Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on October 24, 2011, 01:59:44 pm
Title: Hammond 1760J Upgrade (or 1750J) is this OK for 4 x el84 tubes ??
Post by: kagliostro on October 24, 2011, 01:59:44 pm
Looking to the Hammond 1760J Upgrade datasheet I've seen it is a 4,000ohm 4/8/16ohm 35W Output Transformer (they say for Fender Pro-Reverb, Tremolux, Vibrolux)
https://docs.google.com/viewer?url=http://www.hammondmfg.com/pdf/EDB1760J.pdf&embedded=true&chrome=true (https://docs.google.com/viewer?url=http://www.hammondmfg.com/pdf/EDB1760J.pdf&embedded=true&chrome=true)
as far I can know a 4,000ohm is the right OT for 4 x el84 tubes
no one of the Fender amps they say the transformer is for, uses 4 x el84 tubes
What I'm missing ??, sure something  :w2: :w2: :dontknow: :w2: :w2:
Kagliostro
Title: Re: Hammond 1760J Upgrade (or 1750J) is this OK for 4 x el84 tubes ??
Post by: sluckey on October 24, 2011, 03:21:03 pm
It's also a good choice for a 2 x 6L6 amp.
Post by: kagliostro on October 24, 2011, 03:27:23 pm
As you can see I pay may interest for Vox AC30 and similar amps
I've a limited vision of the world
Many Thanks Sluckey
Kagliostro
Post by: kagliostro on October 29, 2011, 01:40:31 pm
Please can someone explain this:
Hammond 1760J 4000ohm primary 4/8/16ohm secondary - 35W designed for Fender is sold for € 49.31
Hammond 1750V 4000ohm primary 8/16ohm secondary - 30W designed for Vox is sold for € 78.30
does someone knows the reason for this big price difference ?  :dontknow:
and also must consider that the 1760j is rated 35W and has one more output option (the 4 ohm)
as I'm looking for an OT to be used with 4 x el84 tubes do you think that the 1760J is a stupid choise ?
Kagliostro
