Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: plexi50 on March 11, 2012, 01:56:14 pm
Delta Blues that has no sound when switching to the overdrive channel
I have tried the footswitch and no go either. Checked the panel button switch and it is good
Checked the resistor values in the OD circuit and they are good as well
Im missing something /
Touch these points. Does it buzzz?
No it does not make any noise at all or buzz when those points are touched when the OD button is engaged
Bad relay.
Thanks PRR. I thought there was a thread on this not to long ago?
Relay ordered /
New relay installed and OD channel works fine again. I wont forget this one. Very easy changeout.
PRR makes life less stressful. Thankyou again!
PRR makes amps builders understand what they do.
Thats what is great about this forum. Among many other cool projects and ideas*
