Other Stuff => Effects => Topic started by: dude on August 18, 2011, 11:53:49 am
Nothing but the Wah wah pedal and it hums, take it out go straight to amp, quite.
I read about a ground loop but don't know the fix with a pedal.
If I turn the pedal off, no hum.
Any suggestions? I did search and found the ground loop could be causing the problem.
But the fix?
thanks,
al
Does it hum regardless of which amp it's connected to?
Yes any amp, alone or with other pedals in a chain.
It's definitively the wah-wah pedal if I leave the wah off no hum.
I play an 18 watt Trinity SIII TMB, which plays great no hum alone or with these three pedals, strat into a Boss CS-2 compression, then Ibanez TS10 (modded to 808 specs) and sometimes an Ibanez GE10 EQ. I just started to try the wah-wah and put it first in the chain.
Just the strat and wah and it hums too, no other hum with any of the other pedals just when I add the wah in the front.
Thanks,
al
What wah-wah pedal are you using?
Is it powered with battery or a power supply?
Crybaby, from the late eighties or early nineties.
Model GCB-95, made in USA
external power supply at 9.45v dc
Thanks,
al
Try and see what happens with battery.
Sorry for the long delay getting back, I didn't have a good 9 volt and kept forgetting every time I went out.
Anyway, Bingo works great no hum at all.
So I guess I'm limited to a 9 volt for the wah?
thanks,
al
Maybe get a better power supply.
My old Thomas Organ Cry Baby works fine with my power supply and it was never meant to be used with anything except a battery.
