Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: 961le on November 23, 2010, 06:28:25 am
Title: finding the source of a buzz
Post by: 961le on November 23, 2010, 06:28:25 am
i just changed from mallory caps to sozo and rewired my 18 watt build. the new grounding scheme definitely quieted down the hum i was living with from my first build. when i started it up it sounded great at low volumes. as i played up the neck i found that a g# note caused a nice little noise ringing along with the note. it is coming from the speaker. it sounds like metal against glass. a weird ringing.
it does not occur when i use the amp as a head just as a combo. it is in a pro jr cab. other that tubes being replaced what would be some other places to check? i will post a few pics tonight. it will really sound great when i find this noise.
thanks,
doug
Title: Re: finding the source of a buzz
Post by: FYL on November 23, 2010, 06:41:08 am
Probably microphonic tube(s). Check if they are secure in their bases. Use the gentle tap test in order to find the culprit(s).
Post by: 961le on November 23, 2010, 02:04:34 pm
went home for lunch and swapped v1 and v2. it went away. i guess while i had it broken down for the rebuild i got them mixed up. ill post pics later
