Other Stuff => Other Topics => Topic started by: Madison on March 25, 2012, 04:52:20 am
I bought a kit.
Straight out of China.
Not recommended!
( I won't go into too much details but their service and parts suck!)
Anyway.
I found that the rear light had come loose after install, water entered, and I assumed the battery was shot.
Took it off the bike, let the it set for a couple of weeks and just tried it for kicks.
The battery looks okay.
There is a part that was contained within the battery.It's a little red circuit board with led meter levels
I know it is the voltage level check meter but I am wondering if it has something to do with the charge controller?
(I'd assume the charger has an auto shut off)
I thought maybe someone here would know?
If, it is only the meter, I don't care if it doesn't work because there is level meter on the accelerator anyway.
I think it was causing a short and it is definitely shot from getting wet.
Just wondering if I can trash it?
Here are some pics
Can't help with the circuit board thing
Is this a kit to make a bicycle into an electric motorized bike?
Have been seeing ads everywhere for bicycle conversion kits.
This place has a ton of them
Gas engines
http://www.bikeberry.com/gas-engine-kits.html (http://www.bikeberry.com/gas-engine-kits.html)
Electric kits
http://www.bikeberry.com/electric-motor-kits.html (http://www.bikeberry.com/electric-motor-kits.html)
Not that I want one, but all these kits just sprang up out of nowhere recently.
I think it is just your voltmeter. Set it aside.
Charge the battery. See if it runs.
I think you're right.
That's a lot of tiny parts just for a volt meter.
Charger auto shutting off @ 42V, where it should.
I'll put it (back) together and see what happens.
Thanks.
