Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: DummyLoad on July 28, 2011, 05:24:46 pm
Title: 7867 PBP
Post by: DummyLoad on July 28, 2011, 05:24:46 pm
it would seem that tung-sol came up with some A1 & AB1 parameters, slapped a number on the 6CD6GA called it an audio pentode. has the same crappy g2 B+ max. rating, but it does seem as though this is the case.
sensitivity is decent - 33Vrms to get 28W output. seems to be similar to the 7591 gain-wise - just funky PS requirements.
http://scottbecker.net/tube/sheets/127/7/7867.pdf (http://scottbecker.net/tube/sheets/127/7/7867.pdf)
http://scottbecker.net/tube/sheets/127/6/6CD6GA.pdf (http://scottbecker.net/tube/sheets/127/6/6CD6GA.pdf)
delon doubler w/ 120Vrms transformer might be a nice setup - 170Vg2/340Vp for a low budget 30W amp. in that arrangement, i'd use hammond 1645A or 1650G.
it's been a slow day in the network mines.
--DL
Title: Re: 7867 PBP
Post by: Shrapnel on July 29, 2011, 12:21:07 am
Interesting.
My RCA book has the 6CD6GA in it, and also says a related type is the 25CD6GB. It has the graphs, but doesn't hint at audio use as they call it a Horizontal Deflection Amplifier. The 6CD6GA apparently replaced the 6CD6G.  :dontknow:
Subs: (Sam's TUB-8, '64)
6CD6G: 6DC6GA, 6DN6, and 6EX6
6CD6GA: 6EX6.
7867: 6EX6 in parallel circuits
Cross referencing: (RCA's RC-23 '64)
6CD6G - Beam Power - Discontinued
6CD6GA - Beam Power
6DN6 - Beam Power - Renewal type
6EX6 - Beam Power - Renewal type
7591 - Power Pentode
7868 - Power Pentode
6K6GT - Power Pentode
6L6, 6V6 - Beam Power
I guess I need to look at those Tung-Sol datasheets.  :icon_biggrin:
[EDIT:] Looking at your links, the 7867 is intended for audio use. The 6CD6GA wasn't, but through the chain evidence above, should work on a "close enough" basis.
[Duh Statements:] Although, splitting hairs, we all know Beam Power isn't a Power Pentode... However, they do server similar purposes, and in some instances are hard to distinguish differences in audio use.
Title: Re: 7867 PBP
Post by: PRR on July 29, 2011, 01:25:12 am
Speaking generally -- why would you want a higher G2 voltage than needed to pull the maximum current you need? G2 current is just a loss. Use as little as you can.
Also: the plate knee voltage is related to G2 voltage. You know how folks wrongly say a pentode plate must sit higher than G2? Actually, and of-course, it can go lower, but it doesn't work so good when P is below some fraction of Vg2. That fraction is ill-defined, depends on detail design, but for "power" devices may be a number near "5". If you run 450V on G2, the plate won't pull much below 90V; that 90V of B+ is wasted. If Vg2 is 150V, the plate may pull down to 30V; much less waste of B+ power.
Also: screen-tube devices act like triodes except the attracter and collector are separated (G2 and Plate). How do you get more current in a triode (without adding costly cathode area)? Lower the Mu! 12AX7 passes 1-2mA. 12AU7 passes 10-20mA. 2A3 passes 100+mA (albeit with a lot more cathode).
The only annoyance is that odd G2 voltage. If we increase it (ignoring ratings) then the available cathode current is FAR more than we need, and large enough to melt something. Overdrive could smoke. You know why we can't simply resistor drop G2 voltage significantly. Extra windings and rectifiers and caps are a profit-killing expense. So we audio guys tend to run Mu=10 tubes. Then G2 can usually be held near Plate voltage. While we may waste 10s of volts at the knee, another couple dozen volts of main B+ is cheaper than windings rects and caps.
How did this work in a TV? The main power was 117V hot-chassis, 150V DC was cheap. That fed all the small-stuff and G2, and plate to get started. When H-sweeping, energy flowed through the yoke and back through a fat diode. The returned energy was caught on a cap to make B+Boost. It's not free energy, so it does not rise forever, generally levered itself up to 250V-500V. This higher B+ along with the low knee gives a wide swing of plate voltage, good efficiency (however two tubes in the path, sweep and diode), and less leverage needed to make the CRT HV.
If G2 voltage is "reasonable" (high enough to make your current, but not a lot higher), then grid-swing is nearly Vg2/Mu. 400V/10=40V. 150V/4= 37V. No great difference in drive voltage.
Again, TV is not audio. If we need ~~40V of clean drive, we want over 200V of B+ on the driver. The driver needs more than G2 voltage of a Mu=4 tube, however with Mu=10 the G2 voltage is ample even with added filtering. TV H-sweep drivers didn't follow a guitar string, they slammed rail to rail. Nonlinearity was unavoidable and trimmed-away (for this prescribed wave-shape).
The H-Sweep tubes do make much sense when you get farther above "stage amp" size. Over 100W, the added cost of separate G2 supply looms less large, and the plate supply savings start to mount.
The disadvantage is that H-sweep tubes need huge I and V rating, but ideally don't need any Pdiss. In linear audio, V is limited by economic OT winding, and I is often limited by Pdiss. So we want a bigger plate, not so much cathode.
The advantage is that H-sweep tubes are occasionally a glut on the market.
Agree the 6CD6 and 7867 are the "same" tube aimed for different uses. Note that for audio (where we often know our Pdiss even when distressed) the rating is higher than for TV H-Sweep (where Pdiss is low until stuff goes wrong).
Title: Re: 7867 PBP
Post by: DummyLoad on July 30, 2011, 12:03:08 am
interesting?  :icon_biggrin:
http://www.ohio.edu/people/postr/bapix/Duk1a475.gif (http://www.ohio.edu/people/postr/bapix/Duk1a475.gif)
article.
http://www.ohio.edu/people/postr/bapix/Dukane.htm (http://www.ohio.edu/people/postr/bapix/Dukane.htm)
