Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Jack_Hester on December 01, 2012, 09:32:17 am
Title: Ampeg B-12-XY....
Post by: Jack_Hester on December 01, 2012, 09:32:17 am
I'm at it again.  Maybe I won't be so lengthy with this thread, though I can't promise.  The poor old Falcon will just have to wait.  Glad it belongs to me.
I figured as I had my first older Ampeg behind me, I would stay on a roll.  I have a similar model, in B-12-XY configuration.  I've got it close to the basic working condition as the last.  It was purchased as a 'working' amp, but the hum was so very loud.  Not in much of a working condition.  Glad it was reasonably priced.  Here is the schematic that I'm working from:
http://www.el34world.com/charts/Schematics/files/ampeg/Ampeg_B12XY.pdf (http://www.el34world.com/charts/Schematics/files/ampeg/Ampeg_B12XY.pdf)
Anyway, I decided to clean up the wiring in the cabinet first.  I removed the speaker and horn.  The speaker had four repaired tears.  I found a fifth tear.  The four had been glued, but that was all.  I covered them each with a patch of glue saturated paper towel, as well as the tear that I found.  Dried them with my heat gun.  The horn was non-working.  Someone had been inside of it, as both speaker coil wires were broken off.  One, flush with the cone.  I'll have to see if I can find a replacement cone.  Got the cabinet insides cleaned up and new speaker cable strapped in and soldered to the connector.  I left a piece attached for the horn, whenever I have it repaired or replaced.
I replaced the speaker cable connector with a new one, as the old was some damaged.  I also cut and stripped back the cable end, going into the chassis, remembering how badly the last one was damaged.  It already had a grounded cord, but I did the same with it.  Stripped it back and reconnected.
This amp has had 'hands-on', in it's past, and was very trashed in it's appearance.  I won't go into all the detail on what I found, but I made note of each non-standard component and where it was attached.  Then, I removed them all, and put them aside just in case they could be reused.  I started with the power supply by removing the canned decoupling capacitors.  The schematic shows C49a,b,c,d to all be 40uf.  And, C48 to be 30uf.  I had a can that had two 40's, and two 20's, an extra purchased for the last amp repaired.  I installed this one, and paralleled a .22uf with each 20uf.
Then, I began my testing with all tubes removed.  A note here about the tubes.  I tested all of them on my B&K 707, and the 7199 was bad.  I had only one on hand, and it tested good.  All the rest were in good shape.  I powered the amp and measured the mains and filament voltage.  I did not record them, as they all showed higher than normal, with no load.
Next, I put the rectifier tube in, and powered the amp on my lamp limiter.  Standby on, 25W, 40, 60, and 100.  Then with full line voltage/current, I took the same readings for it, plus the DC out.  Those were satisfactory.  I installed the power tubes, and when I put power to them, I got a very load hum in the speaker, with no B+ (standby switch was open).  Shut the power off quickly and removed those tubes.  I did not check the Bias voltage before, so I turned the power on and checked it.  I had a negative DC downstream of the diode.  So, I checked everything around it, by the schematic.  C36 was missing.  It's supposed to be a 100uf.  I looked at my notes, and I removed no cap from this location.  I found a new 100uf and I pulled a 47uf to try, also.  Installed the 47uf first.  Put the power tubes in and powered it up.  Only a slight hum, more like a buzz, was present.  Very low.  I put the 100uf in, and made the same test.  Same buzz, so I left it in.
I went back and put the 100W bulb in and one at a time, I installed the remaining tubes turning the power off between each.  And, listening for a change in sound as I closed the standby switch.  V8 generated the first hum, though it was not very loud.  The rest made no difference.  I grounded V8-pin9 and the amp got quiet.  I moved over to V5-pin4 and grounded it.  Amp went silent.  Moved over to V6-pin4 and grounded it.  No change in hum.  So, it looks like it's in between these two tubes.  I'll not chase this one yet, as I want to do some more checks on the rest of the amp.
A note here.  Vibrato does not work.  And, the Echo is ever so weak.  Turned up full, you just can hear a difference.  But, you've got to listen for it.  I won't chase those just yet.
Jack
Title: Re: Ampeg B-12-XY....
Post by: Jack_Hester on December 01, 2012, 09:37:38 am
I got cut off with too many characters on the last post.  Here's the rest.
I made whole-amp voltage readings and put them in a table.  Figured it would be easier to read than the manner that I posted them on the last amp.  They are attached below, in a graphics file and a pdf.
Please note the highlighted voltage in the table.  It is a little better than twice the value stated on the schematic.  Right now, I'm thinking C33 needs replacing, but I'll await comments.
Anyway, that's where I am now.  I took the opportunity to come to the house and warm up.  The shop was 39°F when I left.  The sun is out, so it should be warmer in there, now.  I'll post my findings as I go.  Have a look at my data, and please comment.  Thanks for all the help.
Jack
Post by: Jack_Hester on December 01, 2012, 02:35:37 pm
I am finding some wiring discrepancies between this amp and the schematic that I downloaded.  This amp does not have one glued to the chassis platform, like the last one did.  The Echo tank is in that spot.  If any of you have an original that you can scan, I would greatly appreciate it.
I sent an email to Loud Technologies, but don't expect an answer for awhile.  Until I can find an accurate one, I'm just going to have to blow this schematic up and divide it into sections.  Or, find somewhere to print it on an 11"x17" sheet, so that I can mark it up as to how this one is built.  Then, I can CAD a correct one.  This alone is going to slow this troubleshooting down, greatly.  But, I'm working on it.  Have a good one.
Jack
Post by: Jack_Hester on December 01, 2012, 05:01:23 pm
Ok, did a little search.  Seems that a couple other people have run into the same situation.  One of them posted a hand-drawn schematic of the Echo circuit.  I haven't confirmed it with mine, but more than likely it is the same.  I've attached it below.  I'll confirm tomorrow afternoon, after Church.  Have a good one.
Jack
Post by: sluckey on December 01, 2012, 07:40:48 pm
You did not mention the separate small speaker cab used for the echo. Do you have it? You must have a separate speaker to hear echo (reverb) from this amp.
I don't trust that hand drawn schematic. Output stage looks whacky.
Post by: PRR on December 02, 2012, 12:02:05 am
I think the OT is drawn in two pieces. If you slide the secondary up-over next to the primary it looks conventional.
Post by: Jack_Hester on December 02, 2012, 06:26:17 am
Yes, the speaker cabinet is there.  Let me clarify a bit, about the Echo.  The signal from the spring tank is amplified very well.  But, I'll reserve judgement on that, until I have it all assembled, and the amp is riding on the rubber mounts.  As it is, laying on the table top, I can thump the table, and get a very good echo from the little speaker box.  Rather clear and loud, though I don't know how it's supposed to sound, as the larger speaker is capable of so much more than the two little ones in the box.  Anyway, I'm thinking that the signal driving the tank is not getting through, though I haven't gone that far in my troubleshooting.  I had another Hammond tank connected to it, just to verify.  Not knowing the impedances of either, I hooked it up briefly as a comparison.  Same results.  Weak.
I don't trust the hand drawn schematic either.  When I have my own markup, I can verify it.
This would be a rather busy schematic to CAD.  At least for now.  What I'm planning on doing first is to take the original (blown up in size) and mark it up as to how my amp is wired.  While I'm at it, I'll see if I can't put in some better component labels, values, and any other items that might need better identification.  When I'm to that point, and I'll be troubleshooting at the same time that's happening, I'll decide if CADing is necessary.
Though the work on the last Ampeg had me scratching my head quite a bit, it was way more basic than this one.  Fortunately, after the cleanup of the chassis and speaker cabinet, and replacing the missing component(s), this one is working at almost the level of the last.  It still has some cleanup of the slight buzz to be done.  But, getting the schematic in good order is a priority right now.  And, I may find some of the issues as I do this.  I'm thinking that the resolution of the Echo will come along first, before the Vibrato.  Already, the caps in the Vibrato don't match the schematic.  The ones with the value of .022uf in the schematic, are actually .01uf in my amp.  Which way do I go with those?  I know that some of my background hum/buzz is coming from that direction.  But, it's not annoying, yet.  At least, until I have all things working.  Then, the chase is on, for that.
I'll confirm this, hopefully within the next day or so.  And post my findings on a copy of the original.
Work hours are rather long for the next week or more, so work on the amp will be minimal at best.  But, I'll keep nibbling at it, until I can spend more time.  Thank you for your comments and please keep me on track if I head off in the wrong direction.  I'll try to post my moves accurately, and not depend on a poor memory.  More to come.  Have a good one.
Jack
Post by: sluckey on December 02, 2012, 07:49:47 am
Yes, I considered that. But the 68µF between the secondary and the RCA speaker jack still looks whacky.
Post by: Jack_Hester on December 02, 2012, 03:25:33 pm
16:05 hrs. -  I got out here at 15:00 hrs..  I don't know when I'll finish a markup of the schematic, but what is labeled as V8b,c is actually V7b on the left and V8b on the right.  And, I have a 50uf-50v cap between the secondary and the RCA connector.  It's not on my schematic, but it is original to the amp.
And at this point, I have verified my amp Echo circuit. Substitute V7b for the left triode, and V8b for the right triode, and it's wired very much like the drawing.  R67 is shown as a 5.6M resistor in series with C39, a .001uf cap, connected to a tie point on J6/8 ohm OT secondary.  Mine has two(2) 5.6M resistors in series, those being in series with C39.  Maybe that's a reason for the weak Echo.
V9 is just as it's drawn.  I just made a quick comparison with the hand sketch that I posted, from the other fellow.  I believe that he has it very close to mine.  Also, my footswitch is like his, in series with R71 to V7-pin6.  Not like the schematic.
Lastly, there are about a half a dozen component value differences, from the schematic.  I'll show those in my markup.
Anyway, I'm calling it quits for this evening.  I'm glad to have the Echo circuit documented.  Of course, the remaining triodes of the V7 and V8 have to be sorted out the same way.  I'll see if I can't get what I've found marked up on a drawing, tomorrow.
More to come.  Have  good one.
Jack
Post by: PRR on December 02, 2012, 05:47:12 pm
Ah. I understood it as a bass-cut. 68u+8r= 300Hz, very reasonable to take the heavy boom/bang/mud out of a spring tank.
There's also 170Hz cut going into Echo Dim pot, and 340Hz cut at 6AQ5 grid.
That cap is drawn as polar electro. And there's pretty good power available. So it will crap-out "young". I've done similar caps as crossovers and they work for years. What was Ampeg's original warranty?
Yup, by now it sure is time to find 68u NON-polar in 25V or 50V rating. PartsExpress tends to have some low-cost options (this isn't a place for silver-foil and mink-oil caps). Or two 150u 50V polar electros + to + in series.
Or strap it. Signal will pass. I suspect it is about the specific speaker they used: great mid-high output but didn't handle bass gracefully. Since reverb for effect is mostly midrange, bass-chop is appropriate, but strapping will tell you signal gets through.
Post by: xm52 on December 02, 2012, 09:04:06 pm
There are a few amp variations in the B-12X series including the B12XY, B12X-B18X and the B12XT. I think that it would help to look at the schematics and compare them. Here is a copy of the B12XT manual and schematic (http://www.vintage-blue.us/blog/schematics/b12xt_manual.pdf (http://www.vintage-blue.us/blog/schematics/b12xt_manual.pdf)).
Concerning the phase inverter pin-9 voltage. Yes it looks off. The pin-3 voltage is usually a lower than pin-9 but not by the amount that your reading revealed. I would check out the voltage divider resistors that connect to pin=9, R56, R57, and R58, are the correct values and are up to spec. The B22X has pin-9 of the 7199 at 115V, so higher voltages than those seen in the XT are not unheard of.
Here is a copy of the B12X schematic. I don't have a better copy of the XT one.
(http://img585.imageshack.us/img585/9139/b12x.gif) (http://imageshack.us/photo/my-images/585/b12x.gif/)
Post by: Jack_Hester on December 03, 2012, 07:41:59 am
Please explain strapping.  Thanks.
Jack
Post by: sluckey on December 03, 2012, 07:49:45 am
Put a jumper wire across the cap.
Post by: Jack_Hester on December 03, 2012, 08:09:31 am
R56 is a 100K.  R57 and R58 are the values shown on the B12XY schematic.
Jack
Post by: sluckey on December 03, 2012, 09:35:42 am
I would not worry about the voltage on pin 9. That PI circuit uses bootstrap biasing which causes the grid impedance to be verrrry high. Meters with a 10M input impedance will load the grid and cause the voltage reading to be much lower than it actually is.
Post by: Jack_Hester on December 03, 2012, 10:43:47 am
10:55 hrs. - Ok.  I believe that I have tubes V7 (6D10) and V8 (6D10) verified, as to where they belong on the schematic.
On Channel 1 (J1, J2), V7a is correct as drawn.  V8c is after the tone stack, instead of V7b.
In the Echo circuit, V7b is the first triode, instead of V8b.  V8b is the second triode, instead of V8c.
In the Vibrato circuit, V8a and V7c are correct as drawn.
Both Vibrato and Echo depend on their cathode resistors being grounded through the footswitch, to work.  Both switches are so intermittent that I will replace them.  For now, I have alligator hard jumpers in place.  Vibrato doesn't even attempt to work.
In all fairness, the Echo may very well be as loud as the two little speakers will let it.  They are 4" speakers, and with the Dimension pot at full, I can pluck a string and dampen it, and I hear the sound/echo in these speakers.  And, it is not quiet, if I test it that way.  This would make a nice little amplifier, by itself.  If it were mic'ed separate from the main speaker cab, it might sound good.  The 12" speaker just drowns it out.  I'm beginning to think that if I had a 12" connected to the RCA jack, I would hear much better 'Echo'.
I'll put this circuit aside (in the troubleshooting) and move on the the Vibrato and the buzz.  I had almost forgotten about the buzz, as it is so subtle.  But, I have the B-12-N to compare, and it is quiet, with no such buzz.  I'll go back and revisit it by grounding grids, now that I have a usable schematic (markup, that is).  More to come.  Have a good one.
Jack
Post by: Jack_Hester on December 03, 2012, 11:33:50 am
I'm in a verifying mode.  I'm going to do so with all the components in the Vibrato.  No detail for every one, just yet.  But, the most obvious differences are C13,14,15, and 16.  They are all .1uf in my amp.  All other Vibrato details will be posted on the corrected drawing, for the whole amp.  Those just stood out.
Jack
Post by: Jack_Hester on December 03, 2012, 04:11:49 pm
16:55 hrs. - The entire amp has been verified and markups made on my drawing.  I printed it in four large (8.5x11 each) sections, so that I could make notes.
Just took a bias voltage reading: -51.5vDC
Measured the bias current on each tube: V1 - 28.2mA, V2 - 26.3mA
So now, I need to figure out how to make a high resolution drawing with the notes.  Windows Paint just don't get it.  I'm unable to save as a high-res file.  Right now, all I have the schematic saved as is a pdf file.  When I copy and paste the schematic into Paint, it is lower resolution than the pdf.  I tried another graphics editor with the same results.  I think that I need to start with a high resolution graphics file and go from there.  I'll post my progress.  Have a good one.
Jack
Post by: Jack_Hester on December 03, 2012, 07:21:36 pm
The heck with learning a new graphics editor.  I can do it in CAD, so I started making a new schematic from the original.  I forgot to bring my notes to the house.  But, using what I posted here, I can at least get the tube nomenclature correct.  That will be rev A.  I will update the drawing with my component values and cal that rev B.
So, here's as far as I got this evening.  Long hours start tomorrow (Tues), and for the next 8 days.  I can try to add a little to it over that time.  More to come.  Have a good one.
Jack
Post by: Willabe on December 04, 2012, 12:59:28 am
That looks real good Jack. Way better than Express SCH, which is what I use.
                    Brad     :icon_biggrin:
Post by: Jack_Hester on December 04, 2012, 08:26:35 am
Brad -
I started to use Express SCH.  But, I already have my symbols library in good shape for tubes, in AutoCAD.  Not very well organized, or clearly labeled.  For someone else to use.  But, I can find just about everything I need.  So, I'll just wade through the schematic and build it a section at a time.  A bit easier time doing this, than hand-tracing it to verify by the old one, like I just completed.  That took a while.
I really need to organize my symbols library better, and rename the symbols to be clearer.  Stuff like that is my rainy day/cold and nasty weather kind of stuff to do.
Anyway, it's coming along.  I might even make a layout of the eyelet board.  It's fairly cut and dried.  I know that it's 2" wide.  And, the eyelets are on a 3/16" (or was it 5/16") spacing.  I don't have symbols made for actual components.  But, a layout with electronic symbols would be a start.
Jack
Post by: Jack_Hester on December 06, 2012, 08:17:00 pm
Just a little on rev-B, which reflects my actual amp configuration.
I just noticed that even though this is the makings of my amp, I still have the component values from the actual schematic, which will be rev-A.  When I'm finished with both, they'll be correct.
Jack
Post by: Jack_Hester on December 08, 2012, 05:43:09 am
I'm still chiseling away at the rev B version of my schematic, 30-45 minutes or so, when I can.  I've also begun the process of troubleshooting the Vibrato circuit (in my head), and wondering where to start with cap replacements.  This portion covers a lot of ground, compared to the rest of the sections.  Should I just go ahead, bite the bullet, and replace all caps from V5, V6, V8a, through V7c?
That is a whole lot of caps at one time.  Or, should I take one tube section at a time, and see what happens?  Or, is there a definite starting point on an oscillator to look for trouble?  I know the Channel works without it.  And from the drawing, the signal wiggle from the oscillator to V3 originates at R29.
I've already changed the cathode cap C23, on V7c.  I did that up front, as part of the cleanup.  It had a big ol' clunker stuck in there, and I put a 25uf-50v back in it's place.  I don't know if it really needed that high of a voltage rating.  But, I had one, it was small, and it fit nicely on the eyelet board.
This is one of the sections of my amp where the component values (mostly caps) are different.  The .05's have .047's in place.  I don't consider that value difference to be an issue.  But, I'll let someone else speak up and clue me in.  Also, most (if not all) of the .022's are .01's on my amp, in this section.  I would consider this to be a point of concern, if they had been all replaced with these values.  But, they have all appearances of being original to the amp.
The first time that I tried the Vibrato was the last test, after going through the steps with the lamp limiter, testing the rest of the amp, and doing some additional cleanup.  When I tested it, I had a guitar laying over on a bench, and connected to Channel 1, volume, treble, bass at 12 o'clock.  I did not use the footswitch.  I strummed the guitar to have a sound coming out of the amp, and jumpered the footswitch teminals.  Vibrato Speed and Intensity were at 12 o'clock.  There was an oscillation that began, died down to none.  And, it hasn't worked since.  Having no real history of the amp, I'm assuming that it's been sitting for quite some time.
Anyway, that's where I am.  Can't spend any hands-on time with the amp.  Just drawings and looking at them as I go.  Please study and comment as to a good direction to start, when I can get back to troubleshooting in the shop.  Thanks for all help.
Jack
Post by: sluckey on December 08, 2012, 06:47:46 am
No. Divide and conquer. Make the oscillator V7c work and the rest of the trem circuit will probably work.
Remove the lamp limiter if still connected and plug the amp straight into the wall. V7c needs full B+ to operate. Check voltages on plate, grid, and cathode of V7c. If oscillating properly the plate voltage will be fluctuating at the trem frequency and will just appear erratic on most dmms. A scope or analog meter would be very nice to monitor the plate. The trem signal on the plate should be a BIG amplitude low frequency AC sine wave. You can view this signal with a scope. Or, your dmm might be able to measure it. My Fluke 87 can measure the RMS voltage as well as read the frequency of most tube trem signals.
If your V7c is not oscillating, swap V7 and V8 first, or subsitute a good tube for V7 if you have a spare. If still no go, change C20, C21, and C22 (.047µF is fine). Next check resistors in V7c circuit and measure resistance to ground for the grid and cathode.
Hopefully the trem will be working at this point. Let us know the results of these few checks.
Post by: Jack_Hester on December 08, 2012, 07:30:18 am
Divide and conquer is what I like.  Thank you very much for the starting point.
I'm past the point of lamp limiter.  It's been on full line voltage/current for the last several times that I've had it on.  I'll use my VTVM for this.  I look for opportunities to use it, as they don't come often.  I'll compare with the Fluke 8062A, but I like the idea of watching a big needle swing.  No doubt about oscillation there.
I'm fairly sure that I've got some 6D10's, though I'd have to look for them.  Both these tested very high, but that don't always tell the story.
I'm hoping a few cap changes will put it back in commission.  I'll replace any and all that's needed.  I'm unable to be in the shop this weekend through next Tuesday.  Come Wednesday, I've got some time off from the long hours, so I'll be out there early.  I will dig out some .047uf caps and have them ready.  Assuming I haven't used them all.  Not sure if RS carries these.  'Back in the day', I used to depend heavily on a Lafayette store, about an hour's drive away.  Plus, there were any number of private shops that carried everything, for their own work.
Anyway, I'll have the parts on hand, and will post the intial results.  Thanks again, for the starting point.  Have a good one.
Jack
Post by: Jack_Hester on December 08, 2012, 08:10:22 am
Thinking out loud, before I head back out on the boiler.  What should I expect from this Vibrato?  Compared to the favored Fenders and such?  It seems way more involved that the typical Tremolo circuit.
Or is this true vibrato?  I am not versed well enough, in the circuits or sounds of each, to see or hear the difference(s).  I contemplated building a stand-alone Dorf Vibrato, until I started searching for the capacitors needed, that had pf values.  I haven't given up on that one.  But, it became very low priority.
Anyway, is there something really exceptional about this one, over others?  I hope so.  I'm a little off center, myself.  More concerned with it working, first, but just wondering what made Ampeg go this route.
Jack
Post by: Jack_Hester on December 12, 2012, 12:57:11 pm
I have some time off, to work on the amp.  However, my parts order has not arrived, so I've been working on the schematic cleanup.  I've got the first draft done, but I've got to do some cleanup and verification.  I'm also going to add a tube legend and voltages, when I'm done troubleshooting.
Anyway, I've attached the first completed draft, knowing I've got to do component verification again, and doublecheck myself on the wiring.  But now, I'm working with a full schematic, and not making one.
Jack
Post by: Tom_Hull on December 12, 2012, 09:39:55 pm
capacitors anyone ,,resistors ???
the caps i needed,,,,the 8 ufs 450 volts were out of stock ,,well a short wait and the caps are in stock,,yaa...now i can finish an amp and start on an ampeg again .
http://www.justradios.com/cart.html (http://www.justradios.com/cart.html)
tom
Post by: Jack_Hester on December 13, 2012, 08:29:49 am
Ok.  The drawing of my amp is complete.  I replaced the one in the previous post attachment.  The corrected component values verified with amp.  And, voltage chart has been added to the drawing.
My parts order still hasn't come, so I'm going out and dig through what I have, and see if I have some .047uf caps to replace for C20, C21, & C22.  I'll look to see if I have enough to replace C18 & C19, and .1uf for C24.  If I don't have anything close, I'll wait.  Correct stuff is on the way.  More to come.  Have a good one.
Jack
Post by: Jack_Hester on December 13, 2012, 10:15:13 am
I found three Orange Drop, .05uf-600v caps.  So, in they went for C20, C21, & C22.  I replaced C24 with another .1uf.  I warmed it up, hooked up the guitar, and strummed a chord.  Jumpered the footswitch and got a warble from the Vibrato.  But, that decayed away to none.  Lifted the jumper and put it back.  Got the warble, but again, it decayed to no warble.
So, I'm off to start digging to see if I have a couple more caps to replace C18 & C19.  As a note: I replaced C23 with a 25uf-25v, back when I first started.  So, that one's new.  I'll be back with the results of my digging.
Jack
Post by: Jack_Hester on December 13, 2012, 10:56:43 am
Found some .047uf caps to replace C18 & C19.  Got that done.  Got out the VTVM and warmed it up.  I have it connected the plate of V7c (pin 2).  No oscillation when I connect the jumper.  With the jumper off, voltage is a steady 250vDC.  Jumper on, steady 70vDC.  I have the Speed pot all the way down, for slowest oscillation.  I'm going to start checking resistance values (in circuit) in the oscillator.
Jack
Post by: Tom_Hull on December 13, 2012, 11:10:22 am
hi ..jack
if it is like mine
the tremolo needs to charge up at the highest speed ..like off on mine and then turn the speed down .
just wondering about your schematic .
i just built a m12 and mine is different....
i am building another amp  an notice ther was no r 31 any where on the schematic .
did ampeg do different things for this curcuit.??.
my amp is like this .like steves 12j ampeg i beleive sort of ..
why is the r31 not on pin 2 in stead of  11,,,,,,r31 to .1 cap ..
and pin 11 directly to the first .047 cap
and the values r33 470k mine is 270 k
and 150k mine is 120k
just wondering
better to listen to steve about this
tom
Post by: Jack_Hester on December 13, 2012, 11:48:11 am
Checked the resistors, in circuit, and they were very close to value.
C18, 19, 20, 21, 22, 23, and 24 are all new.  Pots are correct resistances.
So, I read back over the thread, and decided to make the tube swap (V7/V8) that Steve suggested.  There it was.  The oscillation was obvious on the VTVM needle.  Plugged up the guitar, and I have Vibrato (Tremolo?).  Though it's not very pronouced like some I've heard, it is very clear and varies with speed and intensity.
I'm headed for the house, to see if I can put my hands on a couple more 6D10's.  Though both of these tested good on my B&K 707, the amp tells the difference.  Looks like I've got a triode that not up to snuff, on the one that is now in V8.  What was V7c is now V8c, and is downstream of Channel 1 tone stack.
Tom -
The oscillator does not look a whole lot different from others.  But, the rest of the Vibrato is different from those that I've been studying.  And, as the amp was basically stock in it's wiring, as compared to the schematic, I will troubleshoot it as such before questioning why it's done the way that it is.  But, I appreciate you making the comparisons to those that you are familiar with.  Makes me look closer.  Anyway, I've got it working with that wiring, so it is as they intended.  Just need to see if more tube swaps will improve it.
More to come.  I love it when I'm making progress.
Jack
Post by: Jack_Hester on December 13, 2012, 01:57:31 pm
Didn't find anymore 6D10's, but found some 6AC10's.  The data sheet on the 6D10 says that its a hi-mu and used as an oscillator, and as an amplifier.  The specs on the 6AC10 says that it's hi-mu and has a higher gain than the 6D10.  But, says nothing about being used as an oscillator.  Only an amp.
I tried it in both V7 and V8.  6AC10 in V7 and 6D10 in V8, the Vibrato does not work.  6D10 in V7 and 6AC10 in V8, the Vibrato does work, and Channel 1 sounds brighter.  With both 6D10's in V7 and V8, Channel 1 is nice and clean, but not as bright.  I swapped these two, again, and the Vibrato stopped working.  I definitely don't understand whats going on, as the triodes are obviously working.  So, I went back with the known good 6D10 in V7 and a 6AC10 in V8, for now.  I'm saving the other 6D10, and marking it 'V8 only'.
Now, to do a bit of reading about these tubes, to see if there is a substitute for the 6D10 as an oscillator.
Jack
Post by: Jack_Hester on December 13, 2012, 04:59:34 pm
Why does one triode oscillate, and another doesn't?  And, both work as amps, otherwise?  As I mentioned previously, I have my VTVM connected between the plate and signal ground, on V7c.  I noticed that the oscillation did not start right away.  Gradually, it started and then reached it's peak.  Should there be a particular type of capacitor used in this circuit?
My parts came in the mail, today.  I believe that I'll pop the Orange Drops out, and put in the smaller physical sized caps that came in my order.  I've got to be careful of components sticking up, as the Echo tank fits into this same space.
Anyway, I'm pondering my next move.  Unless someone has a suggestion for me to try, I'll change out C13, 14, 15, and 16.  I didn't order any .15uf caps to replace those on C10 and C12.  Just an oversight.  My goal is to see if I can get more 'Intensity' out of the circuit.  Again, it sounds good, but its like its not making a very big swing in amplitude, like I'm used to hearing with other tremolo circuits.  I'm wondering if that's because the remainder of the circuit is weak, downstream of the oscillator.  Comments much appreciated.
Jack
Post by: Jack_Hester on December 14, 2012, 08:56:57 am
09:35 hrs. - Heated up the pencil iron and removed the Orange Drops from C20, 21, and 22.  Replaced them with .047uf-400v polypropylene caps.  Warmed the amp up with the same tubes in V7 (6D10) and V8 (6AC10) as yesterday.  Got a nice tremolo from it.  I don't know if it's a different day, or there is a difference in the sound.  But, the tremolo sound fuller today, than yesterday.  Inspired me to swap tubes, again.
So, with the 6AC10 in V7 and 6D10 in V8, I now have a working tremolo that I didn't have yesterday with this combination.  I did notice that the sound is not quite as bright, same as the other 6D10 in V8 (the one that wouldn't warble, yesterday).  Now, I'm inspired to give that one a try in V7.  With 6D10's in both V7 and V8, no tremolo.  So, this tube still won't oscillate.  Swapped them around, and I have tremolo.  So, I left the known oscillating 6D10 in V7, and I put the 6AC10 in V8.  Now, I have tremolo and a brighter channel.  And, this channel is brighter than Channel 2, which has octals in the front end.
I'm hoping someone will tell me why a triode won't oscillate and another like it will.  Do you think a higher B+ will help, on that triode?
Anyway, I'm happy with the results and the fact that I can substitute the 6AC10, if I need to.  Next up will be to do some hum cleanup, thought there's not much, except when the Echo is switched in.  Also, there is a loud pop, when switching the Echo.  I need to resolve that, too.
And, some serious cabinet cleanup, though it won't take much.  More to come.  Have a good one.
Jack
Post by: sluckey on December 14, 2012, 09:04:43 am
Because one tube is a little stronger than the other.
Post by: Jack_Hester on December 14, 2012, 09:52:11 am
Steve -
Do you see a problem with using a 6AC10 as an oscillator?  The spec sheets says that it's a bit higher gain than the 6D10, and no mention of use as an oscillator, like the sheet describes the 6D10.  It seems to work very well as one, but I like it in the amp-only position.  But, I'm thinking now that the amp is in good working order, with minor issues to cleanup, the other tubes may show signs of weakness.  Mainly because I plan for this to be an active amp, with a lot of 'on' time.
I've got plenty of 6AC10's.  I may have some 6D10's, but I've got to dig through a lot of unsorted tubes to find them.  The 6AC10's just happened to have been sorted, and in a labeled container.
Tom -
With the VTVM connected, so that I could watch the oscillation, I noticed what you stated.  With the speed pot at minimum, it took a very long time for the needle to begin to deflect and oscillate, after switching the Vibrato on.  However, with the speed pot at maximum, I got instant oscillation.  I tried this several times, with the same results.  Thanks for that info.  Something to watch for in future troubleshooting.
Jack
Post by: sluckey on December 14, 2012, 11:17:29 am
I think the 6D10 will be fine if you get a strong tube. I don't see any problems with the 6AC10 either.
I did a simple mod on my recent J-12 Jet build that will take care of that slow startup issue. I highly recommend you do this mod too. It's easy to do or undo. Look at this schematic and read the conversion notes...
http://home.comcast.net/~seluckey/amps/RCA/Ampeg_J12B.pdf (http://home.comcast.net/~seluckey/amps/RCA/Ampeg_J12B.pdf)
Tom, this mod will work on your amp too.
Post by: Jack_Hester on December 14, 2012, 12:58:02 pm
Steve -
I wondered about that, in my Echo circuit.  Your mod grounds the output, rather than opening or completing the cathode path to ground.  My Echo circuit opens/completes the cathode path to ground, where the original circuit shows the footswitch grounding the output of the tank.  I may make the same mod to both circuits.  Thanks for the schematic and layout.
My next move is to replace both footswitches.  Most of the time, neither will close.  I've got a hand full of momentary, but can't seem to put my hands on some maintained switches.  Maybe Radio Shack will have some.
Jack
Post by: Jack_Hester on December 15, 2012, 10:15:03 am
11:05 hrs. - Mods are made to Vibrato and Echo circuits.  Both cathode resistors are hard wired to the same ground as their caps.  Connecting the footswitch to ground the output of the tank works just fine.  Doing the same to ground the Intensity pot works also.  However, there is a very loud pop whenever it is grounded.  I tried connecting the footswitch to the pot wiper.  Loud pop.  I then moved it to the junction of the pot and C24.  Same loud pop.
As a side note, before I forget to mention it, whenever the amp has been on for some extended time (like now), it pops very loudly when I put it in standby.  I'm wondering if I should put a cap across this switch.
Update - 11:30 hrs. - Changed the Vibrato footswitch back to the original configuration, and it turns on and off without a pop.  I'm thinking Ampeg had this issue, the other way.  So, they wired it in this manner.
Now, to install new switches in the footswitch pedal.  Found a couple new ones this morning.
Jack
Post by: sluckey on December 15, 2012, 11:45:44 am
I just checked my J-12. It pops too! But my pop is not objectionable with the little 6" speaker. It is too loud when using a big speaker though. Sorry 'bout that.  :embarrassed:
Post by: Jack_Hester on December 15, 2012, 12:29:06 pm
Steve -
Not a problem.  I had to give it a try, to make comparisons.
I just replaced both footswitches in the pedal, and now I have reliable switches.
Any ideas of how to eliminate the loud pop when opening the Standby switch?  Other than that issue, I'm pretty well finished with this amp.
Each channel has a open circuit jack, so there is some hum when the volume is turned up and no instrument connected.  I can plug up a guitar or microphone, and the hum disappears.  Nice quiet amp, though there's a bit of hum introduced when the Echo is turned on.  And only when the Intensity is turned up past 1/2.  And then, not very bad.
I'm still real curious as to why Ampeg chose this configuration for their Vibrato (Tremolo).  I will make an observation about the sound, now that I've been in front of the amp for an extended period.  I have the still unresolved Falcon (Reverb hum) close by, so I can compare the two.  The Falcon Tremolo sounds just like it should.  Amplitude modulation.  The volume has a very obvious swing up and down.  I will listen to the Ampeg a little closer now, to confirm what I'm hearing in it.  But, it sounds like it has an almost chime to the resulting warble.  I hesitate to call it a ring, but maybe that's what it is.  Chime, like that of a bell, as the sound decays.  I don't know.  But, I like what I hear.  And, I've been trying to make it sound like the very pronounced Tremolo of the Falcon.  But, it's not.  Maybe it's not supposed to, with this configuration.  I hope that someone can give me a good explanation of the circuit.
Also, with the little Echo speaker cab sitting away from the amp, the sound is very clear and loud.  I think that I'll be satisfied with it, the way it is.  At some point, I'll make an adapter to be able to connect a larger speaker to the RCA jack, and see if there is any improvement.
Jack
Post by: Tom_Hull on December 15, 2012, 06:08:07 pm
hi
nice to hear about the improvement..
tom..
Post by: Tom_Hull on December 16, 2012, 05:41:02 am
hi
PS i forgot
i also attached the ground wire from the output transformer to the chassis so that it goes through the chassis at the far end from the grounded power tran center wire
lucky for me  a 2 inch wire instead of that long wire i had to the ground treminal...
that may have helped  my amp
i read your comment about the sound decay..
yes mine does that ,,maybe ????lol
i have a new reconed old organ tcs conn speaker turned into a guitar speaker . that holds 20 to 25 watts.
its broken in now ...and the sound is great to my ears .
John wants it . for me its mine but he can borrow it any time ..
i sorted out mine tremolo  problems all at once and it worked good after so i did not change anything..
but i put in .047 uf blackbeauties and i thought maybe its slow and all the rest because of them , i then put 3  .0047 polysteirene fast caps from an old organ , one each in  parrell to the three .047 uf caps .
and i canceled out a resistor by a parrel wire accross the resistor,,,, to the intencity ,it was 470k
my amp turn out fast and with intensity,
 any stronger and i would call it an effect pedal .
with an overdrive  vibracaster pedal hooked up,,,with the trem  off .
the amp with the tremolo on with little occilation ,, the sounds a little ear piercingly high for me ,,
so i use a volume pedal made from an lowery organ . its two long contacts that press together attached to a short small spring . which the current flows threw. my reverb tank lol
well a little less volume and that high pitch sustain calms down .
 the sustain from the tremolo  then has a decay that opens up ,,,like lol  ,,,, eeee,,, oooooo ,,,,,,lol
i had a tremolo hum and a normal umm
the humm i had was everything... i think.lol
 my guitar wiring les paule 100 ep  very poor. fixed that
the copper sheild in the guitar is there now,,
 the guitar  cable was  noisy ,changed it .
the jacks ,i put them so they could get the ground from the chassis . wrong
fixed that the jacks are isolated from the chassis now  .
the amp is almost dead silent .
there is no pop sound at all,,, when unattaching and reattaching the tremolo footswit
 hope something helps you  even though they are different amps
tom
Post by: Jack_Hester on December 16, 2012, 06:14:31 am
Thanks, Tom -
I'll sit down and digest all that you've written, when I get back from Church this afternoon.
I need to break the amp down and haul it all to the house.  This thing is heavy, even in individual pieces.  Well, maybe not the little Echo cab.  The one thing that I haven't addressed is the cheap holding 'bracket' for the footswitch.  Two long screws and a spring stretched between them.  Is this what came from the factory?  Anyway, I'll sleeve the screws and put a new spring on with a padded sleeve.  Maybe just a flexible plastic one.  Anything will be better.
I found a very poor dolly missing the original casters.  Lots of holes where a variety have been on it.  I found some casters that are the same specs, holes, wheels size, and just overall correct, as compared to the originals.  Unfortunately, they are shoddy offshore made.  Axle bolts put on with pliers.  I replaced those with stainless, and put thin washers between the each wheel and the metal bracket.  They cleaned up fairly well.  A shame to have to fix something new.  But, they look good.  Filled the correct holes in the dolly and put slightly oversized diameter screws back in.  The originals were #8's and I used #10's.  Can't even find original style clutch head screws.  So, I used phillips head screws.  Glad I had the other dolly as a reference.  I had to put a new attachment knob on it.  It still had the original rubber feet on it.  Cleaned up the tolex and glued the loose pieces back in place.  Doesn't look half bad.  I can see where dollies catch a beating.  This one will have a calm life for awhile.
It's time to put the Falcon back on the bench and take a fresh look at the Reverb hum.  Such a quiet amp, otherwise.  I'll start poking around with the chopstick, and hope something rears it's ugly head.  More to come.  Have a good one.
Jack
Post by: sluckey on December 16, 2012, 11:57:12 am
I have a solution for the slow trem startup. I've tested this on my J12 and it works fine. Fast startup and no pops.
Refer to your schematic...
  1. Connect R30 straight to ground.
  2. Remove the ground connection from the bottom of the speed pot.
  3. Connect the bottom of the speed pot to V7c pin 3 (cathode).
  4. Connect the footswitch between ground and the junction of C21 and C22.
This is basically what Fender did in the 6Gxx series. Gives fast startup and no pop.
Post by: Jack_Hester on December 16, 2012, 02:35:52 pm
Thank you so much.  That will be a project for the upcoming week.  I buttoned it all up, but I just couldn't take it off the bench.
There's a little bit of hum in the Echo that keeps me thinking that it needs another look.  Nothing bad at all.  I can turn the Dimension pot all the way down, and its even less.  I'm thinking about hooking the Hum control pot directly to V7, as it seems to be common to Channel 1 pre-amp, Vibrato, and Echo.  Channel 2 is way quiet, until I enable the Echo, and turn the Dimension pot up.  I will have to revisit it all, to be positively sure of which induces the most.  Again, none of it bad.  But, the last Ampeg was quiet, no built in effects.  It has become the standard.
I've attached my last revision 'C', which is the amp as it is now.  When I make the next mods, I will post the new one as rev 'D', to reflect these changes.  The final copy will go inside the cabinet.
I've been looking for the literature that would have come with this amp.  So far, no luck.  I was fortunate to be sent scanned copies for the last amp (B-12-N).  I compiled those into one pdf file, and those are in that amp cab.
I'll report back with my results.  Have a good one.
Jack
Post by: Tom_Hull on December 17, 2012, 09:07:31 am
hi
now heres is a schematic from the library.
i have no foot switch . i just have a wire grounded waiting . so and but
on this schematic .in the trem section . can any one explain the wire to the foot switch .??
the footswitch
is it a funny switch ,,like    SPDT<< or the jack ...??
Jack does your amp have this wire ????
tom
http://www.el34world.com/charts/Schematics/files/ampeg/reverbrocket3.pdf (http://www.el34world.com/charts/Schematics/files/ampeg/reverbrocket3.pdf)
Post by: sluckey on December 17, 2012, 10:31:26 am
Your footswitch is underneath R41 on that schematic.
The double footswitch for my old Gemini II was hard wired to the chassis without using any kind of jack/plug.
I did resolve the slow startup issue in my J12. The updated schematic is on my website.
Post by: Jack_Hester on December 17, 2012, 11:09:26 am
Mine has no such wire.  I'm not sure if that line is intentional.  Mine has the footswitch, only, between the cathode resistor and ground.
Not sure if I'll have time to make Steve's mod to mine, this evening.  I am getting really spoiled by these amps.  Unscrew the chassis, and flip it over on the transformers.  No need for a cradle.  I put down a padding to protect the finish.  If I can get a hour, I can do the mod and report back with the results.
Jack
Post by: Jack_Hester on December 17, 2012, 11:30:19 am
In the meantime, until I can get back to the amp, can someone explain Ampeg's reasoning for feeding the oscillator signal through the V5 and V6 stages?  Looks like the oscillator signal enters the second stage of V6, and again on the output of same stage, which feeds the first stage of V5.  Then, the oscillator signal enters at the second stage of V5, and again on the output of that stage.  This output then goes into the RC circuit of C13/R23, C14/R24, C15/R25, and C16/R26.  I don't understand that portion of the circuit, but the signal leaves there and feeds a last stage (one triode of a 6D10), before heading down to V3.  I'm impressed.  And, I sure would like to know what's going on with the above RC circuit.
Jack
Post by: xm52 on December 17, 2012, 12:04:21 pm
The RC circuit is a high pass filter. It removes thumping which can sometimes be heard in tremolo outputs.
Check out the VOX AC-30 and AC-15 schematics and you'll see something very similar being done.
Post by: Jack_Hester on December 17, 2012, 01:28:29 pm
Is this the very subtle thumping that I'm hearing in this amp, with volumes turned down and Vibrato turned on?  My early GA-40's do this, also.  One is rather noticeable.  I bought .1uf caps for C13,14,15, and 16, but have not put them in.  On this amp, you can't hardly hear it.  You can, for sure, in the 40's.
Any thoughts on the extra stages that the oscillator feeds?  Looks like the final signal goes through a 1M resistor (R29) before going to V3.  I'm assuming the large value is there for attenuation.  Thanks for the info.
Jack
Post by: Jack_Hester on December 18, 2012, 08:34:31 am
xm52 -
I took a look at the two Vox schematics that you suggested.  Here are a couple links to the old Gibsons that I have:
'55 and later (50's, that is):
http://www.el34world.com/charts/Schematics/files/gibson/ga40.pdf (http://www.el34world.com/charts/Schematics/files/gibson/ga40.pdf)
'52-'54:
http://www.el34world.com/charts/Schematics/files/gibson/ga40_2.pdf (http://www.el34world.com/charts/Schematics/files/gibson/ga40_2.pdf)
The '55 has the high pass filter that you spoke of, along the lines of the Ampeg and Vox's.  The '54 and earlier have none that I can tell.  It has a very noticeable thumping, when turned on.  I don't care.  It is a wonderful sounding amp, and very quiet.  This was one of those slightly cannibalized/abandoned amps.  Decoupling caps bad, and all tubes missing.  Replaced and it is a keeper.
The '55 needed some of the tubes and the chassis reinstalled.  For some reason, the threads were stripped, for the two mouning screws.  I made a quick fix on it by just putting nuts and new 10-32 x 1-1/4" screws in place of the missing ones.  I haven't had that one back for several months, to make the permanent repairs to the stripped holes.
Off topic a bit, but is this common place to find that people just abandon amps, rather than have them fixed.  The '54 obviously had an active life at sometime.  Battle scars on the cab.  The '55 was well taken care of, but who knows why the screws would be stripped in the chassis?  Amp works great with a complete set of tubes.  Why would they be missing?
Jack
Post by: Jack_Hester on December 18, 2012, 04:27:53 pm
Steve -
17:30 hrs. - Fired up the amp, just to verify the operation of the footswitches.  The Echo switching is quiet, grounding the tank output.  The Vibrato had a pop that was hardly noticeable, in either direction.  So, I now had a reference.  I don't depend on memory, from previous work.
Made the mods to the Vibrato Speed pot, ground, and footswitch, as you suggested.  Vibrato works fine, as before.  However, this configuration makes for a very loud pop when opening or closing the footswitch.  I checked and rechecked my wiring, and I had it wired as you asked.
So, I rewired it back to the configuration, as per the original drawing.  Fired it up, and the pop went back to the low, hardly noticeable level that it was before.  So, I will leave it like this.  It was worth a try.  I have attached my rev 'C' drawing, which is the way it is, now.
I think that I will begin chasing the hum in Channel 1.  I'll start first by connecting the Hum Control pot directly to the filaments of V7.  Before I do that, I will make some checks by grounding the grids all Channel 1 related gain stages, with the exception of V7b.  That one is already grounded with the footswitch, and doesn't change the hum when ungrounded.
Anyway, that will start tomorrow afternoon.  Have a good one.
Jack
Post by: Jack_Hester on December 18, 2012, 05:33:15 pm
Well, I couldn't wait.  The amp was warm, and I wanted to make the checks.
A baseline note: With both channels turned completely down, there is some hum.  I turn Channel 1 up, and hum gets louder.  Back down and turn Channel 2 up full.  No real change in hum (maybe some), but a lot of hiss.  Slight hum coming from Echo speakers, regardless of the Dimension pot position.  I'll chase that one later.
Also, another note: I was ready to call it quits on this amp, because it is such a good sounding, good working amp.  In case you haven't gathered from all this yet, these older model Ampegs are fun to troubleshoot.  I'm just nit picking.  It is not as quiet as the last amp.  But then, it's got a lot more going on in it, than the simplicity of the last.
With the Channel 1 volume pot turned up full, and Channel 2 all the way down, a hum was there.  Not real loud, but you would not want to record it.  I grounded V3-pin7.  Got what I was expecting.  Total silence.  I moved to V8-pin9, with the ground.  Silence, again.  I walked my way down Caps C16, 15, 14, and the junction of C14 and 13.  Total silence, each time.  I even grounded the junction of C12 and R22.  No change in the hum.  Still there.
That was a good stopping point.  Tomorrow, I'll start by grounding V7-pin9.  Just in case it's all coming from the open circuit J1.  Probably is.  I'll post my progress.  Have a good one.
Jack
Post by: smackoj on December 19, 2012, 08:25:34 pm
JH; I don't believe that it is common to find many abandoned amps anymore. Lots of would-be musicians bought amps during the 50s and 60s when the only thing available was tube type. Many of those found their way to the garage, basement or attic and lanquished there for yrs. Probably for two or three yrs now, the ebayers have figured out that those dusty attic queens are bringing five x what they thought, so most of them have found their way onto the auction stage. It seems to be mostly a huge waste of time looking on the bay nowadays for amps, chassis, tubes or even resistors. The people have pushed the 'baseline' price up so high that most of it just sits there without any takers. I bought a couple Bogan PA heads off the bay about 5 yrs ago for under a hundred dollars each. Now I see them for 350 BIN!
So, what is the answer? Well, seems to me like most guys have decided to build from scratch and to heck with the bungalow ebay fruitcakes. I mean, looking at the "Show us your favorite build" thread on this forum it is almost heart stopping the beauty of these amps.....total coolness and functionality. It gives sophomores like me inspiration to see what a motivated tone junkie can accomplish.
Post by: Jack_Hester on December 20, 2012, 04:22:51 am
Yep.  Ebay has ruined being able to get anything at reasonable prices.  My wife and I enjoy an occasional antique fair.  We rarely ever buy anything.  And when we do, it's nothing more than what you can carry in one hands.  Old machinist tools are some of my favorites.  I missed a deal last year on several large boxes of tube related test equipment and load of tubes.  I do what I call a 'whirlwind' trip around and through it all, to see the highlights.  The tube stuff was one of those that I would come back to and haul to the truck.  It was all gone when I got back.  Someone else had a better idea.  I've revised my whole outlook on such finds, now.
Jack
Post by: smackoj on December 20, 2012, 08:09:09 am
I used to watch 'American Pickers' on the cable. I like to watch how other people get the good stuff for reasonable. The tall skinny guy is always saying, when you find a good item, make the buy right then, don't wait. I guess the law of averages has proven to wait is to more often lose.
keep on truckin'
JD
Post by: Jack_Hester on December 20, 2012, 04:19:00 pm
16:00 hrs. - Channel 2 Volume at minimum, Channel 1 Volume at maximum.
Shorted J1 (open circuit jack).  No change in hum at full volume.
Grounded V7-pin9.  Hum actually got louder.  Not considering that an issue at this point.
Grounded the wiper of the Treble pot, R2b (Treble at full), and got rid of what sounded like a very high frequency hum.  Now, there's only a low frequency hum.
Turned my overhead lights off and no real change.  Turned the lights on and picked a little bit of the higher frequency hum, though not much.
Removed the ground from the Treble and got all the high freq hum back.  Lower freq hum unchanged, wiper grounded/ungrounded.
Grounded V6-pin4.  Lower freq hum, same as with volume at minimum.
Plugged up a guitar and heard only a little drop in the high frequency hum.  Not much.
Removed V7 and turned the standby back on, volume at full.  Nothing but the lower frequency hum.
Put the other 6D10 (the one that won't oscillate) in and higher freq hum sounded the same.
Put a 6AC10 in and the higher freq hum sounded the same.  Put the good 6D10 back in.
Grounded the junction of C1 and C6.  All higher freq hum went away, leaving lower freq.
So, looks like my problem high freq hum is upstream of C1.  I grounded V8-pin9 and lower freq hum went away.  Total silence.  That's what I want.
17:20 hrs. - I'll stop here, as the rain is so loud that I'm no longer able to hear the two hums like I could.
More tomorrow.  Have a good one.
Jack
Post by: xm52 on December 20, 2012, 06:20:01 pm
xm52 -
I like the tremolo used in the Fender Vibro-champ AA764. It doesn't have the four pole high pass filter. It sounds great as is. One of the nicest tremolos was made by DeArmond. It employs a shaking drum filled with liquid to make and break the signal from the instrument. It is so simple and yet it sounds fantastic. Very organic. There is some info on it here (http://danformosa.com/dearmond/ (http://danformosa.com/dearmond/)). Building one is on my list.
I used to use an amp that added a characteristic thump. The added artifact was part of the sound. It had a very nice attack. I wouldn't want to change it because it sounded like nothing else.
Post by: xm52 on December 20, 2012, 06:42:25 pm
It could be.
The tremolo has a oscillator that is used to modulate the signal. On some of the Ampeg tremolos, they used an amp stage to amplify the oscillator pulse. Having a stronger tremolo oscillator can be used to provide more depth. Too much depth can lead to thumping so you have to balance things. Likewise you can experiment with the component values in the high pass filter to tune the filter frequency.
When you look at some of these designs, you wonder why they did some things the way that they did. Oscillators can be tempermental and sometimes need something to kick them into oscillation. Sometimes filters are added to the design to fix problems that creep in.
One thing that I like to do with tremolos is slow them way down. You can do this in the Fender Vibro-Champ that I mentioned above if you replace one of 0.01uF caps with a 0.02uF. I think that it sounds better that way.
Post by: Jack_Hester on December 21, 2012, 05:22:30 am
Saturday will be my day to troubleshoot Channel 1 more.  Basically, there are two hums.  A recap of yesterday's snooping resulted in the following:
A higher frequency one that originates between the downstream leg of C1 and the input jacks.  Shorting J1 doesn't help.  Grounding V7-pin9 makes little change.  But, grounding the junction of C1/C6 eliminates the high freq hum.  Leaving a ground attached to this junction, a quick check showed that the lower freq hum originates before V8-pin9.  Ever so quiet.  This is where the noise from the heavy rain stopped my troubleshooting.
Channel 2 has neither of these hums, that I remember.  It does have a very high hiss when the volume is up.  Truth be known, there's probably some hum in there.  But, eliminating the hiss is what I will go after.  Then I'll know if a hum is there to address.  No troubleshooting has been done on this channel, and I won't do so, until Channel 1 is done.  Or, someone has a good idea of what to look for, as a starter.
Jack
Post by: Jack_Hester on December 22, 2012, 01:22:52 pm
Well, I've been at this for awhile, today (Sat).  Not making much headway.
Troubleshooting Channel 1, Volume at full.
With a ground on the junction of C2/pot R3c (Vol), total silence.  No hum/hiss of any kind.
Move ground to the junction of C1/C6, very quiet with some background hum.  I would call this normal, as compared to some of the newer tube amps that I've begun listening to, with nothing plugged up.  I could really live with this.
Still no change, when grounding V7-pin9.
I'm wondering if this is something inherent to Compactrons.  Channel 2 has hiss in the upper half of the volume.  But, no hum like coming from Channel 1.  I've done some more tube swapping.  I already had a 6AC10 in V8.  I now have one in V7.  The channel is brighter than before.  I believe the oscillaor circuit works some better, though that may be just me.
I did move the Hum Control pot over to V7.  Left the existing wires, but put heat shrink over the ends and pushed them back against the chassis.  They are still hooked to V1.  I twisted three conductors and routed them under everything else, against the chassis, and soldered them to V7 filament terminals and a nearby signal ground.  Anyway, it made a difference in the lower freq hum.  I can now null most of it out.
I'm hearing hiss in the higher freq hum, that may have been there the last time.  It just got too noisy out here, then.  Grounding C1/C6 eliminates both the hiss and the higher freq hum, leaving the subtle lower hum.
Anyway, time to take a mid-afternoon lunch break.
Jack
Post by: Jack_Hester on December 24, 2012, 07:43:21 pm
I didn't make any more progress, after the break.  So, I closed up for the rest of the weekend.
I'm thinking my next move will be to lift everything from V7-pin9 and tie it directly to ground with maybe a 1M resistor.  The fact that grounding C1/C6 cleans it up pretty well, and the fact that I've replaced R6 and C1, leads me to think that something in the input circuitry of J1/J2 may be amiss.
While I'm at it, I'll re-flow the solder on R5, if I haven't already done it.  I've done that quite a bit on this amp.
Anyway, it's a place to start looking.  More to come.  Have a Blessed and Safe Christmas.
Jack
Post by: Willabe on December 24, 2012, 07:49:44 pm
You too Jack! Take a break with your family and church, you deserve it.
Did I ever say I really love your bottom line personal signature?
              Brad      :icon_biggrin:
Post by: Jack_Hester on December 24, 2012, 07:59:50 pm
Thanks, Brad.  As to the quote, I read it as a kid.  And, it was attributed to George Orwell.  Others have claimed it, as well.  But, when I ran across it again several years ago, Orwell was given credit.  So, I continue to do so.  And, this coming from the man who gave us '1984'.  Had to read that in High School.  I've forgotten most of it, but maybe I can find it for my Kindle reader.  Have a good one.
Jack
Post by: PRR on December 24, 2012, 09:31:34 pm
As a greybeard, it is unlikely you saw those words that way as a kid.
While it is something Orwell *might* have said, there is no record of that phrase before Richard Grenier (http://en.wikipedia.org/wiki/Richard_Grenier) used it in 1993.
http://quoteinvestigator.com/2011/11/07/rough-men/ (http://quoteinvestigator.com/2011/11/07/rough-men/)
I think it sounds more like Kipling, but he didn't say those words either.
Post by: sluckey on December 24, 2012, 10:15:33 pm
I thought Jack Nicholson said that. :wink:
Post by: Willabe on December 25, 2012, 12:41:05 am
Well fellas to me truth is truth no matter who said it first.
Of course we can disagree on what is truth.
          Brad     :icon_biggrin:
Post by: Jack_Hester on December 25, 2012, 06:38:01 am
That could very well be true.  I've given Orwell credit for so long that it's the only origin that I remember.
Post by: smackoj on December 25, 2012, 09:38:01 am
Hello leaders; Because I am a noobish oldster who makes mistakes building amps on a reg. basis, I would like just a few pointers re: this hum/hiss noise chase. I chase a lot of hum on my builds which are mostly re-works of 50's era tube radio/phono amps.
When you use a jumper and short a tube pin to ground, that's just grounded on the chassis? Are there specific pins you  DO NOT ground 'cuz they have HT volts? And, this then would isolate the noise culprit when a pin shorted makes the amp go quiet? Do you use this method on Rs and Cs also?
Sorry if this is so elementary but hey, "it ain't rocket science"  but it ain't simply opening a can of Libbys sweet corn either....know what i mean Vern?    :laugh:
Post by: sluckey on December 25, 2012, 10:31:25 am
Using a ground strap in the signal chain can be a very useful troubleshooting tool. But doing so requires an understanding of schematics and how circuits operate. Lacking that understanding and using a ground strap is an invitation to disaster.
Post by: smackoj on December 25, 2012, 10:37:35 am
copy that SL.....not wanting 'disaster' anytime soon but would like to make these old tube amps as quiet as poss.
thanks for the reality check.
JD     :icon_biggrin:
Post by: Jack_Hester on December 25, 2012, 03:02:53 pm
Practically all of the old amps that I have had my hands in use the chassis as the signal ground.  Some have followed the phylosophy that I tend towards, and have a dedicated signal ground, though I haven't found any that are completely above the chassis.  I troubleshoot from the component end that's supposed to be connected to signal ground.  On these last two Ampegs, they are built as if the chassis is out of the picture, and signal ground is kept for the most part on the eyelet board.  Only at the jacks (input, speaker, etc.) have they utilized the chassis for a signal grounding path.  On the last one, I made sure the jacks were all tied to the same signal ground as the eyelet board.  I will do so with this one, before I'm finished.  Strangely enough, this one has most of them tied together and connected to the eyelet board.  With only two or three depending on the chassis ground.
I use a capacitor on the end of my jumper, when I'm testing for noise on the plate of a tube.  Mostly I don't have to resort to this, as I can usually find what I'm looking for by grounding control grids.  I have done so, with the first stage of Channel 1, and had the same results as grounding the junction of C1/R6.  At this point, I'm going to lift all from V7-pin9, connect it to signal ground with a 1M resistor, and see what it sounds like.  And then, short jumper this point to signal ground, as my long jumper picks up way too much noise.
I'm hoping I'll be troubleshooting the input jacks and the resistors/wiring, because the grid grounding was successful in eliminating the hiss and maybe some hum.  Again, the hum is not really bad.  Just obvious at full volume with nothing attached.  But, it all goes away, back at the junction of C2 and the Volume pot.  This lets me know that the subtle hum may be something that can be made to go away.
I'm hoping that whatever rids the hiss on Channel 1 will be the same solution to rid Channel 2 of it's big hiss (again, at full volume, no connections).  We'll see.  More to come.
Jack
Title: Re: Ampeg B-12-XY....
Post by: Jack_Hester on January 11, 2013, 08:51:18 am
Well, I'm back.  Got one of the worst head colds that I can remember, right after Christmas Day.  By New Year's Day, I was recovered enough to begin my new work schedule at the plant, meaning I haven't touched the amp until yesterday.
I lifted the input to V7-pin9 and connected it to ground with a 1M resistor.  Same hum and hiss as it had with the inputs connected.  Connected it to signal ground and got the same louder hum as I did by shorting J1, when the inputs were connected.  So, I wired it all back up and made the quick grounding checks that I did before.  Grounding the junctions of C2/Vol pot made it dead quiet.  Grounding C1/R6 cleared the hiss, but left the hum.
I buttoned it all back up to make it movable, as I have so much other stuff to finish up outside the shop, before chasing this one again.  It is playable and the hum and hiss is not terrible.  I'm just bound and determined to clean it up to the quality of the B-12-N.  That one came home the weekend before New Year's.  What a fine sounding amp.
Let me comment on the sound of the B-12-XY.  The Vibrato has a really wonderful sound, but I made an interesting discovery.  I patched J1 to J4 and connected the guitar to J3.  With both the Vibrato and Echo on (just because I like the Echo with it), the Vibrato has a completely different response.  The oscillation is much greater sounding, as in swing.  I have to cut the Intensity back below half, so that it doesn't drop the volume to practically nothing.  And, it can be set from a really nice tremolo sound to something that I have no idea how it would be used.  Too much.
So, I tried the opposite.  I patched J3 to J2, and connected the guitar to J1.  Now, the really nice sound is back that doesn't sound like the typical tremolo.  Both times I've had each Treble at max, and Bass at half.  And adjusting volumes only, I can change from a somewhat bright sound to a really warm sound.  Bright being with the Channel 1 volume at half or above, and Channel 2 volume being less than half.  Warm happens with the opposite on the volumes.  Channel 2 half or better, and Channel 1 less than half.
I believe that this would be a really fun amp in the hands of a good musician.  I just can't do it justice.  But, I can enjoy the heck out of it.  No question that I'll be back on this one, to clean it up.  Life can get in the way of fun, at times.  Bad colds always get in the way.  New work schedule will curb my shop time, but I'll still work some in.  By Spring, I should have a routine worked out to spend more time on these projects.  Of course, mowing always gets in the way of fun.  I'll deal with that too.  More to come.  Have a good one.
Jack
