Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: gtrbryan on October 20, 2012, 11:13:33 am
Title: Adding an Additional Octal Preamp and Other Questions GA-9
Post by: gtrbryan on October 20, 2012, 11:13:33 am
I have a lot of old, octal preamp tubes and since I've never built anything outside the 12__7 paradigm I have decided to tread into that territory.  I picked a Gibson GA-9 which has a 6SJ7 preamp and uses two 6v6's in parallel.  Of course, I have a few questions.
1.  The GA-9 power amp is close to the BR-9 which uses a 6SN7 as a preamp tube.  I would like to add a second stage with the 6SN7.  My thought was to use two 220k mixing resistors like I have seen on the Bassman.  However, I'm unsure how this would work right into the power tube.  My idea is listed on my schematic.  Thoughts?
2.  The GA-9 uses a field coil speaker that I don't have and won't be using.  From the schematic, it looks like I need about 275 on the plates of the 6V6's (seems low to me) so I thought I would use a 275-0-275 I have to get about  315.  Sound ok?  From the schematic, it looks like the speaker field knocks the B+ down from 342 to 275.
3.  The GA-9 has a 470 ohm resistor going from pin 5 of one 6V6 to pin 5 of another (signal path). I was going to omit this as I had not seen it on any other parallel schematics.  What would this resistor be used for?  Should I keep it?
3.  Finally, I was thinking about my OT.  My understanding is that I need half the "normal" primary impedance for parallel tubes.  I have a single ended / heavy duty OT with 8k primary.  Can't I just plug a 4ohm speaker in the 8ohm output and the tubes will "see" 4k?
Thanks as always. I have attached my current schematic and all thoughts are welcome.  Also, here are the schematics for the GA-9 http://www.gibson.com/Files/schematics/GA-9%20Amp.pdf (http://www.gibson.com/Files/schematics/GA-9%20Amp.pdf)  and the BR-9 http://www.gibson.com/Files/schematics/BR-9%20Amp.pdf (http://www.gibson.com/Files/schematics/BR-9%20Amp.pdf) for reference.
Title: Re: Adding an Additional Octal Preamp and Other Questions GA-9
Post by: kagliostro on October 20, 2012, 01:23:40 pm
Yes
only remember that the current that cross the OT must be bearable by it
I like the idea - in the 6SN7 path you can also consider if you want a ToneStack
I think that can be do
May be also you can try to bridge the input (6SN7 + 6SJ7)
and/or a pentode/triode morph, look to Tubeswell schematic on this tread
http://ampgarage.com/forum/viewtopic.php?t=19333 (http://ampgarage.com/forum/viewtopic.php?t=19333)
as to experiment different tones
Post by: gtrbryan on October 21, 2012, 04:02:10 pm
Thanks!  My OT is rated for 15 W SE so I'm thinking it will be fine.  Any thought on my choice of PT and voltages?
Post by: HotBluePlates on October 21, 2012, 07:13:13 pm
Do you want the added channel to be very clean?
The 6SN7 is the octal precursor to the 12AU7. I'd expect the cascaded 6SN7 to have a similar gain as the 6SJ7, when the volume is near max. A higher-gain dual-triode might give you a wider range of useful volume settings. You could use a 6SL7, which has a gain more akin to a 5751.
Your new amp doesn't have its speaker? Or its power transformer?
If you're minus the field-coil speaker (because the amp has been cannibalized or butchered), you could just use a 1kΩ resistor in place of the field coil. The schematic shows 342v before the field coil, and 275v after; 342v-275v = 67v. That implies 0.067A across the 1kΩ, and it will dissipate 67v*0.067A = ~4.5w. Use a 1kΩ 10w resistor minimum.
It's a grid-stopper. Presumably, one of the 6V6's is closer to the volume control than the other, and they added the grid stop to the further tube to prevent oscillation. If it were me, I'd probably use 1.5kΩ 1/2w resistors going to both 6V6 grids, and feed both from the common input. I'd probably also add screen resistors (say 470Ω 2w) for each 6V6 screen, to connect to the screen B+ node.
Again, you're confusing me. Is the OT missing from your GA-9, or was it mounted on the (now missing?) field coil speaker?
You didn't ask, but I recommend changing your mix network. You need a 220k-470k resistor to ground per 6V6 (or you can combine two 470k's into one actual 220k resistor to ground). Previously, the 500k volume control performed this function. But you'll be adding a channel, and attempting to isolate them somewhat, so you now need to add that grid reference resistor.
You may consider boosting the existing volume controls to 1MΩ each. The original was 500k, but now you'll be adding that 220k mix network and a 220k-470k resistor to ground. All this is gonna amount to something of a voltage divider and will reduce the effective signal at the 6V6 grids. Using a 1M pot in place of 500k will allow you to recoup a little of that gain (it boosts preamp stage gain because it is a lighter load).
The other reason to use it is that the 500k volume pot needed to be small to be an effective grid reference for the 6V6's if you turned up to max volume. You're now not going to have that situation, so you can use a larger-valued pot.
Post by: gtrbryan on October 21, 2012, 08:33:01 pm
Didn't mean to confuse. This is a scratch build. I have an OT and PT (275-0-275) from other projects I never got to. Thanks for all the good suggestions. I may go 6sl7.  Would probably be more use to me.
Post by: HotBluePlates on October 21, 2012, 08:39:05 pm
Now I see that you said, "I picked a Gibson GA-9..." where I thought you said, "I picked up a Gibson GA-9..."
So my mistake.
Your 275-0-275 transformer is very reasonable. Your B+ may come out higher than 315v, but that's not a problem.
Post by: gtrbryan on October 21, 2012, 10:28:49 pm
Instead of doing the mixing resistors (which will loose power) wouldn't it be better to switch the channels with a 2pos 4 pole rotary switch?
Post by: HotBluePlates on October 21, 2012, 10:38:36 pm
They'll lose voltage, but power is not an issue as the current is so low.
You could use the switch. I was gonna say you couldn't play through both channels at the same time then, but the 2 channels will be out-of-phase due to the odd/even number of stages.
Post by: kagliostro on October 22, 2012, 12:40:57 am
Sorry, I forgot to consider that  :worthy1:
Post by: gtrbryan on November 25, 2012, 08:04:36 pm
I took another stab at a schematic for this new build.  I've decided to go with two stages, one GA-9 and one from the 5C1.  I put in a switch for the signal and before the power tubes.  Would this be the best way, or should I use mixing resistors?  I thought with a 2pos 4 pole switch I could avoid any lost signal going into the power tubes.
Of course any comments are appreciated.
Post by: gtrbryan on November 25, 2012, 09:31:16 pm
Following up on my earlier post, if anyone thinks that mixing resistors are a better idea I would be interested on how to set that up. I don't want to loose gain, but the more I think about it the switch will make a very convoluted layout with long signal path wires (oscillation???). 1m pots for volume with 270k mixing resistors and a 470k to ground before each 6v6??????
Post by: kagliostro on November 28, 2012, 02:28:28 am
Have you considered the new relay board that Doug sells ?
http://www.el34world.com/projects/relay_switch.htm (http://www.el34world.com/projects/relay_switch.htm)
here some documentation about the use
http://www.el34world.com/Forum/index.php?topic=14348.0 (http://www.el34world.com/Forum/index.php?topic=14348.0)
