Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: chuggy on November 07, 2010, 12:31:10 pm
I'd like to substitute diode rectification in my Kay 703 which has a dead 35Z5 half wave recto.
Would this involve a single diode or string from cathode to plate? What diode(s)? A resistor to substitute for the series heater would be needed. The data sheet says heaters run at 35 V with .15 A current.... so 233 or so ohms bridging the heater connections?
THANKS-
JIM
You can use a single 1N4007. Put a sag resistor in series with it to keep the B+ about where it was with the tube. I'd start with 100Ω but experiment to find the best value.
Your math looks good for the filament replacement resistor. Use at least a 10 watter.
You can buy a 35Z5 for $9 at AES (http://www.tubesandmore.com/). They also have a 35Z4 which should work fine for $2.50.
Unless the filament is out, just wire a 1N4007 across pins 5 and 7 and leave the tube in. B+ will go up so use 200V or 250V filter caps.
... B+ will go up so use 200V or 250V filter caps.
Which means buying a new can cap in that amp (in all likelihood). That can costs several times more than a new 35Z5. So it seems like it's "cheaper to keep her."
But maybe you needed new filters anyway. Will a new can rated for higher voltage (due to less diode drop) fit in the old space? Usually there's no room to spare on this type of amp.
Can was replaced with individual caps that fit easily.
Got a NOS 35Z5 via ebay for $1.04, so diodes on hold.
