<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>4</major>
    <minor>4</minor>
    <build>0</build>
  </fileVersion>
  <title>Magnatone M-10A ReVibe</title>
  <author>Stephen Scott</author>
  <description>This is a Reverb/Vibrato effects head that uses&lt;br&gt;the schematic of the M-10A, except for the PI&lt;br&gt;and Power Amp section.  So its similar to the&lt;br&gt;Weber 5H15 kit/Hoffman ReVibe&lt;br&gt;</description>
  <width value="15.125" unit="in"/>
  <height value="3.125" unit="in"/>
  <gridSpacing value="0.2969" unit="in"/>
  <dotSpacing>1</dotSpacing>
  <components>
    <diylc.boards.EyeletBoard>
      <name>Board1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="0.02" y="0.03"/>
        <point x="15.165" y="3.295"/>
      </controlPoints>
      <firstPoint x="0.02" y="0.03"/>
      <secondPoint x="15.165" y="3.295"/>
      <boardColor hex="e3eab4"/>
      <borderColor hex="9ea37d"/>
      <coordinateColor hex="b6b6b6"/>
      <xType>Numbers</xType>
      <coordinateOrigin>Top_Left</coordinateOrigin>
      <coordinateDisplay>One_Side</coordinateDisplay>
      <yType>Letters</yType>
      <mode>TwoPoints</mode>
      <spacing value="0.5" unit="in"/>
      <eyeletColor hex="c3e4ed"/>
    </diylc.boards.EyeletBoard>
    <diylc.connectivity.SolderPad>
      <name>Pad1</name>
      <size value="0.5" unit="in"/>
      <color hex="000000"/>
      <point x="-1.43" y="-0.705"/>
      <type>ROUND</type>
      <holeSize value="0.8" unit="mm"/>
      <layer>_1</layer>
    </diylc.connectivity.SolderPad>
      <name>Pad2</name>
      <point x="-1.625" y="3.08"/>
      <type>ROUND</type>
      <layer>_1</layer>
    <diylc.tube.TubeSocket>
      <name>V1</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AX7</type>
      <angle>0</angle>
      <color hex="f7f7ef"/>
      <electrodeLabels>1,2,3,4,5,6,7,8,9</electrodeLabels>
      <mount>CHASSIS</mount>
      <labelColor hex="acaca7"/>
      <controlPoints>
        <point x="0.885" y="-0.93"/>
        <point x="1.085" y="-0.785"/>
        <point x="0.96" y="-0.695"/>
        <point x="0.81" y="-0.695"/>
        <point x="0.685" y="-0.785"/>
        <point x="0.64" y="-0.93"/>
        <point x="0.685" y="-1.075"/>
        <point x="0.81" y="-1.165"/>
        <point x="0.96" y="-1.165"/>
        <point x="1.085" y="-1.075"/>
      </controlPoints>
    </diylc.tube.TubeSocket>
      <name>V2</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AX7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="2.65" y="-0.875"/>
        <point x="2.85" y="-0.73"/>
        <point x="2.725" y="-0.64"/>
        <point x="2.575" y="-0.64"/>
        <point x="2.45" y="-0.73"/>
        <point x="2.405" y="-0.875"/>
        <point x="2.45" y="-1.02"/>
        <point x="2.575" y="-1.11"/>
        <point x="2.725" y="-1.11"/>
        <point x="2.85" y="-1.02"/>
      </controlPoints>
      <name>V3</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AU7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="4.13" y="-0.87"/>
        <point x="4.33" y="-0.725"/>
        <point x="4.205" y="-0.635"/>
        <point x="4.055" y="-0.635"/>
        <point x="3.93" y="-0.725"/>
        <point x="3.885" y="-0.87"/>
        <point x="3.93" y="-1.015"/>
        <point x="4.055" y="-1.105"/>
        <point x="4.205" y="-1.105"/>
        <point x="4.33" y="-1.015"/>
      </controlPoints>
      <name>V4</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AU7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="5.615" y="-0.88"/>
        <point x="5.815" y="-0.735"/>
        <point x="5.69" y="-0.645"/>
        <point x="5.54" y="-0.645"/>
        <point x="5.415" y="-0.735"/>
        <point x="5.37" y="-0.88"/>
        <point x="5.415" y="-1.025"/>
        <point x="5.54" y="-1.115"/>
        <point x="5.69" y="-1.115"/>
        <point x="5.815" y="-1.025"/>
      </controlPoints>
      <name>V5</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AX7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="7.09" y="-0.87"/>
        <point x="7.29" y="-0.725"/>
        <point x="7.165" y="-0.635"/>
        <point x="7.015" y="-0.635"/>
        <point x="6.89" y="-0.725"/>
        <point x="6.845" y="-0.87"/>
        <point x="6.89" y="-1.015"/>
        <point x="7.015" y="-1.105"/>
        <point x="7.165" y="-1.105"/>
        <point x="7.29" y="-1.015"/>
      </controlPoints>
      <name>V6</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12DW7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="8.85" y="-0.88"/>
        <point x="9.05" y="-0.735"/>
        <point x="8.925" y="-0.645"/>
        <point x="8.775" y="-0.645"/>
        <point x="8.65" y="-0.735"/>
        <point x="8.605" y="-0.88"/>
        <point x="8.65" y="-1.025"/>
        <point x="8.775" y="-1.115"/>
        <point x="8.925" y="-1.115"/>
        <point x="9.05" y="-1.025"/>
      </controlPoints>
    <diylc.passive.Resistor>
      <name>R1</name>
      <alpha>127</alpha>
      <length value="9.0" unit="mm"/>
      <width value="3.2" unit="mm"/>
      <points>
        <point x="-2.25" y="1.515"/>
        <point x="-1.815" y="1.265"/>
        <point x="-3.295" y="-1.47"/>
      </points>
      <bodyColor hex="82cffd"/>
      <borderColor hex="5b90b1"/>
      <labelColor hex="000000"/>
      <leadColor hex="cccccc"/>
      <display>NAME</display>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>false</moveLabel>
      <value value="4.7" unit="M"/>
      <power>HALF</power>
      <colorCode>_5_BAND</colorCode>
      <shape>Standard</shape>
    </diylc.passive.Resistor>
    <diylc.electromechanical.OpenJack1__4>
      <name>J2</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="-1.82" y="1.265"/>
        <point x="-2.255" y="2.015"/>
        <point x="-2.255" y="1.515"/>
      </controlPoints>
      <orientation>DEFAULT</orientation>
      <angle>0</angle>
      <type>SWITCHED</type>
      <showLabels>true</showLabels>
    </diylc.electromechanical.OpenJack1__4>
      <name>R2</name>
      <alpha>127</alpha>
      <points>
        <point x="-1.2" y="0.485"/>
        <point x="-1.81" y="1.255"/>
        <point x="-2.545" y="4.24"/>
      </points>
      <value value="47.0" unit="K"/>
      <power>HALF</power>
    <diylc.passive.AxialFilmCapacitor>
      <name>C1</name>
      <alpha>127</alpha>
      <length value="0.5" unit="in"/>
      <width value="0.125" unit="in"/>
      <points>
        <point x="-1.205" y="0.48"/>
        <point x="-1.425" y="-0.7"/>
        <point x="-2.91" y="0.78"/>
      </points>
      <bodyColor hex="ffe303"/>
      <borderColor hex="b29e02"/>
      <value value="33.0" unit="pF"/>
      <voltage>_63V</voltage>
      <voltageNew value="100.0" unit="MV"/>
      <showOuterFoil>false</showOuterFoil>
      <outerFoilColor hex="ffffff"/>
    </diylc.passive.AxialFilmCapacitor>
    <diylc.connectivity.HookupWire>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="-1.185" y="0.465"/>
        <point x="-0.97" y="0.51"/>
        <point x="-0.685" y="-2.195"/>
        <point x="0.815" y="-1.16"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <pointCount>FOUR</pointCount>
      <style>SOLID</style>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_22</gauge>
      <striped>false</striped>
      <stripeColor hex="ffff00"/>
    </diylc.connectivity.HookupWire>
      <name>R5 WW</name>
      <alpha>127</alpha>
      <length value="0.41" unit="in"/>
      <width value="0.15" unit="in"/>
      <points>
        <point x="-1.4" y="-0.71"/>
        <point x="0.535" y="0.515"/>
        <point x="-0.575" y="1.225"/>
      </points>
      <bodyColor hex="8a5e20"/>
      <borderColor hex="735832"/>
      <value value="470.0" unit="R"/>
      <power>HALF</power>
      <powerNew value="10.0" unit="W"/>
      <shape>Tubular</shape>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="-2.265" y="2.01"/>
        <point x="-2.98" y="-0.3"/>
        <point x="-2.59" y="-0.215"/>
        <point x="-1.45" y="-0.695"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.68" y="-1.06"/>
        <point x="0.305" y="-0.77"/>
        <point x="0.39" y="-0.37"/>
        <point x="1.025" y="0.505"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W4</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.955" y="-1.165"/>
        <point x="0.8" y="-1.47"/>
        <point x="-0.655" y="-1.405"/>
        <point x="0.525" y="0.495"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R3</name>
      <alpha>127</alpha>
      <length value="7.0" unit="mm"/>
      <width value="2.5" unit="mm"/>
      <points>
        <point x="0.535" y="0.985"/>
        <point x="0.54" y="0.5"/>
        <point x="-0.19" y="0.72"/>
      </points>
      <value value="220.0" unit="K"/>
      <power>HALF</power>
      <name>R4</name>
      <alpha>127</alpha>
      <points>
        <point x="1.015" y="0.525"/>
        <point x="0.53" y="1.015"/>
        <point x="1.855" y="0.825"/>
      </points>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <name>C2</name>
      <alpha>127</alpha>
      <points>
        <point x="1.035" y="0.505"/>
        <point x="1.535" y="0.545"/>
        <point x="0.3" y="-0.045"/>
      </points>
      <value value="0.047" unit="uF"/>
      <name>R6</name>
      <alpha>127</alpha>
      <points>
        <point x="1.53" y="0.545"/>
        <point x="1.52" y="1.01"/>
        <point x="1.96" y="-0.715"/>
      </points>
      <value value="330.0" unit="K"/>
      <power>HALF</power>
      <name>C3</name>
      <alpha>127</alpha>
      <points>
        <point x="1.515" y="1.53"/>
        <point x="1.525" y="1.01"/>
        <point x="-1.17" y="2.595"/>
      </points>
      <value value="470.0" unit="pF"/>
    <diylc.passive.PotentiometerPanel>
      <name>Bass Pot 1M Audio</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="1.79" y="4.06"/>
        <point x="1.49" y="4.06"/>
        <point x="1.19" y="4.06"/>
      </controlPoints>
      <resistance value="1.0" unit="M"/>
      <orientation>_180</orientation>
      <taper>LIN</taper>
      <bodyDiameter value="1.0" unit="in"/>
      <spacing value="0.3" unit="in"/>
      <lugDiameter value="0.15" unit="in"/>
      <bodyColor hex="c0c0c0"/>
      <borderColor hex="808080"/>
      <nutColor hex="cbd5db"/>
      <waferColor hex="cd8500"/>
      <type>ThroughHole</type>
      <showShaft>false</showShaft>
      <view>ShaftDown</view>
    </diylc.passive.PotentiometerPanel>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.5" y="1.54"/>
        <point x="1.38" y="1.72"/>
        <point x="1.215" y="2.34"/>
        <point x="1.5" y="4.055"/>
      </controlPoints2>
      <style>DASHED</style>
      <gauge>_22</gauge>
      <name>Treble Pot 1M Audio</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="3.45" y="4.08"/>
        <point x="3.15" y="4.08"/>
        <point x="2.85" y="4.08"/>
      </controlPoints>
      <taper>LIN</taper>
      <name>R7</name>
      <alpha>127</alpha>
      <points>
        <point x="3.145" y="4.08"/>
        <point x="1.505" y="4.07"/>
        <point x="5.27" y="7.97"/>
      </points>
      <value value="120.0" unit="K"/>
      <power>HALF</power>
      <name>C4</name>
      <alpha>127</alpha>
      <points>
        <point x="1.495" y="4.055"/>
        <point x="1.195" y="4.07"/>
        <point x="2.96" y="8.06"/>
      </points>
      <value value="0.0047" unit="uF"/>
      <name>W6</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="-1.62" y="3.07"/>
        <point x="-1.12" y="3.07"/>
        <point x="-0.79" y="3.03"/>
        <point x="0.51" y="3.015"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R8</name>
      <alpha>127</alpha>
      <points>
        <point x="1.495" y="4.065"/>
        <point x="1.195" y="4.055"/>
        <point x="2.905" y="8.14"/>
      </points>
      <power>HALF</power>
      <name>Volume Pot 1M Audio</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="4.985" y="4.09"/>
        <point x="4.685" y="4.09"/>
        <point x="4.385" y="4.09"/>
      </controlPoints>
      <taper>LIN</taper>
      <name>C5</name>
      <alpha>127</alpha>
      <points>
        <point x="3.445" y="4.08"/>
        <point x="1.535" y="3.045"/>
        <point x="3.15" y="8.6"/>
      </points>
      <name>W7</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.525" y="3.025"/>
        <point x="1.835" y="2.73"/>
        <point x="1.74" y="0.725"/>
        <point x="1.54" y="0.53"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C6</name>
      <alpha>127</alpha>
      <points>
        <point x="0.52" y="3.02"/>
        <point x="2.845" y="4.08"/>
        <point x="2.47" y="0.55"/>
      </points>
      <name>W8</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.515" y="1.0"/>
        <point x="2.015" y="1.0"/>
        <point x="1.7" y="2.045"/>
        <point x="1.805" y="4.065"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.52" y="3.045"/>
        <point x="1.02" y="3.045"/>
        <point x="1.02" y="4.045"/>
        <point x="1.165" y="4.055"/>
      </controlPoints2>
      <gauge>_22</gauge>
  </components>
  <groups/>
  <lockedLayers/>
  <hiddenLayers/>
  <font name="Square721 BT Roman" size="14" style="0"/>
</project>
