1.55"/>
        <point x="14.15" y="1.55"/>
      </controlPoints>
      <resistance value="1.0" unit="M"/>
      <orientation>_180</orientation>
      <taper>LOG</taper>
      <showShaft>false</showShaft>
      <view>ShaftDown</view>
      <name>Vibrato Treble</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="13.55" y="1.55"/>
        <point x="13.25" y="1.55"/>
        <point x="12.95" y="1.55"/>
      </controlPoints>
      <resistance value="250.0" unit="K"/>
      <taper>LOG</taper>
      <name>Vibrato Mid</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="12.35" y="1.55"/>
        <point x="12.05" y="1.55"/>
        <point x="11.75" y="1.55"/>
      </controlPoints>
      <resistance value="100.0" unit="K"/>
      <taper>LOG</taper>
      <name>Vibrato Bass</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="11.15" y="1.55"/>
        <point x="10.85" y="1.55"/>
        <point x="10.55" y="1.55"/>
      </controlPoints>
      <taper>LOG</taper>
      <name>Reverb</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="9.95" y="1.55"/>
        <point x="9.65" y="1.55"/>
        <point x="9.35" y="1.55"/>
      </controlPoints>
      <taper>LIN</taper>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="6.95" y="8.55"/>
      <text>Screen</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.05" y="8.55"/>
      <text>Screen</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.15" y="7.55"/>
      <text>Choke</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.25" y="6.1"/>
      <text>C (B+3)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.5" y="9.75"/>
      <text>A Reverb Recovery</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="15.95" y="8.95"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="17.2" y="9.85"/>
      <text>Vibrato Preamp 1 &amp; 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.2" y="7.2"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="0.65" y="8.85"/>
      <text>Safety</text>
      <font name="Tahoma" size="18" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="1.8" y="11.1"/>
      <text>Black = Hot</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="1.55" y="9.9"/>
      <text>Green = Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="0.65" y="8.950000000000001"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="0.65" y="9.05"/>
      <text>Bolt</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.4" y="5.3"/>
      <text>6.3V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="2.9" y="9.18"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="2.8" y="9.53"/>
      <text>V7  GZ34</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.3" y="9.0"/>
      <text>B+ DC Out</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.8" y="9.73"/>
      <text>Rectifier</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="3.15" y="8.85"/>
      <text>8</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="2.5" y="8.7"/>
      <text>4</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="3.0" y="8.4"/>
      <text>6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="2.55" y="9.1"/>
      <text>2</text>
    </diylc.misc.Label>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="16.775" y="2.35"/>
      </points>
      <power>HALF</power>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.95" y="2.65"/>
      </controlPoints2>
      <gauge>_24</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="16.45" y="3.0"/>
        <point x="16.25" y="2.775"/>
      </points>
      <value value="68.0" unit="K"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="16.45" y="2.6"/>
      </points>
      <power>HALF</power>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.35" y="2.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name defined-in="diylc.AbstractComponent">Bright</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="15.25" y="2.0"/>
        <point x="15.25" y="2.4"/>
      </controlPoints>
      <spacing value="0.4" unit="in"/>
      <bodyColor hex="000000"/>
      <name>Bright</name>
      <alpha>127</alpha>
      <points>
        <point x="15.0" y="1.975"/>
      </points>
      <value value="120.0" unit="pF"/>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.8" y="1.3"/>
        <point x="14.95" y="1.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="12.0" y="5.0"/>
        <point x="12.0" y="4.8"/>
        <point x="11.7" y="4.9"/>
      </points>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="14.35" y="5.1"/>
        <point x="14.35" y="4.8"/>
        <point x="14.35" y="4.95"/>
      </points>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="16.999999999999996" y="5.05"/>
        <point x="17.15" y="4.8"/>
        <point x="17.075" y="4.925"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.3" y="2.8"/>
        <point x="18.0" y="4.8"/>
        <point x="17.4" y="4.8"/>
      </controlPoints2>
      <color hex="cc6600"/>
      <gauge>_20</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.35" y="1.4"/>
      <text>Vibrato</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.9" y="1.65"/>
      <text>2 Low</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.8" y="1.65"/>
      <text>1 High</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.5" y="2.1"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.95" y="2.6"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.2" y="2.1"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.75" y="2.65"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.2" y="2.6"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.25" y="1.8"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.55" y="2.45"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.25" y="1.75"/>
      <text>Bright</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.55" y="2.35"/>
      <text>Chassis</text>
    </diylc.misc.Label>
      <name>W11</name>
      <alpha>38</alpha>
      <controlPoints2>
        <point x="16.7" y="3.65"/>
        <point x="15.55" y="6.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>38</alpha>
      <controlPoints2>
        <point x="15.1" y="2.85"/>
        <point x="16.1" y="3.7"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.9" y="3.8"/>
        <point x="15.0" y="3.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.45" y="3.8"/>
        <point x="13.25" y="2.15"/>
      </controlPoints2>
      <color hex="996600"/>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.8" y="3.6"/>
        <point x="12.95" y="2.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.6" y="1.3"/>
        <point x="14.4" y="1.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.2" y="1.3"/>
        <point x="12.6" y="1.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.9" y="1.3"/>
        <point x="11.75" y="1.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.4" y="5.0"/>
        <point x="11.2" y="3.8"/>
        <point x="10.3" y="2.7"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.15" y="3.15"/>
        <point x="10.05" y="4.1"/>
        <point x="11.65" y="4.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <stripeColor hex="cc6600"/>
    <diylc.semiconductors.DiodePlastic>
      <name>1N4007</name>
      <alpha>127</alpha>
      <points>
        <point x="6.2" y="3.05"/>
        <point x="5.3" y="3.05"/>
        <point x="5.75" y="3.05"/>
      </points>
      <bodyColor hex="404040"/>
      <borderColor hex="2c2c2c"/>
      <value>1N4007</value>
      <markerColor hex="dddddd"/>
    </diylc.semiconductors.DiodePlastic>
      <name>50uF  100v</name>
      <alpha>127</alpha>
      <length value="1.55" unit="in"/>
      <width value="0.5" unit="in"/>
      <points>
        <point x="4.3" y="3.5"/>
        <point x="6.2" y="3.5"/>
        <point x="5.25" y="3.5"/>
      </points>
      <bodyColor hex="666666"/>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.75" y="4.15"/>
        <point x="5.05" y="4.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.5" y="4.9"/>
        <point x="1.55" y="4.35"/>
        <point x="4.2" y="3.05"/>
      </controlPoints2>
      <color hex="6600ff"/>
      <gauge>_18</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.9" y="4.0"/>
        <point x="6.85" y="3.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="6.2" y="3.275"/>
      </points>
      <name>ELL2</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="0.9" y="2.0"/>
        <point x="1.35" y="2.45"/>
      </controlPoints>
      <firstPoint x="0.9" y="2.0"/>
      <secondPoint x="1.35" y="2.45"/>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.55" y="10.5"/>
      </controlPoints2>
      <gauge>_24</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.45" y="5.4"/>
      <text>Tone Stack</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.25" y="3.35"/>
      <text>Note Polarity</text>
      <color hex="f0f0f0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="3.15" y="4.9"/>
      <text>Power Transformer 125P5D</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="1.15" y="1.95"/>
      <text>Pilot Light</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="0.55" y="4.4"/>
      <text>To All 6.3V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="0.55" y="4.5"/>
      <text>Fil</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.3" y="2.9"/>
      <text>Bias Board</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="1.45" y="1.75"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.0" y="3.7"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.75" y="2.9"/>
      <text>Bias Rectifier</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.15" y="11.2"/>
      <text>8 Ohm Speaker</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.35" y="10.9"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.25" y="10.95"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.45" y="10.8"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.45" y="10.3"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.65" y="10.45"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.2" y="11.2"/>
      <text>Aux Speaker</text>
    </diylc.misc.Label>
      <name>Pad3</name>
      <point x="3.4" y="10.7"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad3</name>
      <point x="3.4" y="10.4"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="8.92" y="8.799999999999999"/>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.4" y="11.15"/>
      <text>2A Slow Blow Fuse</text>
    </diylc.misc.Label>
      <name>W57</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.15" y="11.3"/>
        <point x="2.6" y="10.8"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W58</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.4" y="7.75"/>
        <point x="-0.1" y="6.45"/>
        <point x="0.75" y="6.0"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.15" y="9.1"/>
        <point x="0.3" y="7.7"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.9" y="8.799999999999999"/>
        <point x="9.2" y="10.3"/>
        <point x="9.5" y="10.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.5" y="11.1"/>
        <point x="10.95" y="11.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.05" y="10.1"/>
        <point x="9.299999999999999" y="10.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.15" y="10.5"/>
        <point x="10.7" y="10.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.75" y="7.4"/>
        <point x="8.9" y="10.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.0" y="10.8"/>
        <point x="13.75" y="10.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Grid Leak V3</name>
      <alpha>127</alpha>
      <points>
        <point x="14.35" y="10.4"/>
        <point x="13.8" y="10.525"/>
      </points>
      <power>HALF</power>
    <diylc.misc.GroundSymbol>
      <name>GND1</name>
      <size value="0.15" unit="in"/>
      <type>DEFAULT</type>
      <stroke>1</stroke>
    </diylc.misc.GroundSymbol>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.0" y="10.05"/>
        <point x="18.25" y="10.0"/>
      </controlPoints2>
      <gauge>_30</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.55" y="9.55"/>
        <point x="14.1" y="10.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.15" y="5.0"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="4.75" y="11.0"/>
      <text>Power</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="8.6" y="9.15"/>
      <text>4k:8 Ohm</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="13.25" y="11.05"/>
      <text>Reverb Pedal</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.35" y="11.05"/>
      <text>Reverb Pan Output</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="15.4" y="11.05"/>
      <text>Reverb Pan Input</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.8" y="10.4"/>
      <text>V3A Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.55" y="2.25"/>
      <text>Preamp</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.75" y="11.25"/>
      <text>By RobRobinette.com  V2.20</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.45" y="3.1"/>
      <text>Grid Stoppers</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.95" y="2.3"/>
      <text>Input</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="1.85" y="10.3"/>
      <text>White = Neutral</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.65" y="4.65"/>
      <text>Max Bias</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.35" y="10.3"/>
      <text>Chassis Ground</text>
    </diylc.misc.Label>
      <name>Max Bias</name>
      <alpha>127</alpha>
      <points>
        <point x="6.4" y="4.199999999999999"/>
      </points>
      <value value="10.0" unit="K"/>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
      </controlPoints2>
      <gauge>_20</gauge>
    <diylc.connectivity.Dot>
      <name>Dot2</name>
      <size value="1.0" unit="mm"/>
      <point x="14.15" y="4.8"/>
    </diylc.connectivity.Dot>
      <name>Dot4</name>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.2" y="1.75"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.95" y="1.75"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="1.0" y="11.15"/>
      <text>AC Power In</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.45" y="5.95"/>
      <text>D</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.2" y="6.05"/>
      <text>D</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.75" y="8.9"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.95" y="8.95"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.85" y="8.95"/>
      <text>Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.7" y="8.85"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.3" y="8.3"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.15" y="8.35"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.95" y="10.2"/>
      <text>AB763 Circuit Board Model Differences</text>
      <font name="Tahoma Bold" size="18" style="1"/>
      <color hex="ff66cc"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.95" y="10.35"/>
      <text>NFB Tail Resistor is 100 ohm in Tremolux, Band-Master</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.1" y="10.55"/>
      <text>All others use 47 ohm</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L3</name>
      <point x="16.1" y="10.45"/>
      <text>Concert, Super Reverb, Dual Showman &amp; Twin Reverb</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.95" y="10.65"/>
      <text>Super Reverb &amp; Concert use .022uF Mid Cap, all others use .047uF</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.95" y="10.75"/>
      <text>Tremolux, Band-Master &amp; Showman use 500pF PI coupling cap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.1" y="10.85"/>
      <text>All others use .001uF</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="15.95" y="10.95"/>
      <text>The Concert, Band-Master, Showman and Twin Reverb use a solid state rectifier</text>
      <font reference="../../diylc.misc.Label[159]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.4" y="4.25"/>
      <text>Bias - 55V</text>
    </diylc.misc.Label>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="12.0" y="4.9"/>
      </points>
    <diylc.connectivity.TwistedWire>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.4" y="6.05"/>
        <point x="4.45" y="6.1"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="ff0000"/>
      <stripeColor2 hex="ffff00"/>
      <stripe1>true</stripe1>
      <stripe2>true</stripe2>
    </diylc.connectivity.TwistedWire>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.45" y="6.65"/>
        <point x="2.75" y="7.7"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <stripe1>false</stripe1>
      <stripe2>false</stripe2>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.4" y="6.5"/>
        <point x="3.75" y="8.1"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="ffff00"/>
      <name>W6</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.775" y="6.4"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <color2 hex="000000"/>
      <stripeColor2 hex="ff00ff"/>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.15" y="6.0"/>
      </controlPoints2>
      <gauge>_20</gauge>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.55" y="7.7"/>
      <text>HV</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="4.1" y="7.7"/>
      <text>Primary</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.6" y="5.1"/>
      <text>355-0-355VAC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="15.95" y="11.05"/>
      <text>See https://robrobinette.com/AB763_Model_Differences.htm for more model differences</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.85" y="6.1"/>
      <text>HV Center Tap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.85" y="5.8"/>
      <text>6.3V Center Tap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.55" y="9.05"/>
      <text>A</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.25" y="8.9"/>
      <text>B</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.65" y="3.5"/>
      <text>+</text>
      <font name="Tahoma" size="54" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.65" y="6.1"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.7" y="6.1"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="8.9" y="6.45"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.4" y="7.85"/>
      <text>Choke 125C3A 50ma 4H </text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.35" y="9.149999999999999"/>
      <text>Reverb Transformer</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.35" y="9.250000000000002"/>
      <text>125A20B  25k:8 Ohm</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="8.15" y="11.3"/>
      <text>O on caps indicates outer foil</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="8.15" y="11.2"/>
      <text>All resistors 1/2 watt 10% unless specified</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="8.15" y="11.1"/>
      <text>Fender cap specification was 400V unless specified</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.45" y="4.4"/>
      <text>Clockwise = Hotter Bias</text>
    </diylc.misc.Label>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.2" y="3.6"/>
        <point x="1.15" y="4.55"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="00ff00"/>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.5" y="2.7"/>
        <point x="1.1" y="2.65"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.9" y="2.55"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.45" y="4.15"/>
        <point x="0.5" y="4.1"/>
      </controlPoints2>
      <gauge>_18</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.45" y="4.6"/>
      <text>Power Amp Ground</text>
      <orientation>DEFAULT</orientation>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="0.75" y="4.25"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="0.4" y="4.25"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.4" y="7.3"/>
      <text>5v Heater</text>
    </diylc.misc.Label>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.3" y="3.35"/>
        <point x="0.45" y="3.65"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="339900"/>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="4.0" y="3.8"/>
      <text>Bias</text>
    </diylc.misc.Label>
      <name>Eyelet61</name>
      <point x="11.68" y="5.1"/>
      <name>Tremolo Load</name>
      <alpha>127</alpha>
      <points>
        <point x="11.7" y="5.1"/>
        <point x="11.35" y="5.2"/>
      </points>
      <value value="56.0" unit="K"/>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L8</name>
      <point x="11.35" y="5.35"/>
      <text>Tremolo&lt;br&gt;Load Resistor</text>
      <font name="Tahoma Bold" size="14" style="1"/>
    </diylc.misc.Label>
      <name>NFB Tail</name>
      <alpha>127</alpha>
      <points>
        <point x="11.075" y="4.975"/>
      </points>
      <value value="47.0" unit="R"/>
      <power>HALF</power>
    <diylc.connectivity.HookupWire>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.1" y="3.1"/>
        <point x="12.55" y="5.65"/>
      </controlPoints2>
      <style>SOLID</style>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_22</gauge>
      <striped>false</striped>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.45" y="5.1"/>
      <text>V3B Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.5" y="4.7"/>
      <text>Preamp Ground Bus</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.55" y="4.0"/>
      <text>Dog House A B C</text>
    </diylc.misc.Label>
      <name>J1</name>
      <alpha>127</alpha>
      <points>
        <point x="11.675" y="4.95"/>
      </points>
      <display>NAME</display>
    <diylc.connectivity.Eyelet>
      <name>Eyelet13</name>
      <size value="0.2" unit="in"/>
      <holeSize value="0.1" unit="in"/>
      <color hex="ffcc00"/>
      <point x="7.7" y="4.75"/>
      <value>Hoffman Eyelet</value>
    </diylc.connectivity.Eyelet>
      <name>Eyelet14</name>
      <point x="7.7" y="5.7"/>
      <name>Eyelet15</name>
      <point x="8.35" y="7.0"/>
      <name>Eyelet16</name>
      <point x="8.35" y="4.75"/>
      <name>Eyelet17</name>
      <name>Screen</name>
      <alpha>127</alpha>
      <points>
        <point x="7.0" y="8.65"/>
        <point x="11.995" y="7.225"/>
      </points>
      <power>HALF</power>
      <name>Mid Minimum</name>
      <alpha>127</alpha>
      <points>
        <point x="12.2" y="4.8"/>
        <point x="13.045" y="-1.175"/>
      </points>
      <value value="6.8" unit="K"/>
      <power>HALF</power>
      <name>470 2W</name>
      <alpha>127</alpha>
      <length value="0.5" unit="in"/>
      <points>
        <point x="4.75" y="3.05"/>
      </points>
      <bodyColor hex="82cffd"/>
      <hideShortLeads>false</hideShortLeads>
      <power>HALF</power>
      <powerNew value="2.0" unit="W"/>
      <name>D1</name>
      <alpha>127</alpha>
      <points>
        <point x="2.25" y="8.85"/>
        <point x="2.25" y="8.5"/>
        <point x="2.25" y="8.675"/>
      </points>
      <labelColor hex="ffffff"/>
      <name>D2</name>
      <alpha>127</alpha>
      <points>
        <point x="2.85" y="8.1"/>
        <point x="3.25" y="8.25"/>
        <point x="3.05" y="8.175"/>
      </points>
      <name>R2</name>
      <alpha>127</alpha>
      <points>
        <point x="7.7" y="5.225"/>
      </points>
      <power>HALF</power>
      <colorCode>_5_BAND</colorCode>
      <name>R3</name>
      <alpha>127</alpha>
      <points>
        <point x="7.7" y="6.125"/>
      </points>
      <power>HALF</power>
      <name>C2</name>
      <alpha>127</alpha>
      <length value="1.26" unit="in"/>
      <width value="0.62" unit="in"/>
      <points>
        <point x="8.35" y="5.875"/>
      </points>
      <borderColor hex="333333"/>
      <value value="20.0" unit="uF"/>
      <name>W4</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.25" y="8.4"/>
        <point x="2.4" y="8.35"/>
        <point x="2.5" y="8.6"/>
      </controlPoints2>
      <color hex="cccccc"/>
      <gauge>_26</gauge>
    </diylc.connectivity.HookupWire>
      <name>W8</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.25" y="8.95"/>
        <point x="2.3" y="9.05"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W10</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.35" y="8.35"/>
        <point x="3.05" y="8.4"/>
        <point x="2.95" y="8.45"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <stripeColor hex="ffff00"/>
      <name>W15</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.8" y="8.05"/>
        <point x="2.65" y="8.3"/>
        <point x="2.725" y="8.475"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W16</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.35" y="5.4"/>
        <point x="5.15" y="5.6"/>
        <point x="4.85" y="5.55"/>
        <point x="4.9" y="4.45"/>
      </controlPoints2>
      <color hex="000000"/>
      <gauge>_20</gauge>
    <diylc.misc.Label>
      <name>L7</name>
      <point x="11.5" y="1.0"/>
      <text>Single Channel With Tremolo Deleted AB763 Blackface Vibroverb</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="6.35" y="7.7"/>
      <text>OT 125A1A</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L10</name>
      <point x="12.1" y="3.25"/>
      <text>Mid Minimum</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>38</alpha>
      <controlPoints2>
        <point x="9.2" y="5.9"/>
        <point x="8.05" y="5.7"/>
      </controlPoints2>
      <pointCount>FOUR</pointCount>
      <gauge>_22</gauge>
      <name>W18</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.1" y="4.6"/>
        <point x="6.3" y="4.9"/>
        <point x="5.55" y="5.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W19</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.9" y="4.55"/>
        <point x="9.35" y="4.65"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W20</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.9" y="6.95"/>
        <point x="8.0" y="7.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W22</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="8.55" y="6.7"/>
        <point x="9.65" y="7.1"/>
        <point x="13.3" y="6.1"/>
      </controlPoints2>
      <color hex="ffff00"/>
      <gauge>_22</gauge>
      <name>W23</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.45" y="5.6"/>
        <point x="6.95" y="5.3"/>
        <point x="5.9" y="5.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>LAB1</name>
      <point x="8.65" y="7.1"/>
      <text>D</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB2</name>
      <point x="5.5" y="5.95"/>
      <text>A</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB3</name>
      <point x="6.15" y="5.15"/>
      <text>B</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB4</name>
      <point x="5.85" y="4.85"/>
      <text>C</text>
    </diylc.misc.Label>
      <name>W21</name>
      <alpha>40</alpha>
      <controlPoints2>
        <point x="13.15" y="7.35"/>
        <point x="8.25" y="7.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W13</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.55" y="7.65"/>
        <point x="7.5" y="8.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>LAB5</name>
      <point x="7.35" y="5.65"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB8</name>
      <point x="5.85" y="5.7"/>
      <text>20</text>
      <color hex="ffffff"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB9</name>
      <point x="5.4" y="5.65"/>
      <text>40</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB10</name>
      <point x="6.0" y="5.3"/>
      <text>20</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB11</name>
      <point x="5.7" y="5.15"/>
      <text>20</text>
    </diylc.misc.Label>
      <name>Slope</name>
      <alpha>127</alpha>
      <points>
        <point x="16.174999999999997" y="7.15"/>
      </points>
      <power>HALF</power>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.75" y="3.45"/>
        <point x="13.8" y="3.85"/>
      </controlPoints2>
      <gauge>_22</gauge>
  </components>
  <groups>
    <set>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[101]"/>
      <diylc.semiconductors.DiodePlastic reference="../../../components/diylc.semiconductors.DiodePlastic[2]"/>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[100]"/>
    </set>
    <set>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[54]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[52]"/>
      <diylc.passive.AxialElectrolyticCapacitor reference="../../../components/diylc.passive.AxialElectrolyticCapacitor[5]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[123]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[55]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[51]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[115]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[35]"/>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[2]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[173]"/>
      <diylc.connectivity.Jumper reference="../../../components/diylc.connectivity.Jumper[7]"/>
      <diylc.boards.BlankBoard reference="../../../components/diylc.boards.BlankBoard[2]"/>
      <diylc.semiconductors.DiodePlastic reference="../../../components/diylc.semiconductors.DiodePlastic"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[53]"/>
    </set>
    <set>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[91]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[88]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[92]"/>
    </set>
    <set>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[3]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad"/>
    </set>
    <set>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[65]"/>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[64]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[105]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[50]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[27]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[9]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[107]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[4]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[104]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[140]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[26]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[103]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[108]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[28]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[6]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[5]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[49]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[141]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[106]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[110]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[109]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[8]"/>
    </set>
    <set>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[3]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[5]"/>
    </set>
    <set>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[18]"/>
      <diylc.shapes.Ellipse reference="../../../components/diylc.shapes.Ellipse"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[17]"/>
    </set>
    <set>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[4]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[2]"/>
    </set>
  </groups>
  <lockedLayers/>
  <lockedComponents/>
  <hiddenLayers/>
</project>
