Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: firemedic on February 16, 2012, 10:28:49 pm
Hey all, I'm almost done with a AA764 Vibrochamp build, from the ashes of my 5879SE that fried. Due to limited knob space I'm replacing the FMV T/B stack with a simple 5F2 one-knob deal, preceded by a .02 or .03 coupling cap. Other than that & a choke, I don't plan on any earth shattering changes. Surely this has been done before, any thoughts, questions, comments or suggestions are always welcome.
What kind of speaker are you using?
The original seemed to roll off some bass response (though you could get plenty of bass). As a result, those who have used a full-range speaker have sometimes run into hum issues, due to the SE design. The solution was to add a stage of filtering ahead of the plate node of the power supply.
Other than that. . . I don't plan on any earth shattering changes. In the guitar amp world the change from E or F tonestacks to FMV is THE earth shattering change!!!
I'm using the one-knob stack, not FMV which is stock AA764. Should give me more overall gain I imagine. As I get better at my playing I'm really appreciating the Tweed tone.
@HBP: The speaker is a Chinese 8" that came stock with the Kustom Contender I butchered to make the amp. It sounds fine with enough bass for me.
I'll see if using a choke will control the hum. My 5879 SE was pretty quiet w/ less capacitance than the V/C on the main cap. If needed I can add the extra filter later.
I just wanted to use what I had laying around to rebuild my little practice amp, all I needed to buy was a new PT.
OK. [Note that the Big Muff tonestack is a one knob equivalent to FMV.]
The build is complete. And pretty quiet. Chokes and shielded wire are good things.
Full volume at @6, then all breakup. Like I like it. The tremolo works nicely, and as we all know, tremolo is the only effect you really need.
The 1M tone pot may be too much, if anything. I see the princeton uses a 250k pot there, I may try that or a 500k. But all the tone settings are usable.
I also have a 47pF bright cap across the volume terminals & may remove that. It's a little too bright.
Other than that, I have a real nice little practice amp that sounds good & didn't cost too much (extra).
Yeah, most single-knob tone plans can balance bright better than a simple treble bypass cap.
Congrats to a good build!
Settled on a 500k tone pot & scrapped the bright cap. Nice sounding little amp. With the intensity turned up over halfway, somehow the treble becomes attenuated a little & it's got a FZ 200 motels kind of tone, very nice.
I've probably owned 4-5 VibroChamps over the years, and I kinda wish I'd kept at least one...
