<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>4</major>
    <minor>20</minor>
    <build>0</build>
  </fileVersion>
  <title>AB763 Deluxe Reverb</title>
  <author>RobRobinette.com</author>
  <description>1963 blackface Deluxe Reverb Tube Guitar Amp</description>
  <width value="22.3" unit="in"/>
  <height value="11.4" unit="in"/>
  <gridSpacing value="0.05" unit="in"/>
  <dotSpacing>1</dotSpacing>
  <components>
    <diylc.connectivity.HookupWire>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.15" y="2.75"/>
        <point x="21.85" y="2.75"/>
      </controlPoints2>
      <color hex="000000"/>
      <pointCount>TWO</pointCount>
      <style>DOTTED</style>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_30</gauge>
      <striped>false</striped>
    </diylc.connectivity.HookupWire>
    <diylc.connectivity.Eyelet>
      <name>Eyelet50</name>
      <size value="0.5" unit="in"/>
      <holeSize value="0.25" unit="in"/>
      <color hex="cccccc"/>
      <point x="15.45" y="10.65"/>
      <value>Jack</value>
    </diylc.connectivity.Eyelet>
    <diylc.connectivity.SolderPad>
      <name>Pad1</name>
      <size value="0.09" unit="in"/>
      <type>ROUND</type>
      <holeSize value="0.8" unit="mm"/>
      <layer>_1</layer>
    </diylc.connectivity.SolderPad>
      <point x="16.55" y="10.65"/>
      <value>Jack</value>
      <name>Pad1</name>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="17.55" y="10.65"/>
      <value>Jack</value>
      <name>Pad1</name>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="14.45" y="10.65"/>
      <value>Jack</value>
      <name>Pad1</name>
      <type>ROUND</type>
      <layer>_1</layer>
    <diylc.electromechanical.MiniToggleSwitch>
      <name>Standby</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="7.7" y="10.55"/>
        <point x="7.7" y="10.75"/>
      </controlPoints>
      <switchType>SPST</switchType>
      <orientation>VERTICAL</orientation>
      <spacing value="0.2" unit="in"/>
      <bodyColor hex="3299cc"/>
      <borderColor hex="236b8e"/>
    </diylc.electromechanical.MiniToggleSwitch>
    <diylc.shapes.Ellipse>
      <name>ELL2</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="6.6" y="10.35"/>
        <point x="7.2" y="10.95"/>
      </controlPoints>
      <firstPoint x="6.6" y="10.35"/>
      <secondPoint x="7.2" y="10.95"/>
      <color hex="ffffff"/>
      <borderColor hex="000000"/>
      <borderThickness value="0.2" unit="mm"/>
    </diylc.shapes.Ellipse>
    <diylc.passive.PotentiometerPanel>
      <name>Bias</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="6.85" y="4.35"/>
        <point x="6.85" y="4.05"/>
        <point x="6.85" y="3.75"/>
      </controlPoints>
      <resistance value="10.0" unit="K"/>
      <orientation>_270</orientation>
      <taper>LIN</taper>
      <bodyDiameter value="1.0" unit="in"/>
      <spacing value="0.3" unit="in"/>
      <lugDiameter value="0.15" unit="in"/>
      <bodyColor hex="c0c0c0"/>
      <borderColor hex="808080"/>
      <nutColor hex="cbd5db"/>
      <waferColor hex="cd8500"/>
      <type>ThroughHole</type>
      <showShaft>true</showShaft>
      <view>ShaftUp</view>
    </diylc.passive.PotentiometerPanel>
    <diylc.shapes.Rectangle>
      <name>Power Transformer</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="1.55" y="4.7"/>
        <point x="4.35" y="7.45"/>
      </controlPoints>
      <firstPoint x="1.55" y="4.7"/>
      <secondPoint x="4.35" y="7.45"/>
      <color hex="333333"/>
      <edgeRadius value="20.0" unit="mm"/>
    </diylc.shapes.Rectangle>
    <diylc.tube.TubeSocket>
      <name>V5</name>
      <alpha>127</alpha>
      <base>OCTAL</base>
      <type>5Y3</type>
      <angle>50</angle>
      <color hex="f7f7ef"/>
      <mount>CHASSIS</mount>
      <controlPoints>
        <point x="2.8" y="8.78"/>
        <point x="2.9" y="9.105"/>
        <point x="2.64" y="9.08"/>
        <point x="2.47" y="8.88"/>
        <point x="2.495" y="8.62"/>
        <point x="2.695" y="8.45"/>
        <point x="2.955" y="8.475"/>
        <point x="3.125" y="8.675"/>
        <point x="3.1" y="8.935"/>
      </controlPoints>
    </diylc.tube.TubeSocket>
    <diylc.boards.BlankBoard>
      <name>Board1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="7.525" y="4.445"/>
        <point x="22.045" y="7.57"/>
      </controlPoints>
      <firstPoint x="7.525" y="4.445"/>
      <secondPoint x="22.045" y="7.57"/>
      <boardColor hex="999999"/>
      <borderColor hex="ada47d"/>
      <coordinateColor hex="b6b6b6"/>
      <drawCoordinates>true</drawCoordinates>
      <coordinateOrigin>Top_Left</coordinateOrigin>
      <length value="14.52" unit="in"/>
      <width value="3.125" unit="in"/>
      <mode>TwoPoints</mode>
      <type>SQUARE</type>
    </diylc.boards.BlankBoard>
      <name>W2</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="16.0" y="4.95"/>
        <point x="16.2" y="5.3"/>
        <point x="16.55" y="5.45"/>
        <point x="17.265" y="6.13"/>
      </controlPoints2>
      <color hex="ffff00"/>
      <pointCount>FOUR</pointCount>
      <style>SOLID</style>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="11.1" y="5.4"/>
        <point x="11.35" y="5.5"/>
        <point x="12.55" y="5.8"/>
        <point x="14.935" y="6.03"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="15.4" y="6.2"/>
        <point x="15.65" y="6.3"/>
        <point x="16.4" y="6.8"/>
        <point x="17.6" y="5.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="17.65" y="5.4"/>
        <point x="17.9" y="5.5"/>
        <point x="17.9" y="6.1"/>
        <point x="20.6" y="6.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Dog House Board</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="0.95" y="0.2"/>
        <point x="5.5" y="2.65"/>
      </controlPoints>
      <firstPoint x="0.95" y="0.2"/>
      <secondPoint x="5.5" y="2.65"/>
      <type>SQUARE</type>
      <name>Bias Board</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="1.45" y="2.85"/>
        <point x="4.37" y="4.095"/>
      </controlPoints>
      <firstPoint x="1.45" y="2.85"/>
      <secondPoint x="4.37" y="4.095"/>
      <type>SQUARE</type>
      <name>Eyelet1</name>
      <size value="0.2" unit="in"/>
      <holeSize value="0.1" unit="in"/>
      <color hex="ffcc00"/>
      <point x="7.87" y="6.185"/>
      <value>Hoffman Eyelet</value>
      <name>Eyelet2</name>
      <point x="7.885" y="6.47"/>
      <name>Eyelet3</name>
      <point x="8.87" y="6.975"/>
      <name>Eyelet4</name>
      <point x="9.25" y="6.19"/>
      <name>Eyelet5</name>
      <point x="9.94" y="6.055"/>
      <name>Eyelet6</name>
      <point x="9.62" y="6.975"/>
      <name>Eyelet7</name>
      <point x="10.25" y="6.975"/>
      <name>Eyelet8</name>
      <point x="10.7" y="6.975"/>
      <name>Eyelet9</name>
      <point x="10.685" y="5.965"/>
      <name>Eyelet10</name>
      <point x="11.105" y="6.195"/>
      <name>Eyelet11</name>
      <point x="11.12" y="6.975"/>
      <name>Eyelet12</name>
      <point x="11.65" y="6.975"/>
      <name>Eyelet13</name>
      <point x="12.27" y="6.975"/>
      <name>Eyelet14</name>
      <point x="12.085" y="6.18"/>
      <name>Eyelet15</name>
      <point x="12.46" y="6.19"/>
      <name>Eyelet16</name>
      <point x="13.1" y="5.985"/>
      <name>Eyelet17</name>
      <point x="13.095" y="6.455"/>
      <name>Eyelet18</name>
      <point x="13.09" y="6.975"/>
      <name>Eyelet19</name>
      <point x="13.94" y="6.975"/>
      <name>Eyelet20</name>
      <point x="14.44" y="6.975"/>
      <name>Eyelet22</name>
      <point x="14.925" y="7.005"/>
      <name>Eyelet23</name>
      <point x="15.87" y="6.975"/>
      <name>Eyelet24</name>
      <point x="16.32" y="6.975"/>
      <name>Eyelet25</name>
      <point x="16.82" y="6.975"/>
      <name>Eyelet26</name>
      <point x="17.27" y="6.975"/>
      <name>Eyelet27</name>
      <point x="18.0" y="6.975"/>
      <name>Eyelet28</name>
      <point x="18.92" y="6.975"/>
      <name>Eyelet29</name>
      <point x="19.36" y="6.975"/>
      <name>Eyelet30</name>
      <point x="19.85" y="6.975"/>
      <name>Eyelet31</name>
      <point x="20.275" y="6.975"/>
      <name>Eyelet32</name>
      <point x="21.0" y="6.975"/>
      <name>Eyelet33</name>
      <point x="21.81" y="6.975"/>
      <name>Eyelet34</name>
      <point x="21.02" y="6.185"/>
      <name>Eyelet35</name>
      <point x="20.63" y="6.18"/>
      <name>Eyelet36</name>
      <point x="21.02" y="5.47"/>
      <name>Eyelet37</name>
      <point x="21.395" y="5.27"/>
      <name>Eyelet38</name>
      <point x="21.82" y="4.975"/>
      <name>Eyelet39</name>
      <point x="20.28" y="4.975"/>
      <name>Eyelet40</name>
      <point x="19.6" y="4.975"/>
      <name>Eyelet41</name>
      <point x="18.94" y="4.975"/>
      <name>Eyelet42</name>
      <point x="18.505" y="5.25"/>
      <name>Eyelet43</name>
      <point x="18.005" y="5.52"/>
      <name>Eyelet44</name>
      <point x="18.005" y="6.185"/>
      <name>Eyelet45</name>
      <point x="17.61" y="6.205"/>
      <name>Eyelet46</name>
      <point x="17.265" y="6.145"/>
      <name>Eyelet47</name>
      <point x="17.25" y="5.615"/>
      <name>Eyelet48</name>
      <point x="17.625" y="5.385"/>
      <name>Eyelet49</name>
      <point x="16.57" y="4.975"/>
      <point x="15.98" y="4.975"/>
      <name>Eyelet51</name>
      <point x="15.5" y="4.975"/>
      <name>Eyelet52</name>
      <point x="15.885" y="5.75"/>
      <name>Eyelet53</name>
      <name>Eyelet54</name>
      <name>Eyelet55</name>
      <point x="14.91" y="5.69"/>
      <name>Eyelet56</name>
      <point x="14.19" y="4.975"/>
      <name>Eyelet57</name>
      <point x="13.825" y="5.21"/>
      <name>Eyelet58</name>
      <point x="13.095" y="5.465"/>
      <name>Eyelet59</name>
      <point x="13.07" y="4.975"/>
      <name>Eyelet60</name>
      <point x="12.46" y="4.975"/>
      <name>Eyelet61</name>
      <point x="12.08" y="4.975"/>
      <name>Eyelet62</name>
      <point x="11.66" y="4.975"/>
      <name>Eyelet63</name>
      <name>Eyelet64</name>
      <point x="10.685" y="5.405"/>
      <name>Eyelet65</name>
      <point x="10.25" y="4.975"/>
      <name>Eyelet66</name>
      <point x="9.62" y="4.975"/>
      <name>Eyelet67</name>
      <point x="9.245" y="5.71"/>
      <name>Eyelet68</name>
      <point x="8.87" y="4.975"/>
      <name>Eyelet69</name>
      <point x="8.35" y="5.0"/>
      <name>Eyelet70</name>
      <point x="8.35" y="5.35"/>
      <name>Eyelet71</name>
      <point x="7.87" y="4.975"/>
      <size value="0.3" unit="in"/>
      <point x="6.47" y="6.8"/>
      <value>Grommet</value>
      <point x="11.12" y="4.2"/>
      <point x="4.65" y="0.4"/>
      <point x="3.9" y="0.4"/>
      <point x="2.95" y="0.4"/>
      <point x="2.2" y="0.4"/>
      <point x="1.45" y="0.4"/>
      <point x="4.65" y="2.4"/>
      <point x="3.9" y="2.4"/>
      <point x="2.95" y="2.4"/>
      <point x="2.2" y="2.4"/>
      <point x="1.45" y="2.4"/>
      <holeSize value="0.19" unit="in"/>
      <point x="3.45" y="2.35"/>
      <point x="5.2" y="0.4"/>
      <point x="1.15" y="0.4"/>
      <point x="17.37" y="4.2"/>
      <point x="21.2" y="6.75"/>
      <holeSize value="0.05" unit="in"/>
      <point x="5.87" y="5.35"/>
      <point x="18.2" y="6.75"/>
      <point x="17.07" y="8.75"/>
      <point x="15.39" y="7.0"/>
      <point x="14.02" y="7.85"/>
      <color hex="c3e4ed"/>
      <point x="2.9" y="6.05"/>
      <value></value>
      <point x="1.35" y="10.5"/>
      <value></value>
      <point x="0.85" y="9.55"/>
      <value>Bolt</value>
      <size value="0.7" unit="in"/>
      <point x="15.0" y="2.2"/>
      <value>Jack</value>
      <point x="15.93" y="2.2"/>
      <value>Jack</value>
      <name>Pad1</name>
      <point x="15.35" y="2.2"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="15.55" y="2.2"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="15.15" y="1.85"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="16.2" y="2.5"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="15.15" y="2.55"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="15.8" y="2.55"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="20.9" y="2.2"/>
      <value>Jack</value>
      <point x="21.83" y="2.2"/>
      <value>Jack</value>
      <name>Pad1</name>
      <point x="21.25" y="2.2"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="21.45" y="2.2"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="21.05" y="1.85"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="22.1" y="2.5"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="21.05" y="2.55"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="21.7" y="2.55"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="3.02" y="3.1"/>
      <point x="1.92" y="3.1"/>
      <point x="2.07" y="3.55"/>
      <point x="3.97" y="3.55"/>
      <point x="3.97" y="3.1"/>
      <name>Pad2</name>
      <point x="0.5" y="2.45"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad2</name>
      <point x="0.75" y="2.45"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <point x="10.75" y="10.6"/>
      <value>Jack</value>
      <point x="11.83" y="10.6"/>
      <value>Jack</value>
      <name>Pad1</name>
      <point x="11.1" y="10.6"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="12.05" y="10.9"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="10.9" y="10.25"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="12.05" y="10.3"/>
      <type>ROUND</type>
      <layer>_1</layer>
      <name>Pad1</name>
      <point x="10.9" y="10.95"/>
      <type>ROUND</type>
      <layer>_1</layer>
    <diylc.passive.RadialCeramicDiskCapacitor>
      <name>C1</name>
      <alpha>127</alpha>
      <length value="0.3" unit="in"/>
      <width value="0.125" unit="in"/>
      <points>
        <point x="21.02" y="5.8275"/>
      </points>
      <bodyColor hex="f0e68c"/>
      <borderColor hex="a8a162"/>
      <labelColor hex="000000"/>
      <leadColor hex="cccccc"/>
      <display>VALUE</display>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>false</moveLabel>
      <pinSpacing value="0.1" unit="in"/>
      <value value="250.0" unit="pF"/>
      <voltage>_63V</voltage>
      <voltageNew value="600.0"/>
    </diylc.passive.RadialCeramicDiskCapacitor>
    <diylc.passive.Resistor>
      <name>R1</name>
      <alpha>127</alpha>
      <length value="0.4" unit="in"/>
      <width value="0.14" unit="in"/>
      <points>
        <point x="21.0" y="6.95"/>
        <point x="20.815" y="6.565"/>
      </points>
      <bodyColor hex="996600"/>
      <borderColor hex="cc6600"/>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="0.5" unit="W"/>
      <colorCode>_4_BAND</colorCode>
      <shape>Tubular</shape>
    </diylc.passive.Resistor>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="20.4525" y="6.5775"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="21.405" y="6.975"/>
      </points>
      <power>HALF</power>
      <name>C1</name>
      <alpha>127</alpha>
      <points>
        <point x="18.005" y="5.8525"/>
      </points>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="18.0" y="6.95"/>
        <point x="17.805000000000003" y="6.5775"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="17.44" y="6.59"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="18.46" y="6.975"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="19.85" y="6.95"/>
        <point x="19.725" y="5.9625"/>
      </points>
      <value value="1.5" unit="K"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="19.35" y="6.95"/>
        <point x="19.475" y="5.9625"/>
      </points>
      <power>HALF</power>
    <diylc.passive.AxialElectrolyticCapacitor>
      <name>25uF  150v</name>
      <alpha>127</alpha>
      <length value="1.0" unit="in"/>
      <width value="0.26" unit="in"/>
      <points>
        <point x="20.0" y="6.415"/>
        <point x="19.9" y="5.465"/>
        <point x="19.95" y="5.94"/>
      </points>
      <bodyColor hex="6666ff"/>
      <borderColor hex="4a4c90"/>
      <labelColor hex="ffff00"/>
      <display>NAME</display>
      <hideShortLeads>false</hideShortLeads>
      <value value="25.0" unit="uF"/>
      <voltageNew value="150.0" unit="V"/>
      <markerColor hex="333333"/>
      <tickColor hex="ffffff"/>
      <polarized>true</polarized>
    </diylc.passive.AxialElectrolyticCapacitor>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.0" y="6.75"/>
        <point x="20.05" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.9" y="5.2"/>
        <point x="19.85" y="5.1"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.65" y="6.95"/>
        <point x="21.4" y="6.8"/>
        <point x="21.4" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <alpha>127</alpha>
      <points>
        <point x="19.225" y="6.395"/>
        <point x="19.325" y="5.445"/>
        <point x="19.275" y="5.92"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.2" y="6.85"/>
        <point x="19.2" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.35" y="5.2"/>
        <point x="19.45" y="5.05"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>C1</name>
      <alpha>127</alpha>
      <points>
        <point x="17.25" y="5.65"/>
        <point x="17.2575" y="5.89"/>
      </points>
      <value value="500.0" unit="pF"/>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="16.695" y="5.975"/>
      </points>
      <value value="820.0" unit="R"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="16.445" y="5.975"/>
      </points>
      <value value="2.2" unit="K"/>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="17.0" y="6.4"/>
        <point x="16.9" y="5.45"/>
        <point x="16.95" y="5.925"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.85" y="5.2"/>
        <point x="16.8" y="5.1"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <alpha>127</alpha>
      <points>
        <point x="16.159999999999997" y="6.37"/>
        <point x="16.26" y="5.42"/>
        <point x="16.21" y="5.895"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.15" y="6.85"/>
        <point x="16.15" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.3" y="5.2"/>
        <point x="16.4" y="5.05"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.95" y="6.75"/>
        <point x="17.0" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="16.91" y="5.295"/>
      </points>
      <value value="1.0" unit="M"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="14.915" y="5.685"/>
        <point x="15.4475" y="5.33"/>
      </points>
      <value value="3.3" unit="M"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="15.205" y="5.3325"/>
      </points>
      <value value="470.0" unit="K"/>
      <power>HALF</power>
      <name>C1</name>
      <alpha>127</alpha>
      <points>
        <point x="15.75" y="5.3"/>
        <point x="15.3" y="5.6"/>
        <point x="15.525" y="5.45"/>
      </points>
      <value value="10.0" unit="pF"/>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.9" y="5.2"/>
      </controlPoints2>
      <pointCount>THREE</pointCount>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.1" y="5.75"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="15.635" y="6.5875"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="14.935" y="6.98"/>
        <point x="15.1675" y="6.59"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="13.1" y="5.45"/>
        <point x="13.8" y="5.2"/>
        <point x="13.45" y="5.325"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="13.1" y="5.95"/>
        <point x="13.8" y="5.25"/>
        <point x="13.45" y="5.6"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="13.435" y="5.0874999999999995"/>
      </points>
      <value value="2.2" unit="M"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="14.45" y="6.95"/>
        <point x="14.32" y="5.9625"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="13.95" y="6.95"/>
        <point x="14.07" y="5.9625"/>
      </points>
      <value value="2.7" unit="K"/>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="14.65" y="6.4"/>
        <point x="14.55" y="5.45"/>
        <point x="14.6" y="5.925"/>
      </points>
      <alpha>127</alpha>
      <points>
        <point x="13.8" y="6.4"/>
        <point x="13.9" y="5.45"/>
        <point x="13.85" y="5.925"/>
      </points>
      <value value="47.0" unit="uF"/>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.8" y="6.85"/>
        <point x="13.8" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.95" y="5.2"/>
        <point x="14.05" y="5.05"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.6" y="6.75"/>
        <point x="14.65" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="14.55" y="5.3325"/>
      </points>
      <value value="220.0" unit="K"/>
      <power>HALF</power>
      <name>C1</name>
      <alpha>127</alpha>
      <points>
        <point x="13.1" y="6.45"/>
        <point x="13.1" y="6.95"/>
        <point x="13.1" y="6.7"/>
      </points>
      <value value="0.02" unit="uF"/>
      <name>C1</name>
      <alpha>127</alpha>
      <points>
        <point x="13.1" y="6.2"/>
      </points>
      <name>C1</name>
      <alpha>127</alpha>
      <points>
        <point x="13.1" y="5.7"/>
      </points>
      <name>ELL1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="12.0" y="5.2"/>
        <point x="12.55" y="5.95"/>
      </controlPoints>
      <firstPoint x="12.0" y="5.2"/>
      <secondPoint x="12.55" y="5.95"/>
      <color hex="666666"/>
    <diylc.connectivity.Jumper>
      <name>J1</name>
      <alpha>127</alpha>
      <points>
        <point x="12.1" y="5.0"/>
        <point x="12.1" y="5.35"/>
        <point x="12.1" y="5.175"/>
      </points>
      <bodyColor hex="ffffff"/>
    </diylc.connectivity.Jumper>
      <name>J1</name>
      <alpha>127</alpha>
      <points>
        <point x="12.45" y="5.0"/>
        <point x="12.45" y="5.35"/>
        <point x="12.45" y="5.175"/>
      </points>
      <name>J1</name>
      <alpha>127</alpha>
      <points>
        <point x="12.1" y="5.8"/>
        <point x="12.1" y="6.15"/>
        <point x="12.1" y="5.975"/>
      </points>
      <name>J1</name>
      <alpha>127</alpha>
      <points>
        <point x="12.45" y="5.8"/>
        <point x="12.45" y="6.15"/>
        <point x="12.45" y="5.975"/>
      </points>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="12.1775" y="6.5775"/>
      </points>
      <value value="10.0" unit="M"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="12.365" y="6.5825"/>
      </points>
      <power>HALF</power>
      <alpha>127</alpha>
      <points>
        <point x="11.655" y="5.975"/>
      </points>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="11.4" y="6.4"/>
        <point x="11.4" y="5.55"/>
        <point x="11.4" y="5.975"/>
      </points>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.4" y="6.8"/>
        <point x="11.4" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.4" y="5.3"/>
        <point x="11.5" y="5.15"/>
        <point x="11.65" y="4.95"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="12.68" y="6.975"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="11.1" y="6.2"/>
        <point x="11.1" y="5.8"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="10.8925" y="5.8025"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="10.25" y="6.95"/>
        <point x="10.4675" y="6.4575"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="10.9025" y="6.47"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="10.25" y="4.95"/>
        <point x="10.4675" y="5.4575"/>
      </points>
      <value value="22.0" unit="K"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="10.7" y="6.95"/>
        <point x="10.6925" y="6.4575"/>
      </points>
      <value value="470.0" unit="R"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="9.95" y="6.05"/>
        <point x="9.95" y="5.2"/>
        <point x="9.95" y="5.625"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="9.25" y="6.2"/>
        <point x="9.435" y="6.5875"/>
      </points>
      <value value="82.0" unit="K"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="9.059999999999999" y="6.5875"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="9.25" y="5.7"/>
        <point x="9.059999999999999" y="5.3375"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="9.435" y="5.3375"/>
      </points>
      <power>HALF</power>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.4" y="4.2"/>
        <point x="17.65" y="4.45"/>
        <point x="17.35" y="5.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>42</alpha>
      <controlPoints2>
        <point x="17.85" y="5.5"/>
        <point x="17.85" y="6.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="10.95" y="4.95"/>
      </points>
      <value value="47.0" unit="R"/>
      <power>HALF</power>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="12.105" y="4.975"/>
        <point x="11.8775" y="4.9625"/>
      </points>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="21.01" y="6.5675"/>
      </points>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="18.0025" y="6.5675"/>
      </points>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="7.8775" y="6.3275"/>
      </points>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.5" y="6.8"/>
        <point x="6.95" y="7.0"/>
        <point x="7.35" y="6.5"/>
        <point x="7.88" y="6.485"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.95" y="6.65"/>
        <point x="7.85" y="5.35"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.95" y="6.7"/>
        <point x="7.35" y="6.2"/>
        <point x="7.85" y="6.2"/>
      </controlPoints2>
      <color hex="ff0000"/>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.35" y="4.3"/>
        <point x="8.8" y="4.2"/>
        <point x="11.1" y="4.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.8" y="4.35"/>
        <point x="9.25" y="4.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.85" y="5.35"/>
        <point x="7.1" y="3.8"/>
        <point x="8.3" y="4.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.5" y="5.75"/>
        <point x="9.8" y="4.45"/>
      </controlPoints2>
      <color hex="996600"/>
      <gauge>_22</gauge>
      <name>W4</name>
      <alpha>28</alpha>
      <controlPoints2>
        <point x="10.7" y="5.4"/>
        <point x="11.25" y="4.1"/>
        <point x="19.385" y="4.475"/>
        <point x="20.3" y="5.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.3" y="4.75"/>
        <point x="8.55" y="4.05"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C1</name>
      <alpha>43</alpha>
      <points>
        <point x="11.95" y="5.35"/>
        <point x="11.95" y="5.8"/>
        <point x="11.95" y="5.575"/>
      </points>
      <name>W1</name>
      <alpha>25</alpha>
      <controlPoints2>
        <point x="12.05" y="6.15"/>
        <point x="11.95" y="6.1"/>
        <point x="11.95" y="5.9"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>25</alpha>
      <controlPoints2>
        <point x="11.95" y="5.25"/>
        <point x="11.95" y="5.1"/>
        <point x="12.05" y="5.0"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>16uF  450v</name>
      <alpha>127</alpha>
      <length value="1.55" unit="in"/>
      <width value="0.71" unit="in"/>
      <points>
        <point x="2.95" y="1.4"/>
      </points>
      <bodyColor hex="666666"/>
      <labelColor hex="f0f0f0"/>
      <value value="16.0" unit="uF"/>
      <voltageNew value="450.0" unit="V"/>
      <alpha>127</alpha>
      <points>
        <point x="2.2" y="1.4"/>
      </points>
      <labelColor hex="ffffff"/>
      <voltageNew value="500.0" unit="V"/>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.3" y="5.8"/>
      <text>Bulb</text>
      <font name="Tahoma" size="14" style="0"/>
      <center>false</center>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
      <orientation>DEFAULT</orientation>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.3" y="5.35"/>
      <text>Resistor</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.3" y="5.55"/>
      <text>Roach</text>
      <font name="Tahoma" size="20" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.25" y="6.7"/>
      <text>PI Plate Load</text>
      <font reference="../../diylc.misc.Label/font"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.25" y="5.15"/>
      <text>Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.5" y="6.0"/>
      <text>LTP PI</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.95" y="5.55"/>
      <text>Channel Mix</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.45" y="5.2"/>
      <text>PI Tail</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.295" y="6.6"/>
      <text>Coupling</text>
      <verticalAlignment>TOP</verticalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.75" y="5.95"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.3" y="6.0"/>
      <text>V5B Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.95" y="5.95"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.55" y="5.95"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.65" y="5.1"/>
      <text>V4B Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.15" y="5.1"/>
      <text>Attenuation</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.6" y="5.55"/>
      <text>Bright</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.105" y="6.425"/>
      <text>V4A Coupling</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.4" y="6.6"/>
      <text>V4 Plate Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.6" y="6.75"/>
      <text>V2 Plate Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.65" y="6.75"/>
      <text>V1 Plate Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.5" y="7.1"/>
      <text>Slope</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.6" y="7.1"/>
      <text>Slope</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.4" y="5.9"/>
      <text>Reverb</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.5" y="5.9"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.045" y="6.545"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.9" y="5.85"/>
      <text>Treble</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.9" y="5.85"/>
      <text>Treble</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="19.7" y="6.2"/>
      <text>V1A Cathode</text>
      <horizontalAlignment>RIGHT</horizontalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.15" y="5.9"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.05" y="5.9"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="19.23" y="5.91"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.065" y="5.795"/>
      <text>Bypass</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.1" y="5.2"/>
      <text>V3 Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.65" y="5.15"/>
      <text>Reverb Mix</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.1" y="6.65"/>
      <text>Buffer</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.55" y="6.55"/>
      <text>V5B Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.2" y="5.25"/>
      <text>V5A Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.95" y="6.95"/>
      <text>V6A Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.45" y="6.9"/>
      <text>V6B Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.25" y="5.05"/>
      <text>Power Tube</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.9" y="5.6"/>
      <text>NFB</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.95" y="4.85"/>
      <text>NFB Tail</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.15" y="5.05"/>
      <text>Reverb</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.85" y="4.8"/>
      <text>A (B+1)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="8.35" y="4.8"/>
      <text>B (B+2)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.7" y="6.35"/>
      <text>B+1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.25" y="5.35"/>
      <text>Power Amp Ground</text>
      <font name="Tahoma" size="22" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.7" y="5.25"/>
      <text>Normal</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.1" y="5.25"/>
      <text>Vibrato</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.0" y="4.7"/>
      <text>Preamp Ground Bus</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.1" y="0.55"/>
      <text>AB763 DELUXE REVERB &quot;BLACKFACE&quot; AMP</text>
      <font name="Tahoma" size="140" style="0"/>
      <horizontalAlignment>LEFT</horizontalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="19.5" y="6.2"/>
      <text>V2A Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.65" y="6.25"/>
      <text>V1B &amp; V2B Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.45" y="6.25"/>
      <text>V3 Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.3" y="6.2"/>
      <text>V4 Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.1" y="6.2"/>
      <text>V5A Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.75" y="6.7"/>
      <text>PI Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.75" y="5.15"/>
      <text>Tremolo</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.85" y="5.55"/>
      <text>Tick Fix</text>
    </diylc.misc.Label>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="4.275" y="2.4"/>
      </points>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="1.825" y="2.4"/>
      </points>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="2.575" y="2.4"/>
      </points>
      <name>10K 3W</name>
      <alpha>127</alpha>
      <length value="0.5" unit="in"/>
      <width value="0.2" unit="in"/>
      <points>
        <point x="2.575" y="0.4"/>
      </points>
      <value value="10.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="3.0" unit="W"/>
      <name>10K 3W</name>
      <alpha>127</alpha>
      <points>
        <point x="1.825" y="0.4"/>
      </points>
      <power>HALF</power>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.39" y="2.37"/>
        <point x="1.4" y="0.075"/>
        <point x="0.85" y="0.45"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.55" y="0.5"/>
        <point x="5.0" y="0.6"/>
        <point x="5.25" y="0.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.55" y="0.6"/>
        <point x="3.2" y="2.05"/>
        <point x="3.45" y="2.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.6" y="0.6"/>
        <point x="4.95" y="0.7"/>
        <point x="5.25" y="0.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.1" y="0.35"/>
        <point x="1.2" y="0.4"/>
        <point x="1.3" y="0.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="8.35" y="5.175"/>
      </points>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.1" y="8.95"/>
        <point x="3.95" y="8.9"/>
        <point x="6.8" y="5.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V1</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AY7</type>
      <angle>320</angle>
      <controlPoints>
        <point x="21.0" y="9.0"/>
        <point x="21.41" y="8.97"/>
        <point x="21.345" y="9.215"/>
        <point x="21.15" y="9.38"/>
        <point x="20.9" y="9.4"/>
        <point x="20.68" y="9.265"/>
        <point x="20.585" y="9.025"/>
        <point x="20.65" y="8.78"/>
        <point x="20.845" y="8.615"/>
        <point x="21.095" y="8.595"/>
      </controlPoints>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.25" y="6.7"/>
        <point x="21.2" y="8.0"/>
        <point x="22.35" y="9.15"/>
        <point x="21.35" y="9.2"/>
      </controlPoints2>
      <color hex="ff6666"/>
      <gauge>_22</gauge>
      <stripeColor hex="ffff00"/>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.15" y="6.7"/>
        <point x="21.15" y="8.3"/>
        <point x="20.65" y="8.35"/>
        <point x="20.65" y="8.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.0" y="7.0"/>
        <point x="20.55" y="8.25"/>
        <point x="21.75" y="8.55"/>
        <point x="21.4" y="8.95"/>
      </controlPoints2>
      <color hex="ffcc33"/>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.2" y="8.1"/>
        <point x="20.3" y="9.05"/>
        <point x="20.6" y="9.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.25" y="8.6"/>
        <point x="19.8" y="8.2"/>
        <point x="20.65" y="8.3"/>
        <point x="20.85" y="8.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.7" y="9.25"/>
        <point x="20.65" y="9.4"/>
        <point x="20.8" y="9.45"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.3" y="9.6"/>
        <point x="20.75" y="9.85"/>
        <point x="21.15" y="9.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V1</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AY7</type>
      <angle>320</angle>
      <controlPoints>
        <point x="19.4" y="9.0"/>
        <point x="19.81" y="8.97"/>
        <point x="19.745" y="9.215"/>
        <point x="19.55" y="9.38"/>
        <point x="19.3" y="9.4"/>
        <point x="19.08" y="9.265"/>
        <point x="18.985" y="9.025"/>
        <point x="19.05" y="8.78"/>
        <point x="19.245" y="8.615"/>
        <point x="19.495" y="8.595"/>
      </controlPoints>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.25" y="6.7"/>
        <point x="18.2" y="7.55"/>
        <point x="20.75" y="8.65"/>
        <point x="19.75" y="9.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.15" y="6.7"/>
        <point x="18.05" y="7.55"/>
        <point x="19.0" y="8.4"/>
        <point x="19.05" y="8.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.85" y="8.15"/>
        <point x="20.15" y="8.55"/>
        <point x="19.8" y="8.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.05" y="7.5"/>
        <point x="18.55" y="8.95"/>
        <point x="19.0" y="9.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.95" y="8.3"/>
        <point x="19.1" y="7.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.1" y="9.25"/>
        <point x="19.05" y="9.4"/>
        <point x="19.2" y="9.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.2" y="8.65"/>
        <point x="20.4" y="9.45"/>
        <point x="19.55" y="9.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V1</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AY7</type>
      <angle>320</angle>
      <controlPoints>
        <point x="17.8" y="9.0"/>
        <point x="18.21" y="8.97"/>
        <point x="18.145" y="9.215"/>
        <point x="17.95" y="9.38"/>
        <point x="17.7" y="9.4"/>
        <point x="17.48" y="9.265"/>
        <point x="17.385" y="9.025"/>
        <point x="17.45" y="8.78"/>
        <point x="17.645" y="8.615"/>
        <point x="17.895" y="8.595"/>
      </controlPoints>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.475" y="6.275"/>
        <point x="17.25" y="8.55"/>
        <point x="17.45" y="8.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.95" y="8.6"/>
        <point x="17.4" y="8.2"/>
        <point x="17.65" y="8.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.5" y="9.25"/>
        <point x="17.45" y="9.4"/>
        <point x="17.6" y="9.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V1</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AY7</type>
      <angle>320</angle>
      <controlPoints>
        <point x="14.6" y="8.95"/>
        <point x="15.01" y="8.92"/>
        <point x="14.945" y="9.165"/>
        <point x="14.75" y="9.33"/>
        <point x="14.5" y="9.35"/>
        <point x="14.28" y="9.215"/>
        <point x="14.185" y="8.975"/>
        <point x="14.25" y="8.73"/>
        <point x="14.445" y="8.565"/>
        <point x="14.695" y="8.545"/>
      </controlPoints>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.3" y="9.6"/>
        <point x="15.15" y="9.2"/>
        <point x="14.95" y="9.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.9" y="5.7"/>
        <point x="13.85" y="7.8"/>
        <point x="14.3" y="8.3"/>
        <point x="14.25" y="8.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.8" y="8.1"/>
        <point x="15.4" y="8.5"/>
        <point x="15.0" y="8.9"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.935" y="7.03"/>
        <point x="13.8" y="8.05"/>
        <point x="13.95" y="9.0"/>
        <point x="14.2" y="8.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.3" y="7.65"/>
        <point x="14.65" y="8.05"/>
        <point x="14.45" y="8.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.3" y="9.2"/>
        <point x="14.3" y="9.35"/>
        <point x="14.45" y="9.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V1</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AY7</type>
      <angle>320</angle>
      <controlPoints>
        <point x="12.45" y="8.95"/>
        <point x="12.86" y="8.92"/>
        <point x="12.795" y="9.165"/>
        <point x="12.6" y="9.33"/>
        <point x="12.35" y="9.35"/>
        <point x="12.13" y="9.215"/>
        <point x="12.035" y="8.975"/>
        <point x="12.1" y="8.73"/>
        <point x="12.295" y="8.565"/>
        <point x="12.545" y="8.545"/>
      </controlPoints>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.7" y="5.7"/>
        <point x="13.4" y="9.3"/>
        <point x="12.8" y="9.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.0" y="6.25"/>
        <point x="11.75" y="8.3"/>
        <point x="12.1" y="8.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.3" y="8.1"/>
        <point x="13.05" y="8.5"/>
        <point x="12.85" y="8.9"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.7" y="8.05"/>
        <point x="11.65" y="9.0"/>
        <point x="12.05" y="8.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.65" y="7.0"/>
        <point x="11.75" y="7.85"/>
        <point x="12.15" y="8.15"/>
        <point x="12.3" y="8.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.15" y="9.2"/>
        <point x="12.1" y="9.35"/>
        <point x="12.25" y="9.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.65" y="7.95"/>
        <point x="13.15" y="9.75"/>
        <point x="12.6" y="9.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V1</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type>12AY7</type>
      <angle>320</angle>
      <controlPoints>
        <point x="10.6" y="8.95"/>
        <point x="11.01" y="8.92"/>
        <point x="10.945" y="9.165"/>
        <point x="10.75" y="9.33"/>
        <point x="10.5" y="9.35"/>
        <point x="10.28" y="9.215"/>
        <point x="10.185" y="8.975"/>
        <point x="10.25" y="8.73"/>
        <point x="10.445" y="8.565"/>
        <point x="10.695" y="8.545"/>
      </controlPoints>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.85" y="7.95"/>
        <point x="11.55" y="8.95"/>
        <point x="10.95" y="9.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.45" y="7.75"/>
        <point x="9.75" y="8.3"/>
        <point x="10.25" y="8.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W27</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.15" y="8.2"/>
        <point x="11.35" y="8.5"/>
        <point x="11.0" y="8.9"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.2" y="8.25"/>
        <point x="9.9" y="9.0"/>
        <point x="10.2" y="8.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.7" y="7.8"/>
        <point x="10.35" y="8.25"/>
        <point x="10.45" y="8.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.3" y="9.2"/>
        <point x="10.25" y="9.35"/>
        <point x="10.4" y="9.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>V4</name>
      <alpha>127</alpha>
      <base>OCTAL</base>
      <type>6L6GT</type>
      <angle>50</angle>
      <controlPoints>
        <point x="5.4" y="8.8"/>
        <point x="5.5" y="9.125"/>
        <point x="5.24" y="9.1"/>
        <point x="5.07" y="8.9"/>
        <point x="5.095" y="8.64"/>
        <point x="5.295" y="8.47"/>
        <point x="5.555" y="8.495"/>
        <point x="5.725" y="8.695"/>
        <point x="5.7" y="8.955"/>
      </controlPoints>
      <name>V3</name>
      <alpha>127</alpha>
      <base>OCTAL</base>
      <type>6L6GT</type>
      <angle>50</angle>
      <controlPoints>
        <point x="7.3" y="8.8"/>
        <point x="7.4" y="9.125"/>
        <point x="7.14" y="9.1"/>
        <point x="6.97" y="8.9"/>
        <point x="6.995" y="8.64"/>
        <point x="7.195" y="8.47"/>
        <point x="7.455" y="8.495"/>
        <point x="7.625" y="8.695"/>
        <point x="7.6" y="8.955"/>
      </controlPoints>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.7" y="8.95"/>
        <point x="6.45" y="9.25"/>
        <point x="7.7" y="9.65"/>
        <point x="7.6" y="8.95"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W13</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.55" y="7.65"/>
        <point x="7.5" y="8.0"/>
        <point x="7.45" y="8.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W14</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.3" y="8.05"/>
        <point x="6.0" y="8.2"/>
        <point x="5.55" y="8.5"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W34</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.05" y="8.9"/>
        <point x="4.25" y="8.9"/>
        <point x="5.7" y="7.5"/>
        <point x="6.45" y="6.8"/>
      </controlPoints2>
      <color hex="663300"/>
      <gauge>_20</gauge>
      <name>W35</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.0" y="7.5"/>
        <point x="6.35" y="7.8"/>
        <point x="6.95" y="8.9"/>
      </controlPoints2>
      <color hex="0000cc"/>
      <gauge>_20</gauge>
      <name>Grid Stopper V4</name>
      <alpha>127</alpha>
      <width value="0.13" unit="in"/>
      <points>
        <point x="5.3" y="8.5"/>
        <point x="5.5" y="9.15"/>
        <point x="5.4" y="8.825"/>
      </points>
      <borderColor hex="5b90b1"/>
      <power>HALF</power>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.25" y="8.8"/>
        <point x="5.9" y="8.6"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <alpha>127</alpha>
      <points>
        <point x="7.2" y="8.5"/>
        <point x="7.4" y="9.15"/>
        <point x="7.3" y="8.825"/>
      </points>
      <power>HALF</power>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.3" y="0.25"/>
      <text>A (B+1) 420V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.95" y="0.25"/>
      <text>B (B+2) 415V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.2" y="0.25"/>
      <text>C (B+3) 325V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="1.45" y="0.25"/>
      <text>D (B+4) 280V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.195" y="0.5750000000000001"/>
      <text>To Power Amp Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="0.55" y="0.55"/>
      <text>To Preamp Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.6" y="2.55"/>
      <text>Doghouse Board</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.6" y="5.25"/>
      <text>D (B+4)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.55" y="4.2"/>
      <text>Dog House D</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="21.35" y="8.95"/>
      <text>1</text>
      <font name="Tahoma" size="24" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="21.0" y="9.65"/>
      <text>V1  12AX7</text>
      <font name="Tahoma" size="34" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="21.1" y="8.5"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="20.85" y="9.3"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="21.05" y="8.65"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="19.75" y="8.95"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="19.4" y="9.65"/>
      <text>V2  12AX7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="19.55" y="8.55"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="19.25" y="9.3"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="19.45" y="8.65"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="17.8" y="9.65"/>
      <text>V3  12AT7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="17.8" y="9.85"/>
      <text>Reverb Driver</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="17.9" y="8.5"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="17.65" y="9.3"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="17.85" y="8.65"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="14.7" y="9.55"/>
      <text>V4  12AX7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.7" y="9.9"/>
      <text>B Vibrato Preamp 3</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="14.75" y="8.45"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="14.45" y="9.25"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="14.7" y="8.6"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="12.75" y="8.9"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="12.45" y="9.55"/>
      <text>V5  12AX7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="12.55" y="8.45"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="12.3" y="9.25"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="12.5" y="8.6"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="10.95" y="8.9"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="10.6" y="9.55"/>
      <text>V6  12AT7</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="10.6" y="9.75"/>
      <text>LTP Phase Inverter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="10.7" y="8.45"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="10.45" y="9.25"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="10.65" y="8.6"/>
      <text>9</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.35" y="9.15"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.5" y="9.2"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="7.3" y="9.5"/>
      <text>V7 6V6GT</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="5.115" y="9.445"/>
      <text>V8  6V6GT</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.15" y="9.2"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.8" y="8.6"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.1" y="9.2"/>
      <text>Fil 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.65" y="8.7"/>
      <text>Fil 1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="6.3" y="9.7"/>
      <text>Push-Pull Power Tubes</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.35" y="9.0"/>
      <text>Grid Stopper</text>
      <font name="Tahoma" size="15" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.15" y="8.9"/>
      <text>3</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="6.9" y="8.9"/>
      <text>3</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="6.95" y="8.65"/>
      <text>4</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.05" y="8.65"/>
      <text>4</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.25" y="8.4"/>
      <text>5</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.35" y="8.4"/>
      <text>5</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.65" y="8.5"/>
      <text>6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.55" y="8.5"/>
      <text>6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.25" y="9.0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.65" y="8.95"/>
      <text>8</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="7.7" y="8.95"/>
      <text>8</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.7" y="9.4"/>
        <point x="8.7" y="5.9"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.45" y="9.7"/>
        <point x="8.6" y="5.75"/>
      </controlPoints2>
      <color hex="3333ff"/>
      <gauge>_22</gauge>
      <name>470 3W</name>
      <alpha>127</alpha>
      <length value="0.35" unit="in"/>
      <points>
        <point x="5.1" y="8.65"/>
        <point x="5.325" y="8.575"/>
      </points>
      <power>HALF</power>
      <name>470 3W</name>
      <alpha>127</alpha>
      <points>
        <point x="7.0" y="8.65"/>
        <point x="7.225" y="8.575"/>
      </points>
      <power>HALF</power>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="10.75" y="9.3"/>
        <point x="10.45" y="8.6"/>
      </points>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="14.75" y="9.3"/>
        <point x="14.45" y="8.6"/>
      </points>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="17.95" y="9.35"/>
        <point x="17.65" y="8.65"/>
      </points>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.4" y="9.0"/>
        <point x="17.65" y="9.1"/>
        <point x="17.9" y="9.15"/>
        <point x="18.2" y="8.95"/>
      </controlPoints2>
      <color hex="0000ff"/>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.75" y="9.05"/>
        <point x="17.8" y="9.25"/>
        <point x="18.15" y="9.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.1" y="8.9"/>
        <point x="17.15" y="9.05"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.4" y="7.0"/>
        <point x="15.735" y="8.635"/>
        <point x="16.48" y="8.879999999999999"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W53</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.05" y="8.75"/>
        <point x="16.95" y="9.35"/>
        <point x="17.15" y="9.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.65" y="6.75"/>
        <point x="13.5" y="10.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.35" y="7.35"/>
        <point x="15.05" y="7.85"/>
        <point x="14.05" y="7.85"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.35" y="7.25"/>
        <point x="12.35" y="7.6"/>
        <point x="14.0" y="7.85"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.9" y="6.45"/>
        <point x="5.15" y="6.1"/>
      </controlPoints2>
      <style>DASHED</style>
      <gauge>_20</gauge>
      <alpha>127</alpha>
      <controlPoints>
        <point x="8.5" y="10.55"/>
        <point x="8.5" y="10.75"/>
      </controlPoints>
      <name>W59</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.63" y="10.8"/>
        <point x="2.25" y="10.8"/>
        <point x="1.69" y="9.325"/>
        <point x="1.37" y="9.23"/>
        <point x="1.05" y="9.135"/>
        <point x="0.85" y="9.25"/>
      </controlPoints2>
      <pointCount>SEVEN</pointCount>
      <gauge>_18</gauge>
      <name>W60</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.4" y="10.7"/>
        <point x="1.45" y="10.75"/>
        <point x="1.6" y="10.8"/>
      </controlPoints2>
      <gauge>_16</gauge>
      <name>Normal Volume</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="19.75" y="1.55"/>
        <point x="19.45" y="1.55"/>
        <point x="19.15" y="1.55"/>
      </controlPoints>
      <resistance value="1.0" unit="M"/>
      <orientation>_180</orientation>
      <taper>LOG</taper>
      <showShaft>false</showShaft>
      <view>ShaftDown</view>
      <name>Normal Treble</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="18.55" y="1.55"/>
        <point x="18.25" y="1.55"/>
        <point x="17.95" y="1.55"/>
      </controlPoints>
      <resistance value="250.0" unit="K"/>
      <taper>LOG</taper>
      <name>Normal Bass</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="17.35" y="1.55"/>
        <point x="17.05" y="1.55"/>
        <point x="16.75" y="1.55"/>
      </controlPoints>
      <taper>LOG</taper>
      <name>Vibrato Volume</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="13.85" y="1.55"/>
        <point x="13.55" y="1.55"/>
        <point x="13.25" y="1.55"/>
      </controlPoints>
      <taper>LOG</taper>
      <name>Vibrato Treble</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="12.65" y="1.55"/>
        <point x="12.35" y="1.55"/>
        <point x="12.05" y="1.55"/>
      </controlPoints>
      <taper>LOG</taper>
      <name>Vibrato Bass</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="11.45" y="1.55"/>
        <point x="11.15" y="1.55"/>
        <point x="10.85" y="1.55"/>
      </controlPoints>
      <taper>LOG</taper>
      <name>Reverb</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="10.25" y="1.55"/>
        <point x="9.95" y="1.55"/>
        <point x="9.65" y="1.55"/>
      </controlPoints>
      <resistance value="100.0" unit="K"/>
      <taper>LIN</taper>
      <name>Tremolo Speed</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="9.05" y="1.55"/>
        <point x="8.75" y="1.55"/>
        <point x="8.45" y="1.55"/>
      </controlPoints>
      <resistance value="3.0" unit="M"/>
      <taper>REV_LOG</taper>
      <name>Tremolo Intensity</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="7.85" y="1.55"/>
        <point x="7.55" y="1.55"/>
        <point x="7.25" y="1.55"/>
      </controlPoints>
      <resistance value="50.0" unit="K"/>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.4" y="7.05"/>
      <text>OT &amp; Choke</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="6.95" y="8.55"/>
      <text>Screen</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="5.05" y="8.55"/>
      <text>Screen</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="8.35" y="5.5"/>
      <text>Choke</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.25" y="6.1"/>
      <text>C (B+3)</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.65" y="6.9"/>
      <text>V5A Load</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.4" y="5.85"/>
      <text>V5B Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="8.15" y="6.485"/>
      <text>Choke</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="8.15" y="6.2"/>
      <text>OT CT</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.7" y="9.75"/>
      <text>A Reverb Recovery</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="18.15" y="8.95"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="19.4" y="9.85"/>
      <text>Vibrato Preamp 1 &amp; 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="21.0" y="9.85"/>
      <text>Normal Preamp 1 &amp; 2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.15" y="8.05"/>
      <text>Dog House B</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.25" y="7.15"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.15" y="7.1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.45" y="11.05"/>
      <text>Vibrato Pedal</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.9799999999999995" y="6.27"/>
      <text>Red-Yellow HV Center Tap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="8.5" y="11.05"/>
      <text>Standby</text>
      <font name="Tahoma Bold" size="22" style="1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="0.85" y="9.7"/>
      <text>Safety</text>
      <font name="Tahoma" size="18" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="2.0649999999999995" y="10.76"/>
      <text>Black = Hot</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="1.905" y="9.895"/>
      <text>Green = Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="0.85" y="9.8"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="0.85" y="9.9"/>
      <text>Bolt</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.73" y="7.645"/>
      <text> Twist</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.565" y="5.275"/>
      <text>6.3v</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="2.9" y="9.18"/>
      <text>1</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="2.85" y="9.45"/>
      <text>V9  GZ34</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.3" y="9.0"/>
      <text>B+ DC Out</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.85" y="9.65"/>
      <text>Rectifier</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="3.15" y="8.85"/>
      <text>8</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.07" y="7.65"/>
      <text>Twist</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.72" y="5.565"/>
      <text>Twist</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="2.5" y="8.7"/>
      <text>4</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="3.0" y="8.4"/>
      <text>6</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="2.55" y="9.1"/>
      <text>2</text>
    </diylc.misc.Label>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="15.875" y="2.35"/>
      </points>
      <power>HALF</power>
    <diylc.connectivity.HookupWire>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.05" y="2.65"/>
      </controlPoints2>
      <color hex="000000"/>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_24</gauge>
      <striped>false</striped>
    </diylc.connectivity.HookupWire>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="15.55" y="3.0"/>
        <point x="15.35" y="2.775"/>
      </points>
      <value value="68.0" unit="K"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="15.55" y="2.6"/>
      </points>
      <power>HALF</power>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.45" y="2.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="21.775" y="2.35"/>
      </points>
      <power>HALF</power>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.85" y="2.65"/>
      </controlPoints2>
      <gauge>_24</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="21.45" y="3.0"/>
        <point x="21.25" y="2.775"/>
      </points>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="21.45" y="2.6"/>
      </points>
      <power>HALF</power>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.35" y="2.2"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>C1</name>
      <alpha>127</alpha>
      <points>
        <point x="13.55" y="1.3"/>
        <point x="13.85" y="1.3"/>
        <point x="13.7" y="1.3"/>
      </points>
      <value value="47.0" unit="pF"/>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.6" y="1.35"/>
        <point x="19.35" y="1.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.4" y="1.35"/>
        <point x="17.6" y="1.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="12.1" y="4.8"/>
        <point x="12.1025" y="4.8875"/>
      </points>
      <borderColor hex="000000"/>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="16.55" y="4.8"/>
        <point x="16.56" y="4.8875"/>
      </points>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="19.6" y="4.95"/>
        <point x="19.6" y="4.8"/>
        <point x="19.6" y="4.875"/>
      </points>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="22.0" y="2.7"/>
        <point x="20.2" y="4.8"/>
      </controlPoints2>
      <color hex="cccccc"/>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.45" y="5.55"/>
        <point x="17.45" y="1.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.35" y="1.4"/>
      <text>Normal</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.9" y="1.65"/>
      <text>2 Low</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.8" y="1.65"/>
      <text>1 High</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.45" y="1.4"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.0" y="1.65"/>
      <text>2 Low</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.9" y="1.65"/>
      <text>1 High</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.6" y="2.1"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.05" y="2.6"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.3" y="2.1"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.85" y="2.65"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.3" y="2.6"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.35" y="1.8"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.5" y="2.1"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.95" y="2.6"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.2" y="2.1"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.75" y="2.65"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="22.02" y="3.195"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.25" y="1.8"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.65" y="1.15"/>
      <text>Bright</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.45" y="3.2"/>
      <text>Mid</text>
      <orientation>_270</orientation>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="22.02" y="3.085"/>
      <text>Chassis</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.3" y="4.5"/>
        <point x="17.75" y="1.6"/>
      </controlPoints2>
      <pointCount>FOUR</pointCount>
      <style>SOLID</style>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="19.4" y="2.7"/>
        <point x="21.0" y="4.4"/>
      </controlPoints2>
      <color hex="ffffff"/>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.4" y="2.7"/>
        <point x="21.2" y="4.95"/>
      </controlPoints2>
      <color hex="ffff00"/>
      <gauge>_22</gauge>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.4" y="4.3"/>
        <point x="21.2" y="5.65"/>
      </controlPoints2>
      <color hex="ff9999"/>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.3" y="5.1"/>
      <text>Normal Tone Stack</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.8" y="2.1"/>
        <point x="18.7" y="3.2"/>
        <point x="19.05" y="4.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.35" y="4.2"/>
        <point x="17.05" y="4.3"/>
        <point x="16.65" y="4.6"/>
        <point x="16.65" y="4.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.05" y="4.2"/>
        <point x="18.45" y="4.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.35" y="3.45"/>
        <point x="19.125" y="4.03"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.25" y="2.75"/>
        <point x="17.2" y="3.95"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.75" y="4.25"/>
        <point x="12.2" y="2.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.5" y="5.25"/>
        <point x="15.1" y="4.25"/>
        <point x="13.2" y="3.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.7" y="1.3"/>
        <point x="13.5" y="1.3"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.45" y="1.35"/>
        <point x="11.75" y="1.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.65" y="3.05"/>
        <point x="10.95" y="3.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.2" y="2.15"/>
        <point x="13.35" y="3.2"/>
        <point x="14.25" y="4.8"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.1" y="3.25"/>
        <point x="15.85" y="5.75"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.4" y="4.8"/>
        <point x="10.35" y="2.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.55" y="1.35"/>
        <point x="9.4" y="1.35"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="8.6" y="1.55"/>
      </points>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.65" y="1.35"/>
        <point x="8.85" y="1.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.75" y="4.8"/>
        <point x="11.4" y="4.85"/>
        <point x="10.2" y="4.3"/>
        <point x="9.0" y="3.75"/>
        <point x="9.75" y="2.0"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.4" y="3.2"/>
        <point x="10.3" y="4.75"/>
        <point x="11.1" y="5.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.46" y="4.975"/>
        <point x="9.3" y="4.1"/>
        <point x="7.85" y="2.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>50K  2W</name>
      <alpha>127</alpha>
      <points>
        <point x="1.95" y="3.1"/>
        <point x="3.0" y="3.1"/>
        <point x="2.475" y="3.1"/>
      </points>
      <value value="50.0" unit="R"/>
      <power>HALF</power>
      <powerNew value="2.0" unit="W"/>
    <diylc.semiconductors.DiodePlastic>
      <name>1N4007</name>
      <alpha>127</alpha>
      <points>
        <point x="3.95" y="3.1"/>
        <point x="3.05" y="3.1"/>
        <point x="3.5" y="3.1"/>
      </points>
      <bodyColor hex="404040"/>
      <borderColor hex="2c2c2c"/>
      <value></value>
      <markerColor hex="dddddd"/>
    </diylc.semiconductors.DiodePlastic>
      <name>25uF  50v</name>
      <alpha>127</alpha>
      <width value="0.5" unit="in"/>
      <points>
        <point x="2.05" y="3.55"/>
        <point x="3.95" y="3.55"/>
        <point x="3.0" y="3.55"/>
      </points>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.67" y="4.705"/>
        <point x="5.05" y="4.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.495" y="8.62"/>
        <point x="1.49" y="6.935"/>
        <point x="1.415" y="4.1"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.85" y="4.35"/>
        <point x="5.7" y="5.35"/>
        <point x="4.7" y="3.15"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="3.95" y="3.325"/>
      </points>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.75" y="3.15"/>
        <point x="11.15" y="3.1"/>
        <point x="13.07" y="4.975"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.shapes.Ellipse>
      <name>ELL2</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="0.4" y="2.0"/>
        <point x="0.85" y="2.45"/>
      </controlPoints>
      <firstPoint x="0.4" y="2.0"/>
      <secondPoint x="0.85" y="2.45"/>
      <borderThickness value="0.2" unit="mm"/>
    </diylc.shapes.Ellipse>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.85" y="4.0"/>
        <point x="0.65" y="3.5"/>
        <point x="1.25" y="3.4"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W51</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.1" y="4.0"/>
        <point x="0.9" y="3.5"/>
        <point x="0.65" y="3.35"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.95" y="0.4"/>
        <point x="3.6" y="0.45"/>
        <point x="3.25" y="2.05"/>
        <point x="3.5" y="2.4"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.2" y="10.4"/>
      </controlPoints2>
      <gauge>_24</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.7" y="5.1"/>
      <text>Vibrato Tone Stack</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.55" y="4.0"/>
      <text>Dog House A B C</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.5" y="4.95"/>
      <text>Trem Jump Start</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="13.25" y="6.35"/>
      <text>Tremolo Oscillator</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.0" y="3.4"/>
      <text>Note Polarity</text>
      <color hex="f0f0f0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="3.1" y="4.9"/>
      <text>Power Transformer &lt;br&gt;Hammond AO-29</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="0.65" y="1.95"/>
      <text>Pilot Light</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="0.95" y="4.1"/>
      <text>To All 6.3V</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="0.95" y="4.2"/>
      <text>Fil</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.95" y="3.9199999999999995"/>
      <text>Bias Board</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="1.45" y="1.75"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.0" y="3.7"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.5" y="2.95"/>
      <text>Bias Rectifier</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.75" y="11.05"/>
      <text>8 Ohm Speaker</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.0" y="10.8"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.9" y="10.85"/>
      <text>Tip</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.1" y="10.7"/>
      <text>Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.1" y="10.2"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="12.3" y="10.35"/>
      <text>Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.85" y="11.05"/>
      <text>Aux Speaker</text>
    </diylc.misc.Label>
    <diylc.connectivity.SolderPad>
      <name>Pad3</name>
      <size value="0.09" unit="in"/>
      <point x="6.9" y="10.65"/>
      <type>ROUND</type>
      <holeSize value="0.8" unit="mm"/>
      <layer>_1</layer>
    </diylc.connectivity.SolderPad>
      <name>Pad3</name>
      <point x="6.9" y="10.35"/>
      <type>ROUND</type>
      <layer>_1</layer>
    <diylc.connectivity.Eyelet>
      <name>Eyelet71</name>
      <size value="0.3" unit="in"/>
      <holeSize value="0.1" unit="in"/>
      <color hex="333333"/>
      <point x="9.77" y="9.7"/>
      <value>Grommet</value>
    </diylc.connectivity.Eyelet>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="6.58" y="11.01"/>
      <text>2A Slow Blow Fuse</text>
    </diylc.misc.Label>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.75" y="9.7"/>
        <point x="10.4" y="9.6"/>
        <point x="10.15" y="10.85"/>
        <point x="10.9" y="10.95"/>
      </controlPoints2>
      <color hex="339900"/>
      <gauge>_22</gauge>
      <name>W28</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.15" y="11.0"/>
        <point x="11.6" y="11.0"/>
        <point x="12.05" y="10.9"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.9" y="10.25"/>
        <point x="10.7" y="10.0"/>
        <point x="9.75" y="10.25"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="12.05" y="10.3"/>
        <point x="11.8" y="10.4"/>
        <point x="11.35" y="10.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.75" y="7.4"/>
        <point x="8.7" y="11.1"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="16.55" y="10.65"/>
        <point x="16.2" y="10.8"/>
        <point x="15.95" y="10.8"/>
        <point x="15.45" y="10.65"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.passive.Resistor>
      <name>R1</name>
      <alpha>127</alpha>
      <length value="0.4" unit="in"/>
      <width value="0.14" unit="in"/>
      <points>
        <point x="16.1" y="10.3"/>
        <point x="15.775" y="10.475"/>
      </points>
      <bodyColor hex="996600"/>
      <borderColor hex="cc6600"/>
      <labelColor hex="000000"/>
      <leadColor hex="cccccc"/>
      <display>VALUE</display>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>false</moveLabel>
      <power>HALF</power>
      <powerNew value="0.5" unit="W"/>
      <colorCode>_4_BAND</colorCode>
      <shape>Tubular</shape>
    </diylc.passive.Resistor>
    <diylc.misc.GroundSymbol>
      <name>GND1</name>
      <size value="0.15" unit="in"/>
      <type>DEFAULT</type>
    </diylc.misc.GroundSymbol>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.15" y="10.05"/>
        <point x="21.85" y="10.05"/>
      </controlPoints2>
      <pointCount>TWO</pointCount>
      <style>DOTTED</style>
      <gauge>_30</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.9" y="6.05"/>
        <point x="3.95" y="6.0"/>
        <point x="5.05" y="5.9"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.07" y="8.75"/>
        <point x="16.915" y="9.435"/>
        <point x="17.055" y="10.075000000000001"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.94" y="4.945"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="7.75" y="11.05"/>
      <text>Power</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="9.55" y="9.47"/>
      <text>OT 125A1A 6.6k:8 Ohm</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="15.45" y="11.05"/>
      <text>Reverb Pedal</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="16.55" y="11.05"/>
      <text>Reverb Pan Output</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="17.6" y="11.05"/>
      <text>Reverb Pan Input</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.8" y="10.3"/>
      <text>V4A Grid Leak</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.05" y="1.25"/>
      <text>Smaller = Faster</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="22.02" y="2.985"/>
      <text>Preamp</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.55" y="3.1"/>
      <text>Grid Stoppers</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.4" y="3.1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.05" y="2.3"/>
      <text>Input</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.95" y="2.3"/>
      <text>Input</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.425" y="5.65"/>
      <text>Green Yellow 6.3V Center Tap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="2.0" y="10.6"/>
      <text>White = Neutral</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.15" y="4.7"/>
      <text>Max Bias</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="10.0" y="9.9"/>
      <text>Twist</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="16.225" y="10.33"/>
      <text>Chassis Ground</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.45" y="9.9"/>
      <text>B Tremolo Driver</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.45" y="9.75"/>
      <text>A Tremolo Oscillator</text>
    </diylc.misc.Label>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="6.85" y="3.75"/>
        <point x="6.35" y="4.55"/>
      </points>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="0.75" y="2.45"/>
        <point x="1.4" y="3.0"/>
      </points>
      <value value="100.0" unit="R"/>
      <power>HALF</power>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="0.5" y="2.45"/>
        <point x="1.75" y="3.55"/>
        <point x="1.125" y="3.0"/>
      </points>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.85" y="3.65"/>
      </controlPoints2>
      <pointCount>THREE</pointCount>
      <gauge>_26</gauge>
    <diylc.connectivity.Dot>
      <name>Dot1</name>
      <size value="1.0" unit="mm"/>
    </diylc.connectivity.Dot>
      <name>Dot2</name>
      <name>Dot3</name>
      <name>Dot4</name>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="7.75" y="11.2"/>
      <text>DPST</text>
      <font name="Tahoma Bold" size="18" style="1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.925" y="7.345"/>
      <text>5v Heater</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.87" y="7.655000000000001"/>
      <text>Twist</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="6.25" y="10.355"/>
      <text>Twist</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.2" y="1.75"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.95" y="1.75"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.835" y="11.11"/>
      <text>Twist</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="1.35" y="11.05"/>
      <text>Power Cord</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.6" y="6.05"/>
      <text>D</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.4" y="6.05"/>
      <text>D</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.65" y="5.95"/>
      <text>D</text>
      <verticalAlignment>BOTTOM</verticalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="8.28" y="9.62"/>
      <text> Twist</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.45" y="9.25"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.55" y="8.95"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.35" y="9.4"/>
      <text>Cathode</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.85" y="8.7"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.75" y="8.8"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.7" y="9.05"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.75" y="8.9"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.95" y="8.95"/>
      <text>Plate</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.85" y="8.95"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.7" y="8.85"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="5.3" y="8.3"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="7.15" y="8.35"/>
      <text>Grid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="1.14" y="2.695"/>
      <text>6.3V Center Tap</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="8.55" y="2.9"/>
      <text>Bundle Yellow, Brown &amp; Blue Tremolo Wires Together</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="8.55" y="3.0"/>
      <text>Keep Away From Other Control Wires</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.18" y="3.67"/>
      <text>Bias - 35V</text>
    </diylc.misc.Label>
    <diylc.connectivity.Jumper>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="14.19" y="4.975"/>
        <point x="14.2" y="4.8"/>
        <point x="14.195" y="4.8875"/>
      </points>
      <bodyColor hex="ffffff"/>
      <display>NAME</display>
    </diylc.connectivity.Jumper>
    <diylc.passive.AxialElectrolyticCapacitor>
      <alpha>127</alpha>
      <points>
        <point x="3.9" y="0.4"/>
        <point x="3.9" y="2.4"/>
        <point x="3.9" y="1.4"/>
      </points>
      <voltage>_63V</voltage>
      <markerColor hex="333333"/>
      <tickColor hex="ffffff"/>
      <polarized>true</polarized>
    </diylc.passive.AxialElectrolyticCapacitor>
      <alpha>127</alpha>
      <points>
        <point x="4.65" y="0.4"/>
        <point x="4.65" y="2.4"/>
        <point x="4.65" y="1.4"/>
      </points>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="4.275" y="0.4"/>
      </points>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="2.27" y="6.895"/>
      <text>HV</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.865" y="8.02"/>
      <text>Primary</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="3.365" y="5.21"/>
      <text>330-0-330VAC</text>
    </diylc.misc.Label>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.9" y="0.45"/>
        <point x="4.794999999999999" y="0.515"/>
        <point x="6.155" y="2.5399999999999996"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.9" y="0.45"/>
        <point x="5.05" y="0.45"/>
        <point x="5.25" y="0.35"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <alpha>127</alpha>
      <points>
        <point x="1.45" y="0.4"/>
        <point x="1.45" y="2.4"/>
        <point x="1.45" y="1.4"/>
      </points>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="9.85" y="1.35"/>
        <point x="10.6" y="1.35"/>
        <point x="10.225" y="1.35"/>
      </points>
      <value value="6.8" unit="K"/>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.7" y="1.35"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.75" y="1.35"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.0" y="1.3"/>
      </controlPoints2>
      <gauge>_26</gauge>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="13.4" y="1.3"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.9" y="1.75"/>
      <text>Filter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.65" y="1.75"/>
      <text>Filter</text>
    </diylc.misc.Label>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="16.4" y="4.8"/>
        <point x="16.575" y="3.175"/>
      </points>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.9" y="6.95"/>
        <point x="18.75" y="6.95"/>
        <point x="18.5" y="6.8"/>
        <point x="18.5" y="6.65"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.25" y="1.2"/>
      <text>Mid</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.3" y="0.15"/>
      <text>Power Tube Plates</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.95" y="0.15"/>
      <text>Power Tube Screens</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.2" y="0.15"/>
      <text>PI</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="1.45" y="0.15"/>
      <text>Preamp</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.45" y="2.55"/>
      <text>V3 &amp; V5 Plates</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="21.15" y="9.1"/>
      <text>A</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="20.85" y="8.9"/>
      <text>B</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.75" y="9.05"/>
      <text>A</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="14.45" y="8.85"/>
      <text>B</text>
      <center>false</center>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
      <orientation>DEFAULT</orientation>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.6" y="9.0"/>
      <text>A</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="12.3" y="8.85"/>
      <text>B</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.25" y="2.55"/>
      <text>Connected In Parallel</text>
      <font name="Tahoma" size="14" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="2.4" y="3.55"/>
      <text>+</text>
      <font name="Tahoma" size="54" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="3.9" y="0.7"/>
      <text>+</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="4.65" y="0.7"/>
      <text>+</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.8" y="6.45"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="21.4" y="5.65"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="20.3" y="6.4"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.95" y="6.45"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="18.5" y="5.65"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="17.25" y="6.85"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="15.85" y="6.65"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="14.9" y="6.1"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="10.25" y="5.5"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.6" y="6.45"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="8.9" y="6.45"/>
      <text>O</text>
    </diylc.misc.Label>
      <name>R1</name>
      <alpha>127</alpha>
      <points>
        <point x="8.65" y="1.35"/>
        <point x="9.025" y="1.35"/>
      </points>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.5" y="1.35"/>
      </controlPoints2>
      <gauge>_26</gauge>
    <diylc.passive.RadialFilmCapacitor>
      <name>.1uF 600V Coupling</name>
      <alpha>127</alpha>
      <fontSizeOverride>16</fontSizeOverride>
      <length value="1.0" unit="in"/>
      <width value="0.45" unit="in"/>
      <points>
        <point x="8.865" y="6.98"/>
        <point x="8.865" y="4.975"/>
        <point x="8.865" y="5.9775"/>
      </points>
      <bodyColor hex="ff4500"/>
      <borderColor hex="381d02"/>
      <hideShortLeads>false</hideShortLeads>
      <value value="0.1" unit="uF"/>
      <voltageNew value="600.0" unit="V"/>
      <showOuterFoil>false</showOuterFoil>
      <outerFoilColor hex="ffffff"/>
      <pinSpacing value="0.1" unit="in"/>
    </diylc.passive.RadialFilmCapacitor>
      <alpha>127</alpha>
      <points>
        <point x="9.615" y="6.985"/>
        <point x="9.62" y="4.975"/>
        <point x="9.6175" y="5.98"/>
      </points>
      <name>.1uF 600V AC Shunt</name>
      <alpha>127</alpha>
      <points>
        <point x="10.25" y="6.97"/>
        <point x="10.25" y="4.965"/>
        <point x="10.25" y="5.9675"/>
      </points>
      <alpha>127</alpha>
      <points>
        <point x="14.925" y="7.005"/>
        <point x="14.93" y="6.05"/>
        <point x="14.9275" y="6.5275"/>
      </points>
      <name>.1uF 600V Bass</name>
      <alpha>127</alpha>
      <points>
        <point x="18.92" y="6.975"/>
        <point x="18.955" y="4.98"/>
        <point x="18.9375" y="5.9775"/>
      </points>
      <alpha>127</alpha>
      <points>
        <point x="21.81" y="6.975"/>
        <point x="21.835" y="4.975"/>
        <point x="21.8225" y="5.975"/>
      </points>
      <name>.001uF 600V</name>
      <alpha>127</alpha>
      <length value="0.64" unit="in"/>
      <width value="0.25" unit="in"/>
      <points>
        <point x="11.095" y="6.205"/>
        <point x="11.12" y="6.975"/>
        <point x="11.1075" y="6.59"/>
      </points>
      <value value="0.001" unit="uF"/>
      <name>.0033uF 600V</name>
      <alpha>127</alpha>
      <length value="0.66" unit="in"/>
      <width value="0.3" unit="in"/>
      <points>
        <point x="15.88" y="5.75"/>
        <point x="15.87" y="6.975"/>
        <point x="15.875" y="6.3625"/>
      </points>
      <value value="0.003316" unit="uF"/>
      <name>.022uF 600V</name>
      <alpha>127</alpha>
      <length value="0.62" unit="in"/>
      <points>
        <point x="17.265" y="6.13"/>
        <point x="17.27" y="6.975"/>
        <point x="17.2675" y="6.5525"/>
      </points>
      <value value="0.022" unit="uF"/>
      <name>.047uF 600V Mid</name>
      <alpha>127</alpha>
      <width value="0.35" unit="in"/>
      <points>
        <point x="18.505" y="5.255"/>
        <point x="18.495" y="6.645"/>
        <point x="18.5" y="5.95"/>
      </points>
      <value value="0.047" unit="uF"/>
      <alpha>127</alpha>
      <points>
        <point x="21.41" y="5.265"/>
        <point x="21.4" y="6.655"/>
        <point x="21.405" y="5.96"/>
      </points>
      <name>.047uF 600V Coupling</name>
      <alpha>127</alpha>
      <points>
        <point x="20.29" y="4.97"/>
        <point x="20.275" y="6.975"/>
        <point x="20.2825" y="5.9725"/>
      </points>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.085" y="5.55"/>
        <point x="10.255" y="5.55"/>
        <point x="10.345" y="5.55"/>
        <point x="10.41" y="5.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W6</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.46" y="5.575"/>
        <point x="9.629999999999999" y="5.575"/>
        <point x="9.719999999999999" y="5.575"/>
        <point x="9.784999999999998" y="5.575"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W7</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.705" y="5.575"/>
        <point x="8.874999999999998" y="5.575"/>
        <point x="8.964999999999998" y="5.575"/>
        <point x="9.03" y="5.575"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W8</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="11.0" y="6.36"/>
        <point x="11.17" y="6.36"/>
        <point x="11.175" y="6.375"/>
        <point x="11.165" y="6.365"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W10</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="14.745" y="6.095"/>
        <point x="14.915" y="6.095"/>
        <point x="15.005" y="6.095"/>
        <point x="15.07" y="6.095"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W15</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="15.796666666666665" y="6.09"/>
        <point x="15.966666666666665" y="6.09"/>
        <point x="15.971666666666666" y="6.105"/>
        <point x="15.961666666666666" y="6.095"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W16</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="17.186666666666664" y="6.303333333333333"/>
        <point x="17.356666666666666" y="6.303333333333333"/>
        <point x="17.361666666666665" y="6.3183333333333325"/>
        <point x="17.351666666666667" y="6.308333333333333"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W17</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.34" y="5.563333333333333"/>
        <point x="18.51" y="5.563333333333333"/>
        <point x="18.6" y="5.563333333333333"/>
        <point x="18.665" y="5.563333333333333"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W18</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="18.786666666666665" y="5.573333333333332"/>
        <point x="18.956666666666663" y="5.573333333333332"/>
        <point x="19.046666666666667" y="5.573333333333332"/>
        <point x="19.111666666666665" y="5.573333333333332"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W19</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.675" y="5.6"/>
        <point x="21.845" y="5.6"/>
        <point x="21.935" y="5.6"/>
        <point x="22.0" y="5.6"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W20</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="20.125" y="5.56"/>
        <point x="20.295" y="5.56"/>
        <point x="20.385" y="5.56"/>
        <point x="20.45" y="5.56"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W22</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="21.245" y="5.57"/>
        <point x="21.415" y="5.57"/>
        <point x="21.505" y="5.57"/>
        <point x="21.57" y="5.57"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.passive.PotentiometerPanel>
      <name>Master Volume</name>
      <alpha>127</alpha>
      <fontSizeOverride>18</fontSizeOverride>
      <controlPoints>
        <point x="5.549999999999998" y="9.97"/>
        <point x="5.250000000000003" y="9.97"/>
        <point x="4.95" y="9.97"/>
      </controlPoints>
      <taper>LIN</taper>
      <bodyDiameter value="1.0" unit="in"/>
      <spacing value="0.3" unit="in"/>
      <lugDiameter value="0.15" unit="in"/>
      <bodyColor hex="c0c0c0"/>
      <borderColor hex="808080"/>
      <nutColor hex="cbd5db"/>
      <waferColor hex="cd8500"/>
      <type>ThroughHole</type>
    </diylc.passive.PotentiometerPanel>
      <name>W23</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.631738413079347" y="4.974471276436179"/>
        <point x="10.106738413079347" y="5.49447127643618"/>
        <point x="7.006738413079347" y="7.729471276436179"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W24</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.87427628618569" y="4.966971651417429"/>
        <point x="8.959276286185691" y="5.0869716514174295"/>
        <point x="7.374276286185691" y="7.22197165141743"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.connectivity.TwistedWire>
      <name>W25</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.5646917654117294" y="2.7920803959802014"/>
        <point x="1.0646917654117294" y="2.7920803959802014"/>
        <point x="1.0646917654117294" y="3.7920803959802014"/>
        <point x="2.8796917654117293" y="6.032080395980201"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="00ff00"/>
      <stripeColor hex="ffff00"/>
      <stripeColor2 hex="ff00ff"/>
      <stripe1>false</stripe1>
      <stripe2>false</stripe2>
    </diylc.connectivity.TwistedWire>
      <name>W26</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.48219589020549053" y="2.454597270136494"/>
        <point x="0.48219589020549053" y="2.534597270136494"/>
        <point x="0.4371958902054905" y="2.594597270136494"/>
        <point x="0.5396917654117295" y="2.7820803959802016"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W29</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.7296835158242095" y="2.4470976451177444"/>
        <point x="0.6996835158242095" y="2.4970976451177442"/>
        <point x="0.6696835158242095" y="2.5720976451177444"/>
        <point x="0.5846835158242095" y="2.7620976451177444"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W30</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.88957552122394" y="6.039418029098547"/>
        <point x="2.2995755212239395" y="6.124418029098547"/>
        <point x="2.4845755212239395" y="7.394418029098547"/>
        <point x="2.5895755212239395" y="8.229418029098547"/>
      </controlPoints2>
      <color hex="ff0000"/>
      <gauge>_18</gauge>
      <color2 hex="ff0000"/>
      <name>W32</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.582090895455228" y="8.236808159592021"/>
        <point x="2.5520908954552284" y="8.321808159592022"/>
        <point x="2.5720908954552284" y="8.456808159592022"/>
        <point x="2.49" y="8.649999999999999"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W33</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.5595920203989806" y="8.221808909554522"/>
        <point x="2.6645920203989806" y="8.221808909554522"/>
        <point x="2.8545920203989805" y="8.316808909554522"/>
        <point x="2.955" y="8.475"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W36</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.8970751462426882" y="6.046917654117294"/>
        <point x="3.137075146242688" y="6.711917654117294"/>
        <point x="3.3970751462426882" y="7.046917654117294"/>
        <point x="3.2270751462426883" y="8.406917654117294"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="ffff00"/>
      <name>W37</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.2420578971051452" y="8.401799910004502"/>
        <point x="3.3620578971051454" y="8.746799910004501"/>
        <point x="3.1" y="8.95"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W38</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="3.234558272086397" y="8.386800659967003"/>
        <point x="3.334558272086397" y="8.301800659967002"/>
        <point x="2.7245582720863966" y="8.716800659967003"/>
        <point x="2.64" y="9.08"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W31</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.9270736463176843" y="6.0244187790610475"/>
        <point x="4.112073646317684" y="6.614418779061047"/>
        <point x="2.667073646317684" y="11.549418779061048"/>
        <point x="6.467073646317684" y="10.124418779061047"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <color2 hex="000000"/>
      <name>W39</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.48189590520474" y="10.119214039298036"/>
        <point x="6.6818959052047395" y="10.189214039298035"/>
        <point x="6.72189590520474" y="10.359214039298035"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <gauge>_22</gauge>
      <name>W40</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.474396280185992" y="10.119214039298036"/>
        <point x="6.974396280185992" y="10.119214039298036"/>
        <point x="7.424396280185992" y="10.209214039298036"/>
        <point x="7.7" y="10.55"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W41</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.6221388930553473" y="10.786680665966703"/>
        <point x="1.9421388930553474" y="11.191680665966704"/>
        <point x="3.4971388930553475" y="11.521680665966704"/>
        <point x="6.752138893055347" y="11.226680665966704"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W42</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.744382780860958" y="11.22165891705415"/>
        <point x="7.674382780860958" y="11.07165891705415"/>
        <point x="7.549382780860958" y="10.451658917054148"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W43</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.244382780860958" y="11.22165891705415"/>
        <point x="7.524382780860958" y="11.121658917054148"/>
        <point x="7.7" y="10.75"/>
      </controlPoints2>
      <gauge>_18</gauge>
      <name>W44</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.214309284535775" y="10.50169491525424"/>
        <point x="8.274309284535775" y="9.946694915254238"/>
        <point x="7.599309284535775" y="7.936694915254239"/>
        <point x="7.664309284535775" y="6.631694915254238"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W45</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.214309284535775" y="10.509194540272988"/>
        <point x="8.249309284535775" y="10.714194540272988"/>
        <point x="8.344309284535775" y="10.659194540272988"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W46</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.221808909554522" y="10.48669566521674"/>
        <point x="8.281808909554522" y="10.501695665216738"/>
        <point x="8.426808909554522" y="10.526695665216739"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W47</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.824339283035849" y="6.644389530523474"/>
        <point x="7.854339283035849" y="6.524389530523474"/>
        <point x="7.885" y="6.47"/>
      </controlPoints2>
      <gauge>_20</gauge>
      <name>W48</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.636838158092096" y="6.624388780560974"/>
        <point x="7.51" y="6.155"/>
        <point x="7.531838158092096" y="5.159388780560973"/>
        <point x="7.87" y="4.975"/>
      </controlPoints2>
      <gauge>_20</gauge>
    <diylc.connectivity.Line>
      <name>LN1</name>
      <alpha>127</alpha>
      <points>
        <point x="6.684385780710966" y="7.689335533223339"/>
        <point x="7.344352782360883" y="7.741832908354584"/>
        <point x="0.0" y="0.0"/>
      </points>
      <thickness value="1.0" unit="px"/>
      <arrowSize value="5.0" unit="px"/>
      <arrowTx serialization="custom">
        <java.awt.geom.AffineTransform>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
        </java.awt.geom.AffineTransform>
      </arrowTx>
      <arrowStart>false</arrowStart>
      <arrowEnd>false</arrowEnd>
    </diylc.connectivity.Line>
      <name>LN2</name>
      <alpha>127</alpha>
      <points>
        <point x="6.691885405729716" y="7.689335533223339"/>
        <point x="7.096865156742165" y="7.629338533073346"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN3</name>
      <alpha>127</alpha>
      <points>
        <point x="18.791267436628168" y="7.559349032548373"/>
        <point x="19.073766311684416" y="7.4118494075296235"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
      <name>LN4</name>
      <alpha>127</alpha>
      <points>
        <point x="21.863626818659068" y="7.756832158392081"/>
        <point x="21.496145192740364" y="7.951822408879557"/>
      </points>
          <default>
            <m00>1.0</m00>
            <m01>0.0</m01>
            <m02>0.0</m02>
            <m10>0.0</m10>
            <m11>1.0</m11>
            <m12>0.0</m12>
          </default>
      </arrowTx>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.4" y="7.2"/>
      <text>Choke 125C3A 50ma 4H</text>
      <font name="Tahoma" size="22" style="0"/>
      <horizontalAlignment>LEFT</horizontalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="17.165000000000003" y="8.324999999999998"/>
      <text>Reverb Transformer</text>
      <horizontalAlignment>RIGHT</horizontalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="17.165000000000003" y="8.425"/>
      <text>125A20B  25k:8 Ohm</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.15" y="4.8"/>
      <text>Smaller = Hotter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="6.2" y="3.8"/>
      <text>Clockwise = Hotter</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="20.6" y="10.55"/>
      <text>----- on caps indicates outer foil</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="20.6" y="10.45"/>
      <text>All resistors 1/2 watt 10% unless specified</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="20.6" y="10.35"/>
      <text>Fender cap specification was 400V unless specified</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="11.1" y="6.3"/>
      <text>O</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="9.05" y="1.15"/>
      <text>Max Speed</text>
      <verticalAlignment>TOP</verticalAlignment>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L7</name>
      <point x="21.405" y="11.28"/>
      <text>AnalogDok V.2.4</text>
      <font name="Dialog.bold" size="26" style="1"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L3</name>
      <point x="6.706884655767213" y="7.546842657867107"/>
      <text>Shielded Cable</text>
      <font name="Dialog.plain" size="22" style="0"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L8</name>
      <point x="19.036268186590675" y="7.329353532323385"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L9</name>
      <point x="21.818629068546574" y="7.681835908204591"/>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L10</name>
      <point x="7.79" y="6.025"/>
      <text>463VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L11</name>
      <point x="3.19" y="8.155"/>
      <text>5.64VAC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L12</name>
      <point x="2.53" y="7.935"/>
      <text>705VAC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L13</name>
      <point x="7.955" y="5.145"/>
      <text>463VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L14</name>
      <point x="8.51" y="5.125"/>
      <text>460VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L15</name>
      <point x="8.775" y="4.815"/>
      <text>-22VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L16</name>
      <point x="9.575" y="4.805"/>
      <text>-22VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L17</name>
      <point x="10.28" y="4.79"/>
      <text>380VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L18</name>
      <point x="9.44" y="7.15"/>
      <text>338VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L19</name>
      <point x="8.55" y="7.0"/>
      <text>390VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L20</name>
      <point x="10.04" y="7.135"/>
      <text>337VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L21</name>
      <point x="4.745" y="9.05"/>
      <text>464VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L22</name>
      <point x="4.795" y="8.645"/>
      <text>1VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L23</name>
      <point x="5.415" y="8.215"/>
      <text>-54VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L24</name>
      <point x="5.78" y="8.405"/>
      <text>1VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L25</name>
      <point x="5.5" y="9.285"/>
      <text>-54VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L26</name>
      <point x="7.34" y="9.21"/>
      <text>-54VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L27</name>
      <point x="6.71" y="8.985"/>
      <text>464VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L28</name>
      <point x="6.745" y="8.655"/>
      <text>1VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L29</name>
      <point x="7.635" y="8.395"/>
      <text>1VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L30</name>
      <point x="7.255" y="8.225"/>
      <text>-54VDC</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L31</name>
      <point x="4.265" y="2.985"/>
      <text>-54VDC</text>
    </diylc.misc.Label>
  </components>
  <groups>
    <set>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[99]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[159]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[12]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[160]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[11]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[102]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[212]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[48]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[173]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[175]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[210]"/>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[98]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[13]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[49]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[103]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[172]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[14]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[15]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[47]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[170]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[16]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[171]"/>
    </set>
    <set>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[3]"/>
      <diylc.shapes.Ellipse reference="../../../components/diylc.shapes.Ellipse[2]"/>
      <diylc.connectivity.Jumper reference="../../../components/diylc.connectivity.Jumper[3]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[2]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label"/>
      <diylc.connectivity.Jumper reference="../../../components/diylc.connectivity.Jumper"/>
      <diylc.connectivity.Jumper reference="../../../components/diylc.connectivity.Jumper[2]"/>
      <diylc.connectivity.Jumper reference="../../../components/diylc.connectivity.Jumper[4]"/>
    </set>
    <set>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[165]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[6]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[211]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[10]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[209]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[164]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[167]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[45]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[46]"/>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[96]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[169]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[5]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[168]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[101]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[9]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[7]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[166]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[163]"/>
      <diylc.connectivity.HookupWire reference="../../../components/diylc.connectivity.HookupWire[97]"/>
      <diylc.misc.Label reference="../../../components/diylc.misc.Label[162]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[100]"/>
      <diylc.passive.Resistor reference="../../../components/diylc.passive.Resistor[44]"/>
    </set>
    <set>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[3]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[3]"/>
    </set>
    <set>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[24]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[25]"/>
      <diylc.shapes.Ellipse reference="../../../components/diylc.shapes.Ellipse"/>
    </set>
    <set>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad"/>
    </set>
    <set>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[2]"/>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[2]"/>
    </set>
    <set>
      <diylc.connectivity.Eyelet reference="../../../components/diylc.connectivity.Eyelet[4]"/>
      <diylc.connectivity.SolderPad reference="../../../components/diylc.connectivity.SolderPad[4]"/>
    </set>
  </groups>
  <lockedLayers/>
  <lockedComponents/>
  <hiddenLayers/>
</project>
