Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: tubenit on February 09, 2012, 06:06:40 am
I've not seen a cathode cap/resistor set up like this before? Anyone know what's going on with this?
Yes you have. Look at half of a long tail PI.
It provides fixed bias to the tube.
What are the advantages to that over the simple cathode bias we normally see on preamp tubes?
the last section to ground ( 3.9k / 2,2uF ) is a typical low-pass filter arrangement
> low-pass
At 18Hz. Won't affect small-signal response. Might be overload-recovery timing. Might be a waste of 3 small parts.
