Other Stuff => Effects => Topic started by: Platefire on December 15, 2010, 12:23:44 pm
On my main pedalboard I have true bypass switch with two switchable effects loops and all my regular effects pedals run through one loop. I have space for one more Boss size pedal. I was looking for a new pedal that would be that small but would have multi effects and maybe some amp modeling but in my searches haven't turned up such an animal. It may not exist! I was wanting to put this on the other effect loop. The closest thing I've found is the old Zoom 505 which is kind of dated that as I recall is a little larger than a Boss pedal. It would be nice to have some whacko effect dialed up and punch it in when I need it. The pedal needs to go where the Digital Delay is on the middle on the extrem right side of pedalboard(that pedal died :cry:).
Does anyone know of a muti-effects pedal in this size? Thanks, Platefire
This is about as small as I could find: http://www.digitech.com/products/Multi-Effects/RP155.php
Thanks! but at 8 3/4" wide x 10 3/4" long x 2 5/8" High----I think my space is way used up :wink:
I did turn up this that kinda fit the bill but the effects are very limited and most of the effects I have on my exiting pedalboard with the exception of phase, flanger and pitch shifter. Plate
http://www.wholenote.com/item--EM.BHR-FX600
