Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jojokeo on January 17, 2011, 09:38:34 am
Quick sheet available for Voltage dividers, Signal Output %, Parallel resistors @
http://www.el34world.com/Forum/Files/VDSO.xls
I developed an Excel spreadsheet a while back that might
be helpful for others to use when dialing in or creating their amps? It has
saved me time of having to re-look up the formula and working this out by
hand to get the amount of signal wanted or when part substituting to get what I
want and also maybe to know what I did. It also will kick out two or three
resistors in parallel like in a calculator link I just saw in another thread recently.
It's set up for creating voltage/signal dividers w/ the usual pot values or if
using fixed resistors too. Instead of typing in 100000 (all of the zeroes) for
100K value - simply type in 100
* You can "save as" & it will save it as a spreadsheet to your computer. When closing please don't "save changes" or it might affect your changes onto others?
Joe
Thanks Joe it shall come in handy.Bill
y/w Doug was kind enough to put it on the site to provide the link.
Thank you for sharing your work!
+1 Thanks!
Chip
