Other Stuff => Cabinets-Speakers => Topic started by: firemedic on November 01, 2011, 11:59:42 am
Okay, I have made a mistake (imagine that).
I bought 2 non-ported 15" speaker cabs (no speakers) today for $60. They are made of particle board.
I am not the sharpest knife in the drawer.
But- they do have crossovers and 8 ohm horns. Plus the handles & metal grills, so at least I have something.
So off I must go to get some real wood, or at least plywood. I have never built a bass cab so what is the process for porting these things? Also, how does the crossover affect the impedance the OT sees? I'd like 8 ohms overall for each cab.
Correction, I think it is really MDF. Maybe not so bad.
Hi firemedic,
MDF is Medium Density Fiber board, denser than particle board, heaver too. Machines nice, takes a finish well, but chips easy just like PB. I've cut more than a few sheets of this and the dust is just terrible from it. Very, very fine, you do not want to breath it. Easy to get a sinus infection from it. :w2:
I can't say from experience, but some guy's like the sound of cab's made from it.
Put a speaker in and see how they sound to you, you might like them? :dontknow: Gonna be a PITA to haul them around tho.
Brad :icon_biggrin:
I'll sand off the really bad parts & just polyurethane the outside for now. They are at least well built & tight.
I'm thinking about closing off the rectangular holes that the horns were in, and mounting some tubular ports instead. Any opinions regarding the use of those horns?
Sounds like a good plan. Since it's for bass and depending on the speaker you put in it, MDF might sound great. Pine is not the only good sounding cab wood/material.
Sorry no, but you know the guys here will help you. Maybe you could leave the horn in and put a switch in on the back to disable it when you want, for different sounds? :icon_biggrin:
Brad :think1:
Bypass the crossovers, you do NOT want them for an instrument speaker.
Yank and sell the horns. Quick-cut thin plywood to cover the horn holes. Make a lot of screw-holes. Start with the port half-open. Run your scales in your lowest octave, listen. Try port full-open and full-closed, scales again. Watch for cone-flap on the lowest notes. When sound is best, cut nice hole-covers for permanent tuning.
(It is possible to pre-compute an "optimum" but you have to know a LOT of numbers, and you have to have a clue what "optimum" is. Optimum for stage-amps is NOT textbook optimum.)
I ordered a couple of 4" adjustable-length port tubes already. I figured I could cover the horn-rectangle and install one or both tubes in one of the cabs, then adjust the tube length as needed.
But before using the ports I could try a sealed cab (perhaps just mount the horns unconnected).
I know nothing about bass speakers. I'm about to buy a new-in-box Peavey Black Widow 15" from a guy in town & I intend to build one cab at a time. Ported s. sealed is academic to me at this point, please insert sage advice here.
The guy who designed the cabinets knew more about speakers than you and I put together. You won't go wrong just using them as-is (minus crossover, and probably with horn removed and hole sealed).
Tuned-box is NOT a simple matter. Duct-length is a very-very minor point. You first find an "optimum" port AREA. Port (duct) length is very secondary.
It might be good to know how big they are inside?
Since i have 2 boxes, I'm sealing one and using a Black Widow 1508-SPS (got it brand new in box & cheap). It has a very helpful spec sheet, and I'm comfortable using it in this application. Once I run a full signal into it and I'm satisfied it won't disintegrate, I'll pretty it up w/ tolex & corners.
The other box will be ported. Speaker TBD. Suggestions welcome.
love those pv spec sheets.
if you like the widow and it doesn't destroy the cab, try to find a low rider for the other one...simply monsterous.
I tried the 40w TOS with a bass guitar, since I haven't built the bass head yet. It really doesn't make much sound so I'm building for 4-6550s now. Stand by for results...
