Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on January 05, 2013, 01:54:56 am
I've seen some seller indicating a 6.6k OT for the 5e3
on the other hand many transformer producer indicate an 8k OT for the 5e3
and I'm talking about a 6v6 version not other final tubes
this is confusing me, also I'm not sure about the PT specs
Which are the right specs for this transformers ?
You can get more power output with the 6.6kΩ OT, which is more typical of a Deluxe Reverb.
Many Thanks HotBluePlates
That confirms what I was supposing
About the original 5e3 PT someone knows if is correct a 355v-0-355v HV winding ?
Thanks again
http://www.hammondmfg.com/pdf/EDB290BEX.pdf (http://www.hammondmfg.com/pdf/EDB290BEX.pdf)
So 330v-0-330v
Many Thanks DummyLoad
