<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>4</major>
    <minor>7</minor>
    <build>0</build>
  </fileVersion>
  <title>Mag 10A-Sluckey startup board</title>
  <author>Stephen</author>
  <width value="15.125" unit="in"/>
  <height value="8.5" unit="in"/>
  <gridSpacing value="0.25" unit="in"/>
  <dotSpacing>1</dotSpacing>
  <components>
    <diylc.tube.TubeSocket>
      <name>V6-12AU7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AU7</type>
      <angle>0</angle>
      <color hex="f7f7ef"/>
      <electrodeLabels>1,2,3,4,5,6,7,8,9</electrodeLabels>
      <mount>CHASSIS</mount>
      <labelColor hex="acaca7"/>
      <controlPoints>
        <point x="11.14" y="6.995"/>
        <point x="11.34" y="7.14"/>
        <point x="11.215" y="7.23"/>
        <point x="11.065" y="7.23"/>
        <point x="10.94" y="7.14"/>
        <point x="10.895" y="6.995"/>
        <point x="10.94" y="6.85"/>
        <point x="11.065" y="6.76"/>
        <point x="11.215" y="6.76"/>
        <point x="11.34" y="6.85"/>
      </controlPoints>
    </diylc.tube.TubeSocket>
    <diylc.boards.BlankBoard>
      <name>Board1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="0.01" y="2.98"/>
        <point x="15.11" y="6.055"/>
      </controlPoints>
      <firstPoint x="0.01" y="2.98"/>
      <secondPoint x="15.11" y="6.055"/>
      <boardColor hex="f8ebb3"/>
      <borderColor hex="ada47d"/>
      <coordinateColor hex="b6b6b6"/>
      <xType>Numbers</xType>
      <coordinateOrigin>Top_Left</coordinateOrigin>
      <coordinateDisplay>One_Side</coordinateDisplay>
      <yType>Letters</yType>
      <length value="15.125" unit="in"/>
      <width value="3.125" unit="in"/>
      <mode>TwoPoints</mode>
      <type>SQUARE</type>
    </diylc.boards.BlankBoard>
    <diylc.connectivity.CopperTrace>
      <name>Trace1</name>
      <alpha>127</alpha>
      <points>
        <point x="2.075" y="0.145"/>
        <point x="14.7" y="0.205"/>
        <point x="8.605" y="0.16"/>
      </points>
      <bodyColor hex="ffffff"/>
      <borderColor hex="000000"/>
      <labelColor hex="000000"/>
      <leadColor hex="999999"/>
      <display>NAME</display>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>false</moveLabel>
      <thickness value="1.0" unit="mm"/>
      <layer>_1</layer>
    </diylc.connectivity.CopperTrace>
      <name>Trace2</name>
      <alpha>127</alpha>
      <points>
        <point x="4.75" y="3.25"/>
        <point x="14.825" y="3.255"/>
        <point x="13.48" y="3.29"/>
      </points>
      <layer>_1</layer>
    <diylc.connectivity.SolderPad>
      <name>Pad1</name>
      <size value="0.25" unit="in"/>
      <color hex="000000"/>
      <point x="14.11" y="1.935"/>
      <type>ROUND</type>
      <holeSize value="0.8" unit="mm"/>
      <layer>_1</layer>
    </diylc.connectivity.SolderPad>
      <name>Pad2</name>
      <point x="14.75" y="6.735"/>
      <type>ROUND</type>
      <layer>_1</layer>
    <diylc.connectivity.Turret>
      <name>Turret3</name>
      <size value="0.16" unit="in"/>
      <holeSize value="0.0625" unit="in"/>
      <color hex="e0c04c"/>
      <point x="14.495" y="3.265"/>
      <value></value>
    </diylc.connectivity.Turret>
      <name>Turret4</name>
      <point x="14.25" y="3.5"/>
      <value></value>
      <name>Turret5</name>
      <point x="14.0" y="3.5"/>
      <value></value>
      <name>Turret6</name>
      <point x="14.25" y="4.25"/>
      <value></value>
      <name>Turret7</name>
      <point x="14.0" y="4.25"/>
      <value></value>
      <name>Turret8</name>
      <point x="14.5" y="5.0"/>
      <value></value>
      <name>Turret9</name>
      <point x="13.75" y="3.25"/>
      <value></value>
      <name>Turret10</name>
      <point x="13.5" y="3.25"/>
      <value></value>
      <name>Turret11</name>
      <point x="13.5" y="4.75"/>
      <value></value>
      <name>Turret12</name>
      <point x="13.75" y="5.0"/>
      <value></value>
      <name>Turret13</name>
      <point x="13.25" y="4.75"/>
      <value></value>
      <name>Turret14</name>
      <point x="14.0" y="5.0"/>
      <value></value>
      <name>Turret15</name>
      <point x="14.25" y="5.0"/>
      <value></value>
      <name>Turret16</name>
      <point x="14.25" y="5.75"/>
      <value></value>
      <name>Turret17</name>
      <point x="14.0" y="5.75"/>
      <value></value>
      <name>Turret18</name>
      <point x="13.25" y="5.5"/>
      <value></value>
      <name>Turret19</name>
      <point x="13.5" y="5.5"/>
      <value></value>
      <name>Turret22</name>
      <point x="12.5" y="4.5"/>
      <value></value>
      <name>Turret23</name>
      <point x="12.5" y="5.5"/>
      <value></value>
      <name>Turret24</name>
      <point x="11.75" y="4.5"/>
      <value></value>
      <name>Turret25</name>
      <point x="11.75" y="3.25"/>
      <value></value>
      <name>Turret26</name>
      <point x="11.0" y="5.75"/>
      <value></value>
      <name>Turret27</name>
      <point x="11.0" y="5.0"/>
      <value></value>
      <name>Turret28</name>
      <point x="12.0" y="4.0"/>
      <value></value>
      <name>Turret29</name>
      <point x="10.75" y="5.5"/>
      <value></value>
      <name>Turret30</name>
      <point x="11.25" y="4.75"/>
      <value></value>
      <name>Turret31</name>
      <point x="12.0" y="4.75"/>
      <value></value>
      <name>Turret32</name>
      <point x="12.0" y="5.5"/>
      <value></value>
      <name>Turret33</name>
      <point x="11.25" y="5.5"/>
      <value></value>
      <name>Turret34</name>
      <point x="11.75" y="5.75"/>
      <value></value>
      <name>Turret35</name>
      <point x="12.25" y="5.5"/>
      <value></value>
      <name>Turret36</name>
      <point x="12.25" y="4.5"/>
      <value></value>
      <name>Turret37</name>
      <point x="11.75" y="5.0"/>
      <value></value>
      <name>Turret38</name>
      <point x="10.75" y="4.75"/>
      <value></value>
      <name>Turret39</name>
      <point x="9.25" y="4.5"/>
      <value></value>
      <name>Turret40</name>
      <point x="9.25" y="3.25"/>
      <value></value>
      <name>Turret41</name>
      <point x="12.75" y="3.75"/>
      <value></value>
      <name>Turret43</name>
      <point x="11.5" y="3.75"/>
      <value></value>
      <name>Turret44</name>
      <point x="11.5" y="4.5"/>
      <value></value>
      <name>Turret45</name>
      <point x="10.75" y="4.5"/>
      <value></value>
      <name>Turret46</name>
      <point x="10.75" y="3.5"/>
      <value></value>
      <name>Turret47</name>
      <point x="10.25" y="3.5"/>
      <value></value>
      <name>Turret48</name>
      <point x="10.25" y="4.5"/>
      <value></value>
      <name>Turret49</name>
      <point x="10.5" y="3.5"/>
      <value></value>
      <name>Turret51</name>
      <point x="9.75" y="3.5"/>
      <value></value>
      <name>Turret52</name>
      <point x="9.75" y="4.25"/>
      <value></value>
      <name>Turret53</name>
      <point x="9.75" y="5.75"/>
      <value></value>
      <name>Turret54</name>
      <point x="9.75" y="5.0"/>
      <value></value>
      <name>Turret55</name>
      <point x="10.5" y="5.0"/>
      <value></value>
      <name>Turret56</name>
      <point x="10.5" y="5.75"/>
      <value></value>
      <name>Turret57</name>
      <point x="11.0" y="3.5"/>
      <value></value>
      <name>Turret58</name>
      <point x="11.0" y="4.25"/>
      <value></value>
      <name>Turret59</name>
      <point x="11.25" y="3.25"/>
      <value></value>
      <name>Turret60</name>
      <point x="11.25" y="4.25"/>
      <value></value>
      <name>Turret62</name>
      <point x="0.43" y="4.28"/>
      <value></value>
      <name>Turret63</name>
      <point x="0.43" y="4.6"/>
      <value></value>
      <name>Turret64</name>
      <point x="0.44" y="4.88"/>
      <value></value>
      <name>Turret65</name>
      <point x="12.25" y="3.25"/>
      <value></value>
      <name>Turret66</name>
      <point x="12.25" y="4.25"/>
      <value></value>
      <name>Turret67</name>
      <point x="13.25" y="4.0"/>
      <value></value>
      <name>Turret68</name>
      <point x="13.25" y="3.25"/>
      <value></value>
      <name>Turret70</name>
      <point x="9.0" y="5.75"/>
      <value></value>
      <name>Turret72</name>
      <point x="8.75" y="4.75"/>
      <value></value>
      <name>Turret73</name>
      <point x="8.75" y="5.75"/>
      <value></value>
      <name>Turret74</name>
      <point x="8.25" y="3.25"/>
      <value></value>
      <name>Turret75</name>
      <point x="7.25" y="4.75"/>
      <value></value>
      <name>Turret76</name>
      <point x="7.25" y="5.5"/>
      <value></value>
      <name>Turret77</name>
      <point x="1.0" y="5.75"/>
      <value></value>
      <name>Turret78</name>
      <point x="2.0" y="5.75"/>
      <value></value>
      <name>Turret79</name>
      <point x="3.0" y="5.75"/>
      <value></value>
      <name>Turret80</name>
      <point x="4.0" y="5.75"/>
      <value></value>
      <name>Turret81</name>
      <point x="4.0" y="3.25"/>
      <value></value>
      <name>Turret82</name>
      <point x="3.0" y="3.25"/>
      <value></value>
      <name>Turret83</name>
      <point x="2.0" y="3.25"/>
      <value></value>
      <name>Turret84</name>
      <point x="1.0" y="3.25"/>
      <value></value>
      <name>Turret85</name>
      <point x="7.75" y="5.5"/>
      <value></value>
      <name>Turret86</name>
      <point x="7.75" y="4.75"/>
      <value></value>
      <name>Turret87</name>
      <point x="7.5" y="5.5"/>
      <value></value>
      <name>Turret88</name>
      <point x="7.5" y="4.75"/>
      <value></value>
      <name>Turret89</name>
      <point x="8.5" y="4.5"/>
      <value></value>
      <name>Turret90</name>
      <point x="8.5" y="5.5"/>
      <value></value>
      <name>Turret91</name>
      <point x="8.25" y="5.5"/>
      <value></value>
      <name>Turret92</name>
      <point x="8.25" y="4.5"/>
      <value></value>
      <name>Turret93</name>
      <point x="8.0" y="4.5"/>
      <value></value>
      <name>Turret94</name>
      <point x="8.0" y="5.5"/>
      <value></value>
      <name>Turret95</name>
      <point x="9.5" y="4.75"/>
      <value></value>
      <name>Turret96</name>
      <point x="9.5" y="5.75"/>
      <value></value>
      <name>Turret97</name>
      <point x="9.25" y="4.75"/>
      <value></value>
      <name>Turret98</name>
      <point x="9.25" y="5.75"/>
      <value></value>
      <name>Turret99</name>
      <point x="10.25" y="4.75"/>
      <value></value>
      <name>Turret100</name>
      <point x="10.25" y="5.5"/>
      <value></value>
      <name>Turret101</name>
      <point x="10.0" y="5.5"/>
      <value></value>
      <name>Turret102</name>
      <point x="10.0" y="4.75"/>
      <value></value>
      <name>Turret103</name>
      <point x="7.575" y="3.67"/>
      <value></value>
      <name>Turret104</name>
      <point x="7.57" y="4.455"/>
      <value></value>
      <name>Turret105</name>
      <point x="7.015" y="4.45"/>
      <value></value>
      <name>Turret106</name>
      <point x="7.015" y="3.67"/>
      <value></value>
      <name>Turret107</name>
      <point x="7.315" y="3.665"/>
      <value></value>
      <name>Turret108</name>
      <point x="7.3" y="4.45"/>
      <value></value>
      <name>Turret109</name>
      <point x="7.015" y="5.215"/>
      <value></value>
      <name>Turret110</name>
      <point x="6.75" y="4.0"/>
      <value></value>
      <name>Turret111</name>
      <point x="6.75" y="4.75"/>
      <value></value>
      <name>Turret112</name>
      <point x="6.75" y="5.5"/>
      <value></value>
      <name>Turret113</name>
      <point x="6.5" y="4.25"/>
      <value></value>
      <name>Turret114</name>
      <point x="6.5" y="5.25"/>
      <value></value>
      <name>Turret115</name>
      <point x="6.5" y="3.5"/>
      <value></value>
      <name>Turret116</name>
      <point x="4.75" y="4.75"/>
      <value></value>
      <name>Turret117</name>
      <point x="4.75" y="5.5"/>
      <value></value>
      <name>Turret118</name>
      <point x="6.25" y="4.5"/>
      <value></value>
      <name>Turret119</name>
      <point x="6.25" y="5.5"/>
      <value></value>
      <name>Turret120</name>
      <point x="6.0" y="4.5"/>
      <value></value>
      <name>Turret121</name>
      <point x="6.0" y="5.25"/>
      <value></value>
      <name>Turret122</name>
      <point x="5.75" y="5.5"/>
      <value></value>
      <name>Turret123</name>
      <point x="5.75" y="4.75"/>
      <value></value>
      <name>Turret124</name>
      <point x="5.5" y="4.5"/>
      <value></value>
      <name>Turret125</name>
      <point x="5.5" y="5.5"/>
      <value></value>
      <name>Turret126</name>
      <point x="5.25" y="3.75"/>
      <value></value>
      <name>Turret127</name>
      <point x="5.25" y="4.5"/>
      <value></value>
      <name>Turret128</name>
      <point x="5.25" y="5.5"/>
      <value></value>
      <name>Turret129</name>
      <point x="4.75" y="4.25"/>
      <value></value>
      <name>Turret130</name>
      <point x="9.5" y="3.25"/>
      <value></value>
      <name>Turret50</name>
      <point x="10.5" y="4.5"/>
      <value></value>
      <name>Turret1</name>
      <point x="0.44" y="3.38"/>
      <value></value>
      <name>Turret2</name>
      <point x="5.0" y="5.5"/>
      <value></value>
      <name>Turret42</name>
      <point x="5.0" y="4.75"/>
      <value></value>
      <name>Turret20</name>
      <point x="12.75" y="5.5"/>
      <value></value>
      <name>Turret21</name>
      <point x="14.75" y="3.5"/>
      <value></value>
      <name>Turret69</name>
      <point x="14.75" y="5.0"/>
      <value></value>
      <name>Turret131</name>
      <point x="4.75" y="3.75"/>
      <value></value>
      <name>Turret132</name>
      <value></value>
      <name>Turret133</name>
      <point x="5.5" y="3.25"/>
      <value></value>
      <name>Turret134</name>
      <point x="6.0" y="3.25"/>
      <value></value>
      <name>Turret135</name>
      <point x="6.75" y="3.25"/>
      <value></value>
      <name>Turret136</name>
      <point x="7.25" y="3.25"/>
      <value></value>
      <name>Turret137</name>
      <point x="8.99" y="3.995"/>
      <value></value>
      <name>Turret138</name>
      <point x="8.5" y="3.75"/>
      <value></value>
      <name>Turret139</name>
      <point x="14.75" y="5.75"/>
      <value></value>
    <diylc.electromechanical.OpenJack1__4>
      <name>J1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="13.785" y="0.9"/>
        <point x="13.35" y="1.65"/>
        <point x="13.35" y="1.15"/>
      </controlPoints>
      <orientation>DEFAULT</orientation>
      <angle>0</angle>
      <type>SWITCHED</type>
      <showLabels>true</showLabels>
    </diylc.electromechanical.OpenJack1__4>
    <diylc.passive.PotentiometerPanel>
      <name>Volume 1M-A</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="12.52" y="0.74"/>
        <point x="12.22" y="0.74"/>
        <point x="11.92" y="0.74"/>
      </controlPoints>
      <resistance value="1.0" unit="M"/>
      <orientation>_180</orientation>
      <taper>LOG</taper>
      <bodyDiameter value="1.0" unit="in"/>
      <spacing value="0.3" unit="in"/>
      <lugDiameter value="0.15" unit="in"/>
      <bodyColor hex="c0c0c0"/>
      <borderColor hex="808080"/>
      <nutColor hex="cbd5db"/>
      <waferColor hex="cd8500"/>
      <type>ThroughHole</type>
      <showShaft>false</showShaft>
      <view>ShaftDown</view>
    </diylc.passive.PotentiometerPanel>
      <name>Bass 1M-A</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="9.52" y="0.68"/>
        <point x="9.22" y="0.68"/>
        <point x="8.92" y="0.68"/>
      </controlPoints>
      <taper>LOG</taper>
      <name>Treble-1M-A</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="11.04" y="0.72"/>
        <point x="10.74" y="0.72"/>
        <point x="10.44" y="0.72"/>
      </controlPoints>
      <taper>LOG</taper>
    <diylc.connectivity.HookupWire>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.92" y="0.72"/>
        <point x="11.9" y="0.18"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <pointCount>FOUR</pointCount>
      <style>SOLID</style>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_22</gauge>
      <striped>false</striped>
      <stripeColor hex="ffff00"/>
    </diylc.connectivity.HookupWire>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.345" y="1.65"/>
        <point x="13.1" y="0.63"/>
        <point x="13.39" y="0.355"/>
        <point x="13.665" y="0.19"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.passive.Resistor>
      <name>R1</name>
      <alpha>127</alpha>
      <length value="9.0" unit="mm"/>
      <width value="3.2" unit="mm"/>
      <points>
        <point x="13.36" y="1.65"/>
        <point x="13.79" y="0.91"/>
        <point x="13.6" y="1.285"/>
      </points>
      <bodyColor hex="82cffd"/>
      <borderColor hex="5b90b1"/>
      <leadColor hex="cccccc"/>
      <display>VALUE</display>
      <value value="4.7" unit="M"/>
      <power>HALF</power>
      <colorCode>_5_BAND</colorCode>
      <shape>Standard</shape>
    </diylc.passive.Resistor>
    <diylc.connectivity.Jumper>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="13.355" y="1.65"/>
        <point x="13.35" y="1.145"/>
        <point x="13.33" y="1.415"/>
      </points>
      <leadColor hex="000000"/>
    </diylc.connectivity.Jumper>
      <name>V1-12AX7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AX7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="13.645" y="7.065"/>
        <point x="13.845" y="7.21"/>
        <point x="13.72" y="7.3"/>
        <point x="13.57" y="7.3"/>
        <point x="13.445" y="7.21"/>
        <point x="13.4" y="7.065"/>
        <point x="13.445" y="6.92"/>
        <point x="13.57" y="6.83"/>
        <point x="13.72" y="6.83"/>
        <point x="13.845" y="6.92"/>
      </controlPoints>
      <name>V5-12AU7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AU7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="12.34" y="7.03"/>
        <point x="12.54" y="7.175"/>
        <point x="12.415" y="7.265"/>
        <point x="12.265" y="7.265"/>
        <point x="12.14" y="7.175"/>
        <point x="12.095" y="7.03"/>
        <point x="12.14" y="6.885"/>
        <point x="12.265" y="6.795"/>
        <point x="12.415" y="6.795"/>
        <point x="12.54" y="6.885"/>
      </controlPoints>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.14" y="3.535"/>
        <point x="14.93" y="1.9"/>
        <point x="14.72" y="0.265"/>
      </controlPoints2>
      <pointCount>FIVE</pointCount>
      <gauge>_22</gauge>
    <diylc.misc.GroundSymbol>
      <name>GND1</name>
      <size value="0.4" unit="in"/>
      <type>DEFAULT</type>
    </diylc.misc.GroundSymbol>
      <name>W4</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.12" y="1.925"/>
        <point x="14.47" y="1.895"/>
        <point x="14.48" y="1.455"/>
        <point x="14.58" y="0.875"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.23" y="1.655"/>
        <point x="14.225" y="1.32"/>
        <point x="14.245" y="0.205"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W6</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.165" y="0.405"/>
        <point x="12.07" y="0.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W7</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.06" y="0.72"/>
        <point x="11.75" y="2.25"/>
        <point x="13.5" y="2.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W8</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.0" y="2.25"/>
        <point x="12.25" y="3.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.755" y="7.265"/>
        <point x="13.995" y="7.285"/>
        <point x="14.125" y="7.13"/>
      </controlPoints2>
      <color hex="cccccc"/>
      <gauge>_26</gauge>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.595" y="6.315"/>
        <point x="14.56" y="6.35"/>
        <point x="14.55" y="6.655"/>
        <point x="14.46" y="6.745"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.passive.AxialFilmCapacitor>
      <name>C1</name>
      <alpha>127</alpha>
      <length value="0.5" unit="in"/>
      <width value="0.125" unit="in"/>
      <points>
        <point x="14.315" y="6.93"/>
      </points>
      <bodyColor hex="ffe303"/>
      <borderColor hex="b29e02"/>
      <hideShortLeads>true</hideShortLeads>
      <value value="33.0" unit="pF"/>
      <voltage>_63V</voltage>
      <showOuterFoil>false</showOuterFoil>
      <outerFoilColor hex="ffffff"/>
    </diylc.passive.AxialFilmCapacitor>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.71" y="7.29"/>
        <point x="13.92" y="7.375"/>
        <point x="14.14" y="7.265"/>
        <point x="14.155" y="7.3"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.745" y="6.75"/>
        <point x="14.68" y="6.78"/>
        <point x="14.575" y="7.04"/>
        <point x="14.485" y="7.14"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>R2</name>
      <alpha>127</alpha>
      <points>
        <point x="14.33" y="7.195"/>
      </points>
      <hideShortLeads>false</hideShortLeads>
      <value value="47.0" unit="K"/>
      <power>HALF</power>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.065" y="5.21"/>
        <point x="14.205" y="5.98"/>
      </controlPoints2>
      <color hex="3366ff"/>
      <gauge>_22</gauge>
      <name>W10</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.755" y="5.555"/>
        <point x="14.62" y="6.185"/>
        <point x="13.575" y="7.285"/>
      </controlPoints2>
      <color hex="ffff00"/>
      <gauge>_22</gauge>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.795" y="7.27"/>
        <point x="12.91" y="7.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.01" y="6.24"/>
        <point x="13.08" y="6.42"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W13</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.75" y="2.39"/>
        <point x="12.875" y="4.07"/>
        <point x="13.0" y="5.75"/>
      </controlPoints2>
      <color hex="ff9900"/>
      <gauge>_22</gauge>
      <name>W14</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.36" y="5.445"/>
        <point x="13.67" y="6.23"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R3</name>
      <alpha>127</alpha>
      <points>
        <point x="14.275" y="5.345"/>
      </points>
      <value value="220.0" unit="K"/>
      <power>HALF</power>
      <name>R4</name>
      <alpha>127</alpha>
      <points>
        <point x="14.4" y="-2.185"/>
      </points>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <name>R5-WW</name>
      <alpha>127</alpha>
      <length value="22.0" unit="mm"/>
      <width value="10.0" unit="mm"/>
      <points>
        <point x="14.505" y="4.145"/>
      </points>
      <bodyColor hex="f6f5f5"/>
      <borderColor hex="cccccc"/>
      <value value="470.0" unit="R"/>
      <power>HALF</power>
      <shape>Tubular</shape>
      <name>C2</name>
      <alpha>127</alpha>
      <points>
        <point x="13.99" y="4.65"/>
      </points>
      <value value="0.047" unit="uF"/>
      <name>R6</name>
      <alpha>127</alpha>
      <points>
        <point x="14.39" y="-3.745"/>
      </points>
      <value value="330.0" unit="K"/>
      <power>HALF</power>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="14.16" y="4.265"/>
      </points>
      <name>C5</name>
      <alpha>127</alpha>
      <points>
        <point x="14.55" y="11.18"/>
      </points>
      <value value="470.0" unit="pF"/>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.245" y="0.68"/>
        <point x="9.315" y="0.495"/>
        <point x="9.865" y="0.48"/>
        <point x="9.81" y="0.695"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.645" y="0.605"/>
        <point x="10.4" y="0.43"/>
        <point x="10.175" y="0.705"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>R7</name>
      <alpha>127</alpha>
      <points>
        <point x="3.25" y="7.52"/>
      </points>
      <value value="120.0" unit="K"/>
      <power>HALF</power>
      <name>R8</name>
      <alpha>127</alpha>
      <points>
        <point x="8.92" y="0.185"/>
        <point x="1.925" y="-6.13"/>
      </points>
      <power>HALF</power>
      <name>C4</name>
      <alpha>127</alpha>
      <points>
        <point x="8.92" y="0.665"/>
        <point x="16.285" y="0.76"/>
      </points>
      <value value="0.0047" unit="uF"/>
      <name>C3</name>
      <alpha>127</alpha>
      <points>
        <point x="9.52" y="0.67"/>
        <point x="9.36" y="0.68"/>
      </points>
      <name>C6</name>
      <alpha>127</alpha>
      <points>
        <point x="10.445" y="0.19"/>
        <point x="10.47" y="0.46"/>
      </points>
      <name>W15</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.12" y="1.91"/>
        <point x="14.43" y="2.215"/>
        <point x="14.665" y="2.89"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.passive.AxialElectrolyticCapacitor>
      <name>C15-E 212V</name>
      <alpha>127</alpha>
      <points>
        <point x="13.54" y="4.06"/>
      </points>
      <bodyColor hex="6b6dce"/>
      <borderColor hex="4a4c90"/>
      <labelColor hex="ffffff"/>
      <value value="1.0" unit="uF"/>
      <voltageNew value="450.0" unit="V"/>
      <markerColor hex="8cacea"/>
      <tickColor hex="ffffff"/>
      <polarized>true</polarized>
    </diylc.passive.AxialElectrolyticCapacitor>
      <name>J4</name>
      <alpha>127</alpha>
      <points>
        <point x="13.74" y="5.265"/>
      </points>
      <name>R23</name>
      <alpha>127</alpha>
      <points>
        <point x="13.505" y="5.155"/>
      </points>
      <value value="10.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="1.0" unit="W"/>
      <name>R9</name>
      <alpha>127</alpha>
      <points>
        <point x="13.62" y="-2.44"/>
      </points>
      <power>HALF</power>
      <name>J5</name>
      <alpha>127</alpha>
      <points>
        <point x="13.38" y="5.09"/>
      </points>
      <name>J6</name>
      <alpha>127</alpha>
      <points>
        <point x="14.235" y="5.755"/>
        <point x="14.095" y="5.77"/>
      </points>
      <name>J7</name>
      <alpha>127</alpha>
      <points>
        <point x="14.39" y="5.02"/>
      </points>
      <name>R10</name>
      <alpha>127</alpha>
      <points>
        <point x="13.76" y="4.125"/>
      </points>
      <value value="2.7" unit="K"/>
      <power>HALF</power>
      <name>R25</name>
      <alpha>127</alpha>
      <points>
        <point x="12.5" y="4.955"/>
      </points>
      <value value="22.0" unit="K"/>
      <power>HALF</power>
      <name>W16</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.5" y="6.0"/>
        <point x="12.59" y="6.815"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R24</name>
      <alpha>127</alpha>
      <points>
        <point x="11.785" y="3.89"/>
      </points>
      <power>HALF</power>
      <name>W17</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.485" y="4.7"/>
        <point x="11.13" y="6.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C18</name>
      <alpha>127</alpha>
      <points>
        <point x="10.775" y="5.12"/>
      </points>
      <name>C17</name>
      <alpha>127</alpha>
      <points>
        <point x="11.54" y="11.78"/>
      </points>
      <name>VR2</name>
      <alpha>127</alpha>
      <points>
        <point x="11.02" y="5.43"/>
      </points>
      <bodyColor hex="e0c68b"/>
      <borderColor hex="a59268"/>
      <power>HALF</power>
      <name>VR1</name>
      <alpha>127</alpha>
      <points>
        <point x="11.97" y="11.89"/>
      </points>
      <power>HALF</power>
      <name>C16</name>
      <alpha>127</alpha>
      <points>
        <point x="12.225" y="5.02"/>
      </points>
      <value value="820.0" unit="pF"/>
      <name>C19</name>
      <alpha>127</alpha>
      <points>
        <point x="12.02" y="5.06"/>
      </points>
      <value value="0.0022" unit="uF"/>
      <name>J10</name>
      <alpha>127</alpha>
      <points>
        <point x="12.4" y="4.51"/>
      </points>
      <name>R26</name>
      <alpha>127</alpha>
      <points>
        <point x="9.765" y="5.37"/>
      </points>
      <power>HALF</power>
      <name>R27</name>
      <alpha>127</alpha>
      <points>
        <point x="10.26" y="0.275"/>
      </points>
      <power>HALF</power>
      <name>R29</name>
      <alpha>127</alpha>
      <points>
        <point x="11.98" y="4.41"/>
      </points>
      <value value="2.2" unit="M"/>
      <power>HALF</power>
      <name>R30</name>
      <alpha>127</alpha>
      <points>
        <point x="9.685" y="-2.25"/>
      </points>
      <power>HALF</power>
      <name>W19</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.76" y="5.375"/>
        <point x="10.155" y="6.745"/>
        <point x="11.55" y="8.115"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R28</name>
      <alpha>127</alpha>
      <points>
        <point x="13.075" y="11.235"/>
      </points>
      <power>HALF</power>
      <name>W20</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.115" y="4.115"/>
        <point x="12.5" y="6.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C20</name>
      <alpha>127</alpha>
      <points>
        <point x="11.71" y="10.7"/>
      </points>
      <name>C21</name>
      <alpha>127</alpha>
      <points>
        <point x="4.975" y="13.44"/>
      </points>
      <name>C22</name>
      <alpha>127</alpha>
      <points>
        <point x="10.015" y="9.815"/>
      </points>
      <name>VR3</name>
      <alpha>127</alpha>
      <points>
        <point x="5.52" y="13.465"/>
      </points>
      <power>HALF</power>
      <name>VR4</name>
      <alpha>127</alpha>
      <points>
        <point x="10.505" y="9.83"/>
      </points>
      <power>HALF</power>
      <name>R31</name>
      <alpha>127</alpha>
      <points>
        <point x="5.575" y="13.655"/>
      </points>
      <power>HALF</power>
      <name>R32</name>
      <alpha>127</alpha>
      <points>
        <point x="10.785" y="10.7"/>
      </points>
      <power>HALF</power>
      <name>J19</name>
      <alpha>127</alpha>
      <points>
        <point x="12.19" y="3.775"/>
      </points>
      <name>J20</name>
      <alpha>127</alpha>
      <points>
        <point x="11.125" y="4.54"/>
      </points>
      <name>J21</name>
      <alpha>127</alpha>
      <points>
        <point x="10.54" y="4.47"/>
      </points>
      <style>DASHED</style>
      <name>J22</name>
      <alpha>127</alpha>
      <points>
        <point x="10.64" y="3.995"/>
      </points>
      <name>J24</name>
      <alpha>127</alpha>
      <points>
        <point x="10.175" y="3.535"/>
      </points>
      <name>C23</name>
      <alpha>127</alpha>
      <points>
        <point x="10.665" y="10.22"/>
      </points>
      <name>R33</name>
      <alpha>127</alpha>
      <points>
        <point x="11.255" y="3.74"/>
      </points>
      <value value="1.0" unit="M"/>
      <power>HALF</power>
      <name>J27</name>
      <alpha>127</alpha>
      <points>
        <point x="10.885" y="3.975"/>
      </points>
      <name>J28</name>
      <alpha>127</alpha>
      <points>
        <point x="11.13" y="4.215"/>
      </points>
      <name>J9</name>
      <alpha>127</alpha>
      <points>
        <point x="12.105" y="5.51"/>
      </points>
      <name>J14</name>
      <alpha>127</alpha>
      <points>
        <point x="10.76" y="5.52"/>
        <point x="10.745" y="5.54"/>
        <point x="10.755" y="5.53"/>
      </points>
      <name>J11</name>
      <alpha>127</alpha>
      <points>
        <point x="11.005" y="4.75"/>
      </points>
      <name>J12</name>
      <alpha>127</alpha>
      <points>
        <point x="13.62" y="0.015"/>
      </points>
      <name>J13</name>
      <alpha>127</alpha>
      <points>
        <point x="15.76" y="1.165"/>
      </points>
      <name>J15</name>
      <alpha>127</alpha>
      <points>
        <point x="16.135" y="1.545"/>
      </points>
      <name>J16</name>
      <alpha>127</alpha>
      <points>
        <point x="17.26" y="5.845"/>
      </points>
      <name>W18</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.98" y="4.91"/>
        <point x="11.655" y="5.99"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J17</name>
      <alpha>127</alpha>
      <points>
        <point x="11.86" y="4.245"/>
      </points>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.25" y="6.0"/>
        <point x="11.5" y="5.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W22</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.465" y="6.095"/>
        <point x="10.75" y="6.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J26</name>
      <alpha>127</alpha>
      <points>
        <point x="11.505" y="4.63"/>
      </points>
      <name>J30</name>
      <alpha>127</alpha>
      <points>
        <point x="4.215" y="7.125"/>
      </points>
      <name>J29</name>
      <alpha>127</alpha>
      <points>
        <point x="10.005" y="3.875"/>
      </points>
      <name>V4-12DW7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12DW7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="9.015" y="6.97"/>
        <point x="9.215" y="7.115"/>
        <point x="9.09" y="7.205"/>
        <point x="8.94" y="7.205"/>
        <point x="8.815" y="7.115"/>
        <point x="8.77" y="6.97"/>
        <point x="8.815" y="6.825"/>
        <point x="8.94" y="6.735"/>
        <point x="9.09" y="6.735"/>
        <point x="9.215" y="6.825"/>
      </controlPoints>
    <diylc.semiconductors.BridgeRectifier>
      <name>BR1-Bridge Rectifier-3N259</name>
      <alpha>100</alpha>
      <value>1</value>
      <controlPoints>
        <point x="0.21" y="4.725"/>
        <point x="0.21" y="4.525"/>
        <point x="0.21" y="4.325"/>
        <point x="0.21" y="4.125"/>
      </controlPoints>
      <pointLabels>
        <string>+</string>
        <string>~</string>
        <string>~</string>
        <string>-</string>
      </pointLabels>
      <display>BOTH</display>
      <bodyColor hex="808080"/>
      <borderColor hex="595959"/>
      <rectifierType>InLine</rectifierType>
      <voltage value="1000.0" unit="V"/>
      <current value="1.0" unit="A"/>
    </diylc.semiconductors.BridgeRectifier>
      <name>J25</name>
      <alpha>127</alpha>
      <points>
        <point x="0.21" y="4.77"/>
        <point x="0.33" y="4.84"/>
      </points>
      <name>C11</name>
      <alpha>127</alpha>
      <length value="2.0" unit="in"/>
      <width value="0.75" unit="in"/>
      <points>
        <point x="1.0" y="4.5"/>
      </points>
      <value value="40.0" unit="uF"/>
      <name>C12</name>
      <alpha>127</alpha>
      <points>
        <point x="3.55" y="2.635"/>
      </points>
      <name>C13</name>
      <alpha>127</alpha>
      <length value="1.75" unit="in"/>
      <points>
        <point x="0.945" y="3.06"/>
      </points>
      <value value="30.0" unit="uF"/>
      <name>C14</name>
      <alpha>127</alpha>
      <points>
        <point x="4.05" y="3.59"/>
      </points>
      <name>V7-12AX7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AX7</type>
      <angle>0</angle>
      <controlPoints>
        <point x="10.08" y="6.98"/>
        <point x="10.28" y="7.125"/>
        <point x="10.155" y="7.215"/>
        <point x="10.005" y="7.215"/>
        <point x="9.88" y="7.125"/>
        <point x="9.835" y="6.98"/>
        <point x="9.88" y="6.835"/>
        <point x="10.005" y="6.745"/>
        <point x="10.28" y="6.835"/>
      </controlPoints>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.085" y="4.76"/>
      <text>Plate Blue-3366FF</text>
      <font name="Square721 BT Roman" size="25" style="0"/>
      <color hex="3355ff"/>
      <center>false</center>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L3</name>
      <point x="16.14" y="4.97"/>
      <text>Grid Orange-FF9900</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="16.14" y="5.185"/>
      <text>Cathode Yellow-FFFF00</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="16.15" y="5.39"/>
      <text>Hookup Green-00FF00</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="16.16" y="5.585"/>
      <text>Jumper Black-000000</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="13.5" y="5.75"/>
      <text>D</text>
      <font name="Square721 BT Roman" size="20" style="0"/>
      <color hex="ff0000"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L7</name>
      <point x="14.0" y="6.0"/>
      <text>E</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L8</name>
      <point x="13.62" y="7.56"/>
      <text>V-1-12AX7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="12.355" y="7.57"/>
      <text>V5-12AU7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L11</name>
      <point x="12.975" y="1.985"/>
      <text>Shielded Cable</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L12</name>
      <point x="15.275" y="1.655"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L14</name>
      <point x="9.06" y="7.565"/>
      <text>V4-12DW7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L15</name>
      <point x="11.135" y="7.58"/>
      <text>V6-12AU7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L16</name>
      <point x="10.135" y="7.57"/>
      <text>V-7-12AX7</text>
    </diylc.misc.Label>
      <name>W23</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.49" y="6.95"/>
        <point x="11.2" y="7.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R34</name>
      <alpha>127</alpha>
      <points>
        <point x="12.255" y="3.755"/>
      </points>
      <value value="270.0" unit="R"/>
      <power>HALF</power>
      <name>W24</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.085" y="4.315"/>
        <point x="12.565" y="5.385"/>
        <point x="11.05" y="7.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J31</name>
      <alpha>127</alpha>
      <points>
        <point x="11.21" y="6.78"/>
        <point x="11.14" y="7.015"/>
      </points>
      <name>R47</name>
      <alpha>127</alpha>
      <points>
        <point x="10.155" y="6.74"/>
        <point x="10.69" y="6.755"/>
      </points>
      <value value="15.0" unit="K"/>
      <power>HALF</power>
      <name>W25</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.13" y="6.725"/>
        <point x="10.795" y="6.755"/>
        <point x="12.75" y="6.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R51</name>
      <alpha>127</alpha>
      <points>
        <point x="13.23" y="3.635"/>
      </points>
      <power>HALF</power>
      <name>J32</name>
      <alpha>127</alpha>
      <points>
        <point x="11.075" y="6.76"/>
        <point x="11.195" y="7.245"/>
        <point x="11.135" y="7.005"/>
      </points>
      <name>J33</name>
      <alpha>127</alpha>
      <points>
        <point x="10.925" y="6.865"/>
        <point x="11.315" y="7.15"/>
        <point x="11.115" y="7.01"/>
      </points>
      <name>R35</name>
      <alpha>127</alpha>
      <length value="16.0" unit="mm"/>
      <width value="6.0" unit="mm"/>
      <points>
        <point x="9.015" y="4.835"/>
      </points>
      <bodyColor hex="d2d7db"/>
      <borderColor hex="b2b7bb"/>
      <value value="5.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="10.0" unit="W"/>
      <name>C33</name>
      <alpha>127</alpha>
      <points>
        <point x="8.75" y="5.255"/>
      </points>
      <name>J34</name>
      <alpha>127</alpha>
      <points>
        <point x="8.855" y="4.385"/>
      </points>
      <name>W26</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.465" y="6.04"/>
        <point x="8.305" y="6.225"/>
        <point x="8.11" y="6.925"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.electromechanical.RCAJack>
      <name>J35</name>
      <alpha>70</alpha>
      <value></value>
      <controlPoints>
        <point x="8.115" y="6.945"/>
        <point x="8.115" y="6.445"/>
      </controlPoints>
    </diylc.electromechanical.RCAJack>
      <name>J36</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="7.25" y="6.97"/>
        <point x="7.25" y="6.47"/>
      </controlPoints>
      <name>R48</name>
      <alpha>127</alpha>
      <points>
        <point x="7.235" y="6.955"/>
        <point x="7.275" y="6.725"/>
      </points>
      <power>HALF</power>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.245" y="6.965"/>
        <point x="7.61" y="7.58"/>
        <point x="9.435" y="8.025"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R49</name>
      <alpha>127</alpha>
      <points>
        <point x="7.255" y="5.13"/>
      </points>
      <power>HALF</power>
      <name>W29</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.175" y="6.465"/>
        <point x="9.63" y="7.06"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J38</name>
      <alpha>127</alpha>
      <points>
        <point x="2.75" y="3.25"/>
        <point x="3.365" y="3.245"/>
      </points>
      <name>J39</name>
      <alpha>127</alpha>
      <points>
        <point x="0.22" y="3.69"/>
      </points>
      <name>J40</name>
      <alpha>127</alpha>
      <points>
        <point x="-0.655" y="3.69"/>
      </points>
      <name>W32</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.44" y="4.875"/>
        <point x="0.225" y="5.605"/>
        <point x="0.94" y="5.875"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.265" y="6.105"/>
        <point x="1.725" y="5.75"/>
        <point x="1.68" y="5.75"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.045" y="5.75"/>
        <point x="1.275" y="5.75"/>
        <point x="1.32" y="5.75"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>R20</name>
      <alpha>127</alpha>
      <points>
        <point x="1.515" y="5.745"/>
      </points>
      <value value="100.0" unit="R"/>
      <power>HALF</power>
      <powerNew value="2.0" unit="W"/>
      <name>R21</name>
      <alpha>127</alpha>
      <points>
        <point x="5.385" y="6.16"/>
      </points>
      <value value="1.5" unit="K"/>
      <power>HALF</power>
      <name>Reverb 1M-A</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="7.175" y="0.69"/>
        <point x="6.875" y="0.69"/>
        <point x="6.575" y="0.69"/>
      </controlPoints>
      <taper>LOG</taper>
      <name>W38</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.42" y="0.16"/>
        <point x="6.57" y="0.335"/>
        <point x="6.375" y="0.445"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W39</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.87" y="0.68"/>
        <point x="6.35" y="2.39"/>
        <point x="7.425" y="4.6"/>
        <point x="6.415" y="7.31"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R50</name>
      <alpha>127</alpha>
      <points>
        <point x="7.75" y="5.125"/>
      </points>
      <value value="270.0" unit="K"/>
      <power>HALF</power>
      <name>C34</name>
      <alpha>127</alpha>
      <points>
        <point x="7.505" y="5.125"/>
      </points>
      <name>J42</name>
      <alpha>127</alpha>
      <points>
        <point x="7.625" y="5.125"/>
      </points>
      <name>W41</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.705" y="6.035"/>
        <point x="9.765" y="7.125"/>
      </controlPoints2>
      <color hex="999900"/>
      <gauge>_22</gauge>
      <name>Output Level 100KA</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="5.775" y="0.68"/>
        <point x="5.475" y="0.68"/>
        <point x="5.175" y="0.68"/>
      </controlPoints>
      <resistance value="100.0" unit="K"/>
      <taper>LOG</taper>
      <name>J43</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="8.145" y="0.86"/>
        <point x="7.71" y="1.61"/>
        <point x="7.71" y="1.11"/>
      </controlPoints>
      <angle>0</angle>
      <name>W42</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.725" y="1.595"/>
        <point x="7.375" y="0.855"/>
        <point x="7.575" y="0.485"/>
        <point x="7.43" y="0.17"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W43</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.175" y="0.665"/>
        <point x="5.125" y="0.56"/>
        <point x="5.07" y="0.35"/>
        <point x="5.07" y="0.16"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W44</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.94" y="5.29"/>
        <point x="9.27" y="6.865"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W45</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.19" y="0.695"/>
        <point x="7.965" y="2.46"/>
        <point x="7.94" y="5.72"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W46</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.475" y="0.695"/>
        <point x="5.315" y="0.46"/>
        <point x="7.545" y="0.135"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W47</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.785" y="0.67"/>
        <point x="6.275" y="1.96"/>
        <point x="7.025" y="2.58"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R53</name>
      <alpha>127</alpha>
      <points>
        <point x="8.505" y="4.995"/>
      </points>
      <power>HALF</power>
      <name>J44</name>
      <alpha>127</alpha>
      <points>
        <point x="8.38" y="5.495"/>
      </points>
      <name>C7</name>
      <alpha>127</alpha>
      <points>
        <point x="8.245" y="5.0"/>
      </points>
      <name>R52</name>
      <alpha>127</alpha>
      <points>
        <point x="7.99" y="5.0"/>
      </points>
      <power>HALF</power>
      <name>J45</name>
      <alpha>127</alpha>
      <points>
        <point x="8.13" y="4.505"/>
      </points>
      <name>W49</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.62" y="5.13"/>
        <point x="7.055" y="5.66"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J46</name>
      <alpha>127</alpha>
      <points>
        <point x="0.215" y="4.32"/>
        <point x="0.42" y="4.28"/>
        <point x="0.32" y="4.295"/>
      </points>
      <name>J47</name>
      <alpha>127</alpha>
      <points>
        <point x="0.205" y="4.52"/>
        <point x="0.435" y="4.59"/>
        <point x="0.315" y="4.55"/>
      </points>
      <name>W50</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="-0.84" y="4.305"/>
        <point x="-0.225" y="4.245"/>
        <point x="-0.015" y="4.215"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="-0.84" y="4.505"/>
        <point x="-0.215" y="4.64"/>
        <point x="-0.085" y="4.64"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J48</name>
      <alpha>127</alpha>
      <points>
        <point x="7.695" y="1.595"/>
        <point x="7.71" y="1.09"/>
        <point x="7.705" y="1.34"/>
      </points>
      <name>GND2</name>
      <name>W52</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.7" y="3.34"/>
        <point x="0.8" y="3.34"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.connectivity.Dot>
      <name>Dot1</name>
      <size value="1.0" unit="mm"/>
    </diylc.connectivity.Dot>
      <name>C31</name>
      <alpha>127</alpha>
      <points>
        <point x="9.5" y="5.25"/>
      </points>
      <value value="0.1" unit="uF"/>
      <name>W36</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.5" y="4.25"/>
        <point x="9.5" y="4.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R46</name>
      <alpha>127</alpha>
      <points>
        <point x="9.245" y="5.25"/>
      </points>
      <power>HALF</power>
      <name>J49</name>
      <alpha>127</alpha>
      <points>
        <point x="9.63" y="5.75"/>
      </points>
      <name>J50</name>
      <alpha>127</alpha>
      <points>
        <point x="9.36" y="5.255"/>
      </points>
      <name>W54</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.0" y="6.0"/>
        <point x="9.16" y="6.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C32</name>
      <alpha>127</alpha>
      <points>
        <point x="10.52" y="10.275"/>
      </points>
      <name>R45</name>
      <alpha>127</alpha>
      <points>
        <point x="9.74" y="0.115"/>
      </points>
      <power>HALF</power>
      <name>J51</name>
      <alpha>127</alpha>
      <points>
        <point x="10.39" y="5.635"/>
      </points>
      <name>J52</name>
      <alpha>127</alpha>
      <points>
        <point x="10.135" y="5.47"/>
      </points>
      <name>W57</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.725" y="6.255"/>
        <point x="9.515" y="6.385"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R44</name>
      <alpha>127</alpha>
      <points>
        <point x="7.58" y="4.465"/>
        <point x="7.86" y="9.265"/>
      </points>
      <power>HALF</power>
      <name>W58</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.53" y="4.74"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J53</name>
      <alpha>127</alpha>
      <points>
        <point x="7.01" y="4.455"/>
        <point x="7.155" y="4.455"/>
      </points>
      <name>R43</name>
      <alpha>127</alpha>
      <points>
        <point x="7.01" y="3.67"/>
        <point x="7.02" y="4.435"/>
        <point x="7.04" y="4.075"/>
      </points>
      <value value="8.2" unit="M"/>
      <power>HALF</power>
      <name>W59</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.085" y="7.2"/>
        <point x="7.775" y="6.68"/>
        <point x="6.86" y="4.96"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C29</name>
      <alpha>127</alpha>
      <points>
        <point x="7.32" y="4.06"/>
      </points>
      <name>J54</name>
      <alpha>127</alpha>
      <points>
        <point x="7.445" y="3.675"/>
      </points>
      <name>J55</name>
      <alpha>127</alpha>
      <points>
        <point x="7.31" y="3.67"/>
        <point x="7.165" y="3.66"/>
      </points>
      <name>C30</name>
      <alpha>127</alpha>
      <points>
        <point x="7.01" y="4.45"/>
        <point x="7.02" y="5.22"/>
        <point x="7.035" y="4.865"/>
      </points>
      <name>J56</name>
      <alpha>127</alpha>
      <points>
        <point x="6.865" y="4.21"/>
      </points>
      <name>R42</name>
      <alpha>127</alpha>
      <points>
        <point x="6.76" y="4.385"/>
      </points>
      <power>HALF</power>
      <name>C28</name>
      <alpha>127</alpha>
      <points>
        <point x="6.76" y="5.14"/>
      </points>
      <name>R41</name>
      <alpha>127</alpha>
      <points>
        <point x="6.725" y="8.72"/>
      </points>
      <power>HALF</power>
      <name>J57</name>
      <alpha>127</alpha>
      <points>
        <point x="6.75" y="4.755"/>
        <point x="6.615" y="5.005"/>
      </points>
      <name>R40</name>
      <alpha>127</alpha>
      <points>
        <point x="6.485" y="3.89"/>
      </points>
      <power>HALF</power>
      <name>Vibrato Intensity 1M-A</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="4.52" y="0.695"/>
        <point x="4.22" y="0.695"/>
        <point x="3.92" y="0.695"/>
      </controlPoints>
      <taper>LOG</taper>
      <name>Vibrato Speed 500K-A</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="3.205" y="0.755"/>
        <point x="2.905" y="0.755"/>
        <point x="2.605" y="0.755"/>
      </controlPoints>
      <resistance value="500.0" unit="K"/>
      <taper>LOG</taper>
      <name>W62</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.75" y="2.75"/>
        <point x="5.36" y="2.19"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W63</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.115" y="6.41"/>
        <point x="5.735" y="6.195"/>
        <point x="5.815" y="5.875"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W64</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.515" y="6.61"/>
        <point x="7.29" y="6.325"/>
        <point x="7.56" y="6.785"/>
        <point x="7.72" y="6.92"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W65</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.925" y="0.715"/>
        <point x="3.855" y="0.42"/>
        <point x="3.7" y="0.26"/>
        <point x="3.75" y="0.17"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W66</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.51" y="0.7"/>
        <point x="4.91" y="2.52"/>
        <point x="5.42" y="2.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C27</name>
      <alpha>127</alpha>
      <points>
        <point x="4.77" y="5.17"/>
      </points>
      <value value="0.068" unit="uF"/>
      <name>W67</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.735" y="6.315"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W68</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.07" y="6.725"/>
        <point x="8.995" y="6.775"/>
        <point x="8.64" y="6.19"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R38</name>
      <alpha>127</alpha>
      <points>
        <point x="6.235" y="5.005"/>
      </points>
      <value value="3.3" unit="M"/>
      <power>HALF</power>
      <name>W69</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.5" y="5.5"/>
        <point x="7.985" y="6.955"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C26</name>
      <alpha>127</alpha>
      <points>
        <point x="6.0" y="4.875"/>
      </points>
      <value value="0.01" unit="uF"/>
      <name>J59</name>
      <alpha>127</alpha>
      <points>
        <point x="6.12" y="4.5"/>
      </points>
      <name>J60</name>
      <alpha>127</alpha>
      <points>
        <point x="5.88" y="5.005"/>
      </points>
      <name>R37</name>
      <alpha>127</alpha>
      <points>
        <point x="6.045" y="8.94"/>
      </points>
      <value value="820.0" unit="K"/>
      <power>HALF</power>
      <name>W71</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.085" y="5.985"/>
        <point x="6.435" y="6.395"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C24</name>
      <alpha>127</alpha>
      <points>
        <point x="5.815" y="8.69"/>
      </points>
      <name>J61</name>
      <alpha>127</alpha>
      <points>
        <point x="5.635" y="5.12"/>
      </points>
      <name>W72</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.62" y="0.75"/>
        <point x="2.55" y="0.51"/>
        <point x="2.62" y="0.35"/>
        <point x="2.67" y="0.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J62</name>
      <alpha>127</alpha>
      <points>
        <point x="2.61" y="0.76"/>
        <point x="2.91" y="0.755"/>
        <point x="2.765" y="0.755"/>
      </points>
      <name>R36</name>
      <alpha>127</alpha>
      <points>
        <point x="3.115" y="10.605"/>
      </points>
      <power>HALF</power>
      <name>W73</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.19" y="3.2"/>
        <point x="3.665" y="1.945"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C25</name>
      <alpha>127</alpha>
      <points>
        <point x="3.295" y="11.38"/>
      </points>
      <value value="0.02" unit="uF"/>
      <name>J63</name>
      <alpha>127</alpha>
      <points>
        <point x="5.38" y="4.51"/>
      </points>
      <name>J65</name>
      <alpha>127</alpha>
      <points>
        <point x="6.505" y="5.52"/>
      </points>
      <name>J66</name>
      <alpha>127</alpha>
      <points>
        <point x="6.885" y="5.36"/>
      </points>
      <name>J68</name>
      <alpha>127</alpha>
      <points>
        <point x="9.76" y="4.76"/>
      </points>
      <name>J69</name>
      <alpha>127</alpha>
      <points>
        <point x="10.125" y="4.75"/>
      </points>
      <name>W30</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.5" y="6.0"/>
        <point x="13.5" y="6.75"/>
      </controlPoints2>
      <color hex="33ffff"/>
      <gauge>_22</gauge>
      <name>W33</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.75" y="6.25"/>
        <point x="7.25" y="6.25"/>
      </controlPoints2>
      <color hex="ffcccc"/>
      <gauge>_22</gauge>
      <name>W34</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.22" y="6.165"/>
      </controlPoints2>
      <color hex="ff6600"/>
      <gauge>_22</gauge>
      <name>W35</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.305" y="6.59"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W48</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.52" y="5.645"/>
        <point x="10.24" y="7.745"/>
        <point x="10.96" y="6.86"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R39</name>
      <alpha>127</alpha>
      <points>
        <point x="5.0" y="-0.425"/>
      </points>
      <power>HALF</power>
      <name>J70</name>
      <alpha>127</alpha>
      <points>
        <point x="4.875" y="5.125"/>
      </points>
      <name>W56</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.13" y="5.825"/>
        <point x="4.625" y="6.175"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.795" y="6.095"/>
        <point x="3.275" y="5.75"/>
        <point x="3.32" y="5.75"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name></name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.955" y="5.75"/>
        <point x="3.725" y="5.75"/>
        <point x="3.68" y="5.75"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>R22</name>
      <alpha>127</alpha>
      <points>
        <point x="-3.465" y="6.005"/>
      </points>
      <power>HALF</power>
      <name>J8</name>
      <alpha>127</alpha>
      <points>
        <point x="5.125" y="5.125"/>
      </points>
      <name>J71</name>
      <alpha>127</alpha>
      <points>
        <point x="12.625" y="5.5"/>
      </points>
    <diylc.passive.AudioTransformer>
      <name>269JX PT</name>
      <alpha>100</alpha>
      <value></value>
      <leadSpacing value="0.1" unit="in"/>
      <windingSpacing value="0.5" unit="in"/>
      <coreThickness value="0.15" unit="in"/>
      <coreWidth value="0.6" unit="in"/>
      <coilWidth value="0.5" unit="in"/>
      <coilLength value="0.6" unit="in"/>
      <controlPoints>
        <point x="-1.34" y="4.305"/>
        <point x="-1.34" y="4.405"/>
        <point x="-1.34" y="4.505"/>
        <point x="-0.84" y="4.405"/>
      </controlPoints>
      <coreColor hex="759daf"/>
      <coreBorderColor hex="516d7a"/>
      <coilColor hex="dddddd"/>
      <coilBorderColor hex="9a9a9a"/>
      <primaryCT>true</primaryCT>
      <secondaryCT>true</secondaryCT>
    </diylc.passive.AudioTransformer>
      <name>Center Tap GND</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="-0.825" y="4.41"/>
        <point x="-0.325" y="4.41"/>
        <point x="0.29" y="3.74"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <striped>true</striped>
      <name>W31</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="-1.34" y="4.295"/>
        <point x="-2.63" y="4.785"/>
        <point x="-1.865" y="4.52"/>
        <point x="-2.135" y="5.075"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="-1.755" y="4.855"/>
        <point x="-1.64" y="5.07"/>
        <point x="-1.83" y="5.185"/>
      </controlPoints2>
      <color hex="ffffff"/>
      <gauge>_22</gauge>
      <name>J23</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
      </controlPoints>
      <angle>0</angle>
      <type>STEREO</type>
      <name>GND4</name>
      <size value="0.2" unit="in"/>
      <name>GND5</name>
      <size value="0.15" unit="in"/>
      <name>J41</name>
      <alpha>127</alpha>
      <points>
        <point x="7.715" y="6.92"/>
        <point x="8.125" y="6.445"/>
        <point x="7.92" y="6.685"/>
      </points>
      <leadColor hex="00ff00"/>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.02" y="5.795"/>
        <point x="3.615" y="6.275"/>
        <point x="4.525" y="6.855"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W37</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.31" y="3.705"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W40</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.845" y="0.695"/>
        <point x="7.22" y="1.335"/>
        <point x="7.345" y="1.695"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L18</name>
      <point x="8.195" y="7.38"/>
      <text>Reverb Input</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L19</name>
      <point x="7.27" y="7.385"/>
      <text>Reverb Output</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L20</name>
      <point x="1.0" y="6.0"/>
      <text>A</text>
      <font name="Square721 BT Roman" size="28" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L21</name>
      <point x="3.005" y="6.0"/>
      <text>B</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L22</name>
      <point x="2.0" y="5.98"/>
      <text>C</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L23</name>
      <point x="4.0" y="6.0"/>
      <text>D</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L24</name>
      <point x="8.135" y="1.85"/>
      <text>Output Jack</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L25</name>
      <point x="6.13" y="7.4"/>
      <text>Vib(Tip)/Rev(Ring) Footswitch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L26</name>
      <point x="13.7" y="1.89"/>
      <text>Input Jack</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L28</name>
      <point x="1.22" y="5.995"/>
      <text>410V</text>
      <font name="Square721 BT Roman" size="14" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L29</name>
      <point x="3.21" y="5.99"/>
      <text>338V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L30</name>
      <point x="2.16" y="5.975"/>
      <text>316V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L31</name>
      <point x="4.2" y="6.005"/>
      <text>256V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L32</name>
      <point x="14.21" y="5.99"/>
      <text>212V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L10</name>
      <point x="6.73" y="6.83"/>
      <font name="Square721 BT Roman" size="18" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L13</name>
      <point x="14.785" y="6.945"/>
      <text>Insulated Standoff</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L17</name>
      <point x="1.24" y="0.605"/>
      <text>This is FINAL LAYOUT completed July 26, 2020</text>
    </diylc.misc.Label>
  </components>
  <groups/>
  <lockedLayers>
    <int>1</int>
    <int>2</int>
  </lockedLayers>
  <lockedComponents/>
  <hiddenLayers/>
</project>
