Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jeff on March 07, 2013, 11:25:03 am
Title: Chassis mounting tips
Post by: jeff on March 07, 2013, 11:25:03 am
I like the hammond aluminum chassis.
What is a good way to mount them to a head or cab?
Title: Re: Chassis mounting tips
Post by: sluckey on March 07, 2013, 12:11:54 pm
Two L brackets (or one continuous 1/2" x 1/2" aluminum angle )on each end of the chassis for head cab. I mounted some 3x4x17 Hammonds in 5E3 style combo cabs with bolts thru the top of the cab just as Fender did, but I also used some wood screws thru the ends of the chassis into the sides of the cab.
Beef up the mounting as best as you can. Those chassis cannot take any stress. You can literally take one of those 3x4x17 aluminum chassis and twist it like a pretzel with your bare hands.
Post by: stratele52 on March 07, 2013, 01:16:58 pm
Head like Trainwreck  alu chassis;
www.trainwreck.com/?page_id=19 (http://www.trainwreck.com/?page_id=19)
Or
ttp://www.google.ca/search?q=trainwreck+amp&hl=fr&client=safari&rls=en&tbm=isch&tbo=u&source=univ&sa=X&ei=ROc4UeHLBK3W0gH7n4HgBQ&ved=0CEIQsAQ&biw=1024&bih=673#imgrc=6L19swWeyKpZOM%3A%3Br9HqvJU6p3R2IM%3Bhttp%253A%252F%252Fimg.photobucket.com%252Falbums%252Fv735%252Ffreebass%252FRocket%252Fback.jpg%3Bhttp%253A%252F%252Fwww.gearslutz.com%252Fboard%252Fguitar-pedals-effects-amps-cabs-backline-accessories-etc%252F130371-trainwreck-amps-long-before-boutique-cool-2.html%3B1024%3B768
Post by: catnine on March 07, 2013, 01:36:16 pm
I only used one aluminum hammond chassis to make a head . It's easy to work with but I just mounted mine on the bottom of the cab tubes facing up and drilled holes through the bottom sides where they flod in and have about a 1/2" lip. Trouble is the aluminum does not due well if the tranny's have any weight to them . I also used those metal clip nuts that slip over and around the aluminum edge so you can use a sheet metal screw and not depend on the aluminum to hold the screw threads. This is the head .
(http://i286.photobucket.com/albums/ll112/blues90/105-0517_img.jpg)
The back panel removed goes down to the chassis and has two cutouts like the tweed fenders for cooling.
(http://i286.photobucket.com/albums/ll112/blues90/105-0519_img.jpg)
 Later I changed the head into a parallel SE and used the black metal chassis , harder to work with but the end result is stronger, They also sell the bottom cover plate for both and this helps.
 I also used a black metal one for a tweed style chassis in a cab I built . I just drilled into the corners like fender did and used a large machine screw and inside the chassis top corners a washer and nut but still added side support to the bottom sides to keep it from bending and flexing . To support the bottom from flexing I drilled through the bottom lip and used the clip nuts and drilled through the back cover panel so once the back panel was in place and the two screws inserted it was pretty solid . If it's tweed style like Slucky did also works and that way you don't need to worry about the screws touching any of the tube sockets or wires. I kept mine spaced so they would clear and short enough so they didn't go in very far.
 I prefer the metal hammonds they have a sort of black krinkle finish which lends well if you want to do a faceplate with lables . I used the type of decals that are for model trains and planes you can get numbers and letters in any size and in gold or white . Microscale makes them . You set them in water and then they slide off and you set them and can move them into place then once dry use micro set or solvset which allows the decals to soften and hold on for ever and allow the decals to melt right into the paint and once dry the decal film cannot be seen  they look like they were lazer painted on. Most hobby shops carry them of on-line . All you need is a very fine pointed 2/0 of smaller model paint brush. They work great. They only seem to work on painted surfaces.
Post by: HotBluePlates on March 07, 2013, 03:19:07 pm
I used a 12ga Dirty Dawg Chassis (http://www.ddawgamps.com/Amp_Chassis.php) for my Standel power amp chassis. I'm probably using transformers heavier than you might have an a 60-100w amp, and there is zero flexing.
I did ask for the corners of the chassis to be alumi-welded, and have the lip of the chassis turned outward. From there, holes in the chassis lip, hole in the cabinet, a T-nut in the cabinet hole and a machine screw through each. Solid as a rock.
Post by: darryl on March 07, 2013, 04:48:21 pm
I attach flanges to the ends of the chassis, and then use cage nuts ( also called captive nuts ) to mount the chassis in a headshell.
(http://i497.photobucket.com/albums/rr333/valvetone/2012%20Projects/simple/blank1.jpg)
(http://i497.photobucket.com/albums/rr333/valvetone/2012%20Projects/simple/blank2.jpg)
(http://i497.photobucket.com/albums/rr333/valvetone/2012%20Projects/simple/front.jpg)
Post by: kagliostro on March 08, 2013, 02:08:38 am
Instead of cage nuts that requires a square hole
(http://www.govgroup.com/images_products/2432122_big.jpg)
or T-nuts (I'm not sure HotBluePlates uses this kind of T-nuts)
(http://heico-fasteners.co.uk/upholstery_nails/t_nuts.jpg)
I use Treaded inserts
(http://www.specialinsert.it/immagini/TC_C_pic.jpg)
(http://forum.amicidellavela.it/uploaded/Guest/201063205942_InsertiFilettati1.jpg)
Post by: HotBluePlates on March 08, 2013, 09:50:31 am
Yes, if I knew about and had a source for those threaded inserts, I'd have used those.
Post by: jeff on March 08, 2013, 11:53:55 am
Wow, those threaded inserts are a great idea! Where do you get them?
Thanks everyone, Lot to think about.
   Jeff
Post by: Fresh_Start on March 08, 2013, 02:14:16 pm
Has anyone used either steel or aluminum angle strips to reinforce the transformer mounting area?
darryl - I like your flange & cage nut approach.
Cheers,
Chip
Post by: HotBluePlates on March 08, 2013, 03:28:23 pm
No, but you very well could, especially if the transformer mounting bolts are also used to hold the new angle pieces.
Post by: kagliostro on March 08, 2013, 03:30:35 pm
@ Jeff
Unfortunately I live in Italy, I find the treaded inserts at the local hardware store but this can't help you  :dontknow:
@ Fresh_Start
If the chassis isn't very large you can use aluminum angle strip or steel stripe, if it is large a good way is an aluminum plate of 2 mm thick,
Darryl's cage nuts are very professional but need a press machine for square holes
which is difficult to have under hand as Diyers
Post by: darryl on March 08, 2013, 05:03:36 pm
. . . or you can drill a circular hole and laboriously file it out to square - as I do.  (http://serve.mysmiley.net/sad/sad0065.gif)
Post by: HotBluePlates on March 08, 2013, 07:25:19 pm
I think by the 2nd amp, I'd be looking for a square punch. I know it would be very expensive, but for more than a couple amps, it seems the time (and wear on your hands) saved would be worth it.
Post by: darryl on March 08, 2013, 08:03:58 pm
If I could justify that sort of money, I'd buy a punch for IEC power connectors first.
I don't like drilling/cutting/filing IEC holes!   (http://i497.photobucket.com/albums/rr333/valvetone/smilies/grumpy.gif)
Post by: Danskman on March 08, 2013, 09:50:21 pm
About the IEC holes: I did some of them using a Dremel and cutting wheels. Worked easy, precise and cheap (once you buy the dremel!) and took about 1-2 minutes per hole . There are different wheels, for different kind of metal.
BR,
Danskman
Post by: DummyLoad on March 09, 2013, 01:22:30 am
it's the devil of amp building. it does however do a lot to improve your dremel and filing skills, no?
now i use a milling machine. 500bux used + 100.00bux for a box of daewoo mill bits - cheaper than the IEC punch.  :BangHead:
Post by: The_Gaz on March 09, 2013, 03:38:59 am
This is what I use:
http://www.mcmaster.com/#cadinlnord/94850a120/=lsu0lf (http://www.mcmaster.com/#cadinlnord/94850a120/=lsu0lf)
Same thing Soldano has always used.
Post by: kagliostro on March 09, 2013, 04:03:10 am
@ Darryl
I think you have much patience with those square holes, are perfect to look  :thumbsup:
@ HotBluePlates
Before to think to a punch machine I'll look if I can find some Threaded Inserts on my area, may be you can find it
and you don't need to buy a specific (expensive) tool as to install the Treaded Inserts
This is a my friend idea
Rivettatrice per Inserti Filettati.wmv (http://www.youtube.com/watch?v=-GFsllloy9w#)
@ The_Gaz
Your link opens but I see nothing in the page, only the search row  :dontknow:
Now all is fine
Post by: catnine on March 09, 2013, 02:30:16 pm
   Jeff
 I know you can get them at ford dealerships parts department . They use them to moung luggage racks and mirrors and those tie downs used on PU trucks . I used a hydrolic pop rivet gun however you can uses a long bolt and a nut and washer . Just drill the hole then place the nut on the threaded bolt first then the flat washer . thread the bolt into the insert then hold the head of the bolt with a wrench the then bring the nut down against the flat washer and turn the nut . This pulls the collapsable part on the insert against the inserts flange and expands the insert. It takes more time than a pop rivet gun with the proper insert but works the same way.
 Still there are clip nuts that you can get that have either a hole for a sheet metal screw and ones for a machine screw . they are hard steel . you drill the hole so the clip nut when slid over the chassis lip butts flat against the lip then slid the clip nut one and run in the machine screw.
http://www.aircraftspruce.com/catalog/hapages/tinnerman2.php (http://www.aircraftspruce.com/catalog/hapages/tinnerman2.php)
http://www.alliedelec.com/search/productdetail.aspx?SKU=70165669 (http://www.alliedelec.com/search/productdetail.aspx?SKU=70165669)
this is the type I used below.
 http://www.alibaba.com/showroom/clip-nuts.html (http://www.alibaba.com/showroom/clip-nuts.html)
