<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>4</major>
    <minor>18</minor>
    <build>0</build>
  </fileVersion>
  <title>SLO-Nakid 6V6</title>
  <author>RobRobinette.com</author>
  <description>SLO-100 with Clean Channel, FX Loop and Switching Deleted</description>
  <width value="21.9" unit="in"/>
  <height value="10.0" unit="in"/>
  <gridSpacing value="0.05" unit="in"/>
  <dotSpacing>1</dotSpacing>
  <components>
    <diylc.tube.TubeSocket>
      <name>V3 12AX7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>9-Pin Socket</type>
      <angle>320</angle>
      <color hex="f7f7ef"/>
      <electrodeLabels>1,2,3,4,5,6,7,8,9</electrodeLabels>
      <mount>CHASSIS</mount>
      <labelColor hex="000000"/>
      <controlPoints>
        <point x="16.75" y="7.55"/>
        <point x="16.995" y="7.53"/>
        <point x="16.955" y="7.68"/>
        <point x="16.84" y="7.775"/>
        <point x="16.69" y="7.79"/>
        <point x="16.56" y="7.705"/>
        <point x="16.5" y="7.565"/>
        <point x="16.54" y="7.415"/>
        <point x="16.655" y="7.32"/>
        <point x="16.805" y="7.305"/>
      </controlPoints>
    </diylc.tube.TubeSocket>
    <diylc.connectivity.Eyelet>
      <name>Eyelet71</name>
      <size value="0.3" unit="in"/>
      <holeSize value="0.1" unit="in"/>
      <color hex="333333"/>
      <point x="5.57" y="6.7"/>
      <value>Grommet</value>
    </diylc.connectivity.Eyelet>
    <diylc.connectivity.HookupWire>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.25" y="8.55"/>
        <point x="5.15" y="8.55"/>
        <point x="4.8" y="8.45"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <pointCount>THREE</pointCount>
      <style>SOLID</style>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_18</gauge>
      <striped>false</striped>
      <stripeColor hex="ffff00"/>
    </diylc.connectivity.HookupWire>
    <diylc.boards.BlankBoard>
      <name>Board1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="8.45" y="3.1"/>
        <point x="21.45" y="6.2"/>
      </controlPoints>
      <firstPoint x="8.45" y="3.1"/>
      <secondPoint x="21.45" y="6.2"/>
      <boardColor hex="999999"/>
      <borderColor hex="ada47d"/>
      <coordinateColor hex="b6b6b6"/>
      <drawCoordinates>true</drawCoordinates>
      <mode>TwoPoints</mode>
      <type>SQUARE</type>
    </diylc.boards.BlankBoard>
      <name>W4</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.15" y="8.7"/>
        <point x="21.75" y="8.65"/>
      </controlPoints2>
      <color hex="000000"/>
      <pointCount>TWO</pointCount>
      <style>DOTTED</style>
      <gauge>_28</gauge>
      <name>W4</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.15" y="1.65"/>
        <point x="21.75" y="1.7"/>
      </controlPoints2>
      <gauge>_28</gauge>
      <name>Eyelet1</name>
      <size value="0.2" unit="in"/>
      <color hex="c3e4ed"/>
      <point x="12.55" y="4.4"/>
      <value></value>
      <point x="12.7" y="4.95"/>
      <value></value>
      <point x="14.8" y="4.499999999999999"/>
      <value></value>
      <point x="14.25" y="3.6"/>
      <value></value>
      <point x="12.1" y="5.75"/>
      <value></value>
      <point x="13.3" y="5.75"/>
      <value></value>
      <point x="14.25" y="5.75"/>
      <value></value>
      <point x="15.4" y="5.75"/>
      <value></value>
      <point x="14.8" y="5.75"/>
      <value></value>
      <point x="15.95" y="3.45"/>
      <value></value>
      <point x="17.15" y="3.95"/>
      <value></value>
      <point x="16.349999999999998" y="4.35"/>
      <value></value>
      <point x="16.349999999999998" y="4.95"/>
      <value></value>
      <point x="17.15" y="5.75"/>
      <value></value>
    <diylc.electromechanical.MiniToggleSwitch>
      <name>Power DPST</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="2.4" y="0.7"/>
        <point x="2.6" y="0.7"/>
      </controlPoints>
      <switchType>SPST</switchType>
      <orientation>HORIZONTAL</orientation>
      <spacing value="0.2" unit="in"/>
      <bodyColor hex="000000"/>
      <borderColor hex="236b8e"/>
    </diylc.electromechanical.MiniToggleSwitch>
    <diylc.shapes.Ellipse>
      <name>2A SB Fuse &amp; Holder</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="4.65" y="9.1"/>
        <point x="4.05" y="9.7"/>
      </controlPoints>
      <firstPoint x="4.05" y="9.1"/>
      <secondPoint x="4.65" y="9.7"/>
      <color hex="ffffff"/>
      <borderColor hex="000000"/>
      <borderThickness value="0.2" unit="mm"/>
    </diylc.shapes.Ellipse>
    <diylc.shapes.Rectangle>
      <name>Power Transformer</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="1.45" y="3.5"/>
        <point x="4.25" y="5.9"/>
      </controlPoints>
      <firstPoint x="1.45" y="3.5"/>
      <secondPoint x="4.25" y="5.9"/>
      <edgeRadius value="20.0" unit="mm"/>
    </diylc.shapes.Rectangle>
      <name>Eyelet39</name>
      <size value="0.5" unit="in"/>
      <point x="2.85" y="4.7"/>
      <value></value>
      <point x="0.75" y="9.25"/>
      <value></value>
    <diylc.passive.AxialFilmCapacitor>
      <name>.02uF  600V Bass</name>
      <alpha>127</alpha>
      <length value="0.73" unit="in"/>
      <width value="0.29" unit="in"/>
      <points>
        <point x="17.15" y="4.85"/>
      </points>
      <bodyColor hex="ffcc00"/>
      <borderColor hex="666666"/>
      <leadColor hex="cccccc"/>
      <display>NAME</display>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>false</moveLabel>
      <value value="0.02" unit="uF"/>
      <voltage>_63V</voltage>
      <voltageNew value="600.0" unit="V"/>
      <showOuterFoil>true</showOuterFoil>
      <outerFoilColor hex="000000"/>
    </diylc.passive.AxialFilmCapacitor>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.7" y="3.9999999999999996"/>
      <text>PI Tail</text>
      <font name="Tahoma" size="14" style="0"/>
      <center>false</center>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
      <orientation>DEFAULT</orientation>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.5" y="4.65"/>
      <text>Treble</text>
      <verticalAlignment>TOP</verticalAlignment>
      <orientation>_270</orientation>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.6" y="5.45"/>
      <text>V4B Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.9" y="5.2"/>
      <text>PI Cathode</text>
      <horizontalAlignment>RIGHT</horizontalAlignment>
    </diylc.misc.Label>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.55" y="7.7"/>
        <point x="16.5" y="7.8"/>
        <point x="16.6" y="7.85"/>
        <point x="16.7" y="7.8"/>
      </controlPoints2>
      <pointCount>FOUR</pointCount>
      <gauge>_22</gauge>
      <name>V4 12AX7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <angle>320</angle>
      <controlPoints>
        <point x="13.85" y="7.6"/>
        <point x="14.095" y="7.58"/>
        <point x="14.055" y="7.73"/>
        <point x="13.94" y="7.825"/>
        <point x="13.79" y="7.84"/>
        <point x="13.66" y="7.755"/>
        <point x="13.6" y="7.615"/>
        <point x="13.64" y="7.465"/>
        <point x="13.755" y="7.37"/>
        <point x="13.905" y="7.355"/>
      </controlPoints>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.65" y="6.6"/>
        <point x="13.7" y="6.9"/>
        <point x="13.75" y="7.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.65" y="7.75"/>
        <point x="13.6" y="7.85"/>
        <point x="13.7" y="7.9"/>
        <point x="13.8" y="7.85"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="16.75" y="8.2"/>
      <text>V3  12AX7</text>
      <font name="Tahoma" size="34" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="16.9" y="7.2"/>
      <text>Fil 1</text>
      <font name="Tahoma" size="24" style="0"/>
      <color hex="009900"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="16.55" y="7.9"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="13.95" y="7.25"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="13.65" y="7.95"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.connectivity.Jumper>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="13.9" y="7.85"/>
        <point x="13.8" y="7.35"/>
      </points>
      <bodyColor hex="ffffff"/>
    </diylc.connectivity.Jumper>
      <name>W59</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.65" y="9.45"/>
        <point x="2.2" y="9.45"/>
        <point x="1.7" y="9.0"/>
        <point x="1.9" y="8.7"/>
        <point x="2.1" y="8.4"/>
        <point x="3.0" y="6.75"/>
        <point x="4.7" y="5.4"/>
      </controlPoints2>
      <pointCount>SEVEN</pointCount>
      <gauge>_18</gauge>
      <name>W60</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.35" y="9.35"/>
        <point x="1.4" y="9.4"/>
        <point x="1.6" y="9.45"/>
      </controlPoints2>
      <gauge>_16</gauge>
    <diylc.passive.PotentiometerPanel>
      <name>OD Gain</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="19.05" y="0.45"/>
        <point x="18.75" y="0.45"/>
        <point x="18.45" y="0.45"/>
      </controlPoints>
      <resistance value="500.0" unit="K"/>
      <orientation>_180</orientation>
      <taper>LOG</taper>
      <bodyDiameter value="1.0" unit="in"/>
      <spacing value="0.3" unit="in"/>
      <lugDiameter value="0.15" unit="in"/>
      <bodyColor hex="c0c0c0"/>
      <borderColor hex="808080"/>
      <nutColor hex="cbd5db"/>
      <waferColor hex="cd8500"/>
      <type>ThroughHole</type>
      <showShaft>false</showShaft>
      <view>ShaftDown</view>
    </diylc.passive.PotentiometerPanel>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="16.75" y="8.4"/>
      <text>OD Preamp 4 &amp; Tone Stack Buffer</text>
      <font name="Tahoma" size="22" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="2.55" y="9.35"/>
      <text>Black = Hot</text>
      <font name="Tahoma" size="18" style="0"/>
      <horizontalAlignment>LEFT</horizontalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="2.4" y="9.55"/>
      <text>Green = Safety Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.1" y="4.45"/>
      <text>6.3V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.6" y="8.5"/>
      <text>To All 6.3V</text>
      <font name="Tahoma" size="20" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.6" y="8.6"/>
      <text>Fil</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.35" y="9.15"/>
      <text>Tip</text>
    </diylc.misc.Label>
      <point x="10.05" y="7.2"/>
      <point x="16.75" y="3.95"/>
      <value></value>
      <point x="13.75" y="5.05"/>
      <value></value>
      <point x="15.95" y="4.6"/>
      <value></value>
      <point x="15.4" y="3.95"/>
      <value></value>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="4.35" y="9.85"/>
      <text>2A Slow Blow Fuse</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.8" y="9.9"/>
      <text>mOOn Amplification version of the SLO-50  V1.0</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="2.05" y="9.7"/>
      <text>White = Neutral</text>
    </diylc.misc.Label>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.9" y="5.4"/>
        <point x="16.75" y="5.25"/>
        <point x="16.75" y="5.1"/>
      </controlPoints2>
      <color hex="cccccc"/>
      <gauge>_26</gauge>
      <name>Mid</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="15.4" y="0.45"/>
        <point x="15.1" y="0.45"/>
        <point x="14.8" y="0.45"/>
      </controlPoints>
      <resistance value="25.0" unit="K"/>
      <taper>LIN</taper>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="0.75" y="9.7"/>
      <text>Power Cord</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="21.7" y="9.15"/>
      <text>Black line on caps indicates outer foil</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.75" y="5.55"/>
      <text>Tone Slope</text>
    </diylc.misc.Label>
    <diylc.connectivity.Dot>
      <name>Dot4</name>
      <size value="1.0" unit="mm"/>
    </diylc.connectivity.Dot>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.8" y="6.65"/>
        <point x="13.25" y="7.55"/>
        <point x="13.55" y="7.5"/>
      </controlPoints2>
      <color hex="ffff00"/>
      <gauge>_22</gauge>
      <name>OD MV</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="10.4" y="0.45"/>
        <point x="10.1" y="0.45"/>
        <point x="9.8" y="0.45"/>
      </controlPoints>
      <resistance value="1.0" unit="M"/>
      <taper>LOG</taper>
      <name>Dot4</name>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.9" y="7.8"/>
        <point x="16.349999999999998" y="6.8"/>
        <point x="16.599999999999998" y="7.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>.02uF  600V Coupling</name>
      <alpha>127</alpha>
      <length value="1.02" unit="in"/>
      <points>
        <point x="15.4" y="4.85"/>
      </points>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.7" y="5.45"/>
      <text>PI Plate Loads</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.7" y="4.800000000000001"/>
      <text>(B+3)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.55" y="5.35"/>
      <text>Primary</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.0" y="4.050000000000001"/>
      <text>NFB</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.2" y="5.15"/>
      <text>V3A Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.55" y="3.85"/>
      <text>V3B Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.05" y="5.45"/>
      <text>V4A Grid Leak</text>
    </diylc.misc.Label>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.2" y="8.3"/>
        <point x="5.05" y="8.35"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>Dot4</name>
      <name>Dot4</name>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.3" y="8.35"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.75" y="8.35"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="13.85" y="8.25"/>
      <text>V4  12AX7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="13.85" y="8.45"/>
      <text>LTP Phase Inverter</text>
    </diylc.misc.Label>
      <name>.1uF  200V AC Shunt</name>
      <alpha>127</alpha>
      <length value="0.85" unit="in"/>
      <points>
        <point x="14.25" y="4.675000000000001"/>
      </points>
      <hideShortLeads>false</hideShortLeads>
      <value value="0.1" unit="uF"/>
      <voltageNew value="200.0" unit="V"/>
      <name>Presence</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="6.95" y="0.45"/>
        <point x="6.65" y="0.45"/>
        <point x="6.35" y="0.45"/>
      </controlPoints>
      <taper>LIN</taper>
      <bodyColor hex="cccccc"/>
      <name>W39</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.15" y="0.8"/>
        <point x="7.2" y="0.7"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.05" y="0.6"/>
        <point x="5.95" y="0.45"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.GroundSymbol>
      <name>GND2</name>
      <point x="6.55" y="1.5"/>
      <size value="0.15" unit="in"/>
      <type>DEFAULT</type>
    </diylc.misc.GroundSymbol>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.5" y="0.25"/>
      <text>Input Jacks</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="6.35" y="0.65"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="6.65" y="0.65"/>
      <text>2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="6.95" y="0.65"/>
      <text>3</text>
    </diylc.misc.Label>
      <name>Bass</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="12.1" y="0.45"/>
        <point x="11.8" y="0.45"/>
        <point x="11.5" y="0.45"/>
      </controlPoints>
      <taper>LOG</taper>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.65" y="0.3"/>
      <text>Use Star Washer On Presence Pot</text>
    </diylc.misc.Label>
      <point x="19.45" y="3.45"/>
      <value></value>
      <point x="19.7" y="4.7"/>
      <value></value>
      <point x="19.25" y="4.7"/>
      <value></value>
      <point x="17.599999999999998" y="5.4"/>
      <value></value>
      <point x="18.4" y="5.4"/>
      <value></value>
      <point x="18.95" y="5.9"/>
      <value></value>
      <point x="19.349999999999998" y="5.9"/>
      <value></value>
      <point x="17.599999999999998" y="3.6"/>
      <value></value>
      <point x="18.4" y="3.45"/>
      <value></value>
      <point x="18.95" y="4.300000000000001"/>
      <value></value>
      <point x="16.75" y="3.6"/>
      <value></value>
      <point x="9.399999999999999" y="5.7"/>
      <value></value>
      <point x="12.1" y="3.6"/>
      <value></value>
      <point x="13.3" y="3.6"/>
      <value></value>
      <point x="12.85" y="4.4"/>
      <value></value>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="9.3" y="7.2"/>
      <text>Output Transformer</text>
    </diylc.misc.Label>
    <diylc.electromechanical.OpenJack1__4>
      <name>Clean Input Jack 12A</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="20.4" y="0.85"/>
        <point x="19.535" y="0.85"/>
        <point x="19.965" y="0.6"/>
      </controlPoints>
      <angle>60</angle>
      <type>SWITCHED</type>
      <showLabels>true</showLabels>
    </diylc.electromechanical.OpenJack1__4>
      <name>OD Input Jack 12A</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="21.45" y="0.85"/>
        <point x="20.585" y="0.85"/>
        <point x="21.015" y="0.6"/>
      </controlPoints>
      <angle>60</angle>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.2" y="0.5"/>
        <point x="21.1" y="0.45"/>
        <point x="21.0" y="0.6"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.connectivity.TwistedWire>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.0" y="8.35"/>
        <point x="1.1" y="4.1"/>
        <point x="1.7" y="4.25"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="00ff00"/>
      <stripeColor2 hex="ff00ff"/>
      <stripe1>false</stripe1>
      <stripe2>false</stripe2>
    </diylc.connectivity.TwistedWire>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.0" y="8.4"/>
        <point x="0.8" y="8.75"/>
        <point x="4.45" y="8.45"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="009900"/>
      <name>Treble</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="17.25" y="0.45"/>
        <point x="16.95" y="0.45"/>
        <point x="16.65" y="0.45"/>
      </controlPoints>
      <resistance value="250.0" unit="K"/>
      <taper>LIN</taper>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.85" y="0.2"/>
        <point x="15.8" y="0.2"/>
      </controlPoints2>
      <color hex="ffcc33"/>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.4" y="0.8"/>
        <point x="14.7" y="0.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.75" y="0.35"/>
        <point x="14.8" y="1.3"/>
        <point x="15.0" y="2.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V2 12AX7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <angle>320</angle>
      <controlPoints>
        <point x="18.65" y="7.55"/>
        <point x="18.895" y="7.53"/>
        <point x="18.855" y="7.68"/>
        <point x="18.74" y="7.775"/>
        <point x="18.59" y="7.79"/>
        <point x="18.46" y="7.705"/>
        <point x="18.4" y="7.565"/>
        <point x="18.44" y="7.415"/>
        <point x="18.555" y="7.32"/>
        <point x="18.705" y="7.305"/>
      </controlPoints>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.45" y="7.7"/>
        <point x="18.4" y="7.8"/>
        <point x="18.5" y="7.85"/>
        <point x="18.6" y="7.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Dot4</name>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.8" y="4.550000000000001"/>
        <point x="19.8" y="4.45"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.8" y="3.65"/>
        <point x="19.8" y="3.55"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>Dot4</name>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.95" y="0.7"/>
        <point x="20.6" y="0.85"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="20.2" y="8.2"/>
      <text>V1  12AX7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="18.8" y="7.2"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="18.45" y="7.9"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="18.65" y="8.4"/>
      <text>OD Preamp 3 &amp; OD Preamp 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.9" y="7.75"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.85" y="7.45"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.8" y="7.9"/>
      <text>Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="20.3" y="7.65"/>
      <text>A</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="20.1" y="7.45"/>
      <text>B</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="19.4" y="4.300000000000001"/>
      <text>V2B Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="19.55" y="4.300000000000001"/>
      <text>V2A Cathode</text>
    </diylc.misc.Label>
    <diylc.passive.Resistor>
      <name>Input</name>
      <alpha>127</alpha>
      <length value="0.4" unit="in"/>
      <width value="0.13" unit="in"/>
      <points>
        <point x="21.55" y="0.75"/>
        <point x="21.375" y="0.625"/>
      </points>
      <bodyColor hex="82cffd"/>
      <borderColor hex="cc6600"/>
      <display>VALUE</display>
      <value value="1.0" unit="M"/>
      <power>HALF</power>
      <powerNew value="0.5" unit="W"/>
      <colorCode>_4_BAND</colorCode>
      <shape>Standard</shape>
    </diylc.passive.Resistor>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.05" y="1.35"/>
      <text>1 OD</text>
    </diylc.misc.Label>
      <name>.02uF  600v Coupling</name>
      <alpha>127</alpha>
      <points>
        <point x="17.599999999999998" y="4.499999999999999"/>
      </points>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.0" y="5.1"/>
      <text>Plate Bypass</text>
    </diylc.misc.Label>
      <name>.02uF  600v Mid</name>
      <alpha>127</alpha>
      <width value="0.28" unit="in"/>
      <points>
        <point x="16.75" y="4.525"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.4" y="5.75"/>
        <point x="18.3" y="5.75"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.passive.AxialElectrolyticCapacitor>
      <name>Cathode Bypass</name>
      <alpha>127</alpha>
      <length value="0.53" unit="in"/>
      <width value="0.26" unit="in"/>
      <points>
        <point x="19.8" y="4.050000000000001"/>
      </points>
      <bodyColor hex="6666ff"/>
      <borderColor hex="4a4c90"/>
      <labelColor hex="ffffff"/>
      <value value="1.0" unit="uF"/>
      <voltageNew value="25.0" unit="V"/>
      <markerColor hex="333333"/>
      <tickColor hex="ffffff"/>
      <polarized>true</polarized>
    </diylc.passive.AxialElectrolyticCapacitor>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="19.9" y="4.050000000000001"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.5" y="0.55"/>
      <text>Input</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.9" y="0.25"/>
        <point x="20.4" y="0.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.65" y="0.85"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.2" y="0.8"/>
        <point x="19.95" y="0.75"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.25" y="0.6"/>
        <point x="19.15" y="0.55"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <alpha>127</alpha>
      <points>
        <point x="18.95" y="5.1"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.3" y="0.55"/>
        <point x="20.1" y="0.5"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="16.95" y="7.7"/>
        <point x="16.5" y="7.6"/>
        <point x="16.725" y="7.65"/>
      </points>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.15" y="-0.05"/>
        <point x="11.5" y="-0.05"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.9" y="5.9"/>
      <text>Dropping</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="19.5" y="0.55"/>
      <text>Attenuator</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.95" y="4.1"/>
      <text>Tone Stack</text>
      <font name="Tahoma Bold" size="20" style="1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.0" y="1.35"/>
      <text>2 Clean</text>
    </diylc.misc.Label>
      <name>.047uF  600V Coupling</name>
      <alpha>127</alpha>
      <points>
        <point x="12.1" y="4.675000000000001"/>
      </points>
      <value value="0.047" unit="uF"/>
      <alpha>127</alpha>
      <points>
        <point x="13.3" y="4.675000000000001"/>
      </points>
      <name>Legend Metal Film - ignore</name>
      <alpha>127</alpha>
      <length value="9.0" unit="mm"/>
      <width value="3.2" unit="mm"/>
      <points>
        <point x="17.85" y="9.399999999999999"/>
        <point x="18.5" y="9.399999999999999"/>
        <point x="18.175" y="9.399999999999999"/>
      </points>
      <borderColor hex="5b90b1"/>
      <value value="470.0" unit="R"/>
      <power>HALF</power>
      <colorCode>_5_BAND</colorCode>
      <name>Legend Metal Oxide - ignore</name>
      <alpha>127</alpha>
      <length value="12.0" unit="mm"/>
      <width value="4.0" unit="mm"/>
      <points>
        <point x="17.85" y="9.6"/>
        <point x="18.5" y="9.6"/>
        <point x="18.175" y="9.6"/>
      </points>
      <bodyColor hex="d2d7db"/>
      <borderColor hex="b2b7bb"/>
      <power>HALF</power>
      <powerNew value="2.0" unit="W"/>
      <name>Plate Load</name>
      <alpha>127</alpha>
      <points>
        <point x="18.0" y="5.4"/>
      </points>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="1.0" unit="W"/>
      <alpha>127</alpha>
      <length value="11.0" unit="mm"/>
      <points>
        <point x="16.5" y="7.55"/>
        <point x="17.0" y="7.55"/>
      </points>
      <value value="220.0" unit="K"/>
      <power>HALF</power>
      <name>PI Tail</name>
      <alpha>127</alpha>
      <points>
        <point x="14.525" y="4.050000000000001"/>
      </points>
      <value value="10.0" unit="K"/>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="5.55" y="7.5"/>
      <text>V6 EL84</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.55" y="9.399999999999999"/>
      <text>Metal Film</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.55" y="9.6"/>
      <text>Metal Oxide</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="4.6" y="7.45"/>
      <text>Fil</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="2.05" y="7.9"/>
      <text>6CA4/EZ81</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.55" y="2.05"/>
      <text>SLO-18</text>
      <font name="Tahoma" size="94" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="5.55" y="2.45"/>
      <text>Single Channel SLO 2xEL84</text>
      <font name="Tahoma Bold" size="32" style="1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="2.9" y="3.7"/>
      <text>Power Transformer</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.85" y="4.9"/>
      <text>6.3V Center Tap</text>
    </diylc.misc.Label>
      <name>W15</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.15" y="0.25"/>
        <point x="19.05" y="0.25"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W16</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.6" y="0.25"/>
        <point x="18.7" y="0.25"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L7</name>
      <point x="18.9" y="0.1"/>
      <text>Bright Cap</text>
    </diylc.misc.Label>
      <name>Eyelet4</name>
      <point x="20.9" y="3.45"/>
      <value></value>
      <name>Eyelet5</name>
      <point x="21.15" y="4.7"/>
      <value></value>
      <name>Eyelet6</name>
      <point x="19.95" y="5.9"/>
      <value></value>
      <name>Eyelet7</name>
      <point x="20.3" y="5.4"/>
      <value></value>
      <name>Eyelet8</name>
      <point x="20.85" y="5.9"/>
      <value></value>
      <name>Eyelet9</name>
      <point x="20.3" y="3.45"/>
      <value></value>
      <name>Eyelet10</name>
      <point x="20.85" y="4.15"/>
      <value></value>
      <name>Eyelet11</name>
      <point x="16.349999999999998" y="5.75"/>
      <value></value>
      <name>Eyelet13</name>
      <point x="9.85" y="3.45"/>
      <value></value>
      <name>Eyelet16</name>
      <point x="10.2" y="5.7"/>
      <value></value>
      <name>Eyelet2</name>
      <point x="19.349999999999998" y="5.4"/>
      <value></value>
      <name>Eyelet21</name>
      <point x="18.95" y="3.6"/>
      <value></value>
      <name>Eyelet23</name>
      <point x="13.75" y="3.6"/>
      <value></value>
      <name>V1 12AX7</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <angle>320</angle>
      <controlPoints>
        <point x="20.2" y="7.55"/>
        <point x="20.445" y="7.53"/>
        <point x="20.405" y="7.68"/>
        <point x="20.29" y="7.775"/>
        <point x="20.14" y="7.79"/>
        <point x="20.01" y="7.705"/>
        <point x="19.95" y="7.565"/>
        <point x="19.99" y="7.415"/>
        <point x="20.105" y="7.32"/>
        <point x="20.255" y="7.305"/>
      </controlPoints>
      <name>W14</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.15" y="6.75"/>
        <point x="20.0" y="6.75"/>
        <point x="20.05" y="7.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W17</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.4" y="7.950000000000001"/>
        <point x="19.599999999999998" y="8.4"/>
        <point x="19.9" y="7.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.1" y="9.15"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L12</name>
      <point x="5.55" y="2.7"/>
      <text>Overdrive Channel Only, FX Loop and Switching Deleted</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L3</name>
      <point x="20.45" y="7.35"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L17</name>
      <point x="20.25" y="7.25"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L18</name>
      <point x="19.85" y="7.4"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L19</name>
      <point x="19.85" y="7.6"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L20</name>
      <point x="18.65" y="8.2"/>
      <text>V2  12AX7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L21</name>
      <point x="20.2" y="8.4"/>
      <text>OD Preamp 1</text>
    </diylc.misc.Label>
      <name>W22</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.25" y="4.6"/>
        <point x="21.25" y="4.45"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W23</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.25" y="3.7"/>
        <point x="21.25" y="3.55"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <alpha>127</alpha>
      <points>
        <point x="21.635" y="-5.825"/>
      </points>
    <diylc.misc.Label>
      <name>L30</name>
      <point x="21.35" y="4.050000000000001"/>
      <text>Cathode Bypass</text>
    </diylc.misc.Label>
      <name>Grid Stopper</name>
      <alpha>127</alpha>
      <points>
        <point x="19.849999999999998" y="7.1"/>
        <point x="19.9" y="6.5"/>
      </points>
      <value value="68.0" unit="K"/>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.9" y="7.2"/>
        <point x="19.9" y="7.35"/>
        <point x="20.0" y="7.4"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <alpha>127</alpha>
      <points>
        <point x="21.69" y="14.38"/>
      </points>
      <name>16uF 475V MOD</name>
      <alpha>127</alpha>
      <length value="1.0" unit="in"/>
      <width value="0.52" unit="in"/>
      <points>
        <point x="21.27" y="-4.920000000000021"/>
      </points>
      <bodyColor hex="666666"/>
      <value value="10.0" unit="uF"/>
      <voltageNew value="450.0" unit="V"/>
      <alpha>127</alpha>
      <length value="13.0" unit="mm"/>
      <points>
        <point x="27.65" y="11.83"/>
      </points>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="19.8" y="6.6"/>
      <text>Grid Stopper</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L32</name>
      <point x="20.4" y="5.85"/>
      <text>V1A Plate Load 1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L33</name>
      <point x="20.3" y="5.25"/>
      <text>(B+5)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L34</name>
      <point x="20.3" y="4.9"/>
      <text>B+5 Filter</text>
    </diylc.misc.Label>
      <name>W10</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.95" y="6.6"/>
        <point x="19.0" y="7.15"/>
        <point x="18.849999999999998" y="7.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L35</name>
      <point x="20.8" y="7.7"/>
      <text>V1A Not Used</text>
    </diylc.misc.Label>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.65" y="6.3"/>
        <point x="17.7" y="7.950000000000001"/>
        <point x="16.8" y="7.7"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.5" y="3.95"/>
        <point x="16.4" y="6.6"/>
        <point x="16.5" y="7.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Cathode</name>
      <alpha>127</alpha>
      <points>
        <point x="16.474999999999998" y="-4.754999999999979"/>
      </points>
      <value value="22.0" unit="K"/>
      <power>HALF</power>
      <name>Tone Slope</name>
      <alpha>127</alpha>
      <points>
        <point x="5.7350000000000065" y="7.660000000000005"/>
      </points>
      <value value="47.0" unit="K"/>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L11</name>
      <point x="17.95" y="3.75"/>
      <text>V3B Grid Leak</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.95" y="3.35"/>
        <point x="16.7" y="1.85"/>
        <point x="16.599999999999998" y="0.35"/>
      </controlPoints2>
      <color hex="996600"/>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.2" y="0.35"/>
        <point x="17.55" y="1.9"/>
        <point x="16.95" y="2.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.55" y="0.75"/>
        <point x="21.05" y="2.4"/>
        <point x="21.15" y="3.45"/>
      </controlPoints2>
      <gauge>_20</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.6" y="1.2"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.6" y="1.1"/>
      <text>Chassis</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.6" y="1.0"/>
      <text>Amp</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.9" y="1.55"/>
      <text>Use Star Washer On OD Input</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L14</name>
      <point x="21.5" y="1.9"/>
      <text>RG174</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L15</name>
      <point x="19.65" y="1.9"/>
      <text>RG174</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L16</name>
      <point x="18.65" y="1.9"/>
      <text>RG174</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.0" y="4.45"/>
        <point x="4.8" y="4.6"/>
      </controlPoints2>
      <color hex="ff0000"/>
      <gauge>_18</gauge>
      <striped>true</striped>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.85" y="4.5"/>
      <text>HV Center Tap</text>
    </diylc.misc.Label>
      <name>15K 1W</name>
      <alpha>127</alpha>
      <points>
        <point x="10.63" y="5.525000000000001"/>
      </points>
      <value value="15.0" unit="K"/>
      <power>HALF</power>
      <name>W19</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.3" y="5.25"/>
        <point x="18.2" y="5.25"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W20</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.75" y="5.25"/>
        <point x="17.849999999999998" y="5.25"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <alpha>127</alpha>
      <points>
        <point x="21.01" y="23.505"/>
      </points>
      <value value="1.8" unit="K"/>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="4.480000000000007" y="22.275"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="-1.1500000000000046" y="15.864999999999991"/>
      </points>
      <value value="39.0" unit="K"/>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L48</name>
      <point x="19.75" y="5.55"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.4" y="5.25"/>
      <text>(B+4)</text>
    </diylc.misc.Label>
      <name>Cathode/Attenuator</name>
      <alpha>127</alpha>
      <points>
        <point x="5.46" y="0.6799999999999988"/>
      </points>
      <value value="82.0" unit="K"/>
      <power>HALF</power>
      <name>Grid Leak</name>
      <alpha>127</alpha>
      <points>
        <point x="18.3" y="3.6"/>
        <point x="16.509999999999998" y="9.015"/>
      </points>
      <value value="300.0" unit="K"/>
      <power>HALF</power>
      <name>Grid Stop</name>
      <alpha>127</alpha>
      <points>
        <point x="25.95499999999999" y="-2.08"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="10.259999999999998" y="-4.749999999999999"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="15.11" y="8.33"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="21.345" y="-1.2900000000000011"/>
      </points>
      <power>HALF</power>
      <name>PI Cathode</name>
      <alpha>127</alpha>
      <points>
        <point x="18.465" y="-3.495"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="6.74979999999999" y="13.138599999999997"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="18.902599999999993" y="12.951800000000016"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="15.855000000000002" y="16.590000000000003"/>
      </points>
      <value value="470.0" unit="K"/>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="8.855" y="-0.9499999999999988"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="0.7712846255040426" y="-3.2687633333169646"/>
      </points>
      <value value="4.7" unit="K"/>
      <power>HALF</power>
      <name>Treble Peaker</name>
      <alpha>127</alpha>
      <points>
        <point x="18.855" y="-7.06"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="19.099999999999998" y="7.25"/>
        <point x="17.909999999999968" y="16.83499999999999"/>
      </points>
      <power>HALF</power>
      <name>W40</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.15" y="7.35"/>
        <point x="19.1" y="7.55"/>
        <point x="18.85" y="7.7"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L49</name>
      <point x="17.849999999999998" y="5.4"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L50</name>
      <point x="18.55" y="5.55"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L51</name>
      <point x="16.25" y="3.9"/>
      <text>Cathode/Attenuator</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L52</name>
      <point x="16.85" y="7.45"/>
      <text>V3B Plate Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L53</name>
      <point x="18.25" y="8.55"/>
      <text>Cold Clipper</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L54</name>
      <point x="14.45" y="3.9"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.8" y="4.7"/>
      <text>LTP PI</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L57</name>
      <point x="12.9" y="5.2"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L58</name>
      <point x="12.5" y="5.2"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L59</name>
      <point x="19.1" y="6.65"/>
    </diylc.misc.Label>
      <name>W24</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.3" y="5.65"/>
        <point x="19.9" y="8.25"/>
        <point x="18.7" y="7.7"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.4" y="6.75"/>
        <point x="18.3" y="6.65"/>
        <point x="18.5" y="7.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <alpha>127</alpha>
      <points>
        <point x="24.635" y="12.725"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="18.5" y="3.6"/>
        <point x="10.1053855912956" y="-0.05964102682974442"/>
      </points>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L29</name>
      <point x="21.3" y="4.4"/>
      <text>V1B Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L60</name>
      <point x="16.6" y="7.55"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.9" y="3.35"/>
      <text>Ground Bus</text>
    </diylc.misc.Label>
      <name>Depth</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="8.6" y="0.45"/>
        <point x="8.3" y="0.45"/>
        <point x="8.0" y="0.45"/>
      </controlPoints>
      <taper>LOG</taper>
    <diylc.misc.Label>
      <name>L61</name>
      <point x="19.05" y="3.9"/>
      <text>Grid Stop/Attenuator</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L62</name>
      <point x="18.7" y="3.75"/>
      <text>V2B Grid Leak</text>
    </diylc.misc.Label>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.250000000000002" y="0.35"/>
        <point x="9.55" y="1.7"/>
        <point x="10.1" y="2.7"/>
        <point x="10.45" y="3.15"/>
      </controlPoints2>
      <color hex="339900"/>
      <gauge>_22</gauge>
      <name>W45</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.55" y="0.35"/>
        <point x="10.85" y="2.6"/>
        <point x="12.65" y="2.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.passive.RadialFilmCapacitor>
      <name>Depth Poly</name>
      <alpha>127</alpha>
      <length value="0.32" unit="in"/>
      <width value="0.125" unit="in"/>
      <points>
        <point x="8.35" y="0.25"/>
        <point x="8.5" y="0.25"/>
        <point x="17.725" y="0.25"/>
      </points>
      <borderColor hex="b25900"/>
      <value value="0.0047" unit="uF"/>
      <showOuterFoil>false</showOuterFoil>
      <outerFoilColor hex="ffffff"/>
      <pinSpacing value="0.1" unit="in"/>
    </diylc.passive.RadialFilmCapacitor>
      <name>W46</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.7" y="0.25"/>
        <point x="8.6" y="0.25"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W47</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.15" y="0.25"/>
        <point x="8.25" y="0.25"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>.1uF 100V Depth</name>
      <alpha>127</alpha>
      <length value="0.8" unit="in"/>
      <points>
        <point x="13.75" y="4.325"/>
      </points>
      <moveLabel>true</moveLabel>
      <voltageNew value="100.0" unit="V"/>
    <diylc.misc.Label>
      <name>L67</name>
      <point x="8.45" y="0.1"/>
      <text>Depth</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.9" y="0.35"/>
        <point x="7.3" y="1.6"/>
        <point x="14.1" y="3.05"/>
      </controlPoints2>
      <color hex="ff6633"/>
      <gauge>_22</gauge>
      <name>W48</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.25" y="3.6"/>
        <point x="18.349999999999998" y="3.6"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L70</name>
      <point x="18.0" y="5.55"/>
      <text>V2B Plate Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.099999999999998" y="3.7"/>
      <text>V3B Grid Stop</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L71</name>
      <point x="12.7" y="5.65"/>
      <text>PI Snubber</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L75</name>
      <point x="18.55" y="5.4"/>
      <text>350V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L76</name>
      <point x="20.5" y="5.4"/>
      <text>363V</text>
    </diylc.misc.Label>
      <name>W18</name>
      <alpha>30</alpha>
      <controlPoints2>
        <point x="10.95" y="3.8"/>
        <point x="10.75" y="5.4"/>
        <point x="10.95" y="6.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Eyelet3</name>
      <point x="17.5" y="5.75"/>
      <value></value>
      <name>Eyelet14</name>
      <point x="10.2" y="3.45"/>
      <value></value>
      <name>Eyelet12</name>
      <point x="9.399999999999999" y="3.45"/>
      <value></value>
      <point x="11.2" y="5.7"/>
      <value></value>
      <point x="11.2" y="3.45"/>
      <value></value>
      <name>Eyelet15</name>
      <point x="12.7" y="3.45"/>
      <value></value>
      <name>W3</name>
      <alpha>50</alpha>
      <controlPoints2>
        <point x="15.85" y="6.4"/>
        <point x="14.15" y="6.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>15K 1W</name>
      <alpha>127</alpha>
      <points>
        <point x="17.9" y="5.75"/>
      </points>
      <power>HALF</power>
      <name>W33</name>
      <alpha>50</alpha>
      <controlPoints2>
        <point x="19.099999999999998" y="5.75"/>
        <point x="17.4" y="5.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.95" y="7.45"/>
        <point x="17.5" y="7.3"/>
        <point x="17.55" y="6.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.599999999999998" y="6.5"/>
        <point x="17.7" y="7.6"/>
        <point x="18.349999999999998" y="7.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <alpha>127</alpha>
      <points>
        <point x="18.675" y="5.65"/>
      </points>
      <power>HALF</power>
      <name>W41</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.65" y="6.2"/>
        <point x="18.05" y="7.15"/>
        <point x="18.4" y="7.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.55" y="5.85"/>
      <text>V2A Plate Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L38</name>
      <point x="13.5" y="9.45"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L43</name>
      <point x="13.5" y="9.55"/>
      <text>Weber W404248</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L66</name>
      <point x="13.5" y="9.649999999999999"/>
      <text>4K:2, 4, 8 Ohm 40W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L80</name>
      <point x="13.5" y="8.85"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L81</name>
      <point x="13.5" y="9.05"/>
      <text>340-0-340VAC 50mA</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="6.0" y="6.45"/>
    </diylc.misc.Label>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.45" y="5.0"/>
        <point x="1.55" y="5.75"/>
        <point x="2.05" y="7.15"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="ff0000"/>
      <stripeColor hex="ffffff"/>
      <stripeColor2 hex="ffffff"/>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.85" y="4.75"/>
        <point x="4.35" y="4.65"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W42</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.1" y="0.55"/>
        <point x="8.2" y="0.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>NFB</name>
      <alpha>127</alpha>
      <points>
        <point x="7.0950000000000015" y="-4.56"/>
      </points>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L82</name>
      <point x="13.5" y="8.95"/>
      <text>Weber W025130</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L13</name>
      <point x="19.9" y="7.75"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L84</name>
      <text>1W</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.15" y="3.3"/>
        <point x="16.099999999999998" y="1.35"/>
        <point x="15.05" y="0.35"/>
      </controlPoints2>
      <color hex="0000ff"/>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.95" y="3.05"/>
        <point x="13.35" y="2.35"/>
        <point x="10.05" y="0.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.65" y="2.65"/>
        <point x="10.55" y="0.9"/>
        <point x="9.750000000000002" y="0.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Speaker Jack 12A</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="11.2" y="9.05"/>
        <point x="10.335" y="9.05"/>
        <point x="10.765" y="8.8"/>
      </controlPoints>
      <angle>60</angle>
      <name>W13</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.75" y="8.8"/>
        <point x="10.5" y="8.95"/>
        <point x="10.35" y="9.05"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L23</name>
      <text>Hole</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L85</name>
      <point x="14.8" y="5.3"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L86</name>
      <point x="16.349999999999998" y="5.5"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L87</name>
      <point x="16.2" y="4.35"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L88</name>
      <point x="19.349999999999998" y="3.9"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L89</name>
      <point x="19.55" y="3.9"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L90</name>
      <point x="21.0" y="3.9"/>
      <text>1W</text>
    </diylc.misc.Label>
      <name>W8</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.85" y="8.25"/>
        <point x="9.75" y="8.4"/>
        <point x="9.35" y="8.8"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.8" y="8.8"/>
        <point x="10.2" y="8.25"/>
        <point x="10.15" y="7.7"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W31</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.75" y="4.550000000000001"/>
        <point x="15.75" y="4.4"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W49</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.75" y="3.65"/>
        <point x="15.75" y="3.5"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <alpha>127</alpha>
      <points>
        <point x="6.259999999999999" y="-5.664999999999999"/>
      </points>
    <diylc.misc.Label>
      <name>L91</name>
      <point x="10.55" y="8.75"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L92</name>
      <point x="15.95" y="4.2"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L94</name>
      <point x="20.3" y="4.749999999999999"/>
      <text>+</text>
      <font name="Tahoma" size="48" style="0"/>
      <color hex="f0f0f0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L95</name>
      <point x="21.25" y="4.2"/>
      <text>+</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L96</name>
      <point x="19.8" y="4.2"/>
      <text>+</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.35" y="7.1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.35" y="7.35"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.3" y="7.6"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L42</name>
      <point x="15.85" y="3.9999999999999996"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L97</name>
      <point x="15.75" y="4.15"/>
      <text>+</text>
    </diylc.misc.Label>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.75" y="6.9"/>
        <point x="14.4" y="7.2"/>
        <point x="14.05" y="7.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.6" y="6.3"/>
        <point x="14.7" y="7.950000000000001"/>
        <point x="14.0" y="7.65"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.85" y="7.25"/>
        <point x="13.35" y="6.4"/>
        <point x="13.6" y="7.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W50</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.95" y="0.45"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>Legend - ignore</name>
      <alpha>127</alpha>
      <points>
        <point x="17.85" y="9.2"/>
        <point x="18.5" y="9.2"/>
        <point x="27.475000000000005" y="9.200000000000003"/>
      </points>
      <name>Aux Speaker 11</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="11.55" y="9.000000000000002"/>
        <point x="11.959190199673992" y="8.822079037465617"/>
        <point x="12.432290556722599" y="9.348433211335657"/>
      </controlPoints>
      <angle>310</angle>
      <type>MONO</type>
      <name>W54</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.35" y="9.0"/>
        <point x="11.45" y="8.95"/>
        <point x="11.55" y="9.0"/>
      </controlPoints2>
      <gauge>_20</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.5" y="5.95"/>
      <text>(B+3)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L98</name>
      <point x="20.45" y="5.5"/>
      <text>1W</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L31</name>
      <point x="18.55" y="9.2"/>
      <text>Poly Cap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L68</name>
      <point x="18.55" y="9.0"/>
      <text>Ceramic Cap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L101</name>
      <point x="21.7" y="9.05"/>
      <text>All resistors 1/2 watt 1% unless specified</text>
    </diylc.misc.Label>
      <name>W29</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.0" y="6.25"/>
        <point x="11.15" y="6.75"/>
        <point x="11.85" y="8.2"/>
        <point x="11.95" y="8.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>.1uF 100V</name>
      <alpha>127</alpha>
      <points>
        <point x="6.3" y="1.05"/>
      </points>
    <diylc.passive.RadialCeramicDiskCapacitor>
      <name>Plate Bypass</name>
      <alpha>127</alpha>
      <length value="0.35" unit="in"/>
      <points>
        <point x="18.025" y="5.25"/>
      </points>
      <bodyColor hex="f0e68c"/>
      <borderColor hex="a8a162"/>
      <value value="0.001" unit="uF"/>
      <voltageNew value="600.0"/>
    </diylc.passive.RadialCeramicDiskCapacitor>
      <alpha>127</alpha>
      <points>
        <point x="17.85" y="9.0"/>
        <point x="18.5" y="9.0"/>
        <point x="18.175" y="9.0"/>
      </points>
      <name>PI Snubber</name>
      <alpha>127</alpha>
      <points>
        <point x="12.7" y="5.75"/>
      </points>
      <value value="47.0" unit="pF"/>
      <name>Bright Cap</name>
      <alpha>127</alpha>
      <points>
        <point x="18.875" y="0.25"/>
      </points>
      <alpha>127</alpha>
      <points>
        <point x="19.6" y="0.675"/>
      </points>
      <value value="0.002" unit="uF"/>
      <name>Treble</name>
      <alpha>127</alpha>
      <points>
        <point x="16.349999999999998" y="4.65"/>
      </points>
      <value value="470.0" unit="pF"/>
      <name>W48</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.45" y="3.6"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L69</name>
      <point x="19.45" y="0.75"/>
      <text>Treble Peaker</text>
    </diylc.misc.Label>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
      </controlPoints2>
      <gauge>_20</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.45" y="3.6"/>
      <text>Grid Leaks</text>
    </diylc.misc.Label>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.9" y="0.5"/>
        <point x="19.4" y="1.35"/>
        <point x="19.95" y="2.75"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>RG174</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.4" y="0.75"/>
        <point x="21.8" y="1.7"/>
        <point x="20.099999999999998" y="2.9"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>RG174</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.7" y="0.35"/>
        <point x="17.8" y="1.3"/>
        <point x="20.05" y="2.35"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <alpha>127</alpha>
      <points>
        <point x="19.369999999999983" y="-4.919999999999998"/>
      </points>
    <diylc.misc.Label>
      <name>L93</name>
      <point x="18.4" y="4.749999999999999"/>
      <text>+</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.4" y="4.9"/>
      <text>B+4 Filter</text>
    </diylc.misc.Label>
    <diylc.tube.SubminiTube>
      <name>V6</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="5.0" y="7.45"/>
        <point x="5.105" y="7.54"/>
        <point x="5.02" y="7.59"/>
        <point x="4.93" y="7.57"/>
        <point x="4.87" y="7.495"/>
        <point x="4.87" y="7.405"/>
        <point x="4.93" y="7.33"/>
        <point x="5.02" y="7.31"/>
        <point x="5.105" y="7.36"/>
      </controlPoints>
      <bodyColor hex="dddddd"/>
      <folded>false</folded>
      <leadLength value="0.4" unit="in"/>
      <leadArrangement>Circular</leadArrangement>
      <topLead>false</topLead>
      <diameter value="0.4" unit="in"/>
      <length value="1.375" unit="in"/>
      <pinCount>_8</pinCount>
      <leadSpacing value="0.1" unit="in"/>
    </diylc.tube.SubminiTube>
      <name>V5</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="6.65" y="7.45"/>
        <point x="6.755" y="7.54"/>
        <point x="6.67" y="7.59"/>
        <point x="6.58" y="7.57"/>
        <point x="6.52" y="7.495"/>
        <point x="6.52" y="7.405"/>
        <point x="6.58" y="7.33"/>
        <point x="6.67" y="7.31"/>
        <point x="6.755" y="7.36"/>
      </controlPoints>
      <name>V3</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="2.05" y="7.45"/>
        <point x="2.155" y="7.54"/>
        <point x="2.07" y="7.59"/>
        <point x="1.98" y="7.57"/>
        <point x="1.92" y="7.495"/>
        <point x="1.92" y="7.405"/>
        <point x="1.98" y="7.33"/>
        <point x="2.07" y="7.31"/>
        <point x="2.155" y="7.36"/>
      </controlPoints>
      <name>W7</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.55" y="7.15"/>
        <point x="2.5" y="7.7"/>
        <point x="2.15" y="7.55"/>
      </controlPoints2>
      <color hex="ff0033"/>
      <gauge>_22</gauge>
      <name>W43</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.85" y="7.2"/>
        <point x="1.55" y="7.4"/>
        <point x="2.0" y="7.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W55</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.85" y="4.75"/>
        <point x="3.35" y="4.75"/>
        <point x="3.35" y="5.75"/>
        <point x="2.3" y="7.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <color2 hex="ffffff"/>
      <name>W56</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.95" y="7.55"/>
        <point x="1.75" y="8.0"/>
        <point x="1.9" y="7.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W61</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.15" y="7.3"/>
        <point x="1.75" y="7.15"/>
        <point x="1.95" y="7.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W62</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.0" y="7.6"/>
        <point x="1.7" y="8.45"/>
        <point x="0.85" y="4.85"/>
        <point x="1.45" y="2.85"/>
      </controlPoints2>
      <color hex="cc0000"/>
      <gauge>_18</gauge>
      <name>W63</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.7" y="7.45"/>
        <point x="4.75" y="7.4"/>
        <point x="4.8" y="7.45"/>
        <point x="4.85" y="7.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W64</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.75" y="7.5"/>
        <point x="4.8" y="7.55"/>
        <point x="4.85" y="7.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W65</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.35" y="7.45"/>
        <point x="6.4" y="7.4"/>
        <point x="6.45" y="7.45"/>
        <point x="6.5" y="7.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W66</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.4" y="7.5"/>
        <point x="6.45" y="7.55"/>
        <point x="6.5" y="7.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.passive.MultiSectionCapacitor>
      <name>32/32</name>
      <alpha>127</alpha>
      <value>
        <org.diylc.core.measures.Capacitance/>
      </value>
      <voltage value="450.0" unit="V"/>
      <controlPoints>
        <point x="3.6" y="7.1"/>
        <point x="4.01" y="7.51"/>
        <point x="3.19" y="7.51"/>
      </controlPoints>
      <bodyColor hex="6b6dce"/>
      <baseColor hex="333333"/>
      <pinColor hex="759daf"/>
      <display>BOTH</display>
      <diameter value="1.375" unit="in"/>
    </diylc.passive.MultiSectionCapacitor>
      <name>GND3</name>
      <name>W67</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.7" y="5.05"/>
        <point x="3.65" y="6.15"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W68</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.25" y="6.45"/>
        <point x="1.35" y="8.55"/>
        <point x="2.05" y="9.15"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W69</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.8" y="4.8"/>
        <point x="1.15" y="4.65"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W70</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.75" y="4.0"/>
        <point x="2.65" y="0.65"/>
        <point x="3.7" y="0.7"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>Dot1</name>
      <point x="4.35" y="9.25"/>
      <name>Dot2</name>
      <point x="4.35" y="9.5"/>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.65" y="9.6"/>
        <point x="2.45" y="9.0"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W57</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.9" y="8.8"/>
        <point x="1.2" y="8.1"/>
        <point x="0.9" y="4.25"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W25</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.55" y="6.7"/>
        <point x="6.05" y="6.7"/>
        <point x="6.55" y="7.1"/>
        <point x="6.6" y="7.35"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W30</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.3" y="6.6"/>
        <point x="4.65" y="7.0"/>
        <point x="4.95" y="7.35"/>
      </controlPoints2>
      <color hex="663300"/>
      <gauge>_18</gauge>
      <name>W32</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.2" y="7.5"/>
        <point x="3.45" y="6.7"/>
        <point x="4.4" y="6.3"/>
        <point x="5.6" y="6.7"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>RECT1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="2.3" y="0.8"/>
        <point x="2.75" y="1.2"/>
      </controlPoints>
      <firstPoint x="2.3" y="0.8"/>
      <secondPoint x="2.75" y="1.2"/>
      <edgeRadius value="0.0" unit="mm"/>
      <name>SW1</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="3.9" y="0.7"/>
      </controlPoints>
      <name>RECT2</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="3.6" y="0.8"/>
        <point x="4.05" y="1.2"/>
      </controlPoints>
      <firstPoint x="3.6" y="0.8"/>
      <secondPoint x="4.05" y="1.2"/>
      <name>W26</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.4" y="0.7"/>
        <point x="4.4" y="0.65"/>
        <point x="4.4" y="2.1"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W34</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.4" y="2.8"/>
        <point x="2.5" y="3.15"/>
        <point x="1.05" y="3.6"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W35</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.95" y="3.65"/>
        <point x="0.85" y="3.85"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W36</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.1" y="0.75"/>
        <point x="1.9" y="0.7"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W37</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.9" y="7.3"/>
        <point x="5.5" y="5.9"/>
        <point x="4.6" y="3.7"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W58</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.15" y="0.7"/>
        <point x="3.15" y="0.8"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W71</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.7" y="4.1"/>
        <point x="8.7" y="3.85"/>
        <point x="8.899999999999999" y="3.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W72</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.95" y="5.7"/>
        <point x="8.7" y="5.35"/>
        <point x="8.7" y="5.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W75</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.65" y="5.3"/>
        <point x="8.250000000000002" y="3.6499999999999995"/>
        <point x="8.649999999999999" y="3.5"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>125 5W</name>
      <alpha>127</alpha>
      <length value="22.0" unit="mm"/>
      <width value="10.0" unit="mm"/>
      <points>
        <point x="8.7" y="4.6"/>
      </points>
      <bodyColor hex="f6f5f5"/>
      <borderColor hex="cccccc"/>
      <value value="125.0" unit="R"/>
      <power>HALF</power>
      <powerNew value="5.0" unit="W"/>
      <shape>Tubular</shape>
      <name>100 3W</name>
      <alpha>127</alpha>
      <length value="16.0" unit="mm"/>
      <width value="6.0" unit="mm"/>
      <points>
        <point x="10.2" y="5.6"/>
        <point x="10.024999999999999" y="4.525"/>
      </points>
      <value value="100.0" unit="R"/>
      <power>HALF</power>
      <powerNew value="3.0" unit="W"/>
      <name>1.5K 5W</name>
      <alpha>127</alpha>
      <points>
        <point x="4.1" y="7.9"/>
        <point x="3.05" y="7.9"/>
        <point x="3.575" y="7.9"/>
      </points>
      <value value="1.5" unit="K"/>
      <power>HALF</power>
      <name>W6</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.0" y="7.5"/>
        <point x="4.05" y="7.65"/>
        <point x="4.1" y="7.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W44</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.15" y="7.6"/>
        <point x="3.05" y="7.7"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W76</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.2" y="3.8"/>
        <point x="7.2" y="4.35"/>
        <point x="5.4" y="5.8"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W77</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.05" y="7.1"/>
        <point x="4.55" y="6.6"/>
        <point x="5.45" y="5.9"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>8.2K 3W</name>
      <alpha>127</alpha>
      <points>
        <point x="10.525" y="4.575"/>
      </points>
      <value value="8.2" unit="K"/>
      <power>HALF</power>
      <name>W38</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.55" y="5.65"/>
        <point x="11.85" y="5.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W78</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.05" y="7.2"/>
        <point x="4.75" y="9.1"/>
        <point x="4.9" y="7.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W81</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.6" y="7.55"/>
        <point x="6.5" y="7.75"/>
        <point x="4.9" y="8.25"/>
        <point x="4.95" y="7.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W82</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.35" y="6.35"/>
        <point x="10.15" y="7.0"/>
        <point x="6.7" y="7.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W83</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.1" y="7.35"/>
        <point x="5.25" y="7.05"/>
        <point x="6.7" y="6.75"/>
        <point x="6.75" y="7.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W84</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.95" y="7.2"/>
        <point x="5.6" y="6.45"/>
        <point x="10.65" y="6.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W85</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.6" y="7.2"/>
        <point x="6.35" y="6.4"/>
        <point x="11.3" y="6.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <alpha>127</alpha>
      <points>
        <point x="12.169999999999984" y="-4.769999999999997"/>
      </points>
      <value value="16.0" unit="uF"/>
      <name>500uF 50V</name>
      <alpha>127</alpha>
      <width value="0.35" unit="in"/>
      <points>
        <point x="10.369999999999983" y="-4.770000000000003"/>
      </points>
      <value value="500.0" unit="uF"/>
      <voltageNew value="50.0" unit="V"/>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="11.246544851311937" y="-1.9236942866291917"/>
      </points>
      <labelColor hex="000000"/>
      <power>HALF</power>
      <name>R2</name>
      <alpha>127</alpha>
      <points>
        <point x="12.9729322603717" y="-2.110092637415986"/>
      </points>
      <power>HALF</power>
    <diylc.electromechanical.RotarySelectorSwitch>
      <name>SW2</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="9.55" y="9.35"/>
        <point x="9.32007882323144" y="8.79492117676856"/>
        <point x="8.765" y="8.565"/>
        <point x="8.209921176768562" y="8.79492117676856"/>
        <point x="6.98" y="9.85"/>
      </controlPoints>
      <positionCount>THREE</positionCount>
    </diylc.electromechanical.RotarySelectorSwitch>
    <diylc.connectivity.HookupWire>
      <name>W73</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.9" y="7.45"/>
        <point x="9.5" y="8.45"/>
        <point x="8.75" y="8.55"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <style>SOLID</style>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_18</gauge>
      <striped>false</striped>
      <stripeColor hex="ffff00"/>
    </diylc.connectivity.HookupWire>
      <name>W74</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.2" y="8.8"/>
        <point x="8.25" y="8.35"/>
        <point x="9.45" y="7.8"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W79</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.95" y="10.15"/>
        <point x="13.55" y="9.9"/>
      </controlPoints2>
      <color hex="0033ff"/>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L55</name>
      <point x="7.2" y="7.5"/>
      <text>V5 EL84</text>
      <color hex="000000"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L28</name>
      <point x="6.25" y="7.45"/>
      <text>Fil</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L10</name>
      <point x="3.8" y="1.3"/>
      <text>Power</text>
      <font name="Dialog.bold" size="22" style="1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L36</name>
      <point x="2.5" y="1.3"/>
      <text>Standby</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L37</name>
      <point x="3.3" y="5.4"/>
      <text>5V</text>
      <font name="Dialog.plain" size="22" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L22</name>
      <point x="2.85" y="3.95"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L24</name>
      <point x="9.3" y="7.35"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L25</name>
      <point x="13.5" y="9.15"/>
      <text>6.3V/5A, 5.0V/3A</text>
      <font name="Dialog.plain" size="14" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L26</name>
      <point x="8.1" y="8.55"/>
      <text>2Ω</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L27</name>
      <point x="8.9" y="8.35"/>
      <text>4Ω</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L39</name>
      <point x="9.45" y="8.5"/>
      <text>8Ω</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L8</name>
      <point x="2.5" y="0.95"/>
      <text>Panel&lt;br&gt;Mount&lt;br&gt;Rocker</text>
      <font reference="../../diylc.misc.Label[158]/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="3.8" y="1.0"/>
      <text>Panel&lt;br&gt;Mount&lt;br&gt;Rocker&lt;br&gt;Lighted</text>
    </diylc.misc.Label>
  </components>
  <groups/>
  <lockedLayers>
    <int>2</int>
  </lockedLayers>
  <lockedComponents/>
  <hiddenLayers/>
</project>
