Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jjackson7 on March 29, 2012, 11:02:40 pm
I have a friend's Jet City 100H that has malfunctioned. During band practice the volume dropped to about a quarter of what it was. After checking the obvious (cords, guitar, cab) we decided to change tubes. I had some known good 6L6 and 12ax7s laying around so we changed all and still the same problem. I posted the voltages from the tubes on the voltage charts here under Jet City 100H. There are no obvious burnt resistors anywhere in the amp. I chopsticked around to see if I could get the volume to come back - no luck. We went from the effects loop send into the effects loop return in my amp - plenty loud. Then went the other way with it - same problem. I guessed the problem was a bad solder joint somewhere in the power amp. Re-flowed the tubes and output transformer primary - same problem. I'm running out of ideas. But am willing to try any suggestions. My tools are limited but I do have a good meter Fluke 179. Thanks in advance for any help. I have a pdf of the schem for the 50 watt if that helps.
Been searching earlier posts. It seems there is probably a resistor open somewhere. I'm going to keep searching. Any other tips would be great. Thanks.
Had one of these in my shop with the same issue... Thought is was fixed and then it wasn't. Found that the OT died and replaced it. Do you have a spare lying around to swap it out for a test?
PM me if you want some more info about a replacement.
The only OT I have laying around is from my bassman 70. Is there a way to test the OT besides unsoldering and ohming? I checked primary and from center to each side is 15.6 ohms. I didn't unsolder the secondary. Where there any measurable indications that the OT you replaced was bad? I don't think my friend is going to believe he needs a new OT but I haven't found anything else even remotely suspect (I am relatively new to this though.)
Okay found this article. http://www.geofex.com/ampdbug/outtrans.htm. (http://www.geofex.com/ampdbug/outtrans.htm.) "Sometimes a primary will have enough resistance that the transformer does not burn up or burn the wires in two , but will just bog down, have low power and sound bad." This seems familiar though the tone of the amp is the same. I don't have a variac to do the advanced test but I'll look around for one to borrow. I would be interested to see the results of the test even if it is fine.
