Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: oldhippy on March 23, 2011, 10:27:42 am
hey guys
I've been reading about this TOS and I've got to have one. I'm interested in building it as an FX unit so I could use it with a variety of amps. If I missed it, my apologies, but has anyone here done so? Practical? My wife would have a cow if another amp showed up but she might miss this...any thoughts? Thanks in advance
I don't see why you couldn't make that work?
I think if I were going to attempt that, I'd do the preamp (clean and OD) and
add a 12AU7 active effects loop. And then plug it into a passive effects loop return of another amp. This is sort of the idea & direction I'd head.
I'm in the planning stages of a similar project, unrelated to the TOS. I have a few builds lying around with power amp inputs wired in them, and then I came across a small $25 PT that David Allen sells that *think* will fit in a 1U chassis and has enough juice for three 12A_7's. This PT wouldn't handle Tubenit's suggestion, but I happen to be building a d'lator along with my preamp in another 1U chassis, so the end result will be the same.
For Oldhippy
Tubenit some days ago posted a layout for that preamp
http://www.el34world.com/Forum/index.php?topic=11017.msg101586#msg101586
For Boots Deville
please can you give more infos about that PT ?
have you a link ?
Kagliostro
I guess since Doug doesn't offer a similar product, this is OK.
Link: http://allenamps.com/parts.php#transformers
Look for model TP2X
260V (no CT) at 10mA, 6.3V @ 1A
Kagliostro
