Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on April 03, 2011, 11:23:16 am
Title: Geloso G. 213-A - How to mod for guitar use ?
Post by: kagliostro on April 03, 2011, 11:23:16 am
Yesterday I got another Geloso amp
that is an old G. 213-A model
mounting:
1 x 5V4-G (missing because replaced by the previous owner with 2 diodes)
2 x 12SL7-GT
2 x 6V6-G
If the V1 was a 12ax7 I've lot of  schematicas to be copied as to modify the input in order to have a guitar input
but octal tubes in this position are new for me
1) how to arrange the V1a - V1b to have a standard guitar amp input ?
2) which ToneStack is better to put between V1b and V2a ?
    or is better to maintain a one knob control (as is or with which modifies) ?
3) any mod to the PI section ?
4) I'm confused about Filament Supply and Bias Supply
Kagliostro
p.s.: that in the photo is one I've find in the web, not mine (and it is modified)
Title: Re: Geloso G. 213-A - How to mod for guitar use ?
Post by: sluckey on April 03, 2011, 11:39:31 am
Here's what I did to a similar octal amp. V1 is now a higher gain 6SL7. Page 4 is the modified 'for guitar' amp. May give you some ideas...
http://home.comcast.net/~seluckey/amps/rocky/rocky.pdf
Post by: kagliostro on April 03, 2011, 12:00:13 pm
Thanks Sluckey
your Rock-Ola Mod looks very interesting and very well documented
a good source of ideas
with your solution if I don't want to make new holes on the front panel I must find double 250k and 1M pots (not ganged) and put a resistor in parallel as to use one of the 1M pots as raw control
I must verify the voltages of the Geloso, I don't know it
Kagliostro
