Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: garyboy on November 20, 2012, 01:02:23 pm
I am looking at a hammond 100W OT P-T1650R on TUBESANDMORE.COM. The description for the tranny says it has 4/8/16R impedance on the secondary and it's CT is 5000R. When you look at their diagram for the OT it show's 0/4/8R and a 0/4R secondary taps. How would you wire this for 16R operation if there isn't a 16R tap like they say it has?
You would have to go to the hammond website and look up that transformer. Then you would find the wiring diagram (see attached pic). If you are considering the 1650R OT may I suggest getting the 1650RA instead? It has a straightforward (easy wire) secondary. I hate those OTs that require a jumper kludge to get what you want. That really complicates switching impedance.
garyboy ,
The P-T1650R is a linear transfomer . Kind of transformer the worst Fender Silverface's amp have.
Why don't you order Hammond 1700 serie ? That's the real tube classic for guitar amp.
www.hammondmfg.com/guitarLineOT.htm (http://www.hammondmfg.com/guitarLineOT.htm)
I don't know why Antique Electronics Supply ( tubesandmore) don't have this serie.
Few weeks ago I ordered an 1750G from my hammond distributor.
I've used the 1650R and it's a great transformer. Just because the U/L taps are there it doesn't mean you can't use pentode hook-up, and with a DPDT switch you can experience that Silverface nostalgia at your convenience.
I don't talk about the early 70s Siverface wich are like Blackface ,very good. I talk about the mid and late 70's silverface. There are no nostalgia about those one.
Ultralinear are costly too
Hammond list price ;1650R $190 and in direct replacement the 1750W is listed at $116
'Twas a joke my friend. On a more serious note, nothing in the 1700 lineup has 5k primary at 100 watts if that's what the OP was looking for and indeed it was what I needed for a pair of KT88's. Switching secondaries is easy with Hammond's rotary impedance switch.
Tumbs up .
I see thanks Sluckey. I wasn't sure if i was understanding the diagram because i was low on coffee and it was late when i looked at it or just being dumb. I also saw they offer a prewired impedance selector for those style hammonds.
AES DOES carry the 1700 series.
The 1650R is a bigger, heavier transformer, with a wider full-power frequency range and has a much bigger core.
1650R: 30Hz-30kHz, 12 lbs (but 5k primary)
1750W: 70Hz-15kHz, 4.5 lbs
The 1650T may be a better comparison, at 1.9k primary and 14 lbs.
The bigger Hammond may be "too good" for classic guitar sounds.
92 clams. ya gotta wait though.
http://www.edcorusa.com/p/459/cxpp100-ms-5k (http://www.edcorusa.com/p/459/cxpp100-ms-5k)
--DL
