Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Colas LeGrippa on October 27, 2011, 09:38:54 pm
this question certainly has been asked rather twice than once: in a SE amp, adding a power tube in parallel will ask for doubling or dividing the speaker load by two ? and what is the math behind the answer ? ( 2 * x = 2x :l2: )
thanks
Colas
2 x parallel tubes = 1/2 the load resistance of 1 tube (all other things like; tube type, bias voltage, plate voltage and plate current per tube etc being equal)
As I can see, in calculating the reflected load impedance, we consider output tubes only as being resistors.. putting two resistors in parallel will divide the total load by 2. I was not quite sure if this formula would apply to tubes too. I have never considered the tolerances of any kind in building amps, I was going rather with my ears. And it was giving pretty much good results, I must admit. But now that I have experienced weird things like getting much more power out of an EL84 than a 6L6 ( weird because a certain lack of overall understanding), I just want to do things differently in order to avoid, by example, spending a week on a troubleshooting that appeared to be just a defective a/c cord................... :cussing:
Regards
Colas
Yes Colas Legrippa, tubes are "like" resistor. It is easy to have information on push pull amp. Two tubes push pull need a primary impedance output transformer twice than the four output tubes transformer.
