Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on December 23, 2011, 02:26:20 pm
I have an amnesia
time ago there was a discussion about the use of a champ circuit as an effect
there was a load resistor connected instead of a speaker and the signal was send to another amp
Please I don't remember who do that and also would like to see the original schematic that was posted
Kagliostro
Garnet Gillies maker of Garnet amps made an amp called the Herzog. I think that's what your talking about.
There's a site on the net about his amps, with schematics.
Brad :icon_biggrin:
here is.
http://www.aronnelson.com/gallery/main.php/v/Caseys-Vintage-Effect-Page/album27/Garnet_Herzog.jpg.html (http://www.aronnelson.com/gallery/main.php/v/Caseys-Vintage-Effect-Page/album27/Garnet_Herzog.jpg.html)
MANY THANKS
That is ! :smiley:
Kagliostro
Check out Ted Webers little transformer.
https://taweber.powweb.com/store/balun.jpg
It is a low watt 150 ohm : 150 ohm transformer that is great for tapping off the speaker side of an amp.
If I were to build such a thing (hertzog), I would replace the 6 r 10W dummy load with a speaker motor and use Webers little transformer.
I think the purely resistive dummy load would affect the tone greatly.
If one tried, I bet this could be built into a very small box
Hi Stingray
I'm not going to build such a thing, the info was for a friend that is building something similar
don't know the impact that can have the use of a speaker motor and a transformer in place of the resistor, but anyway that is a good info, I've never considered such a thing
Thanks for the input
Kagliostro
Wow! I was just thinking of doing the same thing!
I was going to use just a 4 ohm resistor, any reason to use a 6 ohm? Maybe it's close enough and it's what the builder had avalible???
The one I'm building will have a switch for EL84 or 6V6 by paralleling the sockets(except for the cathodes) with a switch to ground one or the others cathode resistor. Also a switching speaker jack that disconnects the 4 ohm resistor so it could be used as an amp or an effect.
I was thinking of using a DPDT center off switch. One pole would be AC the other would connect the cathode to ground so it would be 6V6-OFF-EL84. This way you'd be turning it off when you are switching power tubes.
Is it OK to use a DPDT switch with AC on one pole and the powert tube's cathode on the other?
I was thinking maybe a pure resistive load could be good in this situation. If the reactive load changes with frequencies and has more/less gain at different frequencies and you're using this for a preamp, then it will be double EQ(The reactive load of the preamp tube changing with frequency, then the reactive load of the amp you're driving changing with frequency). In other words the frequencies accented by the power amp will also be accented by the preamp doubling the effect.
Using a reactive load for an attenuator, I get it, but maybe not so bad to use a purely resistive load in this case if it's used as a preamp.
Just a thought.
Stupid question due at my low knowledge
what will happen
if instead to use an OT and than a resistor as load in the secondaries
we use only a resistor to load the final tube/tubes and take the signal from there ?
I know this is a crazy question but it come to me :think1:
Kagliostro
I don't know. A while ago I had the same idea but never tried it or got any feedback on it.
If you had a 6V6 running at 250V plate and screen at 48mA with a 5K:4 ohm transformer hooked to a 4ohm load would that be the same as using a 5K resistor as a load?
You'd have to increase the plate supply when using the resistor as a load instead of the transformer to 490V because the 5K resistor would drop 240V @ 48mA whereas the transformer wouldn't. I was thinking of using a voltage doubler and taking the screen and preamp B+ off the botton cap.
Aside from the fact you're taking the output from the plate rather than from the 4 ohm loaded secondary, wouldn't the load line be the same and the tube be acting exactally the same?
Something like this? would it work?
what will happen
Gar Gillies and Randy Bachman didn't care if the resistor load didn't sound like a speaker, because the padded output was then plugged into the input jack of another tube amp as, essentially, an effect pedal!
So the thing distorted, and speaker response was still being afforded by the final amp's speakers.
