Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: phsyconoodler on November 21, 2011, 04:20:47 pm
can you use an FET like Dumbles use for a gain boost instead of a 10-20db boost?In other words can you make the FET overdrive and use it as a gain stage? The reason I ask is it's easy to build the FET stage and it would be a useful gain stage in an amp.Or at least I think it would.
I made a pedal out of one It was ok... the stratoblaster makes a better version..
You don't know the power of the dark side.
I almost heard the breathing too Sluckey!
Hi noodler, Found this on the net when comparing a FET input and a Op amp input as see in Duncans blue amp 112(schem in dougs library under MISC) they are saying that the FET is a nicer smoother sound. Dumble fet was mainly to boost the input signal of acoustic guitar pups.Thats about all i know. :icon_biggrin:
http://www.runoffgroove.com/fetzervalve.html (http://www.runoffgroove.com/fetzervalve.html)
