Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: llama on February 01, 2013, 12:04:38 pm
I'm getting the mad scientist bug again, and found a variety of Variable Capacitors . Some smaller ones have a range from 7 to 350 pF.
Where in the circuit would a small shift in the capacitance be most useful?
Some of them have several plates and can measure over 5 inches in length.
My purpose to find a location where the swing will make a tonal difference and then use a similar value of a fixed cap to finish.
-LLama
No personal experience, just what I've read: across the plates of the PI, across the plate resistor of the preamp tube (especially a small pentode like the EF86 or 5879), and on your tone and/or volume pots. Tubenit will have more ideas, I'm betting.
Probably nowhere in an audio/guitar amp.
These things are for adjusting a circuit operating at frequencies above the audio range, typically into RF. To make an R-C circuit that allows the cap variation to impact audio, you'd need prohibitively-large circuit resistances.
You might find some value in using the largest of those (the 350pF one) as a variable plate resistor bypass when trying to figure a desired value of plate load bypass to reduce a stage's treble. You'd do that, then replace the big variable cap with a small ceramic or mica cap and button the amp up.
Problem is, you might lack a way to accurately measure the resulting capacitance that you liked. The measurement might vary with the placement of measuring leads and your hands/arms. And the variable cap is usually bigger than a simple cap-substitution box where you had a switch selecting different caps to apply different capacitances to a circuit for taste-testing.
Those things might be gold for a radio guy, or someone who has a similar device performing high-frequency compensation in an old oscilloscope, or (if you have some giant ones) as a frequency dial in some signal generators. I've got some audio signal generators that use a 3- or 4-section variable cap for the frequency dial, but that thing is about 4" square by 8-10" deep, and the circuit design allows for 10MΩ+ resistors for low-frequency ranges (which is generally not true in a guitar amp).
While you might find some use in a guitar amp, there are easier, cheaper, smaller ways to do anything these variable caps could do in the audio range.
This is the only kind of audio gear that uses variable capacitors that I know
http://theremin.us/126/126.htm (http://theremin.us/126/126.htm)
(http://theremin.us/126/126_schematic_p1_rev_1.GIF)
(http://theremin.us/126/126_schematic_p2.gif)
