Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: nandrewjackson on April 20, 2013, 08:49:56 pm
Title: 12ax7 long tail pair phase inverter driving el84's
Post by: nandrewjackson on April 20, 2013, 08:49:56 pm
I haven't built a tube power section yet, but plan on building a (2) or (4) el84 push pull poweramp soon.
I've been studying schematics such as Vox style el84 and the Hoffman 18Watt Stout schematics.
I have a couple "theory" questions.  I understand a basic triode gain stage, and I think I see what's going on in push pull el84's, but I just don't understand how the 12ax7 phase inverter is working.
I guess I don't need to understand it to build it,  :l2:  , but I would like to.   :l2:
It's quite obvious that the first grid of the phase splitter is getting the "input" signal, but how in the world does the second triode of the phase splitter(inverter) get it's signal?
I've commonly seen that the grids are either 470K or 1M each with an additional 47K above ground, with the cathodes tied together about 1K plus the 47K to ground.  And there's a cap (.o1 or .02) across the second grid R either to ground or above the 47K to ground.
Can someone give me a short "layman's" explanation of how the second grid of the longtail pair gets input?
And my logic tells me the 2 triodes would be in phase because the grids are tied together????
Thanks for your help, This Forum is THE BEST  :icon_biggrin:
Title: Re: 12ax7 long tail pair phase inverter driving el84's
Post by: PRR on April 20, 2013, 09:03:09 pm
No they are not.
> grid ...is getting the "input" signal
Input signal of a tube is *grid to cathode*.
When cathode is pretty groundy, we might short-think "grid input"; but here we must see a bigger picture.
Post by: nandrewjackson on April 20, 2013, 10:09:19 pm
Big OOOPS
I meant to write CATHODES tied together.   :BangHead:
The first triode is getting it's signal with [470K plus 47K] grid to ground, and about [1K plus 47K] cathode to ground.  I get that.  That part totally makes sense.  It looks like standard triode guitar gain stage with high grid/ground R and low cathode/ground R.
I see that triode 2 is getting signal, it just seems that it's being ran in a grounded-grid fashion with more +V on the cathode than the grid.....  Is this right?
I realize grounded-grid is not the right term for it, but would it be ok to compare the second half of the Phase Inverter/ Phase splitter to a grounded-grid triode?
Post by: nandrewjackson on April 20, 2013, 10:14:03 pm
Or instead of comparing triode 2 of the phase splitter to a grounded grid triode, should I just let the sleeping dog lie, and
faaaagedddaboudit'
 :icon_biggrin:
Post by: sluckey on April 20, 2013, 10:19:35 pm
Here's a good short read about a LTP PI...
http://www.aikenamps.com/LongTailPair.htm (http://www.aikenamps.com/LongTailPair.htm)
Post by: kagliostro on April 21, 2013, 04:36:29 am
And here further info
DC Coupled Long-Tailed Pair
http://www.valvewizard.co.uk/dcltp.html (http://www.valvewizard.co.uk/dcltp.html)
AC Copuled Long-Tailed Pair
http://www.valvewizard.co.uk/acltp.html (http://www.valvewizard.co.uk/acltp.html)
Post by: PRR on April 21, 2013, 02:42:06 pm
Exactly right.
But does it help? No other audio amp runs grounded-grid, so we don't have much gut-level experience or intuition.
It may be useful to think input is "grid to cathode". Or in this case, the first cathode is not very groundy (47K away from ground) so the input is "grid to cathode to cathode to grid". Two grid-cathode nodes split the input. Ignoring the tail, they split input equally. (Tail current diverts a little signal and causes 5%-20% un-balance, which may be NBD.)
Post by: nandrewjackson on April 21, 2013, 10:45:03 pm
Thanks cagliostro and sluckey for the links, nice stuff there.
Thanks PRR for the "input" *pun inttended*
I have a better idea of what's going on there, it's just weird to see one, let alone, two triodes 47K above ground, plus all the extras, let alone if there's NFB or Presence control going on!
Thanks again,
you all are awesome!
