<?xml version="1.0" encoding="UTF-8" ?>
<project>
  <fileVersion>
    <major>4</major>
    <minor>20</minor>
    <build>0</build>
  </fileVersion>
  <title>JCM800_effects_loop</title>
  <author>radio</author>
  <width value="29.0" unit="cm"/>
  <height value="21.0" unit="cm"/>
  <gridSpacing value="0.1" unit="in"/>
  <dotSpacing>1</dotSpacing>
  <components>
    <diylc.boards.BlankBoard>
      <name>Board1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="5.67" y="5.425"/>
        <point x="8.834999999999999" y="7.44"/>
      </controlPoints>
      <firstPoint x="5.67" y="5.425"/>
      <secondPoint x="8.834999999999999" y="7.44"/>
      <boardColor hex="f8ebb3"/>
      <borderColor hex="ada47d"/>
      <coordinateColor hex="b6b6b6"/>
      <xType>Numbers</xType>
      <coordinateOrigin>Top_Left</coordinateOrigin>
      <coordinateDisplay>One_Side</coordinateDisplay>
      <yType>Letters</yType>
      <mode>TwoPoints</mode>
      <type>SQUARE</type>
    </diylc.boards.BlankBoard>
    <diylc.connectivity.Turret>
      <name>Turret1</name>
      <size value="0.16" unit="in"/>
      <holeSize value="0.0625" unit="in"/>
      <color hex="e0c04c"/>
      <point x="10.0" y="5.5"/>
      <value></value>
    </diylc.connectivity.Turret>
      <name>Turret2</name>
      <point x="8.065" y="5.615"/>
      <value></value>
    <diylc.passive.PotentiometerPanel>
      <name>Send Level</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="9.63" y="2.025"/>
        <point x="9.93" y="2.025"/>
        <point x="10.23" y="2.025"/>
      </controlPoints>
      <resistance value="1.0" unit="M"/>
      <orientation>DEFAULT</orientation>
      <taper>REV_LOG</taper>
      <bodyDiameter value="1.0" unit="in"/>
      <spacing value="0.3" unit="in"/>
      <lugDiameter value="0.15" unit="in"/>
      <bodyColor hex="c0c0c0"/>
      <borderColor hex="808080"/>
      <nutColor hex="cbd5db"/>
      <waferColor hex="cd8500"/>
      <type>ThroughHole</type>
      <showShaft>false</showShaft>
      <view>ShaftDown</view>
    </diylc.passive.PotentiometerPanel>
      <name>Return Level</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="4.7" y="1.97"/>
        <point x="5.0" y="1.97"/>
        <point x="5.3" y="1.97"/>
      </controlPoints>
    <diylc.electromechanical.CliffJack1__4>
      <name>Send Input Jack</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="8.015" y="2.975"/>
        <point x="8.615" y="2.975"/>
        <point x="8.015" y="2.375"/>
        <point x="8.615" y="2.375"/>
      </controlPoints>
      <type>MONO</type>
      <orientation>_270</orientation>
      <value></value>
    </diylc.electromechanical.CliffJack1__4>
      <name>Return Input Jack</name>
      <alpha>127</alpha>
      <controlPoints>
        <point x="6.5" y="3.0"/>
        <point x="7.1" y="3.0"/>
        <point x="6.5" y="2.4"/>
        <point x="7.1" y="2.4"/>
      </controlPoints>
      <type>MONO</type>
      <value></value>
    <diylc.tube.TubeSocket>
      <name>V1</name>
      <alpha>127</alpha>
      <base>B9A</base>
      <type></type>
      <angle>0</angle>
      <color hex="f7f7ef"/>
      <electrodeLabels>1,2,3,4,5,6,7,8,9</electrodeLabels>
      <mount>CHASSIS</mount>
      <labelColor hex="acaca7"/>
      <controlPoints>
        <point x="7.475" y="4.27"/>
        <point x="7.6752317061078" y="4.415476849942387"/>
        <point x="7.5514817061078" y="4.505386487783051"/>
        <point x="7.3985182938922005" y="4.505386487783051"/>
        <point x="7.2747682938922" y="4.415476849942387"/>
        <point x="7.2275" y="4.27"/>
        <point x="7.2747682938922" y="4.124523150057613"/>
        <point x="7.3985182938922005" y="4.034613512216949"/>
        <point x="7.5514817061078" y="4.034613512216949"/>
        <point x="7.6752317061078" y="4.124523150057613"/>
      </controlPoints>
    </diylc.tube.TubeSocket>
    <diylc.shapes.Rectangle>
      <name>RECT1</name>
      <alpha>127</alpha>
      <value></value>
      <controlPoints>
        <point x="1.6" y="0.5"/>
        <point x="2.2" y="0.9"/>
      </controlPoints>
      <firstPoint x="1.6" y="0.5"/>
      <secondPoint x="2.2" y="0.9"/>
      <color hex="ffffff"/>
      <borderColor hex="000000"/>
      <borderThickness value="0.2" unit="mm"/>
      <edgeRadius value="0.0" unit="mm"/>
    </diylc.shapes.Rectangle>
    <diylc.connectivity.HookupWire>
      <name>W1</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.1" y="0.5"/>
        <point x="1.8" y="-0.1"/>
        <point x="8.7" y="0.5"/>
      </controlPoints2>
      <color hex="00cccc"/>
      <pointCount>FOUR</pointCount>
      <style>SOLID</style>
      <smooth>true</smooth>
      <lastUpdatePointIndex>-1</lastUpdatePointIndex>
      <gauge>_22</gauge>
      <striped>false</striped>
      <stripeColor hex="ffff00"/>
    </diylc.connectivity.HookupWire>
    <diylc.connectivity.Jumper>
      <name>J1</name>
      <alpha>127</alpha>
      <points>
        <point x="1.7" y="0.9"/>
        <point x="1.7" y="0.5"/>
        <point x="1.7" y="0.7"/>
      </points>
      <bodyColor hex="ffffff"/>
      <labelColor hex="000000"/>
      <leadColor hex="0000ff"/>
      <display>NAME</display>
      <flipStanding>false</flipStanding>
      <labelOriantation>Directional</labelOriantation>
      <moveLabel>false</moveLabel>
      <hideShortLeads>false</hideShortLeads>
    </diylc.connectivity.Jumper>
      <name>W3</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="10.7" y="1.9"/>
        <point x="10.7" y="2.9"/>
      </controlPoints2>
      <color hex="000000"/>
      <gauge>_22</gauge>
    <diylc.passive.Resistor>
      <name></name>
      <alpha>127</alpha>
      <length value="9.0" unit="mm"/>
      <width value="3.2" unit="mm"/>
      <points>
      </points>
      <bodyColor hex="82cffd"/>
      <borderColor hex="5b90b1"/>
      <leadColor hex="cccccc"/>
      <display>VALUE</display>
      <value value="100.0" unit="K"/>
      <power>HALF</power>
      <powerNew value="0.5" unit="W"/>
      <colorCode>_4_BAND</colorCode>
      <shape>Standard</shape>
    </diylc.passive.Resistor>
      <name>Turret3</name>
      <point x="7.9" y="6.48"/>
      <value></value>
      <name>Turret4</name>
      <point x="7.905" y="7.27"/>
      <value></value>
      <name>R1</name>
      <alpha>71</alpha>
      <length value="0.5" unit="in"/>
      <width value="0.125" unit="in"/>
      <points>
        <point x="7.905" y="6.475"/>
        <point x="7.985" y="6.045"/>
      </points>
      <value value="1.0" unit="M"/>
      <power>HALF</power>
      <colorCode>_5_BAND</colorCode>
    <diylc.misc.Label>
      <name>L1</name>
      <point x="10.29" y="5.57"/>
      <text>Ground&lt;br&gt;to Chassis</text>
      <font name="Dialog.plain" size="14" style="0"/>
      <center>false</center>
      <horizontalAlignment>CENTER</horizontalAlignment>
      <verticalAlignment>CENTER</verticalAlignment>
    </diylc.misc.Label>
      <name>R2</name>
      <alpha>71</alpha>
      <points>
        <point x="7.905" y="6.485"/>
        <point x="7.9" y="7.27"/>
        <point x="7.9025" y="6.8775"/>
      </points>
      <value value="22.0" unit="K"/>
      <power>HALF</power>
      <name>W7</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="1.53" y="2.73"/>
        <point x="4.91" y="2.785"/>
        <point x="9.245" y="3.84"/>
      </controlPoints2>
      <color hex="ff0000"/>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L2</name>
      <point x="0.935" y="2.735"/>
      <text>To B+ (260v-280v)&lt;br&gt;From pin 6 of 2nd preamp tube</text>
      <font reference="../../diylc.misc.Label/font"/>
    </diylc.misc.Label>
      <name>W8</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.51" y="2.415"/>
        <point x="6.84" y="2.395"/>
        <point x="6.83" y="2.45"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W9</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.435" y="2.435"/>
        <point x="7.455" y="2.68"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W10</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="8.625" y="2.37"/>
        <point x="8.96" y="2.405"/>
        <point x="9.89" y="2.78"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Turret5</name>
      <point x="7.54" y="5.595"/>
      <value></value>
      <name>R3</name>
      <alpha>71</alpha>
      <points>
        <point x="7.55" y="5.605"/>
        <point x="7.725" y="6.0425"/>
      </points>
      <value value="560.0" unit="R"/>
      <power>HALF</power>
      <name>Turret7</name>
      <point x="7.305" y="6.52"/>
      <value></value>
    <diylc.passive.AxialFilmCapacitor>
      <name>.68 250v Mylr</name>
      <alpha>127</alpha>
      <points>
        <point x="7.54" y="5.6"/>
        <point x="7.4225" y="6.06"/>
      </points>
      <bodyColor hex="ffe303"/>
      <borderColor hex="b29e02"/>
      <value value="0.68" unit="F"/>
      <voltage>_63V</voltage>
      <voltageNew value="250.0" unit="V"/>
      <showOuterFoil>false</showOuterFoil>
      <outerFoilColor hex="ffffff"/>
    </diylc.passive.AxialFilmCapacitor>
      <name>W11</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.4" y="4.505"/>
        <point x="7.385" y="4.655"/>
        <point x="7.245" y="5.29"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R4</name>
      <alpha>71</alpha>
      <points>
        <point x="7.305" y="6.525"/>
        <point x="7.6025" y="6.8975"/>
      </points>
      <power>HALF</power>
      <name>W5</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.795" y="6.435"/>
        <point x="9.05" y="8.615"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W13</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.13" y="4.205"/>
        <point x="7.015" y="4.845"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Turret9</name>
      <point x="8.605" y="6.485"/>
      <value></value>
      <name>Turret6</name>
      <point x="6.79" y="5.655"/>
      <value></value>
      <name>C1</name>
      <alpha>127</alpha>
      <points>
        <point x="8.335" y="6.05"/>
      </points>
      <value value="0.022" unit="uF"/>
      <voltageNew value="600.0" unit="V"/>
      <name>W2</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="9.88" y="2.43"/>
        <point x="9.47" y="5.435"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W14</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.645" y="0.215"/>
        <point x="1.145" y="0.215"/>
        <point x="1.86" y="0.175"/>
        <point x="1.93" y="0.505"/>
      </controlPoints2>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L3</name>
      <point x="0.405" y="0.34"/>
      <text>From preamp&lt;br&gt;Master Volume VR2</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L4</name>
      <point x="1.945" y="0.675"/>
      <text>DPDT Switch</text>
    </diylc.misc.Label>
    <diylc.misc.Label>
      <name>L5</name>
      <point x="0.45" y="1.33"/>
      <text>To power amp&lt;br&gt;C9 coupling cap</text>
    </diylc.misc.Label>
      <name>W17</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.31" y="1.985"/>
        <point x="5.22" y="2.295"/>
        <point x="5.59" y="2.545"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W18</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.755" y="3.395"/>
        <point x="5.235" y="3.005"/>
      </controlPoints2>
      <color hex="00ff00"/>
      <gauge>_22</gauge>
    <diylc.misc.Label>
      <name>L6</name>
      <point x="8.325" y="4.29"/>
      <text>12DW7 Triode&lt;br&gt;Send: pins 1,2,3&lt;br&gt;Return: pins 6,7,8</text>
    </diylc.misc.Label>
      <name>Turret10</name>
      <point x="6.665" y="6.68"/>
      <value></value>
      <name>C2</name>
      <alpha>127</alpha>
      <points>
        <point x="6.89" y="5.775"/>
        <point x="6.91" y="6.465"/>
        <point x="6.9" y="6.12"/>
      </points>
      <moveLabel>true</moveLabel>
      <value value="35.0" unit="uF"/>
      <voltageNew value="25.0" unit="V"/>
      <name>R5</name>
      <alpha>71</alpha>
      <points>
        <point x="6.725" y="5.805"/>
        <point x="6.745" y="6.445"/>
        <point x="6.735" y="6.125"/>
      </points>
      <value value="2.2" unit="K"/>
      <power>HALF</power>
      <name>J2</name>
      <alpha>127</alpha>
      <points>
        <point x="6.72" y="5.79"/>
        <point x="6.755" y="5.7225"/>
      </points>
      <name>J3</name>
      <alpha>127</alpha>
      <points>
        <point x="6.84" y="5.715"/>
      </points>
      <name>J4</name>
      <alpha>127</alpha>
      <points>
        <point x="6.7875" y="6.5725"/>
      </points>
      <name>J5</name>
      <alpha>127</alpha>
      <points>
        <point x="6.75" y="6.45"/>
        <point x="6.7075" y="6.565"/>
      </points>
      <name>W15</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.4" y="4.76"/>
        <point x="7.26" y="2.925"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W16</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.675" y="6.68"/>
        <point x="7.13" y="6.845"/>
        <point x="7.48" y="7.255"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>Turret11</name>
      <point x="6.32" y="5.655"/>
      <value></value>
      <name>C3</name>
      <alpha>127</alpha>
      <points>
        <point x="6.02" y="6.655"/>
        <point x="6.17" y="6.155"/>
      </points>
      <name>Turret12</name>
      <value></value>
      <name>W19</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="5.625" y="4.625"/>
        <point x="6.16" y="4.025"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>R6</name>
      <alpha>71</alpha>
      <points>
        <point x="6.315" y="5.66"/>
        <point x="6.49" y="6.17"/>
      </points>
      <power>HALF</power>
      <name>W20</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="0.78" y="1.3"/>
        <point x="1.28" y="1.3"/>
        <point x="1.785" y="1.295"/>
        <point x="1.9" y="0.915"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W21</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="2.115" y="0.91"/>
        <point x="2.105" y="1.605"/>
        <point x="2.615" y="1.91"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W22</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="6.51" y="3.01"/>
        <point x="6.785" y="2.66"/>
        <point x="6.83" y="3.045"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W12</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="4.4" y="2.57"/>
        <point x="6.15" y="2.66"/>
      </controlPoints2>
      <gauge>_22</gauge>
      <name>W6</name>
      <alpha>127</alpha>
      <controlPoints2>
        <point x="7.735" y="4.765"/>
        <point x="8.015" y="5.305"/>
      </controlPoints2>
      <gauge>_22</gauge>
  </components>
  <groups/>
  <lockedLayers/>
  <lockedComponents/>
  <hiddenLayers/>
</project>
