Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: SLW on September 11, 2011, 04:30:18 pm
Well here goes. Feel free to comment on what you see here. I enjoy learning from others.
The Beginning
I have never done anything like this before and wasn't sure where to start. I decided to start at the beginning. Props to Tubenit and Geezer for the circuit and all the work they put into the design. I based this heavily on their design. I wanted a tube based effects loop and VVR so I added them to the circuit. Here are the schematic and layout that I am working from. I used inkscape to draw everything to scale when I developed the layout. I spent many weeks working on the layout before I ordered a single part. I want to do everything that gives me the best chance of success on any project. I guess I am a bit of a perfectionist. I tried to figure out every part and its position in the amp before I ordered a single part or drilled a single hole. Even then, I did make a few generalizations in the layout like the channel changing and 5VDC board.
Here are the boards. The big one is the main circuit for the amp. The two smaller boards are for filter caps used in the power supply portion of the amp. The boards are made from the turrets and board material that Doug sells here. I cut the boards to size. I covered the board with painters tape and laid out the positions of everything using my layout. Drilled the holes and installed everything. Pretty simple.
The PCB is for the channel switching portion of the amp. I laid out the PCB and had it made with a batch of prototypes for pedals.
Looking good!! Thanks for sharing. :occasion14:
Very nicely done!
NICE !
Many thanks for sharing
Kagliostro
VERY neat workmanship!
Having built Tubenits and Geezers TOS myself I do know that lead dress will be critical.
Well worth the effort for sure, It is one of the most versatile amps I've ever heard and without a doubt my proudest build.
Ray
Chassis
I bought a 17.5 X 8 chassis for Watts Tube Audio. Just like the boards, covered the chassis in painters tape. Using my layout I marked up the cutouts and the centers for all of the holes. I used a step drill for the larger holes. I used a jig saw to cut the rectangles and finished them up with a file.
Looks real good.
What are the little holes above the vol. and tone pots for? LED's or switches?
Thanks, Brad :icon_biggrin:
Nicely done! I'm taking notes. :smiley:
They are for LED's. I am using 3mm LED's with a bezel. They just barely fit. There is just enough room for the nut to turn and not hit the top of the chassis.
Time to start the putting it all together. I wasn't sure where to start so I decided to start with things that were on the bottom first. I mounted the transformers first. Next came all of the LED bezels. I mounted the relay board, main switch and the VVR parts. I then started wiring things up. The VVR, LEDs and relay board worked out fine.
Then the first two snags showed up.
First snag.
The small board for the rectifiers, first PS filter stage and the heater connections mounted just fine in the space allowed but there is not enough room to get my iron in there. See the photo.
Second snag.
There is a conflict of space between the second small filter board and the switch in the chassis. When the board is mounted on the stand offs one of the caps hits the lugs on the switch. See the photo.
I am not sure what to do. I have thought about moving the rectifier board back but there is not enough room. I have thought about standing the filter board up on brackets. I have four 5 lug terminal strips that I could use somehow but I have not put any effort into figuring it out. Any good ideas out there?
For the next amp I build I will get a chassis that has more room.
Hi SLW, Looking Good :icon_biggrin: The rectifier board,could it be mounted with some aluminium angle so that it sets above the power socket and the same with the other board so that it is mounted between the VVR and switch???
I just looked again and thinking you won't want bolt heads on the front panel.So reusing the bolt holes already there, bolt it upright with the aluminium angle.
First snag.
Twist, then attach the leads from the transformer prior to bolting the board down. you might wind up with wires a shade longer than your "ideal" but still neat and workable.
Second snag.
It's hard to see in the photo's perspective... can you rotate this board 180 degree to place the resistor under the switch and gain your clearance?
If that doesn't work, 2 L-brackets can hold the board up on edge. Ideal brackets may have a continuous channel running down the middle, so you don't have to line up board holes to bracket holes.
You might be able to use radial lead electro-caps?
Look's good other wise.
Brad :icon_biggrin:
Fish paper,
Bolt it under the spacers on the filter board
Then slide it between the lug and cap, be generous
been done millions of times works 100%
I built my TOS in a 19" chassis and I swore when I build it again I will never use less than a 24" chassis
How Tubnit and Geezer ever crammed all that into an 18" chassis...And then modded it time an again.. Hats off to them both for such a great amp but WOW I must defer to the masters for that shoehorn!!
Ray
OH!
Super Sano build! neat and clean!
Thanks for the help guys.
That sounds like a simple solution. I like it.
The board will fit vertically in the chassis. I will explore this option.
Fish paper,
Fish paper is a new one on me. What is fish paper?
I like radial lead caps and use them all the time in my pedals. I will spend a little effort in my next amp working them into the build. There is somebody on the forum that uses radial caps on a circuit board that they make. I like the sound of that. I decided to build this amp in the conventional way just for the experience. I have experience laying out PCB's, but not for high voltage applications. That will be another good thing to learn. :icon_biggrin:
Fishpaper is a vulcanized fiber material, which can be sometimes used for insulation. Note that not all fishpaper is rated for electrical insulation; the stuff listed here (http://www.mcmaster.com/#8490k15/=ebdzkx) has a separate listing for the stuff you want to use.
They don't give the ratings for each thickness of electrical grade fishpaper listed on that site; I'd think that 0.030" is thick enough to offer good insulation, while still being just thin enough to easily cut and punch out screw holes.
Your choice on whether to insulate and mount as originally planned, or use an L-bracket to stand the board up.
I finally had a rainy Saturday and a few hours to work on my amp. We spend as much time as possible outside before winter gets here. My 4 children keep me pretty busy and my wife gets an hour or two a day. All that cuts into “tinker” time.
I decided to mount the filter board vertically. I bought a ˝ X ˝ Al angle and made a little bracket. The bracket is screwed to the chassis. The hole in the bracket is clearance for a turret. With that mounted I attached the all the PT wires. I did attach wires to the rectifier board before mounting the board. The start of the heater wires are in. I also hooked up the primary side of the OT. I made sure to install tubes in the sockets before soldering anything to the sockets. I will hook up the secondary site of the OT next. After that I will install the pots and hook them up.
WHY?
I've never done that, am I missing a trick?
Be sure to leave your leads long, seems when I cut them to length a howl and have to reverse them.
With so many pots in my TOS build, I mounted the pot outside and soldered up all my leads and caps and what nots leaving long flying leads to solder to the board after you un-mount the pots and put them inside.
WHY?
Hi Ray, take a look in here, reply # 4 ....
http://www.el34world.com/Forum/index.php?topic=12428.0 (http://www.el34world.com/Forum/index.php?topic=12428.0)
Brad :icon_biggrin:
SLW, looking good! Look's like you got it wooped now.
Hey, your gut pic's are great! I just bought a dig. camera and I'm trying to learn how to how to take pic's as good as your's. :dontknow:
I started a post on this here..... http://www.el34world.com/Forum/index.php?topic=12283.0 (http://www.el34world.com/Forum/index.php?topic=12283.0)
Would you please look at it and add to it? I'm having a problem with lighting.
How did you light those shots???? :think1:
I don’t consider myself much of a picture taker. I have two of the fluorescent 4’ fixtures above my workbench. Each has two bulbs, no covers or anything, just a box with two bulbs mounted to it. Enough of the bulb is above the work surface of my bench that I don’t get any real shadows and it doesn’t matter where I stand.
Great job and thanks for showing all steps I always like looking at others work and seeing how achieving the same things can be done differently. The TOS will be one of my next builds.
Very neatly done looks like a lot of pre planing went into this. Look forward to seeing more posts.
Today a got a couple of hours to tinker. I finished the OT wiring and I got the FX loop jacks and pots hooked up. I had my little buddy “helping” me tonight. I took this shot of him looking at the amp. Notice he is holding a pair of needle nose in his right hand. I know this isn’t amp building but I am a proud dad. I have some fun discussions with him while tinkering. He is 6.
Son – what is that thing?
Me - It’s a capacitor.
Son – What does a cap-sister do?
Me – It stores electricity.
Son – Like a jar?
Me – Yep.
Me – It’s a resistor.
Son – What does a re-sister do?
Me (not sure what to say) - It slows down electricity.
Son – Like brakes on my bike?
Me - Yep.
Son – What is that thing?
Me - It’s a transformer.
Son – What does it do?
Me - Here is a wire. Will you cut it into small pieces for me?
Anybody know how to explain a transformer to a six year old?
Can't do it. Especially if he's seen the movies! :icon_biggrin:
a transformer transforms the voltage to either high or low?
It makes more electricity..... now keep cutting up those little wires. :laugh:
Maybe show him with/on a little wall wart from one of his games or something like that? Use a DVM. FWIW, you'r a good dad teaching your son how to use his hands and mind. :icon_biggrin:
Brad
Wow -- nice work!!
Hey if you ever decide you want to sell some of those channel switch boards, I am your man!!! I bought a TOS board awhile ago but I am very leary of taking on the whole channel switch wirefest -- but it is the real allure of this amp so I am kinda stuck!!
Been trying to get into the short-run PCB thing - been hoping Doug would answer a question I sent him about his inkjet printer hack -- but alas -- nothing yet.
Again very cool work!!
Thanks for the kind words Willabe. This son likes to tinker. I bought him a kids carpentry book for Christmas. We have had a good time building different projects from the book. We have made him a saw horse, a sign in the shape of his name, a boomerang(that only flew straight) and several boats. Having a 6 year old tell you why the boomerang did not come back is very entertaining.
The board in this amp was designed with this circuit in mind. I have thought abought a generic relay PCB for use in amps but have not tried to take it any further.
SLW
Sounds like you two are having a lot of fun. :icon_biggrin:
Brad :thumbsup:
I had a chance to work on the amp this weekend. I put the input jack and controls into the amp this weekend. No real issues here. Just a lot of figuring it out as I went. Even though I spent a lot of time working on a layout, things are working out differently than I had planned. The ground wire for the pots is a good example. I had planned on tucking it in close and under the pots. It turns out that there was not really enough room with the channel switching PCB in its location. I decided to stick it out in the air above the PCB.
I have discovered that I am short a 33k resistor and a 0.0047uF. I usually would not care too much about missing a component since I have a nice electronics store in town. The store was flooded when we had terrible flooding here in September. I stopped by yesterday to check on the owners progress in rebuilding. They have been operating out of a shipping container in the parking lot.
My little buddy has a tape measure and has been measuring EVERTHING. The TV, the furniture, me, the door, EVERYTHING. It is pretty fun.
Best way to learn fractions!
Decimals are for people who don't want to think! :icon_biggrin:
I had time to tinker this holiday between all the eating. I finished wiring it up! I added all of the wires that go under the main board first. Wires that went from a tube socket to a pot are shielded. Next I added all of the wires that are under the board that run between turrets. With all that done I installed the board. I then made all the connections between the board and the off-board parts. As you are all aware it is a lot of work. Next I will sit down with the schematic and go over everything. I need to build a lamp limiter. Then I will try to start it up. Keep your fingers crossed.
I am happy to have it finished. There are some things I would change at this point but I am going to leave them as-is and move forward. Things I would change are:
1. The area behind the pots is very busy and cluttered looking to me. Heaven help me if I ever have to change a pot. Looking at it now I should have soldered the ground buss to the back of the pots or did it like they used to in the old days.
2. I would like to have the channel switching on the main board.
3. A larger chassis and more room would have been great(I have already whined about this).
4. I used 18gauge stranded wire for most of the connections. I have a lot of this stuff on hand(enough for 10 amps easy) and want to use it up. Solid wire makes for better looking connections and is easier to deal with in tight quarters.
I have learned a quite a few things and about building an amp.
1. Orange drops are huge!
2. There is a limit to how many connections you should make on a turret. In one place I have six. The turret looks like a tree. I try not to look at it but it is like looking at a train wreck.
3. Only two leads fit into the top of a turret.
4. I can’t see small things as well as I used to. The magnifying glass is handy.
5. I need to have a set of design rules in place before I layout an amp.
It has taken nearly a year to get this far and it has been a lot of fun.
SLW
Wow!!! That looks fantastic! Great job.
:thumbsup: :thumbsup:
Thanks for sharing the photos! Can't wait to hear how you like it.
Don't be so critical!
It really looks great! Tear apart an old AA5 radio and you'll know what a real mess is! and landing 6 leads on 1 turret is a trick in itself! damn the aesthetics!
That flying ground bus WORKS! I used it in my TOS build.
Soldering a ground bus to the back of pots REALLY makes a job out of replacing pots.
There are pro's and cons of stranded vs solid wire, the trick is using them in their best situation.
The TOS is a high gain amp and susceptible to crosstalk in many areas, what looks neatest may very well not be what will sound/perform best.
I think it looks like a really clean, well thought out build. It is NOT an easy build at all.
Kudos to you!
You've done an outstanding job! Really great looking build.
I'm trying to plan more upfront to avoid the midstream modifications (a la custom motorcycle builder shows).
Thanks for the kind words guys. I do apreciate it.
I am convinced that a lot of effort in the planning stages pays off in the build phase. I spent many weeks with the layout. I drew everything to size(and color) in my layout and kept adjusting the position of it all before I drilled a single hole. Even with that prep I had three unexpected issues to deal with during the build.
A set of design rules makes a lot of decisions before you even begin a layout. For my next amp I will write down my design rules before I start the layout. Design rules could be anything from colors and gauges of wires to grounding schemes to the number of leads per turret. You could be as complicated or as simple with the rules as you like. I believe everybody has a set of design rules. Some folks write them down and some commit them to memory. We could start another topic about design rules.
Outstanding build please report back or add a sound clip when you fire it up.
One of these days if I ever get any time again I want to build this amp also.
I built a lamp limiter and began to start it up. I plugged in the limiter and turned the amp on with no tubes in it. The lamp flashes and goes dark. I install the first tube and switch it on and get the same response from the limiter. I continue adding preamp(two 12AX7, 12AY7, 5751, 5879) tubes and testing with the limiter. I am still getting a flash then a dim bulb. I feel pretty good at this point. I install the two 5881's and test it again. This time the bulb stays bright. I quickly turn it off and start to worry. I am using a 100W bulb and the current limited by the bulb should be 100/115 = 0.87A I then realize that heater current should be about 3A with all those tubes in so the lamp should be bright at this point. I think I feel a little better but... I hope you more experienced builders can chime in here and tell me if my thinking is correct or flawed.
No, if it stays bright then there's something wrong. :w2:
Brad
Well OK. I was just in denial I guess. I have never used a lamp limiter before so I am not sure what to expect to see. I repeated the test. When the power tubes are in the light glows bright. If I just put one power tube in and flip the switch the lamp takes many seconds to brighten up.
I have checked the wiring and everything matches the schematic and layout. I am not sure where to look next. :dontknow: You guys will surely suggest something.
3A x 6.3V = 18.9W
If the light is bright, something is drawing heavy current
SLW, I'm not the guy you want to help you trouble shoot this, but I wonder if it's the VVR? :think1: Maybe you could try to bypass the VVR?
Also are you sure those OP tubes are good? The pics you've posted sure look good, looks like you've been careful wiring up things. :dontknow:
The guys will help you find it. :icon_biggrin:
Brad
Do you have any good closeups of the output tube sockets and associated wiring?
Without looking back at a schematic, this amp appears to be cathode biased, judging by the big resistor on the board.
How about taking voltage readings with the tubes out. You should have only high (and essentially equal) voltage on pins 3 & 4 (plate, screen). Is that right? There's nothing boogering the wiring to pin 5 is there?
Here is a pic of the output tube sockets. The amp is cathode biased. I took voltage readings on the output tube sockets with the tubes out. All of the preamp tubes are still in.
Pin 3 - 410V
Pin 4 - 406V
I don't see anything wrong with pin 5 wiring. I checked for a short to ground or another pin and such. I did not find anything wrong.
Can an output tube fail in a way that causes high current to move through them. I have a pair of 6l6 and a pair of 6v6 tubes I could try.
Thanks for the help.
SLW
The Story Continues.
I tried my 6L6 tubes with the same result. After flipping the switch from stand-by to "on" I get a flash on the lamp limiter that quickly goes away. After 10 seconds or so the lamp starts to get brighter until it is glowing well and there is hum coming from the speaker. I interpret this to mean that as the output tubes warm up and start to conduct, the current through them is going crazy. This happens if only one tube is in either socket. This does not happen when the output tubes are removed.
I decide that the problem is something that the two tubes have in common. I start with the VVR like Willabe suggested. I remove the VVR from the circuit and replace it with a jumper. I power up the circuit and get the same result from the limiter.
I double check the values of all the resistors that are part of the output tubes circuit and find no errors. None of the caps short to ground. At this point I am scratching my head. The other things that the two tubes have in common are the filter caps, the cathode connections and the two transformers.
I am not sure what to check next. I am looking for suggestions. Feel free to state what might be obvious to you. There is obviously something wrong.
SLW
Wish I could help but I am just a beginner I have very good building skills but still lacking in the practical knowledge. I don't understand the power tube pin 1, 4 jump along with jumping pin 1 from one tube to pin 1 of the other. I always thought pins 1 & 8 tied together for use with EL34's or 6L6's. I also dont understand the pin 5,6 jump and never messed with a VVR. But I will tell you I have done some pretty stupid things and thought all was installed correctly only to find later I had something backwards. At least you used the lamp limiter unlike me on my 1st build and toasted the PT. I did use it on other builds and it did save me like it seems to be doing for you.
Looks like you did everything methodically from the layout & schematic to the final build so I would tell you the same as I was told on a post a while back. Divide and conquer, go back and trace it all out again but with a different mind set that something is wrong. Look to see if something is wired reverse but in your mind it looks correct. I would think if something was wrong in the schematic you posted one of the guru's on here would have picked it out earlier on.
Hopefully you find that one small something and one of the senior guys on here will eventually be able to help you.
Good Luck
Hi SLW,shortfuse may have hit the jackpot!!!! I to have limited knowledge on how all this works, so i tend to try to do the things that most other builders do to try to limit problems. Pin 1,8 on these types of power tubes are for cathodes as some and aren't connected internally and you are using pin1 as a support for the screen resistor. If you can place a tag strip near pin4 and use it to support and solder wire to. In future tie pin1,8 together for interchangeable power tubes.
As for pin6 this is not used for any type of power tube so can and is often used to support the grid resistor.Hope this helps.
In the picture you have posted, the pin 8 wiring on the power tube socket on the right side doesn't look very solid?
However, that might just be the picture angle? But if it's not a solid solder, that would account for too much current, I think?
Also look at the pin 2 heater wiring on that same socket on the right. That doesn't look solid either?
I am wondering if the VVR is playing a factor in this also? Does anything change with the light glowing if you change the VVR setting?
I hit the pins again and put more solder on them. I took the VVR out of the circuit. I removed both of the connections of the VVR (in and out) and bypassed it with a wire. No difference with the dim bulb tester. I would have to put it back to answer your question.
I got the idea to use pin one as a support here on the forum. My 5881's don't even have a pin in position one. I don't think that is a problem but I don't have any other answers either. I will probably try to rig up something for a test.
I just finished tracing out the wiring for the output tube portion of the circuit and did not find any issues. Could something in preamp portion of the circuit be causing this? I don't think so.
I was thinking about the loud hum coming from the speaker so I went looking for a short to the heaters on the output tubes but did not find anything.
All of these things are bound to be telling me something but my inexperience keeps me from seeing the answer. I am grateful for your input and hope to get more questions from you.
SLW
You may have already answered this ......... but have you tried those two tubes in another amp and know for sure that the tubes are good? Have you tried other tubes known to be good in this amp?
Have you tried the bulb limiter with another amp that you know is a perfectly good working amp? Did it do the same thing? Let's make sure the bulb limiter is working correctly.
If the cathode pins aren't grounded or there is no bias resistor to ground, then that could be an issue? IF you are using a PPIMV as a dual ganged pot in the TOS also ......... is the dual gang pot grounded?
Have you tried NOT using the negative feedback and just grounding the LTPI section without NFB?
Have you double or triple checked the cathode resistor value for the power tubes?
Is the VVR grounded?
Any chance a filter cap is NOT grounded?
Do all the voltages on the B+ rail look correct or reasonable?
When you had the tubes in ....... did you try playing the guitar thru the amp and IF so, did it sound OK or did it make an odd noise? IF all the voltages look right through out the amp, I would be tempted to play the guitar thru the amp and see what happens? BUT there is a risk in doing that certainly and it might not be a good idea.
Did you try it with NO preamp tubes in and ONLY the power tubes in with the lamp limiter?
Just grasping for straws here ..............
PLEASE keep working on it! The Tweed Overdrive Special is a great sounding amp and your layout and chassis work is just fantastic!
I know you can and you will get this resolved.
+1 on this quote - and - every thing else Tubenit said. Your pics look great on the work you have done, you'll find that bug.
Tubenit, IMO is a very good amp trouble shooter, safe to say he's been around the block more than a few times. :wink:
I never would have said to you to make sure/check out that the bulb limiter is working on another amp. (Very well could be your problem?)
On the OP tubes cathode R, have you actualy measured it with a meter?
Brad :think1:
Thanks for all of the questions. I will answer what I can.
I have not tried those tubes in another amp. The only other amp I have is a 5F2A (SE tweed Princeton). I guess I could try the 6V6 form that amp in each socket. I will do that and report back.
I have not. I will have to rig up something to do it. I think I made the limiter properly. I cut a IEC type cord in half. I inserted the lamp socket so that it is in the hot path. I reconnected the neutrals and grounds.
The amp has no PPIMV. The cathode pins connect to the cathode resistor and caps then to ground. All connections have been checked.
No I will try that and report back.
Yes. It measures 356 ohms.
It was when it was hooked up. It is still out of the circuit.
I just checked them all again. They are all grounded.
I guess so. Using the lamp limiter with all tubes installed I measure:
A=266, B=243, C=220, G=212, D=205, E=149 and F=147 all DCV. The letters correspond to a node on the rail.
No I have not tried this. I have been too chicken. :)
Yes. The limiter gets brighter after the initial flash and dimming. This is the same behavior I have reported.
I am not going to give up. I am going to my mother-in-laws for a week, it will be here calling me when I get back. :) Keep the questions coming.
SLW
I think the light bulb has served it's purpose. It's time to plug the amp straight into the wall and do a few checks.
Plug straight into the wall and turn power off. Turn standby off (switch open). Pull the output tubes and set aside. Connect a voltmeter across the first filter cap. Turn the amp on but keep your hand on the switch and be ready to kill power at the first sign of smoke or arcing or stinky smells or unusual noises. Hopefully your meter will read your B+ which will be higher than expected because of the the open standby switch. If B+ looks OK then turn the standby switch on and measure the plate and screen voltages on the empty output tube sockets. What are the readings?
I thought a video of the lamp might be useful http://youtu.be/LT5RXu96omA (http://youtu.be/LT5RXu96omA). Since I have never used a limiter before. It could be that I just don't know what to expect. It is a 100W lamp. The first click is going into standby. The second click is into full power mode. The buzz at the end is what happens all the time. What do you think?
SLW
Without knowing what that light bulb looks like at full brightness, I'd say it's behaving normally and you no longer need the light bulb. The hum I hear sounds like an open grid near the input, kinda like a guitar cord plugged in the amp but no guitar connected and volume pots maxed. Turn all pots to zero and leave the VVR disabled for now. Does the buzz go away? Check voltages on the output tubes and report.
Thanks for the input fellas.
Well I did it. I plugged it straight the wall after reading sluckey's comment. Good news! No smoke or fire! With all pots on zero the buzz goes away. Here are the voltage readings on the tubes with all of the pot on zero. http://www.el34world.com/charts/valve/ValveData.php?e=view&f=12274 (http://www.el34world.com/charts/valve/ValveData.php?e=view&f=12274)
The VVR is still out of the circuit. V3 is a 5879 and the readings I got are 150 volts on pin 8 and 41 volts on pin7.
As soon as I turn the level pot the buzz is back.
What now?
SLW
You have a lot of relay contacts and circuitry that could be part of the buzz problem. Since the amp is quiet with the level control set to zero, I suspect the PI and output stages are OK. It's time to divide and conquer. I would disconnect the wire from the wiper of the level pot P4. Then disconnect the wire labeled FX Loop return from the PI input cap C26. Now connect the wiper of the level pot P4 directly to the PI input cap C26. This will remove the OD circuitry and the FX Loop circuitry. Your signal path will now be V1a, V1b, V2a, V5, V6, and V7. This is a simple amp. How does a guitar sound thru this configuration? If my suspicions are correct, you will still have the buzz.
Also, since the amp is quiet with the level control set to zero, I suspect the problem lies between the input jack and the level control. Make the changes above and report back. I have some more suggestions based on your findings.
Listen to Sluckey! He has given me more answers to amp problems than anyone I can think of. He just has a knack of walking you thru to the solution.
As a side note, I've had the passive effects loop jacks cause buzz before & needed to replace them.
Stick with it SLW, Try a 50 ohm resistor to ground off one leg of your 5vac relay power supply. Worked a charm on my MSJ relay PSU. :icon_biggrin:
Here are a couple things to try before you bypass the OD and FX circuits...
1. Turn the volume pot to zero. Does this kill the buzz even when the level pot is turned up?
2. What is your purpose for the switch and R57 at the input? And what is the value of R57? If it's large it will likely cause a buzz such as you have. Set the switch to bypass R57. Does the buzz go away?
Here's a spliced pic showing only the input circuit...
I am wondering if a heater wire is touching a plate wire on a preamp or power tube? AND check for solder drops that wedge between the heater pin and plate pin also.
IF that is it, it would account for the hum not being there initially but building up after it has been turned on for a second or two. It makes a hum similar to that noise.
I will try that before I bypass anything. I am at grandma's (my mother-in-law)house for a week. The kids are wound up tight. I am happy to be here also. Every day at 5pm my mother-in-law brings me a beer!
The switch and R57 are my attempt to have a switchable form of high/lo input. R57 is 33K. I need to update the schematic. My engineering mentor would chew me out for not having my documents in order. I hope it is obvious what is going on with the switch.
Even though I am not finished with the amp yet I want to publicly thank all of you for your input and time invested in following and helping with my project.
Merry Christmas to all of you!
SLW
sounds like 120Hz not 60
http://www.soundsnap.com/tags/120hz (http://www.soundsnap.com/tags/120hz)
http://www.soundsnap.com/search/audio/60hz/score (http://www.soundsnap.com/search/audio/60hz/score)
Back home now. Happy new year! Here is what I found.
The buzz is there with the volume pot at zero. The buzz is gone when the level pot is at zero. Does this imply a problem with v1b?
The input level switch has no effect on the buzz. I get the same buzz with R57 in or out of the circuit.
SLW
Yes, but it could also be V2A. Pull V2 to narrow the buzz source.
Thanks. Here is what I found. Pull V2 and still have buzz. Pull V1 and still have buzz. Pull both V1 and V2 and still have buzz. I plugged in a guitar and the amp plays but the buzz is still there. What do I look at now? Do I start to bypass stuff to make it as simple as possible or do I check some parts?
SLW
Can you please look carefully to make sure there is NO contact between a heater wire and a plate wire or anything else and report back that you have done that? Also please look for any solder drops connecting heater to something else.
The symptoms you're describing can be there with a single strand of heater wire touching a preamp or power tube plate. The report of it sounds OK until you flip the stand-by (to allow sound) then it sounds OK for a second or so then hum will happen with heater wires touching plates.
Double check that no shielded wiring got grounded on both ends. Check the pots grounding also. That can cause hum if the pot is not grounded well.
Then report back again, please.
with respect, Tubenit
That's what I would do. Refer to reply 58.
How about going straight from V1a to LTPI? Skip the V1b, DPDT, OD & FX.
Would you please reply to the concern about heater wires touching plates also? Thanks.
I think the heater/plate short is a possibility and can be easily confirmed/ruled out by closely inspecting the socket wiring. It's worth the effort to do so. I am more suspicious of the wiring for the relay board or maybe the 5vdc power supply for the relays. That's why I suggested bypassing all that stuff and get to a simple straightforward circuit. If still have hum with all that stuff bypassed, it will be much easier to track down. And if the hum disappears, well then look to the relay and FX circuitry.
I just inspected the tube socket connections using a flashlight and a magnifying glass. I can confirm that there are no stray strands connecting the heaters to the plates.
I am going to bypass the OD and FX portions by going from the wiper of the level pot to PI input cap C26 and I will report back.
SLW
I removed all connections to / from the relay board. I ran a jumper from the level pot wiper to the PI input cap C26. The buzz was gone. I have to turn the volume and level pots up pretty far(Level at 3 o'clock and volume at noon) to hear any noise. With a guitar(epi les paul) plugged in the noise gets a lot louder. My shop area is only lit with florescent bulbs and one is three feet above the open amp.
For fun I patched in the OD portion by running a jumper form the junction of C7 and the level pot to R15/C13. I connected a jumper form the wiper of the OD level pot to the PI input cap. This buzz was still gone but there was more noise. The amp would give me a ringing squeal if the drive was turned up past 10 or 11 o'clock.
I went ahead and patched in the FX portion by changing the jumper from the wiper of the OD level pot to C20 at the start of the FX loop and I put another jumper from C24/R26 to C26 at the PI. The buzz was still gone but the noise was even greater. The amp would make a funny squeak/squeal that died off a second or two after the note was struck. The only way to make it stop was to turn down the send/return pots to zero.
I put the amp back to just coming out of the level pot and going into the PI input cap. This is the same as the first test in this post.
I take this to mean that there is a problem with my 5VDC/ switching setup. Let me know what you guys think. I will proceed from there.
OK, that's progress. Now we know the problem lies with the bells and whistles or the wiring to/from the main amp. Let's continue dividing and conquering. Add one section at a time.
I would like you to wire in ONLY the OD section and K1. Put a jumper between K1 and C26 as shown by the red line in the attached pic. Do you have buzz again?
I'll tell you my concerns about your 5v power supply, but do the above test first. 5VAC is really lean to drive a 5V regulator chip. 5VACRMS is only 7VACpeak and that may not be enough headroom for your regulator to make clean 5VDC. It may be producing a lot of 120hz switching noise. Check the DC voltage output of the regulator and then switch your meter to measure AC ripple at the output of the regulator. We want that ac ripple to be very, very low. A scope would be very helpful with this check. Even if everything looks OK, try another input source for your bridge. If you have a 12VAC transformer use that. Or you can connect a 6V lantern battery to the bridge AC inputs (polarity doesn't matter). Does any of this cure your buzz?
I'd be interested in seeing you wire it like this bypassing the relay and FX only.
Tubenit, he wired it exactly as per your drawing and the buzz was gone.
That's a lot of gain stages strung together! It's gonna want to squeal and be noisy. Lead dress and layout are gonna be critical. And you will probably need to decrease the gain of some stages to tame that. But the good news is the buzz is gone. That points toward the relay board or 5v power supply, or a miswired relay. Fix the buzz then tackle the noise/squeal.
Sluckey,
Sorry about that ............. I was trying to follow what you were saying as I am very interested in his build being a success!
I just wasn't comprehending what was unfolding. Please accept my apology.
For my own clarity ............... is the schematic you drew with the red line, the same idea as this schematic? Is that what you're saying he needs to do to pinpoint this as a relay/5v issue?
What send/return pots are you referring to? Do you mean master volume and/or the OD pots? Typically, I think of send/return pots as in an active FX loop?
No need for apologies. The disappearing message made me pause for a minute though. By the time I responded, the message was gone. :icon_biggrin:
Yes, that schematic is the same except I wanted the relay K1 wired in also, rather than hard wiring the OD section. This schematic is the same as the one you posted earlier with the blue jumpers. He's already wired it exactly like that and there was no buzz. Now I'm wanting him to add in the K1 relay to begin checking for the return of the buzz (sounds like a Star Wars episode!)
You'll have to look at his original schematic to see the send/return pots in the FX loop. I've purposely omitted the FX loop from my partial schematics for the time being just to keep it simple.
in your video, that sounds like 120Hz buzz from PS. relay board PS is mis-wired and/or needs to be grounded and/or the footswitch jack needs to be an isolated type. IMO, 470uF is too small a filter for that PS. in similar applications, i like to use as much filter as i can stuff into the space allotted. use coax for signal connections to and from the relay board.
post the artwork of the relay board and the model/mfg. of the relays, if you care to share; sometimes another pair of eyes can help.
you can confirm that the relay board /relay PS is not the issue with a 6V battery and a pair of clip leads. 6V won't damage the relays, however, if you're still concerned about it, use a series dropping resistor in the + path. BTW: if you can't find a 6V lantern battery, 4 D cells in a radio shabby battery holder would work.
slucky has you going down right path. i'm stepping out of the way now, i just wanted to share my thoughts and limited experience.
respectfully,
--DL
The buzz returns.
I measured the 5VDC power supply and it is puny. I am getting 4.3VDC and 135mVAC of noise just measuring with my Fluke. I should have hooked it up to the 6.3VAC winding. Oh well...
At this point I am thinking about pulling the switching board and hooking it back up with simple DPDT switches. I think I can focus on getting the amp to run its best that way. Once we have it running well I can put the fancy switching back into the amp.
My little buddy is asking me to make a "steam shovel" with him. He is standing here with wood and a saw in his hands. After that I have a delay pedal that I want to finish up so it will be a couple of days before there is any progress.
I am grateful for all of the help and encouragement you guys have been willing to give me.
SLW
That sounds reasonable to me. Reality is I am flipping a switch between clean and OD when I play at home anyway. Only hook up the foot pedal playing live.
PLEASE do NOT give up! These are really sweet sounding amps and are worth the effort, IMO.
We'll be looking for to your updates and progress.
what is the ACV measurement @ the + terminal of the bridge recto? remove/clip the V reg out of the ckt. before you measure - if it's less than 7VAC you're going to have problems unless you're using a Low Drop Out (LDO) regulator.
agree, 6.3AVC taps would have been the way to go with "conventional" 78xx type regulator.
--DL
The buzz returns.
Disconnect the 5vac PT winding from the relay board and connect a lantern battery to the bridge. Heck, even a 9V battery will power K1 long enough to know if the buzz will go away.
And here's a cheap alternative... You really don't need a regulated supply for those relay coils and LEDs. Just pull the VR chip and the 47µF cap. Replace the 470µF cap with a 2200 or 4700µF and finally put a jumper strap where the VR in and out pins were connected. Bet that will cure the buzz. As DL said earlier, you may have to ground the negative rail of the 5v power supply to chassis. Or maybe not.
for your consideration should you wish to continue using a Vreg. otherwise, omit and use a series dropping resistor for relays - you should "tune" series drop R for 4.5-5VDC with all 3 relays + LED on.
--DL
Any progress?
Got any update for us?
It has been a very busy few days in my house and at work. I have only mounted the DPDT's. I hope to get to it some more this weekend. I am going to redo some of the signal wires since they are looking a little beat from all the prior trouble shooting. I used shielded wire for any run that was longer than 4" or so. Should I consider using shielded for the ones that I am redoing?
SLW
I spent the some time with the amp this weekend. I pulled the 5V supply and switching board. I replaced the relays with two simple DPDT switches. I hooked it up with shielded wire except for a couple of short lengths. I reconnected the VVR.
I am happy to report it works. I played it for about a half an hour. The clean and OD channel work with no buzzing or other noises. I have a homemade tweed Princeton and the noise level seems about the same to me. I have not tried the effects loop at this time.
I am going to put the cover on and play it for a few days. The speaker in my cab is new and need to break in.
I eventually need to redo the relays and indicator lights. I think my issue with the last switching setup was using the 5VAC to power it. I will use the 6.3VAC to power it this time. I am open to more suggestions on channel switching from the forum.
Thanks for all the help with everything. I will report back after I live with it for a while.
Shawn
Wonderful news! THANK you for reporting on the progress!
I am going to send you a PM.
Here is some documentation from Doug, about relay supply and montage
http://www.el34world.com/projects/relay_switch.htm (http://www.el34world.com/projects/relay_switch.htm)
Kagliostro
All right Shawn! Nice job! :thumbsup:
I'm sure you'll get relays and FX loop working too.
Brad :icon_biggrin:
Man that's great I can only imagine the amount of time you spent taking things apart to find it. Congrats.
Hi SLW
where did you buy the relays board ?
(http://www.el34world.com/Forum/index.php?action=dlattach;topic=12278.0;attach=25864;image)
Many Thanks
Kagliostro
It is one that I had made. When I have prototype pcb's for pedals made I have to pay for a minimum amount of board space whether I use it all or not. I will put small things like this on it so I don't waste space(and money). My mistake with it was using 5VAC to power it. I am pretty certain that it would have worked well if I had used the 6.3VAC to power it. I already have something new for the next attempt with the switching relays. :icon_biggrin:
SLW
If you still have the draw of that PCB can you post it ?
Kagliostro
EDIT: this days I started learning Eagle, I've find a PCB Layout that I can modify for this use
I wanted to give a little update now that I have played the amp for a few hours.
Clean Channel – I like it the way it is. It sounds good with my strat. The tone control has a nice range. Perhaps a little more “sparkle” with my strat would be nice but I don’t want to try to change it at this time.
Overdrive channel is not offensive. I am still getting to know it. Need more time with it. I do like it in general.
I am not feeling any love for the VVR. It doesn’t seem do a lot until I have the knob at 9:00 or so. I am not in a hurry to change it.
The effects loop needs a little work. It changes the tone a little. I expected this. There is a hum present when you engage the loop. I did not expect that. Perhaps the PS node needs another level of filtering. The big issue(to me) is a strange oscillation or something that dies away with the note. For lack of a better description, it sounds a little like a cricket. It happens when the guitar (and amp) is louder. It does not happen when I play softly or have the volume on the guitar turned down. I want to tackle this first. Is this a problem of too much gain in the FX loop?
SLW
When I build my FX-Reverb unit, I discovered that I liked a 12AU7 the best in the FX. I think I liked a 12AU7 best on the on board FX I built also, but can't remember for sure?
Is the hum there with an effects pedal in the loop?
And yes, I discovered I needed more fitering also then I would have anticipated. Not sure why the hum is there though?
If you are referring to 9:00 as being like 9 o'clock, ..... then I agree. I've done a few of the Dana Hall VVR's and anything under "4" (1-10) sounded kind of anemic to me. I typically would have the VVR dialed in between 5-7 (90%) of the time.
After you get used to your overdrive, please give us an update. And I'd be happy to offer any suggestions if you can describe how you would want the OD to sound differently.
Yes, I do mean 9 o'clock. I am thinking about pulling it out and reworking the power supply in a more normal way. Perhaps with a couple of nodes in front of the the FX loop node the hum will go away. I will try another tube in the loop. I think I have a 12AU7 but not sure.
SLW
I originally built my TOS and the Carolina Overdrive Special with VVR. Sold the COS.
And when I rebuilt the TOS into the TOS 2CF, I removed the VVR and installed a LarMar PPIMV. At the volumes I normally play at, I decided I liked the PPIMV better. Having said that, playing with a band, the VVR was very useful to me & it is easier to record OD tones with the VVR, IMO.
I tried "all the 12A_7's" in the FX loop. I thought 12AU7 sounded the most transparent without adding significant gain. 12AY7 was nice also.
