Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Tone Junkie on January 14, 2011, 09:32:18 pm
Guys Im always crappy with this stuff could you check me and see if Im right, Sorry for such newbie crap. Thanks Bill
100k/39k=28k
100k/68k=40k
Im doing some stuff on switches and need to get it right. :angel
Here's a handy online calculator: http://www.1728.com/resistrs.htm
Thanks worked great and I was right.Bill
R1*R2/R1+R2= resistance.
Or you add up the inverse of each resistance value and you get the inverse of the total paralleled value.
i.e.: e.g.: for 220k in parallel with 68k in parallel with 47k = 1/220k + 1/68k + 1/47k = 1/24.67k
JM2CW
I actually I have the math problems printed out and pinned to the wall so I can continue to use it for several things involving tube amps its just been 30 yrs since I took algebra and really used it, It was nice to get to the online calculaters and get them to work and check my math.
Thanks Bill
There's a machine for that now....
100k/39k=28k ?
(http://i.imgur.com/0kDh3.gif)
100000
1/X
39000
1/X
1/X
In Windows: Start, Run, "calc". The default skin lacks 1/X, use View menu to change to Scientific.
(Yes, if you know why, you can simplify to 100 and 39 and get 28.05..)
However we must not become dependent on machines.
39K is not far short of 50K. And 50K is exactly 100K||100K. So 50K||100K is the same as 100K||100K||100K. Which of course is 33.3K.
Or -- 39K is a bit high of 33K. And 33.3K is 100K||100K||100K. So 33K||100K is the same as 100K||100K||100K||100K. Which is of course 25K.
The answer is between 33K and 25K. Often this is close-enough.
If you must slice thinner: interpolate. 50-39= 11. 39-33= 6. The 33K cheat is closer to the truth than the 50K cheat. And the answer is roughly 1/3rd of the way from 25K to 33K. 33-25 is 8. 1/3rd of 8 is about 3. 25K+3= 28K. About 28K.
PRR man I wish you were my neighbor we would have some fun chats.
thanks Bill
