<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>4</major>
    <minor>40</minor>
    <build>0</build>
  </fileVersion>
  <title>New Project</title>
  <author>User</author>
  <width value="50.0" unit="cm"/>
  <height value="35.0" unit="cm"/>
  <gridSpacing value="0.1" unit="in"/>
  <dotSpacing>1</dotSpacing>
  <components>
    <diylc.passive.PotentiometerPanel>
      <name>1M</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="9.565" y="2.8666666666666663"/>
        <point x="9.865" y="2.8666666666666663"/>
        <point x="10.165" y="2.8666666666666663"/>
      </controlPoints>
      <orientation>DEFAULT</orientation>
      <taper>LOG</taper>
      <bodyDiameter value="1.0" unit="in"/>
      <spacing value="0.3" unit="in"/>
      <lugDiameter value="0.15" unit="in"/>
      <bodyColor hex="c0c0c0"/>
      <borderColor hex="808080"/>
      <nutColor hex="cbd5db"/>
      <waferColor hex="cd8500"/>
      <type>ThroughHole</type>
      <showShaft>false</showShaft>
      <view>ShaftDown</view>
    </diylc.passive.PotentiometerPanel>
    <diylc.connectivity.Jumper>
      <name>J5</name>
      <alpha>127</alpha>
      <points>
        <point x="10.165" y="2.8833333333333337"/>
        <point x="10.07" y="4.4383333333333335"/>
        <point x="10.1175" y="3.6608333333333336"/>
      </points>
      <bodyColor hex="ffffff"/>
      <borderColor hex="000000"/>
      <labelColor hex="000000"/>
      <leadColor hex="000000"/>
      <display>NAME</display>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>false</moveLabel>
      <hideShortLeads>false</hideShortLeads>
      <style>SOLID</style>
    </diylc.connectivity.Jumper>
    <diylc.connectivity.HookupWire>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.142280178883617" y="3.81"/>
        <point x="9.637280178883616" y="3.805"/>
        <point x="10.196666666666667" y="3.825"/>
        <point x="11.297280178883616" y="3.785"/>
      </controlPoints2>
      <color hex="33ccff"/>
      <pointCount>FOUR</pointCount>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_22</gauge>
      <striped>false</striped>
      <stripeColor hex="ffff00"/>
    </diylc.connectivity.HookupWire>
    <diylc.tube.TubeSocket>
      <name>V1</name>
      <alpha>127</alpha>
      <angle>90</angle>
      <base>B9A</base>
      <type></type>
      <color hex="f7f7ef"/>
      <electrodeLabels>A,G,C,H,H,A,G,C,CT</electrodeLabels>
      <mount>CHASSIS</mount>
      <labelColor hex="acaca7"/>
      <controlPoints>
        <point x="8.29" y="3.92"/>
        <point x="8.144523150057614" y="4.120231706107799"/>
        <point x="8.05461351221695" y="3.9964817061077995"/>
        <point x="8.05461351221695" y="3.8435182938922003"/>
        <point x="8.144523150057614" y="3.7197682938922"/>
        <point x="8.29" y="3.6725"/>
        <point x="8.435476849942386" y="3.7197682938922"/>
        <point x="8.52538648778305" y="3.8435182938922003"/>
        <point x="8.52538648778305" y="3.9964817061077995"/>
        <point x="8.435476849942386" y="4.120231706107799"/>
      </controlPoints>
    </diylc.tube.TubeSocket>
    <diylc.passive.Resistor>
      <name>470</name>
      <alpha>127</alpha>
      <length value="12.0" unit="mm"/>
      <width value="4.0" unit="mm"/>
      <points>
        <point x="7.04" y="3.8475"/>
        <point x="8.05" y="3.8275"/>
        <point x="7.545" y="3.8375"/>
      </points>
      <bodyColor hex="d2d7db"/>
      <borderColor hex="b2b7bb"/>
      <leadColor hex="cccccc"/>
      <value value="470.0" unit="R"/>
      <power>HALF</power>
      <colorCode>_4_BAND</colorCode>
      <shape>Standard</shape>
    </diylc.passive.Resistor>
    <diylc.boards.BlankBoard>
      <name>Board1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="1.94" y="2.81"/>
        <point x="6.24" y="4.71"/>
      </controlPoints>
      <firstPoint x="1.94" y="2.81"/>
      <secondPoint x="6.24" y="4.71"/>
      <boardColor hex="f8ebb3"/>
      <borderColor hex="ada47d"/>
      <coordinateColor hex="b6b6b6"/>
      <xType>Numbers</xType>
      <coordinateOrigin>Top_Left</coordinateOrigin>
      <coordinateDisplay>One_Side</coordinateDisplay>
      <yType>Letters</yType>
      <mode>TwoPoints</mode>
      <type>SQUARE</type>
    </diylc.boards.BlankBoard>
    <diylc.connectivity.CopperTrace>
      <name>Trace1</name>
      <alpha>127</alpha>
      <points>
        <point x="2.04" y="3.01"/>
        <point x="2.94" y="3.01"/>
        <point x="2.49" y="3.01"/>
      </points>
      <thickness value="1.0" unit="mm"/>
      <layer>_1</layer>
    </diylc.connectivity.CopperTrace>
      <name>Trace2</name>
      <alpha>127</alpha>
      <points>
        <point x="2.04" y="3.61"/>
        <point x="2.04" y="4.61"/>
        <point x="2.04" y="4.11"/>
      </points>
      <layer>_1</layer>
      <name>Trace3</name>
      <alpha>127</alpha>
      <points>
        <point x="5.535" y="4.615"/>
        <point x="3.7875" y="4.6125"/>
      </points>
      <layer>_1</layer>
      <name>Trace4</name>
      <alpha>127</alpha>
      <points>
        <point x="2.94" y="3.51"/>
        <point x="2.94" y="3.26"/>
      </points>
      <layer>_1</layer>
      <name>Trace5</name>
      <alpha>127</alpha>
      <points>
        <point x="3.34" y="3.01"/>
        <point x="3.14" y="3.01"/>
      </points>
      <layer>_1</layer>
      <name>Trace6</name>
      <alpha>127</alpha>
      <points>
        <point x="4.04" y="3.01"/>
        <point x="4.54" y="3.01"/>
        <point x="4.29" y="3.01"/>
      </points>
      <layer>_1</layer>
      <name>Trace7</name>
      <alpha>127</alpha>
      <points>
        <point x="5.24" y="3.01"/>
        <point x="5.54" y="3.01"/>
        <point x="5.39" y="3.01"/>
      </points>
      <layer>_1</layer>
      <name>Trace8</name>
      <alpha>127</alpha>
      <points>
        <point x="5.54" y="3.51"/>
        <point x="5.54" y="3.26"/>
      </points>
      <layer>_1</layer>
      <name>Trace9</name>
      <alpha>127</alpha>
      <points>
        <point x="4.24" y="3.51"/>
        <point x="4.24" y="3.01"/>
        <point x="4.24" y="3.26"/>
      </points>
      <layer>_1</layer>
      <name>Trace10</name>
      <alpha>127</alpha>
      <points>
        <point x="2.94" y="4.01"/>
        <point x="2.94" y="4.61"/>
        <point x="2.94" y="4.31"/>
      </points>
      <layer>_1</layer>
      <name>Trace11</name>
      <alpha>127</alpha>
      <points>
        <point x="4.24" y="4.01"/>
        <point x="4.24" y="4.61"/>
        <point x="4.24" y="4.31"/>
      </points>
      <layer>_1</layer>
      <name>Trace12</name>
      <alpha>127</alpha>
      <points>
        <point x="5.54" y="4.01"/>
        <point x="5.5375" y="4.3125"/>
      </points>
      <layer>_1</layer>
      <name>J1</name>
      <alpha>127</alpha>
      <points>
        <point x="8.13" y="3.73"/>
        <point x="8.21" y="3.70125"/>
      </points>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="7.035" y="4.155"/>
        <point x="7.0375" y="4.00125"/>
      </points>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="7.18" y="3.7"/>
        <point x="7.11" y="3.77375"/>
      </points>
      <name>J4</name>
      <alpha>127</alpha>
      <points>
        <point x="7.955" y="3.6825"/>
        <point x="8.004806756108474" y="3.7630091469461"/>
      </points>
    <diylc.semiconductors.BridgeRectifier>
      <name>BR1</name>
      <alpha>100</alpha>
      <value></value>
      <controlPoints>
        <point x="2.04" y="3.21"/>
        <point x="2.04" y="3.41"/>
      </controlPoints>
      <pointLabels>
        <string>+</string>
        <string>~</string>
        <string>~</string>
        <string>-</string>
      </pointLabels>
      <display>BOTH</display>
      <bodyColor hex="808080"/>
      <borderColor hex="595959"/>
      <labelColor hex="ffffff"/>
      <rectifierType>InLine</rectifierType>
    </diylc.semiconductors.BridgeRectifier>
    <diylc.passive.RadialElectrolytic>
      <name>33uF 450V</name>
      <alpha>127</alpha>
      <length value="31.5" unit="mm"/>
      <width value="16.0" unit="mm"/>
      <points>
        <point x="2.94" y="3.76"/>
      </points>
      <bodyColor hex="333333"/>
      <labelColor hex="dddddd"/>
      <pinSpacing value="7.5" unit="mm"/>
      <type>Panasonic NHG</type>
      <value value="33.0" unit="uF"/>
      <voltage>_63V</voltage>
      <voltageNew value="450.0" unit="V"/>
      <markerColor hex="dddddd"/>
      <tickColor hex="000000"/>
      <polarized>true</polarized>
      <folded>false</folded>
      <height value="0.4" unit="in"/>
      <invert>false</invert>
    </diylc.passive.RadialElectrolytic>
      <alpha>127</alpha>
      <points>
        <point x="4.24" y="3.76"/>
      </points>
      <alpha>127</alpha>
      <points>
        <point x="5.54" y="3.76"/>
      </points>
      <name>10K</name>
      <alpha>127</alpha>
      <points>
        <point x="3.69" y="3.01"/>
      </points>
      <value value="10.0" unit="K"/>
      <power>HALF</power>
    <diylc.connectivity.SolderLug>
      <name>SL1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="1.04" y="4.61"/>
        <point x="1.37" y="4.61"/>
        <point x="1.445" y="4.61"/>
      </controlPoints>
      <orientation>_270</orientation>
    </diylc.connectivity.SolderLug>
      <name>10K</name>
      <alpha>127</alpha>
      <points>
        <point x="4.89" y="3.01"/>
      </points>
      <power>HALF</power>
      <name>100R</name>
      <alpha>127</alpha>
      <length value="9.0" unit="mm"/>
      <width value="3.2" unit="mm"/>
      <points>
        <point x="7.589761575028806" y="3.9373841469461"/>
      </points>
      <bodyColor hex="82cffd"/>
      <borderColor hex="5b90b1"/>
      <value value="100.0" unit="R"/>
      <power>HALF</power>
    <diylc.passive.AxialElectrolyticCapacitor>
      <name>50uF</name>
      <alpha>127</alpha>
      <length value="0.5" unit="in"/>
      <width value="0.125" unit="in"/>
      <points>
        <point x="7.95" y="3.6825"/>
        <point x="7.175" y="3.7"/>
        <point x="7.5625" y="3.69125"/>
      </points>
      <bodyColor hex="6b6dce"/>
      <borderColor hex="4a4c90"/>
      <markerColor hex="8cacea"/>
      <tickColor hex="ffffff"/>
    </diylc.passive.AxialElectrolyticCapacitor>
      <name>10K</name>
      <alpha>127</alpha>
      <points>
        <point x="8.028333333333332" y="4.569166666666666"/>
        <point x="8.041473422775141" y="4.282824186387233"/>
      </points>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.44" y="4.61"/>
        <point x="1.74" y="4.61"/>
        <point x="1.64" y="4.81"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <gauge>_22</gauge>
    <diylc.connectivity.TwistedWire>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.74" y="2.31"/>
        <point x="1.24" y="2.31"/>
        <point x="1.24" y="3.31"/>
        <point x="1.74" y="3.31"/>
      </controlPoints2>
      <color hex="ff3300"/>
      <gauge>_22</gauge>
      <color2 hex="000000"/>
      <stripeColor2 hex="ff00ff"/>
      <stripe1>false</stripe1>
      <stripe2>false</stripe2>
    </diylc.connectivity.TwistedWire>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.94" y="3.31"/>
        <point x="1.84" y="3.21"/>
      </controlPoints2>
      <color hex="ff0000"/>
      <gauge>_22</gauge>
      <name>W4</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.84" y="3.31"/>
        <point x="1.94" y="3.51"/>
      </controlPoints2>
      <color hex="000000"/>
      <gauge>_22</gauge>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.04" y="2.01"/>
        <point x="4.24" y="2.01"/>
        <point x="4.24" y="2.71"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W6</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.44" y="2.01"/>
        <point x="5.44" y="2.01"/>
        <point x="5.54" y="2.71"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W7</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.035" y="4.615"/>
        <point x="6.535" y="4.715"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.143333333333333" y="4.814166666666666"/>
        <point x="9.858333333333333" y="4.174166666666666"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>LAB1</name>
      <point x="5.14" y="1.91"/>
      <text>B+1 &amp; B+2</text>
      <font name="Dialog.plain" size="20" style="0"/>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB2</name>
      <point x="6.54" y="1.91"/>
      <text>B+3</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB3</name>
      <point x="6.245" y="4.83"/>
      <text>Power Amp Cathode &amp; Filament Centre Tap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB4</name>
      <point x="0.44" y="2.31"/>
      <text>250 VAC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB6</name>
      <point x="7.775" y="4.491666666666666"/>
      <text>Grid Stopper</text>
      <font name="Dialog.plain" size="16" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB7</name>
      <point x="9.308333333333332" y="5.216666666666666"/>
      <text>To Output Transformer</text>
    </diylc.misc.Label>
      <name>100k</name>
      <alpha>127</alpha>
      <points>
        <point x="8.487" y="2.952"/>
        <point x="8.461238424971192" y="3.3358841469461002"/>
      </points>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
    <diylc.misc.GroundSymbol>
      <name>GND1</name>
      <size value="0.3" unit="in"/>
      <type>DEFAULT</type>
      <stroke>2</stroke>
    </diylc.misc.GroundSymbol>
      <name>J6</name>
      <alpha>127</alpha>
      <points>
        <point x="9.27538648778305" y="4.259166666666666"/>
        <point x="10.076666666666668" y="4.26"/>
        <point x="9.676026577224858" y="4.2595833333333335"/>
      </points>
    <diylc.passive.AxialFilmCapacitor>
      <name>0.022</name>
      <alpha>127</alpha>
      <length value="16.5" unit="mm"/>
      <width value="6.0" unit="mm"/>
      <points>
        <point x="8.438333333333333" y="3.708333333333334"/>
        <point x="9.001666666666667" y="3.2875"/>
      </points>
      <bodyColor hex="ffe303"/>
      <borderColor hex="b29e02"/>
      <value value="0.022" unit="uF"/>
      <voltageNew value="400.0" unit="V"/>
      <showOuterFoil>false</showOuterFoil>
      <outerFoilColor hex="ffffff"/>
      <type>Mallory 150</type>
    </diylc.passive.AxialFilmCapacitor>
      <name>1K</name>
      <alpha>127</alpha>
      <points>
        <point x="8.90038648778305" y="4.127824186387233"/>
      </points>
      <value value="1.0" unit="K"/>
      <power>HALF</power>
      <name>W8</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.424523150057613" y="4.4852317061077995"/>
        <point x="8.644523150057614" y="5.1252317061078"/>
        <point x="9.144523150057614" y="5.1252317061078"/>
      </controlPoints2>
      <color hex="ff9933"/>
      <gauge>_22</gauge>
      <name>100R</name>
      <alpha>127</alpha>
      <points>
        <point x="8.4425" y="4.1325"/>
        <point x="7.73875" y="4.14375"/>
      </points>
      <power>HALF</power>
      <name>10K</name>
      <alpha>127</alpha>
      <points>
        <point x="8.833833333333333" y="3.8267591469461"/>
      </points>
      <power>HALF</power>
      <name>W10</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.5920000000000005" y="1.942"/>
        <point x="8.592" y="1.942"/>
        <point x="8.492" y="2.642"/>
        <point x="8.492" y="2.9419999999999997"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>LAB8</name>
      <point x="7.577999999999999" y="2.045"/>
      <text>B+2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB5</name>
      <point x="11.08" y="3.8875"/>
      <text>From V1b</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB9</name>
      <point x="8.93" y="3.725"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>LAB10</name>
      <point x="1.145" y="4.865"/>
      <text>Power Amp Ground</text>
    </diylc.misc.Label>
  </components>
  <groups/>
  <lockedLayers/>
  <lockedComponents/>
  <hiddenLayers/>
  <font name="Dialog.plain" size="14" style="0"/>
</project>
