<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>3</major>
    <minor>56</minor>
    <build>0</build>
  </fileVersion>
  <title>New Project</title>
  <author>BG230269</author>
  <width value="16.0" unit="cm"/>
  <height value="15.0" unit="cm"/>
  <gridSpacing value="0.1" unit="in"/>
  <components>
    <diylc.connectivity.SolderPad>
      <name>Pad1</name>
      <size value="0.09" unit="in"/>
      <color hex="000000"/>
      <point x="1.5" y="1.2"/>
      <type>ROUND</type>
      <holeSize value="0.8" unit="mm"/>
      <layer>_1</layer>
    </diylc.connectivity.SolderPad>
    <diylc.passive.TransformerCoil>
      <name>L2</name>
      <controlPoints>
        <point x="0.3" y="4.8"/>
        <point x="0.3" y="5.0"/>
      </controlPoints>
      <orientation>DEFAULT</orientation>
      <color hex="0000ff"/>
      <tapSpacing value="0.2" unit="in"/>
      <body>
        <java.awt.geom.GeneralPath serialization="custom">
          <unserializable-parents/>
          <java.awt.geom.Path2D_-Float>
            <default/>
            <byte>48</byte>
            <int>4</int>
            <int>8</int>
            <byte>1</byte>
            <byte>64</byte>
            <float>60.0</float>
            <float>960.0</float>
            <byte>65</byte>
            <float>85.0</float>
            <byte>64</byte>
            <float>60.0</float>
            <float>1000.0</float>
            <byte>65</byte>
            <float>85.0</float>
            <byte>97</byte>
          </java.awt.geom.Path2D_-Float>
        </java.awt.geom.GeneralPath>
            <default/>
            <byte>48</byte>
            <int>5</int>
            <int>26</int>
            <byte>1</byte>
            <byte>64</byte>
            <float>85.0</float>
            <byte>67</byte>
            <float>95.0</float>
            <float>95.0</float>
            <float>970.0</float>
            <float>85.0</float>
            <byte>67</byte>
            <float>95.0</float>
            <float>95.0</float>
            <float>980.0</float>
            <float>85.0</float>
            <byte>67</byte>
            <float>95.0</float>
            <float>95.0</float>
            <float>990.0</float>
            <float>85.0</float>
            <byte>67</byte>
            <float>95.0</float>
            <float>95.0</float>
            <float>85.0</float>
            <byte>97</byte>
      </body>
    </diylc.passive.TransformerCoil>
    <diylc.passive.TransformerCore>
      <name>T1</name>
      <controlPoints>
        <point x="0.5" y="4.4"/>
        <point x="0.5" y="5.4"/>
      </controlPoints>
    </diylc.passive.TransformerCore>
    <diylc.connectivity.Line>
      <name>LN41</name>
      <alpha>127</alpha>
      <points>
        <point x="0.3" y="5.2"/>
      </points>
      <bodyColor hex="ffffff"/>
      <borderColor hex="000000"/>
      <labelColor hex="000000"/>
      <leadColor hex="cccccc"/>
      <display>NAME</display>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <style>SOLID</style>
      <thickness value="1.0" unit="px"/>
      <arrowSize value="5.0" unit="px"/>
      <arrowTx serialization="custom">
        <java.awt.geom.AffineTransform>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
        </java.awt.geom.AffineTransform>
      </arrowTx>
      <arrowStart>false</arrowStart>
      <arrowEnd>false</arrowEnd>
    </diylc.connectivity.Line>
      <name>LN42</name>
      <alpha>127</alpha>
      <points>
        <point x="0.3" y="4.6"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN43</name>
      <alpha>127</alpha>
      <points>
        <point x="0.7" y="4.5"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN44</name>
      <alpha>127</alpha>
      <points>
        <point x="0.7" y="3.9"/>
        <point x="0.7" y="4.4"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.semiconductors.DiodeSymbol>
      <name>D1</name>
      <alpha>127</alpha>
      <length value="0.1" unit="in"/>
      <width value="0.1" unit="in"/>
      <points>
        <point x="1.0" y="4.2"/>
        <point x="1.3" y="3.9"/>
      </points>
      <bodyColor hex="0000ff"/>
      <leadColor hex="000000"/>
      <labelPosition>ABOVE</labelPosition>
    </diylc.semiconductors.DiodeSymbol>
      <name>D2</name>
      <alpha>127</alpha>
      <points>
        <point x="1.3" y="4.5"/>
        <point x="1.6" y="4.2"/>
      </points>
      <name>D3</name>
      <alpha>127</alpha>
      <points>
      </points>
      <name>D4</name>
      <alpha>127</alpha>
      <points>
      </points>
    <diylc.misc.GroundSymbol>
      <name>GND5</name>
      <point x="0.9" y="4.3"/>
      <size value="0.15" unit="in"/>
      <type>DEFAULT</type>
    </diylc.misc.GroundSymbol>
      <name>LN49</name>
      <alpha>127</alpha>
      <points>
        <point x="0.9" y="4.2"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN50</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN51</name>
      <alpha>127</alpha>
      <points>
        <point x="1.3" y="3.8"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN52</name>
      <alpha>127</alpha>
      <points>
        <point x="0.7" y="3.8"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN53</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN55</name>
      <alpha>127</alpha>
      <points>
        <point x="0.7" y="4.6"/>
        <point x="1.3" y="4.6"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN56</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN57</name>
      <alpha>127</alpha>
      <points>
        <point x="2.1" y="4.2"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.passive.CapacitorSymbol>
      <name>C1</name>
      <alpha>127</alpha>
      <length value="0.05" unit="in"/>
      <width value="0.15" unit="in"/>
      <points>
        <point x="2.1" y="4.9"/>
      </points>
      <borderColor hex="0000ff"/>
      <display>BOTH</display>
      <value value="20.0" unit="uF"/>
      <voltage>_63V</voltage>
      <voltageNew value="400.0" unit="V"/>
      <polarized>true</polarized>
    </diylc.passive.CapacitorSymbol>
      <name>C2</name>
      <alpha>127</alpha>
      <points>
        <point x="2.6" y="4.2"/>
        <point x="2.6" y="4.9"/>
      </points>
      <value value="10.0" unit="uF"/>
    <diylc.passive.ResistorSymbol>
      <name>R2</name>
      <alpha>127</alpha>
      <length value="0.3" unit="in"/>
      <width value="0.08" unit="in"/>
      <points>
      </points>
      <value value="1.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="0.5" unit="W"/>
    </diylc.passive.ResistorSymbol>
      <name>R5</name>
      <alpha>127</alpha>
      <points>
        <point x="5.2" y="3.7"/>
        <point x="4.7" y="3.7"/>
      </points>
      <value value="3.0" unit="K"/>
      <power>HALF</power>
    <diylc.passive.PotentiometerSymbol>
      <name>VR1</name>
      <value>50k</value>
      <controlPoints>
        <point x="3.1" y="4.6"/>
        <point x="2.9" y="4.4"/>
        <point x="3.3" y="4.4"/>
      </controlPoints>
      <flip>NONE</flip>
      <display>NONE</display>
      <orientation>_270</orientation>
    </diylc.passive.PotentiometerSymbol>
      <name>LN58</name>
      <alpha>127</alpha>
      <points>
        <point x="2.9" y="4.6"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN59</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>C3</name>
      <alpha>127</alpha>
      <points>
        <point x="3.9" y="4.4"/>
        <point x="3.9" y="4.9"/>
      </points>
      <value value="1.0" unit="uF"/>
      <name>C4</name>
      <alpha>127</alpha>
      <points>
        <point x="5.2" y="4.3"/>
      </points>
      <name>R6</name>
      <alpha>127</alpha>
      <points>
        <point x="5.7" y="3.7"/>
      </points>
      <value value="2.0" unit="K"/>
      <power>HALF</power>
      <name>C6</name>
      <alpha>127</alpha>
      <points>
        <point x="5.7" y="4.3"/>
      </points>
    <diylc.shapes.Polygon>
      <name>POLY1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="3.8" y="4.2"/>
        <point x="3.9" y="4.1"/>
        <point x="4.0" y="4.2"/>
      </controlPoints>
      <firstPoint x="3.8" y="4.1"/>
      <secondPoint x="3.9" y="4.2"/>
      <color hex="ffffff"/>
      <borderThickness value="0.2" unit="mm"/>
      <pointCount>_3</pointCount>
    </diylc.shapes.Polygon>
      <name>POLY1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="5.1" y="3.5"/>
        <point x="5.2" y="3.4"/>
        <point x="5.3" y="3.5"/>
      </controlPoints>
      <firstPoint x="5.1" y="3.4"/>
      <secondPoint x="5.2" y="3.5"/>
      <name>POLY1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="5.6" y="3.5"/>
        <point x="5.7" y="3.4"/>
        <point x="5.8" y="3.5"/>
      </controlPoints>
      <firstPoint x="5.6" y="3.4"/>
      <secondPoint x="5.7" y="3.5"/>
      <name>C4</name>
      <alpha>127</alpha>
      <points>
        <point x="4.7" y="4.4"/>
        <point x="4.7" y="4.9"/>
      </points>
      <name>R4</name>
      <alpha>127</alpha>
      <points>
      </points>
      <power>HALF</power>
      <name>LN61</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN62</name>
      <alpha>127</alpha>
      <points>
        <point x="5.2" y="3.5"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN63</name>
      <alpha>127</alpha>
      <points>
        <point x="5.7" y="3.5"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN64</name>
      <alpha>127</alpha>
      <points>
        <point x="3.9" y="4.2"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>POLY1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="4.6" y="4.2"/>
        <point x="4.7" y="4.1"/>
        <point x="4.8" y="4.2"/>
      </controlPoints>
      <firstPoint x="4.6" y="4.1"/>
      <secondPoint x="4.7" y="4.2"/>
      <name>LN64</name>
      <alpha>127</alpha>
      <points>
        <point x="4.7" y="4.2"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN65</name>
      <alpha>127</alpha>
      <points>
        <point x="3.2" y="3.7"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN66</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>GND2</name>
      <name>GND2</name>
      <name>GND2</name>
      <name>GND2</name>
      <name>GND2</name>
      <name>GND2</name>
      <name>R3</name>
      <alpha>127</alpha>
      <points>
        <point x="3.4" y="4.4"/>
      </points>
      <value value="7.0" unit="K"/>
      <power>HALF</power>
      <name>LN60</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN67</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="1.8" y="4.9"/>
        <point x="1.8" y="4.2"/>
      </points>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <name>GND2</name>
      <name>L3</name>
      <controlPoints>
      </controlPoints>
      <orientation>_180</orientation>
      <body>
            <default/>
            <byte>48</byte>
            <int>4</int>
            <int>8</int>
            <byte>1</byte>
            <byte>64</byte>
            <float>140.0</float>
            <float>920.0</float>
            <byte>65</byte>
            <float>115.0</float>
            <byte>64</byte>
            <float>880.0</float>
            <byte>65</byte>
            <byte>97</byte>
            <default/>
            <byte>48</byte>
            <int>5</int>
            <int>26</int>
            <byte>1</byte>
            <byte>64</byte>
            <byte>67</byte>
            <float>105.0</float>
            <float>910.0</float>
            <byte>67</byte>
            <float>900.0</float>
            <byte>67</byte>
            <float>890.0</float>
            <byte>67</byte>
            <byte>97</byte>
      </body>
      <name>L3</name>
      <controlPoints>
        <point x="0.7" y="5.4"/>
        <point x="0.7" y="5.2"/>
      </controlPoints>
      <body>
            <default/>
            <byte>48</byte>
            <int>4</int>
            <int>8</int>
            <byte>1</byte>
            <byte>64</byte>
            <float>1080.0</float>
            <byte>65</byte>
            <byte>64</byte>
            <float>1040.0</float>
            <byte>65</byte>
            <byte>97</byte>
            <default/>
            <byte>48</byte>
            <int>5</int>
            <int>26</int>
            <byte>1</byte>
            <byte>64</byte>
            <byte>67</byte>
            <float>1070.0</float>
            <byte>67</byte>
            <float>1060.0</float>
            <byte>67</byte>
            <float>1050.0</float>
            <byte>67</byte>
            <byte>97</byte>
      </body>
    <diylc.shapes.Rectangle>
      <name>RECT1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="1.0" y="5.1"/>
        <point x="1.8" y="5.5"/>
      </controlPoints>
      <firstPoint x="1.0" y="5.1"/>
      <secondPoint x="1.8" y="5.5"/>
      <edgeRadius value="0.0" unit="mm"/>
    </diylc.shapes.Rectangle>
      <name>LN54</name>
      <alpha>127</alpha>
      <points>
        <point x="1.0" y="5.2"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN74</name>
      <alpha>127</alpha>
      <points>
        <point x="1.0" y="5.4"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.tube.PentodeSymbol>
      <name>V1 (6au6)</name>
      <value></value>
      <showHeaters>false</showHeaters>
      <flip>NONE</flip>
      <controlPoints>
        <point x="2.7" y="1.5"/>
        <point x="3.0" y="1.1"/>
        <point x="2.9" y="1.7"/>
        <point x="3.3" y="1.4"/>
        <point x="2.7" y="1.3"/>
        <point x="3.0" y="1.7"/>
        <point x="3.1" y="1.7"/>
      </controlPoints>
      <exposeSuppressorGrid>true</exposeSuppressorGrid>
    </diylc.tube.PentodeSymbol>
      <name>R12</name>
      <alpha>127</alpha>
      <points>
        <point x="2.2" y="1.5"/>
      </points>
      <power>HALF</power>
      <name>L2</name>
      <controlPoints>
        <point x="3.0" y="0.7"/>
        <point x="3.0" y="0.9"/>
      </controlPoints>
      <body>
            <default/>
            <byte>48</byte>
            <int>4</int>
            <int>8</int>
            <byte>1</byte>
            <byte>64</byte>
            <float>600.0</float>
            <byte>65</byte>
            <float>625.0</float>
            <byte>64</byte>
            <float>180.0</float>
            <byte>65</byte>
            <byte>97</byte>
            <default/>
            <byte>48</byte>
            <int>5</int>
            <int>26</int>
            <byte>1</byte>
            <byte>64</byte>
            <byte>67</byte>
            <float>635.0</float>
            <float>150.0</float>
            <byte>67</byte>
            <float>160.0</float>
            <byte>67</byte>
            <float>170.0</float>
            <byte>67</byte>
            <byte>97</byte>
      </body>
      <name>L3</name>
      <controlPoints>
        <point x="3.4" y="0.9"/>
        <point x="3.4" y="0.7"/>
      </controlPoints>
      <body>
            <default/>
            <byte>48</byte>
            <int>4</int>
            <int>8</int>
            <byte>1</byte>
            <byte>64</byte>
            <float>680.0</float>
            <byte>65</byte>
            <float>655.0</float>
            <byte>64</byte>
            <byte>65</byte>
            <byte>97</byte>
            <default/>
            <byte>48</byte>
            <int>5</int>
            <int>26</int>
            <byte>1</byte>
            <byte>64</byte>
            <byte>67</byte>
            <float>645.0</float>
            <byte>67</byte>
            <byte>67</byte>
            <byte>67</byte>
            <byte>97</byte>
      </body>
      <name>T1</name>
      <controlPoints>
        <point x="3.2" y="0.7"/>
        <point x="3.2" y="0.9"/>
      </controlPoints>
      <name>POLY1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="2.9" y="0.4"/>
        <point x="3.0" y="0.5"/>
        <point x="3.1" y="0.4"/>
      </controlPoints>
      <firstPoint x="2.9" y="0.4"/>
      <secondPoint x="3.0" y="0.5"/>
      <name>C7</name>
      <alpha>127</alpha>
      <points>
        <point x="3.2" y="1.8"/>
        <point x="3.2" y="2.8"/>
      </points>
      <polarized>false</polarized>
      <name>VR2</name>
      <value></value>
      <controlPoints>
        <point x="2.0" y="1.5"/>
        <point x="1.8" y="1.3"/>
        <point x="1.8" y="1.7"/>
      </controlPoints>
      <flip>X</flip>
      <name>LN34</name>
      <alpha>127</alpha>
      <points>
        <point x="1.8" y="2.9"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN35</name>
      <alpha>127</alpha>
      <points>
        <point x="2.9" y="2.8"/>
        <point x="2.9" y="2.9"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN36</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN37</name>
      <alpha>127</alpha>
      <points>
        <point x="2.9" y="1.8"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN39</name>
      <alpha>127</alpha>
      <points>
        <point x="2.7" y="1.8"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN40</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>GND2</name>
      <name>GND3</name>
      <name>GND4</name>
      <point x="3.5" y="1.0"/>
      <name>LN41</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN42</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN43</name>
      <alpha>127</alpha>
      <points>
        <point x="3.7" y="0.9"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN44</name>
      <alpha>127</alpha>
      <points>
        <point x="3.7" y="0.7"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN45</name>
      <alpha>127</alpha>
      <points>
        <point x="3.5" y="0.9"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>Speaker</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="3.7" y="0.6"/>
        <point x="4.1" y="1.0"/>
      </controlPoints>
      <firstPoint x="3.7" y="0.6"/>
      <secondPoint x="4.1" y="1.0"/>
    <diylc.connectivity.Dot>
      <name>Dot2</name>
      <size value="1.0" unit="mm"/>
    </diylc.connectivity.Dot>
      <name>POLY1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="4.5" y="0.4"/>
        <point x="4.6" y="0.5"/>
        <point x="4.7" y="0.4"/>
      </controlPoints>
      <firstPoint x="4.5" y="0.4"/>
      <secondPoint x="4.6" y="0.5"/>
      <name>LN46</name>
      <alpha>127</alpha>
      <points>
        <point x="4.6" y="1.4"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>R7</name>
      <alpha>127</alpha>
      <points>
        <point x="3.9" y="1.4"/>
        <point x="3.4" y="1.4"/>
      </points>
      <power>HALF</power>
      <name>LN47</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN48</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN38</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>R8</name>
      <alpha>127</alpha>
      <points>
        <point x="2.9" y="2.3"/>
      </points>
      <power>HALF</power>
      <name>R9 1R</name>
      <alpha>127</alpha>
      <points>
      </points>
      <value value="1.0" unit="R"/>
      <power>HALF</power>
      <name>R10</name>
      <alpha>127</alpha>
      <points>
        <point x="2.2" y="2.9"/>
      </points>
      <power>HALF</power>
      <name>LN68</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>GND2</name>
      <name>LN69</name>
      <alpha>127</alpha>
      <points>
        <point x="1.8" y="1.2"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN70</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN71</name>
      <alpha>127</alpha>
      <points>
        <point x="4.1" y="0.6"/>
        <point x="4.3" y="0.4"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN72</name>
      <alpha>127</alpha>
      <points>
        <point x="4.3" y="1.2"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN73</name>
      <alpha>127</alpha>
      <points>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="3.7" y="4.0"/>
      <text>HT1 50-150V @10mA</text>
      <font name="Square721 BT Roman" size="14" style="0"/>
      <center>false</center>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="4.6" y="4.0"/>
      <text>HT2 50-150V @4mA</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="5.1" y="3.3"/>
      <text>HT3 235V @2mA</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="5.8" y="3.3"/>
      <text>HT4 230V @2mA</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="3.1" y="4.3"/>
      <text>VR1 50k</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L12</name>
      <point x="1.4" y="5.3"/>
      <text>heating circuit</text>
      <font reference="../../diylc.misc.Label/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L13</name>
      <point x="0.8" y="4.5"/>
      <text>190 VAC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L12</name>
      <point x="0.8" y="5.3"/>
      <text>6.3 VAC </text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="3.0" y="0.3"/>
      <text>HT1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="4.6" y="0.3"/>
      <text>HT2</text>
      <font reference="../../diylc.misc.Label[9]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="3.9" y="0.8"/>
      <text>Speaker</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L8</name>
      <point x="2.8" y="0.8"/>
      <text>OT [20kΩ / 8Ω]</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L11</name>
      <point x="1.5" y="1.1"/>
      <text>Preamp / FX return</text>
    </diylc.misc.Label>
  </components>
  <groups/>
  <lockedLayers/>
  <hiddenLayers/>
</project>
