Amp Stuff => EZ Board postings => Topic started by: Geezer on June 17, 2005, 09:03:29 pm
> installing pots
<< Prev Topic | Next Topic >>
Author Comment
vinman753
Junior tube assistant
(2/14/04 8:40 am)
installing pots
kind of a basic 101 question, but....
when you guys install pots do you put a nut and washer on both sides or just the outside and be careful not to overtighten? (i pulled one apart by accidentally overtightening.)
Tiny Daddy
I will work on all amps
(2/14/04 9:17 am)
Re: installing pots
Pots have a sholder that is supposed to rest against the inside of the panel so an inside nut is not necessary.
bluesbear
Hey get your own solder
(2/14/04 10:30 am)
Re: installing pots
"Pots have a sholder that is supposed to rest against the inside of the panel so an inside nut is not necessary. "
Definitely! The only exception would be to adjust the length of the shaft if it is a little too long.
Dave
vinman753
(2/14/04 11:40 am)
Re: installing pots
the pots i have gotten have one or two (depending on mfr.) little tabs that face forward, so there is a gap between the inside of the pot and the surface. I hope i explained that right. is that what you mean by the shoulder or should those little tabs be bent or snipped? thanks.
6G6
(2/14/04 12:44 pm)
Re: installing pots
The little tabs are there to go into little holes to keep the pot from turning with the shaft if the nut is loose.
Tiny Daddy
(2/14/04 12:46 pm)
Re: installing pots
Some panels have holes for the tabs to help prevent the pot from rotating. But you can just break them off.
ganzonimx
(2/14/04 12:57 pm)
Re: installing pots
I always drill a small hole on the corresponding side for these tabs, its fast and easy and the hole will be covered by the faceplate. These tabs also helps to not stress the case of the pot when bolting them to the chassis.
Cris
vinman753
(2/14/04 3:20 pm)
Re: installing pots
thanks a lot everybody.
Topic Commands
jump to: Tube Amp Building - Tweaks - Repairs (New)New Product Suggestions (New)Praises - Complaints - Suggestions (New)Buy - Sell- Trade (New)Archives (New)
Powered By ezboard® Ver. 7.32
