Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: bbirling on July 09, 2012, 02:44:27 pm
I am working on a 70's Sonic what Appears to be a pa amp possibly. It runs (4) 8417 and (4) 12AX7's Control panel shows Volume-Treble-Presence-Bass-Reverb and a Bright Switch. The back panel has 2-4-8-70 volt Speaker outs and a FS for the reverb.
Right now it's output is very low volume. One 12ax7 in question is the one in the middle of the picture.
Voltages-(1)302(2)0(3)2(4)H(5)H(6)0(7)0(8)0(9)0
I do not have a schematic for this amp and can not find one.
Hopefully we can start there.
From the vacant holes in the chassis, this amp seems to have been pretty heavily modded. I would suspect the tubes first and try known good tubes first to see if that corrects it. I always clean pots and tube sockets with contact cleaner on any old amp I get. Platefire
> (6)0(7)0(8)0
There's stuff on those pins, so it isn't un-used.
Find where Plate (probably pin 6) is supposed to be getting power from, and find why it isn't getting it.
While I really didn't have the time to reverse engineer this thing I did find this link with the same Sonic Head in question. The Kern looks almost identical from the outside but the chassis is much different on the inside.
http://vintageamps.com/plexiboard/viewtopic.php?f=11&t=87506&p=992851 (http://vintageamps.com/plexiboard/viewtopic.php?f=11&t=87506&p=992851)
... The Kern looks almost identical from the outside but the chassis is much different on the inside.
A little different, but not very different. Tube sockets and wiring appears the same, best I can tell from their low-res photo.
You amp has additional filter caps inside the chassis, while theirs appears to have 2 extra can caps mounted approximately where your Cornell Dubilier filter caps are.
